Date/Time: Sat, 18 May 2024 09:54:16 +0000
orderflow Rithmic
View Count: 1032
[2014-11-03 17:47:22] |
User72411 - Posts: 3 |
Hallo SC, today I have in my SC a new datafeed - Rithmic, but the orderflow NQ and YM is incorrect. (see attached file) I don´t know what´s the problem.. thanks |
bandicam 2014-11-03 18-39-34-314.jpg / V - Attached On 2014-11-03 17:47:16 UTC - Size: 352.74 KB - 318 views |
[2014-11-03 18:59:33] |
update: 2 accounts, both of them have Rithmic datafeed but orderflow is different (see attached files) |
Rithmic_A.PNG / V - Attached On 2014-11-03 18:59:09 UTC - Size: 114.04 KB - 318 views Rithmic_B.PNG / V - Attached On 2014-11-03 18:59:24 UTC - Size: 451.82 KB - 302 views |
[2014-11-04 09:53:53] |
Make sure you have a tick by tick data configuration: http://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Re-download the data in the chart with Edit >> Delete All Data and Download. In the next release coming out there is tick data support from Rithmic for the most recent 10 minutes of data. The most recent 10 minutes of data comes from Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
