Date/Time: Wed, 04 Nov 2026 05:14:55 +0000
Large Volume Trade Indicator does not show up on chart
View Count: 368
[2026-08-02 11:04:50]
User126307 - Posts: 3
HI SC team. I have added the default setting "Large Volume Trade Indicator" on my ES chart but it shows nothing.
I followed some past posts to change the "Intraday Data Storage Time Unit (List)" to 1 tick but the problem is still not resolved.
I have attached the file and the screenshot for your reference. Thanks
attachment1.cht - Attached On 2026-08-02 11:03:15 UTC - Size: 4.44 KB - 82 views
image1234.png / V - Attached On 2026-08-02 11:04:01 UTC - Size: 50.6 KB - 100 views
[2026-08-02 19:59:56]
Sierra_Chart Engineering - Posts: 25370
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
You also need to re-download the data as explained.
Also set the Volume Threshold Input with the study to 1.
Date Time Of Last Edit: 2026-08-02 20:00:15
