Date/Time: Sat, 18 May 2024 17:30:18 +0000
Windows error code 10061
View Count: 1013
[2014-11-04 08:42:36] |
User11942 - Posts: 298 |
Hi SC support, I receive the following message today on any instance of SC I try to run (either IB or Rithmic connection). | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-04 03:25:27
What could cause the problem?Please find the message log attached. |
Private File |
[2014-11-04 08:48:20] |
Disregard this if there is no other problem.
[2014-11-04 08:49:32] |
OK. Thanks. Apart from popping log, there is no other problem.
