Date/Time: Tue, 10 Nov 2026 19:11:15 +0000
Error
View Count: 272
| [2026-08-11 23:05:40] |
| User130696 - Posts: 119 |
Hello, I see following error in modal window when I start Sierrachart instance, and all my original settings have been erased, please fix it asap. Sierra Chart X There has been a configuration file checksum error. OK |
| [2026-08-11 23:46:15] |
| Sierra_Chart Engineering - Posts: 25407 |
Exit from all instances of Sierra Chart, and then restore a backup copy of the global configuration file for the instance of Sierra Chart that is giving this error, from the past. Instructions: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Restoring Backup Global Configuration File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
