Date/Time: Tue, 17 Nov 2026 19:06:57 +0000
rithmic data feed for funded firms
View Count: 768
| [2026-08-18 06:43:27] |
| b1u3lee - Posts: 43 |
Hi Team Im currently running on Denali data feed on Teton order routing. How is this compatible with rithmic data which is used by funded firms. |
| [2026-08-18 08:27:19] |
| User135243 - Posts: 334 |
of course Teton order routing has nothing to do with Rithmic, but if you've this and also have Denali real-time data, you can set up Rithmic Direct - DTC to route orders to your Rithmic-accounts
| [2026-08-18 08:48:01] |
im assuming i cant run both data feed concurently right? cause i need charting from denali but at the same time need rithimic for the funded accounts? |
| [2026-08-18 08:55:35] |
of course you can use your Denali data for charting and Rithmic just for order-routing, if you set up the Rithmic Direct - DTC there is a settings allow Sierra Chart data, this is the best solution trading Rithmic-account (way better as using Rithmic data for charting). I use it since years and it works perfect.
| [2026-08-18 09:11:37] |
oh cool.. but wait a min are you part of sierra team? cant tell from your username man |
| [2026-08-18 09:48:45] |
no, I'm just a client :)
| [2026-08-18 11:45:46] |
i see, Are you on rithmic then? The monthly data plan is at $49.99, quite pricey
| [2026-08-18 11:58:14] |
no I use Denali data and route my orders to my Rithmic-accounts
| [2026-08-18 12:41:12] |
So are you using any funded programs? most require rithmic
| [2026-08-18 12:46:41] |
need to be on funded programs for now
| [2026-08-18 14:30:50] |
| John - SC Support - Posts: 48562 |
As was pointed out, Rithmic and Teton are two completely different order routing services. They can not be used together. To connect to an account using Rithmic, follow these instructions: Rithmic Trading Platform Service: Setup Instructions Since you have the Denali Exchange Data Feed already setup, you will get your data from us while you are connected to Rithmic. Refer to the following: Denali Exchange Data Feed: Integration with Trading Services Keep in mind that Prop Firms do not count toward the requirement of having a live, funded, futures trading account in order to qualify for the non-professional data rates for the CME Group. Therefore, you need to have the account with which you use Teton in order to be able to continue to get this data. Refer to the following: Denali Exchange Data Feed: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you are actively trading both accounts (Teton and Rithmic) then you should install a second Sierra Chart so that you have one that is connected to your Teton account and one connected to your Prop Firm account. Refer to the following for how to do this: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-18 14:51:50] |
To your last point, if i am not actively trading both accounts i.e (charting for teton & prop for Rithmic) i would not be required to install a second sierra chart? |
| [2026-08-18 14:59:10] |
You are never "required" to install a second Sierra Chart. It is a recommendation, so you are not constantly switching back and forth. So you can keep just the one installation, this is fine. But again, be sure you keep your Teton account active with that broker. With a Teton account, we use a back-end verification of your live trading account, so you do not actually need to connect your Sierra Chart software to that account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-18 15:13:43] |
so if i am using teton for charting & rithmic for the prop firms, will i be constantly switching back and forth?
| [2026-08-18 19:05:04] |
We do not understand what you mean by "i am using teton for charting & rithmic for the prop firms". Teton and Rithmic do the same thing - they are order routing services. If you have an account with AMP, Edge Clear, Stage 5, or a number of other possible brokers that suppor Teton, then you are trading that brokerage account using Teton. Your connection to a Prop Firm using Rithmic is completely separate and you are trading that Prop Firm when you are connected to Rithmic. The Denali Exchange Data Feed is something different from the above. This is our data feed. You can get this data regardless of what order routing service (broker/Prop Firm) you are connected to. If you are trading both your account that uses Teton and the Prop Firm, then you would either be swapping back and forth within a single installation, or you would be better off having two installations. If you are only trading the Prop Firm, then you just need the one installation and you do not need to do anything else, except ensure that your live account using Teton has enough funds in it to keep that account open in order to qualify for the non-professional CME Group data rates. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-19 03:25:23] |
Do i still have to sign the CME Non‑Professional Market Data Agreement through R|Trader Pro before market data will load for funded account trading through Sierra?
| [2026-08-19 03:42:59] |
If i were to load rithmic data via the prop accounts, would I lose my charting from teton?
| [2026-08-19 13:31:11] |
If you are getting your data from Rithmic, then Yes, you do need to sign those agreements. If you are getting your data from our Denali Exchange Data Feed, then No, you do not need to sign the agreements. If i were to load rithmic data via the prop accounts, would I lose my charting from teton?
It depends on whether you continue to have the data setup from our Denali Exchange Data Feed. You can have that data setup and get the data from Rithmic. To do this, you would need to set the option for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to "No". But, we really do not recommend this. You will have much better data with our Denali Exchange Data Feed data, along with all our historical data. There is a lack of historical data available from Rithmic. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
