Date/Time: Sun, 08 Nov 2026 17:11:40 +0000
Spreadsheet Study- Use of Subgraphs cells
View Count: 351
[2026-08-07 22:19:56]
User841161 - Posts: 357
Can a spreadsheet formulas use something conceptually like:
=ID3.SG2 + ID7.SG1
instead of relying on columns such as AD3 and AP3?
I am trying to use something in spreadsheet formulas that will change when subgraph columns get added and subtracted inside of Sierra Chart Spreadsheet..
[2026-08-09 18:05:37]
ForgivingComputers.com - Posts: 1251
You need to add the row of the spreadsheet with the @ symbol and the row, like this.
=ID3.SG2@3 + ID7.SG1@3
If you put this in a cell, it will propagate down and increment the row number automatically.
[2026-08-14 07:26:25]
Sierra_Chart Engineering - Posts: 25402
Refer to:
Working with Spreadsheets: References to Study Subgraph Columns when using the Spreadsheet Study
