Date/Time: Tue, 03 Nov 2026 19:20:59 +0000
[Programming Help] - 5 minute chart will not scroll left or load historical bars
View Count: 301
[2026-08-04 14:40:50]
User865480 - Posts: 1
Today when I opened up my chart there was a chunk of missing candlesticks so clicked "delete all data" and "download." But then when I downloaded it, I can only see the most recent candlesticks, and the screen doesn't let me scroll to the left, so I can only see the candlesticks that you see in the picture. Please help; I've been trying to fix this for the past hour and a half.
imagesierra chart Screenshot 2026-08-04 102812.png / V - Attached On 2026-08-04 14:33:36 UTC - Size: 68.12 KB - 64 views
[2026-08-04 14:49:05]
John - SC Support - Posts: 48408
You are getting your data from Rithmic, and they have a lack of historical data. So most likely what you are getting is all that you can get from them.
But, make sure you have the "Historical Data Username/Password" filled out on the "Data/Trade Service Settings" for your Rithmic connection. If this is filled in, then you are being limited by Rithmic's interface.
