Date/Time: Tue, 03 Nov 2026 19:22:57 +0000
Market Depth Pulling Stacking - Negative Values Don't Show Any Volume Bars
View Count: 326
| [2026-08-04 16:36:59] |
| Rui S - Posts: 258 |
Hello Support, After checking every setting I could find, I can't find a way to make my Trade DOM show any negative Volume Bars on the "Market Depth Pulling/Stacking Levels". Positive volume show all the volume bars normally. Will you please let me know how to make it work? |
| [2026-08-04 17:26:42] |
| John - SC Support - Posts: 48408 |
Please update to the latest release to ensure you have a version that does have the support for the negative pulling/stacking volume bars. Follow these instructions to update: Market Depth Pulling Stacking - Negative Values Don't Show Any Volume Bars After that, if you are still not seeing the negative volume bars, then check the Graphics Settings - Colors for the "Chart/Trade DOM Bid/Ask Market Depth Pulling/Stacking Negative Volume Bar" and make sure the option for "Enable" is set to "Yes". Refer to the following: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Bid Market Depth Pulling/Stacking Negative Volume Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
