Date/Time: Sun, 01 Nov 2026 04:40:17 +0000
Chart delay
View Count: 467
[2026-07-30 06:14:41]
User686430 - Posts: 6
The price in the chart is displayed with a delay in the DAX; what is the reason for that?
Regards
Frank
[2026-07-30 14:19:18]
You are properly setup to get the data for EUREX from us, so you should not be having an issue.
What exactly are you seeing that makes you think the data is delayed?
Also, please get us your Message Log by following these instructions for a DAX chart:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2026-07-30 18:47:11]
2026-07-30 20:31:46.429 | Trade activity files set size: 744
2026-07-30 20:31:46.677 | Created the DTC Protocol server.
2026-07-30 20:31:46.677 | DTC Protocol Server listening on port 11099. Address: 0.0.0.0
2026-07-30 20:31:46.677 | Reading Internal Order ID file.
2026-07-30 20:31:46.689 | Reading Trade Orders file.
2026-07-30 20:31:46.698 | Reading Trade Positions file.
2026-07-30 20:31:46.708 | Reading Trade Account Data files.
2026-07-30 20:31:46.709 | UDPListener (1712). Port 22903 | Listening on UDP port 22903.
2026-07-30 20:31:46.710 | Software version: 2899 64-bit
2026-07-30 20:31:46.710 | Primary Thread ID: 2004
2026-07-30 20:31:46.710 | Usage end date: 2026-10-05
2026-07-30 20:31:46.710 | Enabled for: Sierra Chart Historical Data Service.
2026-07-30 20:31:46.710 | Enabled for: Denali Real-Time Exchange Data Feed.
2026-07-30 20:31:46.710 | Enabled for: Delayed Denali Exchange Data Feed.
2026-07-30 20:31:46.710 | Enabled for exchange2: EUREX EOBI
2026-07-30 20:31:46.710 | Allow Support for Sierra Chart Data Feeds is enabled.
2026-07-30 20:31:46.710 | Current selected Data/Trading service: SC Data
2026-07-30 20:31:46.710 | Custom symbol settings values: enabled
2026-07-30 20:31:46.710 | Chart Update Interval: 1000
2026-07-30 20:31:46.710 | Intraday Data Storage Time Unit: 0
2026-07-30 20:31:46.710 | Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00)
2026-07-30 20:31:46.710 | 2026-07-30 18:31:46 Local computer time in UTC
2026-07-30 20:31:46.710 | 2026-07-30 20:31:46 Local computer time in SC Time Zone
2026-07-30 20:31:46.710 | 2026-07-30 18:31:35 Server time in UTC
2026-07-30 20:31:46.710 | Local computer UTC time and Server UTC time difference: 1 seconds.
2026-07-30 20:31:46.710 | Program path: C:\SierraChart\
2026-07-30 20:31:46.710 | Data Files path: C:\SierraChart\Data\
2026-07-30 20:31:46.711 | OS Version Number: 10.0
2026-07-30 20:31:46.711 | Locale Setting: C
2026-07-30 20:31:46.711 | Crash reporter started: true
2026-07-30 20:31:46.711 | NTP Client | Add Server: 0.pool.ntp.org Port: 123
2026-07-30 20:31:46.712 | NTP Client | Add Server: 1.pool.ntp.org Port: 123
2026-07-30 20:31:46.712 | NTP Client | Add Server: 2.pool.ntp.org Port: 123
2026-07-30 20:31:46.712 | NTP Client | Add Server: 3.pool.ntp.org Port: 123
2026-07-30 20:31:46.714 | NTP Client | Service successfully started.
2026-07-30 20:31:46.734 | Created the DTC Protocol historical data server.
2026-07-30 20:31:46.734 | HD Server Manager | Listening on port 11098.
2026-07-30 20:31:46.735 | Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1.
2026-07-30 20:31:46.736 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2026-07-30 20:31:46.829 | NTPClient (4) | Creating socket.
2026-07-30 20:31:46.829 | NTPClient (4) | New receive buffer size: 0
2026-07-30 20:31:46.829 | NTPClient (4) | Connecting to IP: 194.177.210.54.
2026-07-30 20:31:46.886 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2026-07-30 20:31:46.886 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2026-07-30 20:31:46.900 | NTPClient (5) | Creating socket.
2026-07-30 20:31:46.901 | NTPClient (5) | New receive buffer size: 0
2026-07-30 20:31:46.901 | NTPClient (5) | Connecting to IP: 185.201.254.21.
2026-07-30 20:31:46.984 | NTPClient (6) | Creating socket.
2026-07-30 20:31:46.984 | NTPClient (6) | New receive buffer size: 0
2026-07-30 20:31:46.984 | NTPClient (6) | Connecting to IP: 162.159.200.123.
2026-07-30 20:31:47.078 | NTPClient (7) | Creating socket.
2026-07-30 20:31:47.078 | NTPClient (7) | New receive buffer size: 0
2026-07-30 20:31:47.078 | NTPClient (7) | Connecting to IP: 147.52.190.11.
2026-07-30 20:31:47.189 | Received 5 login tokens.
2026-07-30 20:31:47.717 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:31:47.717 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:31:47.717 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:31:47.717 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:31:47.986 | NTP Client | Received Packet | RoundTripDelay=0.26798391342163086S, SystemClockOffset=0.28649210929870605S
2026-07-30 20:31:47.987 | NTP Client | Received Packet | RoundTripDelay=0.2699856758117676S, SystemClockOffset=0.2871239185333252S
2026-07-30 20:31:47.987 | NTP Client | Received Packet | RoundTripDelay=0.2699122428894043S, SystemClockOffset=0.285597562789917S
2026-07-30 20:31:47.996 | NTP Client | Received Packet | RoundTripDelay=0.27799367904663086S, SystemClockOffset=0.2873499393463135S
2026-07-30 20:31:48.337 | Symbol settings MD5 received. Request ID: 1.
2026-07-30 20:31:48.337 | Symbol settings are up-to-date for scdataallservices.
2026-07-30 20:31:48.721 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
2026-07-30 20:31:49.237 | Requested user files to download.
2026-07-30 20:31:51.243 |
2026-07-30 20:31:51.243 | SC Data | Connection to server complete.
2026-07-30 20:31:51.243 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-07-30 20:31:51.243 | Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees.
2026-07-30 20:31:54.469 | Files to Open on Startup | Opening file: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:31:54.581 | Loading DLL: C:\SierraChart\Data\Essentials.dll (Essentials_64.dll). Handle: 66000000
2026-07-30 20:31:54.739 | Loading DLL: C:\SierraChart\Data\Aussenstab.dll (Aussenstab_64.dll). Handle: 67a0000
2026-07-30 20:31:54.778 | FDAXU26-EUREX [CB] 1 Day #1 | Reloading chart.
2026-07-30 20:31:55.010 | Starting DelayedDownloadMonitoringTimer
2026-07-30 20:31:55.010 | Starting HDTimeoutTimer
2026-07-30 20:31:55.010 | Added historical Intraday data request for FDAXU26-EUREX to the queue.
2026-07-30 20:31:55.010 | Triggering next historical data download in queue.
2026-07-30 20:31:55.027 | FDAXU26-EUREX [CB] 1 Day #1 | Performing continuous chart historical Daily data download for symbol FDAXU26-EUREX starting at last date in file.
2026-07-30 20:31:55.027 | Starting DelayedDownloadMonitoringTimer
2026-07-30 20:31:55.027 | Starting HDTimeoutTimer
2026-07-30 20:31:55.027 | Added historical Daily data request for FDAXU26-EUREX to the queue.
2026-07-30 20:31:55.028 | Triggering next historical data download in queue.
2026-07-30 20:31:55.185 | FDAXU26-EUREX [CB] 1 Day #1 | Waiting for historical downloads to complete with the IDs: 1, 2,
2026-07-30 20:31:55.460 | Loading DLL: C:\SierraChart\Data\Aussenstab-v02.dll (Aussenstab-v02_64.dll). Handle: a470000
2026-07-30 20:31:55.575 | Loading DLL: C:\SierraChart\Data\ExtendBarPOC.dll (ExtendBarPOC_64.dll). Handle: a560000
2026-07-30 20:31:55.650 | FDAXU26-EUREX [CB] 1 Min #2 | Reloading chart.
2026-07-30 20:31:55.688 | FDAXU26-EUREX [CB] 1 Min #2 | Waiting for historical downloads to complete with the IDs: 1, 2,
2026-07-30 20:31:55.740 | FDAXU26-EUREX [CB] 3 Min #3 | Reloading chart.
2026-07-30 20:31:55.791 | FDAXU26-EUREX [CB] 3 Min #3 | Waiting for historical downloads to complete with the IDs: 1, 2,
2026-07-30 20:31:55.893 | FDAXU26-EUREX [CB] 15 Min #7 | Reloading chart.
2026-07-30 20:31:55.920 | FDAXU26-EUREX [CB] 15 Min #7 | Waiting for historical downloads to complete with the IDs: 1, 2,
2026-07-30 20:31:56.022 | FDAXU26-EUREX [CB] 2 Min #14 | Reloading chart.
2026-07-30 20:31:56.041 | FDAXU26-EUREX [CB] 2 Min #14 | Waiting for historical downloads to complete with the IDs: 1, 2,
2026-07-30 20:31:56.103 | FDAXU26-EUREX [CB] 60 Min #6 | Reloading chart.
2026-07-30 20:31:56.141 | FDAXU26-EUREX [CB] 60 Min #6 | Waiting for historical downloads to complete with the IDs: 1, 2,
2026-07-30 20:31:56.162 | FDAXU26-EUREX [CB] 15 Min #9 | Reloading chart.
2026-07-30 20:31:56.201 | FDAXU26-EUREX [CB] 15 Min #9 | Waiting for historical downloads to complete with the IDs: 1, 2,
2026-07-30 20:31:56.260 | FDAXU26-EUREX [CB] 30 Min #4 | Reloading chart.
2026-07-30 20:31:56.307 | FDAXU26-EUREX [CB] 30 Min #4 | Waiting for historical downloads to complete with the IDs: 1, 2,
2026-07-30 20:31:56.388 | FDAXU26-EUREX [CB] 240 Min #5 | Reloading chart.
2026-07-30 20:31:56.447 | FDAXU26-EUREX [CB] 240 Min #5 | Waiting for historical downloads to complete with the IDs: 1, 2,
2026-07-30 20:31:57.225 | NAS100 [CB] 2 Min #10 | Reloading chart.
2026-07-30 20:31:57.225 | NAS100 [CB] 2 Min #10 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-07-30 20:31:57.225 | NAS100 [CB] 2 Min #10 | There are no continuous futures contract symbols. Loading data normally.
2026-07-30 20:31:57.414 | US30 [CB] 2 Min #13 | Reloading chart.
2026-07-30 20:31:57.414 | US30 [CB] 2 Min #13 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-07-30 20:31:57.414 | US30 [CB] 2 Min #13 | There are no continuous futures contract symbols. Loading data normally.
2026-07-30 20:31:57.482 | FDAXU26-EUREX [CB] 5 Day #11 | Reloading chart.
2026-07-30 20:31:57.755 | FDAXU26-EUREX [CB] 5 Day #11 | Waiting for historical downloads to complete with the IDs: 1, 2,
2026-07-30 20:31:57.778 | Files to Open on Startup | Opening file: MP-Oli.scss
2026-07-30 20:31:57.873 | Mapping FDAXU26-EUREX to FDAX202609_FUT_EUREX. Service code: eurex
2026-07-30 20:31:57.873 | Using symbol data fast lookup vector
2026-07-30 20:31:57.874 | HD Request # 1 | Downloading Intraday chart data for FDAXU26-EUREX to the file FDAXU26-EUREX.scid. Service: eurex
2026-07-30 20:31:57.876 | HD Request # 1 | Download start date-time: 2026-07-30 16:56:06.000000. File last date-time: 2026-07-30 16:56:06.130002
2026-07-30 20:31:57.876 | HD Request # 1 | Using server: ds50.sierracharts.com port 10150
2026-07-30 20:31:57.880 | HD Request # 2 | Downloading Historical Daily chart data for FDAXU26-EUREX. Starting date: 2026-07-27. Service: eurex
2026-07-30 20:31:58.028 | Socket (1) | Creating socket.
2026-07-30 20:31:58.029 | Socket (1) | New receive buffer size: 0
2026-07-30 20:31:58.029 | Socket (1) | Connecting to IP: 62.209.53.225.
2026-07-30 20:31:58.181 | HD Request # 1 | Setting DTC encoding to Binary VLS
2026-07-30 20:31:58.181 | HD Request # 1 | Sending historical data logon request message.
2026-07-30 20:31:58.418 | Using Bid/Ask average for last trade price for NAS100
2026-07-30 20:31:58.419 | SC Data with Depth | Starting real-time market data updates for: NAS100. ID: 2 Service code: fxcm
2026-07-30 20:31:58.428 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048
2026-07-30 20:31:58.428 | SC Data with Depth | Requesting security definition data for: NAS100. ID: 2
2026-07-30 20:31:58.428 | Added historical Intraday data request for NAS100 to the queue.
2026-07-30 20:31:58.428 | Intraday data recording state for symbol NAS100 is set to download 'Pending'.
2026-07-30 20:31:58.428 | Triggering next historical data download in queue.
2026-07-30 20:31:58.449 | Using Bid/Ask average for last trade price for US30
2026-07-30 20:31:58.450 | SC Data with Depth | Starting real-time market data updates for: US30. ID: 3 Service code: fxcm
2026-07-30 20:31:58.450 | SC Data with Depth | Requesting security definition data for: US30. ID: 3
2026-07-30 20:31:58.450 | Added historical Intraday data request for US30 to the queue.
2026-07-30 20:31:58.450 | Intraday data recording state for symbol US30 is set to download 'Pending'.
2026-07-30 20:31:58.450 | Triggering next historical data download in queue.
2026-07-30 20:31:58.572 | DTC Client socket (8) | Creating socket.
2026-07-30 20:31:58.572 | DTC Client socket (8) | New receive buffer size: 0
2026-07-30 20:31:58.572 | DTC Client socket (8) | Connecting to IP: 69.39.70.241.
2026-07-30 20:31:58.662 | HD Request # 2 | Requesting historical Daily data for DYU26 starting at 2026-07-26. SC External HD service.
2026-07-30 20:31:58.679 | HD Request # 1 | Requesting Intraday data. Start date-time: 2026-07-30 16:56:06. Record interval: 0. Symbol: FDAX202609_FUT_EUREX
2026-07-30 20:31:58.713 | SC Data with Depth | Network connection to server complete.
2026-07-30 20:31:58.713 | SC Data with Depth | Starting socket receive thread.
2026-07-30 20:31:58.713 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard
2026-07-30 20:31:58.751 | HD Request # 1 | Decompressing data.
2026-07-30 20:31:58.827 | HD Request # 1 | Receiving Intraday data for FDAXU26-EUREX starting at 2026-07-30 16:56:06.130000
2026-07-30 20:31:58.893 | Socket (1) | CloseSocket call.
2026-07-30 20:31:58.893 | Socket (1) | Shutdown started. Waiting for graceful close.
2026-07-30 20:31:58.894 | Historical data download thread signaled to stop.
2026-07-30 20:31:58.894 | HD Request # 1 | Timestamp of first Intraday data file record written: 2026-07-30 16:56:09.599000.
2026-07-30 20:31:58.894 | HD Request # 1 | Received 3426 Intraday data records from 2026-07-30 16:56:06.130000 to 2026-07-30 20:31:39.096000 (3.6 hours. Delay: 19.8 seconds) and wrote 3423 records for FDAXU26-EUREX
2026-07-30 20:31:58.904 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2026-07-30 18:31:39.096000
2026-07-30 20:31:58.904 | HD Request # 1 | Completion time: 1s.
2026-07-30 20:31:58.904 | HD Request # 1 | Intraday data download complete for FDAXU26-EUREX. Unique request ID: 1
2026-07-30 20:31:58.904 | Removing historical data download ID 1.
2026-07-30 20:31:58.904 | Real-time Intraday chart data file updates started for FDAXU26-EUREX
2026-07-30 20:31:58.904 | Intraday chart data file opened for FDAXU26-EUREX
2026-07-30 20:31:58.904 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2026-07-30 20:31:58.904 | Triggering next historical data download in queue.
2026-07-30 20:31:58.904 | Historical data for FDAXU26-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2026-07-30 20:31:58.904 | Delaying start of download for NAS100.
2026-07-30 20:31:58.904 | SC Data with Depth | Setting DTC encoding to Binary VLS
2026-07-30 20:31:58.904 | SC Data with Depth | Sending logon request message.
2026-07-30 20:31:58.958 | Socket (1) | Socket gracefully closed by remote side.
2026-07-30 20:31:58.958 | Socket (1) | Closed.
2026-07-30 20:31:59.103 | HD Request # 2 | Receiving historical Daily data for FDAXU26-EUREX starting at 2026-07-27.
2026-07-30 20:31:59.103 | HD Request # 2 | Writing historical Daily data to the file FDAXU26-EUREX.dly.
2026-07-30 20:31:59.111 | HD Request # 2 | Bytes received: 159
2026-07-30 20:31:59.111 | HD Request # 2 | Received 3 Daily data records from 2026-07-27 00:00:00 to 2026-07-29 00:00:00 (3.0 days) and wrote 3 records for FDAXU26-EUREX
2026-07-30 20:31:59.111 | HD Request # 2 | Completion time: 2s.
2026-07-30 20:31:59.111 | HD Request # 2 | Daily data download complete for FDAXU26-EUREX. Unique request ID: 2
2026-07-30 20:31:59.111 | Removing historical data download ID 2.
2026-07-30 20:31:59.111 | No download requests in the queue to start downloads for.
2026-07-30 20:31:59.118 | FDAXU26-EUREX [CB] 60 Min #6 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-30 20:31:59.119 | FDAXU26-EUREX [CB] 60 Min #6 | Reloading chart.
2026-07-30 20:31:59.163 | SC Data with Depth | Received logon response.
2026-07-30 20:31:59.163 | SC Data with Depth | Server Name: SC Realtime Server.
2026-07-30 20:31:59.163 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2026-07-30 20:31:59.163 | SC Data with Depth | Successfully connected.
2026-07-30 20:31:59.163 | SC Data with Depth | Trading is not supported.
2026-07-30 20:31:59.163 | SC Data with Depth | MarketDepthIsSupported: 1
2026-07-30 20:31:59.163 | SC Data with Depth | Restarting real-time data updates for symbol: NAS100
2026-07-30 20:31:59.163 | SC Data with Depth | Restarting real-time data updates for symbol: US30
2026-07-30 20:31:59.182 | FDAXU26-EUREX [CB] 15 Min #9 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-30 20:31:59.183 | FDAXU26-EUREX [CB] 15 Min #9 | Reloading chart.
2026-07-30 20:31:59.260 | FDAXU26-EUREX [CB] 30 Min #4 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-30 20:31:59.263 | FDAXU26-EUREX [CB] 30 Min #4 | Reloading chart.
2026-07-30 20:31:59.397 | SC Data with Depth | Setting external service identifier for symbol NAS100 to 52
2026-07-30 20:31:59.397 | SC Data with Depth | Received security definition for symbol NAS100
2026-07-30 20:31:59.397 | SC Data with Depth | Setting external service identifier for symbol US30 to 58
2026-07-30 20:31:59.397 | SC Data with Depth | Received security definition for symbol US30
2026-07-30 20:31:59.418 | FDAXU26-EUREX [CB] 240 Min #5 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-30 20:31:59.419 | FDAXU26-EUREX [CB] 240 Min #5 | Reloading chart.
2026-07-30 20:31:59.720 | FDAXU26-EUREX [CB] 5 Day #11 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-30 20:31:59.828 | FDAXU26-EUREX [CB] 5 Day #11 | Reloading chart.
2026-07-30 20:32:00.497 | FDAXU26-EUREX [CB] 15 Min #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:00.503 | Chart: FDAXU26-EUREX [CB] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:00.524 | Chart: FDAXU26-EUREX [CB] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:00.667 | FDAXU26-EUREX [CB] 15 Min #9 | Chart data loading complete.
2026-07-30 20:32:00.675 | FDAXU26-EUREX [CB] 60 Min #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:00.679 | Chart: FDAXU26-EUREX [CB] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:00.681 | Chart: FDAXU26-EUREX [CB] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:00.741 | FDAXU26-EUREX [CB] 60 Min #6 | Chart data loading complete.
2026-07-30 20:32:00.746 | Chart: FDAXU26-EUREX [CB] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:00.749 | Chart: FDAXU26-EUREX [CB] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:00.834 | Chart: FDAXU26-EUREX [CB] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:00.836 | Chart: FDAXU26-EUREX [CB] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:00.900 | FDAXU26-EUREX [CB] 30 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:00.912 | Chart: FDAXU26-EUREX [CB] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:00.914 | Chart: FDAXU26-EUREX [CB] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:01.102 | FDAXU26-EUREX [CB] 30 Min #4 | Chart data loading complete.
2026-07-30 20:32:01.103 | FDAXU26-EUREX [CB] 240 Min #5 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:01.105 | Chart: FDAXU26-EUREX [CB] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:01.106 | Chart: FDAXU26-EUREX [CB] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:01.147 | FDAXU26-EUREX [CB] 240 Min #5 | Chart data loading complete.
2026-07-30 20:32:01.161 | Chart: FDAXU26-EUREX [CB] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:01.164 | Chart: FDAXU26-EUREX [CB] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:01.421 | Chart: FDAXU26-EUREX [CB] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:01.423 | Chart: FDAXU26-EUREX [CB] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:01.514 | FDAXU26-EUREX [CB] 1 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-30 20:32:01.515 | FDAXU26-EUREX [CB] 1 Min #2 | Reloading chart.
2026-07-30 20:32:01.601 | FDAXU26-EUREX [CB] 3 Min #3 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-30 20:32:01.602 | FDAXU26-EUREX [CB] 3 Min #3 | Reloading chart.
2026-07-30 20:32:01.696 | FDAXU26-EUREX [CB] 1 Day #1 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-30 20:32:01.698 | FDAXU26-EUREX [CB] 1 Day #1 | Reloading chart.
2026-07-30 20:32:02.222 | FDAXU26-EUREX [CB] 15 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-30 20:32:02.223 | FDAXU26-EUREX [CB] 15 Min #7 | Reloading chart.
2026-07-30 20:32:02.231 | FDAXU26-EUREX [CB] 2 Min #14 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-30 20:32:02.232 | FDAXU26-EUREX [CB] 2 Min #14 | Reloading chart.
2026-07-30 20:32:02.235 | FDAXU26-EUREX [CB] 60 Min #6 | Reloading chart.
2026-07-30 20:32:02.441 | FDAXU26-EUREX [CB] 15 Min #9 | Reloading chart.
2026-07-30 20:32:02.651 | FDAXU26-EUREX [CB] 30 Min #4 | Reloading chart.
2026-07-30 20:32:03.114 | FDAXU26-EUREX [CB] 240 Min #5 | Reloading chart.
2026-07-30 20:32:03.400 | FDAXU26-EUREX [CB] 15 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:03.403 | Chart: FDAXU26-EUREX [CB] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:03.405 | Chart: FDAXU26-EUREX [CB] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:03.735 | FDAXU26-EUREX [CB] 15 Min #7 | Chart data loading complete.
2026-07-30 20:32:03.773 | Chart: FDAXU26-EUREX [CB] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:03.776 | Chart: FDAXU26-EUREX [CB] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:04.081 | FDAXU26-EUREX [CB] 2 Min #14 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:04.161 | Chart: FDAXU26-EUREX [CB] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:04.234 | Chart: FDAXU26-EUREX [CB] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:06.529 | FDAXU26-EUREX [CB] 2 Min #14 | Chart data loading complete.
2026-07-30 20:32:06.534 | FDAXU26-EUREX [CB] 3 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:06.584 | Chart: FDAXU26-EUREX [CB] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:06.603 | Chart: FDAXU26-EUREX [CB] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:09.166 | FDAXU26-EUREX [CB] 3 Min #3 | Chart data loading complete.
2026-07-30 20:32:09.173 | FDAXU26-EUREX [CB] 1 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:09.315 | Chart: FDAXU26-EUREX [CB] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:09.355 | Chart: FDAXU26-EUREX [CB] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:10.643 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:10.643 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:10.643 | Chart #2 has tagged chart #5 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:10.643 | Chart #2 has tagged chart #6 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:10.643 | Chart #2 has tagged chart #7 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:10.643 | Chart #2 has tagged chart #9 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:10.651 | FDAXU26-EUREX [CB] 1 Min #2 | Chart data loading complete.
2026-07-30 20:32:10.666 | HD Request # 3 | Downloading Intraday chart data for NAS100 to the file NAS100.scid. Service: fxcm
2026-07-30 20:32:10.713 | HD Request # 3 | Download start date-time: 2026-07-30 16:56:09.000000. File last date-time: 2026-07-30 16:56:09.113001
2026-07-30 20:32:10.719 | HD Request # 3 | Using server: ds12.sierracharts.com port 10149
2026-07-30 20:32:10.719 | Socket (1) | Creating socket.
2026-07-30 20:32:10.719 | Socket (1) | New receive buffer size: 0
2026-07-30 20:32:10.719 | Socket (1) | Connecting to IP: 69.39.70.241.
2026-07-30 20:32:10.762 | Chart: FDAXU26-EUREX [CB] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:10.775 | Chart: FDAXU26-EUREX [CB] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:11.003 | HD Request # 3 | Setting DTC encoding to Binary VLS
2026-07-30 20:32:11.003 | HD Request # 3 | Sending historical data logon request message.
2026-07-30 20:32:11.162 | HD Request # 3 | Requesting Intraday data. Start date-time: 2026-07-30 16:56:09. Record interval: 0. Symbol: NAS100
2026-07-30 20:32:11.301 | HD Request # 3 | Decompressing data.
2026-07-30 20:32:11.466 | HD Request # 3 | Receiving Intraday data for NAS100 starting at 2026-07-30 16:56:09.007000
2026-07-30 20:32:12.009 | HD Request # 3 | Timestamp of first Intraday data file record written: 2026-07-30 16:56:09.129000.
2026-07-30 20:32:12.183 | Chart: FDAXU26-EUREX [CB] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:12.198 | Chart: FDAXU26-EUREX [CB] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:13.842 | Chart: FDAXU26-EUREX [CB] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:13.875 | Chart: FDAXU26-EUREX [CB] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:14.848 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:14.848 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:14.876 | FDAXU26-EUREX [CB] 15 Min #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:14.880 | Chart: FDAXU26-EUREX [CB] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:14.883 | Chart: FDAXU26-EUREX [CB] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:14.969 | FDAXU26-EUREX [CB] 15 Min #9 | Chart data loading complete.
2026-07-30 20:32:14.975 | FDAXU26-EUREX [CB] 60 Min #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:14.979 | Chart: FDAXU26-EUREX [CB] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:14.981 | Chart: FDAXU26-EUREX [CB] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.032 | FDAXU26-EUREX [CB] 60 Min #6 | Chart data loading complete.
2026-07-30 20:32:15.037 | FDAXU26-EUREX [CB] 30 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:15.043 | Chart: FDAXU26-EUREX [CB] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.046 | Chart: FDAXU26-EUREX [CB] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.193 | FDAXU26-EUREX [CB] 30 Min #4 | Chart data loading complete.
2026-07-30 20:32:15.198 | FDAXU26-EUREX [CB] 240 Min #5 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:15.200 | Chart: FDAXU26-EUREX [CB] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.201 | Chart: FDAXU26-EUREX [CB] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.231 | FDAXU26-EUREX [CB] 240 Min #5 | Chart data loading complete.
2026-07-30 20:32:15.406 | Chart #1 has tagged chart #14 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:15.406 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:15.406 | Chart #1 has tagged chart #3 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:15.406 | Chart #1 has tagged chart #4 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:15.406 | Chart #1 has tagged chart #5 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:15.406 | Chart #1 has tagged chart #6 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:15.406 | Chart #1 has tagged chart #7 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:15.406 | Chart #1 has tagged chart #9 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:15.423 | FDAXU26-EUREX [CB] 1 Day #1 | Chart data loading complete.
2026-07-30 20:32:15.426 | FDAXU26-EUREX [CB] 5 Day #11 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:15.428 | Chart: FDAXU26-EUREX [CB] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.430 | Chart: FDAXU26-EUREX [CB] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.473 | FDAXU26-EUREX [CB] 5 Day #11 | Chart data loading complete.
2026-07-30 20:32:15.497 | Chart: FDAXU26-EUREX [CB] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.500 | Chart: FDAXU26-EUREX [CB] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.577 | Chart: FDAXU26-EUREX [CB] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.580 | Chart: FDAXU26-EUREX [CB] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.640 | Chart: FDAXU26-EUREX [CB] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.644 | Chart: FDAXU26-EUREX [CB] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.786 | Chart: FDAXU26-EUREX [CB] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.788 | Chart: FDAXU26-EUREX [CB] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.821 | Chart: FDAXU26-EUREX [CB] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.822 | Chart: FDAXU26-EUREX [CB] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:15.918 | Socket (1) | CloseSocket call.
2026-07-30 20:32:15.918 | Socket (1) | Shutdown started. Waiting for graceful close.
2026-07-30 20:32:15.944 | Historical data download thread signaled to stop.
2026-07-30 20:32:15.944 | HD Request # 3 | Received 965786 Intraday data records from 2026-07-30 16:56:09.007000 to 2026-07-30 20:32:15.035000 (3.6 hours. Delay: 0.9 seconds) and wrote 965764 records for NAS100
2026-07-30 20:32:15.956 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2026-07-30 18:32:15.035000
2026-07-30 20:32:15.956 | Added 21 Time and Sales records to Intraday data file for NAS100 after download.
2026-07-30 20:32:15.956 | HD Request # 3 | Completion time: 5s.
2026-07-30 20:32:15.956 | HD Request # 3 | Intraday data download complete for NAS100. Unique request ID: 3
2026-07-30 20:32:15.956 | Removing historical data download ID 3.
2026-07-30 20:32:15.956 | Real-time Intraday chart data file updates started for NAS100
2026-07-30 20:32:15.956 | Intraday chart data file opened for NAS100
2026-07-30 20:32:15.956 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2026-07-30 20:32:15.956 | Triggering next historical data download in queue.
2026-07-30 20:32:15.956 | HD Request # 4 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm
2026-07-30 20:32:15.956 | HD Request # 4 | Download start date-time: 2026-07-30 16:56:09.000000. File last date-time: 2026-07-30 16:56:09.104000
2026-07-30 20:32:15.956 | HD Request # 4 | Using server: ds4.sierracharts.com port 10150
2026-07-30 20:32:15.982 | FDAXU26-EUREX [CB] 5 Day #11 | Reloading chart.
2026-07-30 20:32:16.062 | Socket (1) | Socket gracefully closed by remote side.
2026-07-30 20:32:16.062 | Socket (1) | Closed.
2026-07-30 20:32:16.102 | Socket (2) | Creating socket.
2026-07-30 20:32:16.102 | Socket (2) | New receive buffer size: 0
2026-07-30 20:32:16.102 | Socket (2) | Connecting to IP: 64.152.155.113.
2026-07-30 20:32:16.379 | HD Request # 4 | Setting DTC encoding to Binary VLS
2026-07-30 20:32:16.379 | HD Request # 4 | Sending historical data logon request message.
2026-07-30 20:32:16.533 | HD Request # 4 | Requesting Intraday data. Start date-time: 2026-07-30 16:56:09. Record interval: 0. Symbol: US30
2026-07-30 20:32:16.592 | FDAXU26-EUREX [CB] 1 Min #2 | Reloading chart.
2026-07-30 20:32:16.670 | HD Request # 4 | Decompressing data.
2026-07-30 20:32:16.699 | FDAXU26-EUREX [CB] 3 Min #3 | Reloading chart.
2026-07-30 20:32:16.856 | FDAXU26-EUREX [CB] 1 Day #1 | Reloading chart.
2026-07-30 20:32:16.966 | HD Request # 4 | Receiving Intraday data for US30 starting at 2026-07-30 16:56:09.037000
2026-07-30 20:32:17.161 | HD Request # 4 | Timestamp of first Intraday data file record written: 2026-07-30 16:56:09.129000.
2026-07-30 20:32:17.848 | FDAXU26-EUREX [CB] 15 Min #7 | Reloading chart.
2026-07-30 20:32:17.861 | Socket (2) | CloseSocket call.
2026-07-30 20:32:17.861 | Socket (2) | Shutdown started. Waiting for graceful close.
2026-07-30 20:32:17.887 | Historical data download thread signaled to stop.
2026-07-30 20:32:17.887 | HD Request # 4 | Received 165436 Intraday data records from 2026-07-30 16:56:09.037000 to 2026-07-30 20:32:17.056000 (3.6 hours. Delay: 0.8 seconds) and wrote 165434 records for US30
2026-07-30 20:32:17.899 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2026-07-30 18:32:17.056000
2026-07-30 20:32:17.900 | HD Request # 4 | Completion time: 2s.
2026-07-30 20:32:17.900 | HD Request # 4 | Intraday data download complete for US30. Unique request ID: 4
2026-07-30 20:32:17.900 | Removing historical data download ID 4.
2026-07-30 20:32:17.900 | Real-time Intraday chart data file updates started for US30
2026-07-30 20:32:17.900 | Intraday chart data file opened for US30
2026-07-30 20:32:17.900 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2026-07-30 20:32:17.900 | No download requests in the queue to start downloads for.
2026-07-30 20:32:17.906 | Denali Data Feed | Starting real-time market data updates for: FDAXU26-EUREX (FDAX202609_FUT_EUREX). ID: 1 Service code: eurex
2026-07-30 20:32:17.907 | Denali Data Feed | Connecting to the server ds50.sierracharts.com. Port 443
2026-07-30 20:32:17.907 | Denali Data Feed | Requesting security definition data for: FDAXU26-EUREX (FDAX202609_FUT_EUREX). ID: 1
2026-07-30 20:32:17.909 | DTC Client socket (1) | Creating socket.
2026-07-30 20:32:17.909 | DTC Client socket (1) | New receive buffer size: 0
2026-07-30 20:32:17.909 | DTC Client socket (1) | Connecting to IP: 62.209.53.225.
2026-07-30 20:32:17.909 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:17.910 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:17.948 | FDAXU26-EUREX [CB] 2 Min #14 | Reloading chart.
2026-07-30 20:32:17.984 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:18.001 | Socket (2) | Socket gracefully closed by remote side.
2026-07-30 20:32:18.001 | Socket (2) | Closed.
2026-07-30 20:32:18.010 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:18.051 | Denali Data Feed | Network connection to server complete.
2026-07-30 20:32:18.051 | Denali Data Feed | Starting socket receive thread.
2026-07-30 20:32:18.105 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2026-07-30 20:32:18.111 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:18.111 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:18.292 | FDAXU26-EUREX [CB] 1 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:18.431 | Chart: FDAXU26-EUREX [CB] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:18.475 | Chart: FDAXU26-EUREX [CB] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:19.315 | Opened cached Intraday file: C:\SierraChart\Data\NAS100.scid. Thread ID: 12044
2026-07-30 20:32:19.315 | Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 12044
2026-07-30 20:32:19.980 | Chart #2 has tagged chart #11 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:19.980 | Chart #2 has tagged chart #5 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:19.980 | Chart #2 has tagged chart #6 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:19.980 | Chart #2 has tagged chart #9 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:19.987 | FDAXU26-EUREX [CB] 1 Min #2 | Chart data loading complete.
2026-07-30 20:32:19.988 | FDAXU26-EUREX [CB] 3 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:20.081 | Chart: FDAXU26-EUREX [CB] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:20.154 | Chart: FDAXU26-EUREX [CB] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:22.017 | FDAXU26-EUREX [CB] 3 Min #3 | Chart data loading complete.
2026-07-30 20:32:22.105 | Chart: FDAXU26-EUREX [CB] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:22.143 | Chart: FDAXU26-EUREX [CB] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:23.289 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:23.343 | Chart: FDAXU26-EUREX [CB] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:23.361 | Chart: FDAXU26-EUREX [CB] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:25.040 | FDAXU26-EUREX [CB] 15 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:25.044 | Chart: FDAXU26-EUREX [CB] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:25.046 | Chart: FDAXU26-EUREX [CB] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:25.160 | FDAXU26-EUREX [CB] 15 Min #7 | Chart data loading complete.
2026-07-30 20:32:25.167 | FDAXU26-EUREX [CB] 2 Min #14 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:25.199 | Chart: FDAXU26-EUREX [CB] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:25.227 | Chart: FDAXU26-EUREX [CB] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:26.507 | FDAXU26-EUREX [CB] 2 Min #14 | Chart data loading complete.
2026-07-30 20:32:26.514 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-07-30 20:32:26.514 | Denali Data Feed | Sending logon request message.
2026-07-30 20:32:26.546 | US30 [CB-D][M] 2 Min #13 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:26.594 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:26.631 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:27.422 | US30 [CB-D][M] 2 Min #13 | Chart data loading complete.
2026-07-30 20:32:27.470 | Chart: FDAXU26-EUREX [CB] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:27.472 | Chart: FDAXU26-EUREX [CB] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:27.577 | Chart: FDAXU26-EUREX [CB] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:27.587 | Chart: FDAXU26-EUREX [CB] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:28.834 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:28.872 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:29.731 | Chart #1 has tagged chart #11 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:29.731 | Chart #1 has tagged chart #13 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:29.731 | Chart #1 has tagged chart #14 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:29.731 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:29.731 | Chart #1 has tagged chart #3 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:29.731 | Chart #1 has tagged chart #4 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:29.731 | Chart #1 has tagged chart #5 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:29.731 | Chart #1 has tagged chart #6 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:29.731 | Chart #1 has tagged chart #7 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:29.731 | Chart #1 has tagged chart #9 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:29.747 | FDAXU26-EUREX [CB] 1 Day #1 | Chart data loading complete.
2026-07-30 20:32:29.751 | FDAXU26-EUREX [CB] 5 Day #11 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:29.753 | Chart: FDAXU26-EUREX [CB] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:29.754 | Chart: FDAXU26-EUREX [CB] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:29.793 | FDAXU26-EUREX [CB] 5 Day #11 | Chart data loading complete.
2026-07-30 20:32:29.805 | Denali Data Feed | Received logon response.
2026-07-30 20:32:29.805 | Denali Data Feed | Server Name: SC Realtime Server.
2026-07-30 20:32:29.805 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-07-30 20:32:29.805 | Denali Data Feed | Successfully connected.
2026-07-30 20:32:29.805 | Denali Data Feed | Trading is not supported.
2026-07-30 20:32:29.805 | Denali Data Feed | MarketDepthIsSupported: 1
2026-07-30 20:32:29.806 | Added historical Intraday data request for FDAXU26-EUREX to the queue.
2026-07-30 20:32:29.806 | Intraday data recording state for symbol FDAXU26-EUREX is set to download 'Pending'.
2026-07-30 20:32:29.806 | Triggering next historical data download in queue.
2026-07-30 20:32:29.806 | Denali Data Feed | Restarting real-time data updates for symbol: FDAXU26-EUREX -> FDAX202609_FUT_EUREX
2026-07-30 20:32:29.815 | Chart: FDAXU26-EUREX [CB] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:29.816 | Chart: FDAXU26-EUREX [CB] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:29.853 | Delaying start of download for FDAXU26-EUREX.
2026-07-30 20:32:30.029 | Denali Data Feed | Setting external service identifier for symbol FDAXU26-EUREX to 9921661
2026-07-30 20:32:30.029 | Denali Data Feed | Received security definition for symbol FDAXU26-EUREX
2026-07-30 20:32:30.037 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.037 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.055 | US30 [CB-D][M] 2 Min #13 | Reloading chart.
2026-07-30 20:32:30.056 | US30 [CB-D][M] 2 Min #13 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-07-30 20:32:30.056 | US30 [CB-D][M] 2 Min #13 | There are no continuous futures contract symbols. Loading data normally.
2026-07-30 20:32:30.062 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.062 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.085 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.085 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.114 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.114 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.138 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.141 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.193 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.198 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.278 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.280 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.477 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.477 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.562 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.563 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.589 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.592 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.622 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.622 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.648 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.649 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.765 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:30.797 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:31.533 | Chart #2 has tagged chart #11 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:31.533 | Chart #2 has tagged chart #13 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:31.533 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:31.533 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:31.533 | Chart #2 has tagged chart #5 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:31.533 | Chart #2 has tagged chart #6 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:31.533 | Chart #2 has tagged chart #7 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:31.533 | Chart #2 has tagged chart #9 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:31.552 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:31.552 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:31.713 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:31.715 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.235 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.235 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.331 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.331 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.362 | HD Request # 5 | Downloading Intraday chart data for FDAXU26-EUREX to the file FDAXU26-EUREX.scid. Service: eurex
2026-07-30 20:32:34.363 | HD Request # 5 | Download start date-time: 2026-07-30 20:31:39.000000. File last date-time: 2026-07-30 20:31:39.096000
2026-07-30 20:32:34.363 | HD Request # 5 | Using server: ds50.sierracharts.com port 10149
2026-07-30 20:32:34.381 | Socket (2) | Creating socket.
2026-07-30 20:32:34.381 | Socket (2) | New receive buffer size: 0
2026-07-30 20:32:34.381 | Socket (2) | Connecting to IP: 62.209.53.225.
2026-07-30 20:32:34.511 | HD Request # 5 | Setting DTC encoding to Binary VLS
2026-07-30 20:32:34.511 | HD Request # 5 | Sending historical data logon request message.
2026-07-30 20:32:34.613 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.613 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.646 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.646 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.849 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.849 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.855 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.855 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.989 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.989 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:34.994 | HD Request # 5 | Requesting Intraday data. Start date-time: 2026-07-30 20:31:39. Record interval: 0. Symbol: FDAX202609_FUT_EUREX
2026-07-30 20:32:35.043 | HD Request # 5 | Decompressing data.
2026-07-30 20:32:35.047 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.047 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.068 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.068 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.149 | HD Request # 5 | Receiving Intraday data for FDAXU26-EUREX starting at 2026-07-30 20:31:39.096000
2026-07-30 20:32:35.149 | Socket (2) | CloseSocket call.
2026-07-30 20:32:35.149 | Socket (2) | Shutdown started. Waiting for graceful close.
2026-07-30 20:32:35.149 | Historical data download thread signaled to stop.
2026-07-30 20:32:35.150 | HD Request # 5 | Timestamp of first Intraday data file record written: 2026-07-30 20:32:02.677000.
2026-07-30 20:32:35.150 | HD Request # 5 | Received 3 Intraday data records from 2026-07-30 20:31:39.096000 to 2026-07-30 20:32:07.177000 (28.1 seconds. Delay: 28.0 seconds) and wrote 2 records for FDAXU26-EUREX
2026-07-30 20:32:35.160 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2026-07-30 18:32:07.177000
2026-07-30 20:32:35.160 | HD Request # 5 | Completion time: 1s.
2026-07-30 20:32:35.160 | HD Request # 5 | Intraday data download complete for FDAXU26-EUREX. Unique request ID: 5
2026-07-30 20:32:35.160 | Removing historical data download ID 5.
2026-07-30 20:32:35.160 | Real-time Intraday chart data file updates started for FDAXU26-EUREX
2026-07-30 20:32:35.160 | Intraday chart data file opened for FDAXU26-EUREX
2026-07-30 20:32:35.160 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2026-07-30 20:32:35.160 | No download requests in the queue to start downloads for.
2026-07-30 20:32:35.206 | Socket (2) | Socket gracefully closed by remote side.
2026-07-30 20:32:35.206 | Socket (2) | Closed.
2026-07-30 20:32:35.355 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.355 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.366 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.366 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.615 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.615 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.648 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.648 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.663 | Chart #2 has tagged chart #11 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:35.866 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.866 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.874 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.874 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.976 | Chart #1 has tagged chart #11 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:35.976 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:35.976 | Chart #1 has tagged chart #4 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:35.976 | Chart #1 has tagged chart #5 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:35.976 | Chart #1 has tagged chart #6 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:35.976 | Chart #1 has tagged chart #9 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:32:35.989 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:35.989 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.043 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.043 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.071 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.071 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.275 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.275 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.352 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.353 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.618 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.618 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.650 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.650 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.867 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.867 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.874 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.874 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.995 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:36.995 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:37.062 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:37.062 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:37.086 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:37.087 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:38.289 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:38.289 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:38.382 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:38.382 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:38.630 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:38.630 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:38.650 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:38.650 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:38.896 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:38.896 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:38.902 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:38.902 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:39.004 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:39.004 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:39.062 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:39.062 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:39.114 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:39.114 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:39.286 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:39.286 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:39.395 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:39.395 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.117 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.117 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.386 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.387 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.398 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.398 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.634 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.634 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.655 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.655 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.919 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.919 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.925 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:40.925 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:41.013 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:41.014 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:41.070 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:41.071 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:42.677 | US30 [CB-D][M] 2 Min #13 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:32:42.725 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:42.756 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:43.595 | US30 [CB-D][M] 2 Min #13 | Chart data loading complete.
2026-07-30 20:32:43.641 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:43.669 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.489 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.489 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.498 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.498 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.588 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.588 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.661 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.661 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.671 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.672 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.850 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.850 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.861 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.861 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.871 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.871 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.884 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:44.884 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.002 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.002 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.028 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.028 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.035 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.035 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.108 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.108 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.166 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.166 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.225 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.251 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.929 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.929 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.937 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.937 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.945 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.945 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.963 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.963 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.988 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:45.988 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.018 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.018 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.030 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.030 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.135 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.135 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.204 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.204 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.221 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.221 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.326 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.326 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.334 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.334 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.553 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.553 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.690 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.690 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.715 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.715 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.969 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.969 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.975 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:46.975 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:47.226 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:47.226 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:47.707 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:47.707 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:47.728 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:47.728 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:47.971 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:47.971 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:47.978 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:47.978 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.051 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.051 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.109 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.109 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.145 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.145 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.240 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.240 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.268 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:32:48.268 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:32:48.268 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:32:48.268 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:32:48.275 | NTP Client | Received Packet | RoundTripDelay=0.0069828033447265625S, SystemClockOffset=0.15651321411132812S
2026-07-30 20:32:48.276 | NTP Client | Received Packet | RoundTripDelay=0.007909297943115234S, SystemClockOffset=0.1544950008392334S
2026-07-30 20:32:48.276 | NTP Client | Received Packet | RoundTripDelay=0.007982730865478516S, SystemClockOffset=0.15662407875061035S
2026-07-30 20:32:48.283 | NTP Client | Received Packet | RoundTripDelay=0.014986515045166016S, SystemClockOffset=0.1567094326019287S
2026-07-30 20:32:48.331 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.331 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.441 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.441 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.708 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.708 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.728 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.728 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.990 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.990 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.996 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:48.996 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.073 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.073 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.133 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.133 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.162 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.162 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.255 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.255 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.271 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
2026-07-30 20:32:49.347 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.347 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.440 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.440 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.727 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.727 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.755 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.755 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.990 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.990 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.996 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:49.996 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.077 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.077 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.130 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.130 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.164 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.164 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.266 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.266 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.353 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.353 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.447 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.447 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.715 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.715 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.738 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.738 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.994 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:50.994 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:51.001 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:51.001 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:51.182 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:51.182 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:52.180 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:52.180 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:53.190 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:53.190 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:54.304 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:54.304 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:54.741 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:54.741 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:54.763 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:54.763 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.038 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.038 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.046 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.046 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.135 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.135 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.192 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.192 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.202 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.202 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.401 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.401 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.403 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.403 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.496 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.496 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.732 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.732 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.735 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:55.735 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.095 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.095 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.107 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.107 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.172 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.172 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.233 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.233 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.285 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.285 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.302 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.302 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.394 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.394 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.519 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.520 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.739 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.739 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.742 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:56.742 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.037 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.037 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.044 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.044 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.107 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.108 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.166 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.166 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.221 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.221 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.241 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.242 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.413 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.413 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.522 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.522 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.742 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.742 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.745 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:57.745 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:58.220 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:58.220 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:32:59.213 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:32:59.213 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:00.231 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:00.231 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:01.240 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:01.240 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:02.234 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:02.235 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:02.252 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:02.252 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:02.404 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:02.404 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:02.531 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:02.532 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:02.784 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:02.784 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:02.787 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:02.787 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.084 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.084 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.090 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.090 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.151 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.151 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.208 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.208 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.263 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.263 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.285 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.285 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.416 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.416 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.542 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.542 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.806 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.806 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.809 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:03.809 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.089 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.089 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.095 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.095 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.160 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.160 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.218 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.218 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.276 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.276 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.299 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.299 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.431 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.431 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.542 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.542 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.822 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.822 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.825 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:04.826 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.121 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.121 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.127 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.127 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.190 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.190 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.249 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.249 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.308 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.308 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.324 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.324 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.432 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.432 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.543 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.543 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:05.792 | Opened cached Intraday file: C:\SierraChart\Data\FDAXU26-EUREX.scid. Thread ID: 12044
2026-07-30 20:33:06.307 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:06.307 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.136 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.136 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.142 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.142 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.206 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.206 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.261 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.261 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.324 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.325 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.341 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.341 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.422 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.422 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.578 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.578 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.827 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.827 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.830 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:07.830 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.139 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.139 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.145 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.145 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.210 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.210 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.267 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.267 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.328 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.328 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.345 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.345 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.420 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.420 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.588 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.588 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.828 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.828 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.831 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:08.831 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.156 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.156 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.163 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.163 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.226 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.227 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.285 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.285 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.338 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.338 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.358 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.359 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.437 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.437 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.593 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.593 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.828 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.828 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.831 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:09.831 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.226 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.226 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.235 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.235 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.372 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.372 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.529 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.529 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.582 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.582 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.599 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.599 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.601 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.601 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.607 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.607 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.841 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.841 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.845 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:10.845 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.170 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.170 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.178 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.178 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.242 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.242 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.300 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.300 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.357 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.357 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.454 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.454 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.611 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:11.611 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:12.336 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:12.337 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:12.358 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:12.358 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:12.470 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:12.470 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:12.611 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:12.611 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:12.862 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:12.862 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:12.866 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:12.866 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:13.177 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:13.177 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:13.184 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:13.184 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:13.246 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:13.246 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:13.307 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:13.307 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:13.357 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:13.357 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.301 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.301 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.358 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.358 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.374 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.374 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.480 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.480 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.621 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.621 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.856 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.856 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.860 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:14.860 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.171 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.171 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.178 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.178 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.242 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.242 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.300 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.300 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.352 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.352 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.373 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.373 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.485 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.485 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.641 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.641 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.861 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.861 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.865 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:15.865 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:16.352 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:16.352 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.202 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.202 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.210 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.210 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.271 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.272 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.332 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.332 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.382 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.383 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.401 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.401 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.513 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.513 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.638 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.638 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.886 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.886 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.890 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:19.890 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:20.359 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:20.359 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:20.516 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:20.516 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:20.656 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:20.656 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:20.890 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:20.890 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:20.894 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:20.894 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:21.219 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:21.219 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:21.225 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:21.226 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:21.292 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:21.292 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:21.348 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:21.348 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:21.400 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:21.400 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:21.418 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:21.418 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:22.398 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:22.398 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:23.399 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:23.399 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:25.403 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:25.403 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.783 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.783 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.836 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.836 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.887 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.887 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.905 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.905 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.907 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.907 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.908 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.908 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.928 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.928 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.931 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:26.931 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:27.267 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:27.267 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:27.274 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:27.274 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:27.833 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:27.833 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:28.158 | NAS100 [CB-D][M] 2 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:33:28.201 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:28.229 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:28.847 | NAS100 [CB-D][M] 2 Min #10 | Chart data loading complete.
2026-07-30 20:33:28.888 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:28.913 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:29.545 | FDAXU26-EUREX [CB][M] 3 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:33:29.575 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:29.586 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:30.760 | FDAXU26-EUREX [CB][M] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:33:30.765 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:30.767 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:30.872 | FDAXU26-EUREX [CB][M] 15 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:33:30.878 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:30.882 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:30.961 | FDAXU26-EUREX [CB][M] 2 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:33:30.985 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:30.993 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.050 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.050 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.064 | FDAXU26-EUREX [CB][M] 5 Day #11 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:33:32.066 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.067 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.093 | FDAXU26-EUREX [CB][M] 240 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:33:32.095 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.096 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.110 | FDAXU26-EUREX [CB][M] 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:33:32.112 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.114 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.174 | NAS100 [CB-D][M] 2 Min #10 | Reloading chart.
2026-07-30 20:33:32.174 | NAS100 [CB-D][M] 2 Min #10 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-07-30 20:33:32.174 | NAS100 [CB-D][M] 2 Min #10 | There are no continuous futures contract symbols. Loading data normally.
2026-07-30 20:33:32.176 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.177 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.181 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.181 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.207 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:32.207 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:33.509 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:33.509 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:34.421 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:34.422 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:34.437 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:34.437 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:34.594 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:34.594 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:34.688 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:34.688 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:34.952 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:34.952 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:34.955 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:34.955 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.267 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.267 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.325 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.325 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.334 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.334 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.405 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.405 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.461 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.461 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.610 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.610 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.703 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.703 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.967 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.967 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.970 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:35.970 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.264 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.264 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.312 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.312 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.317 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.317 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.379 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.379 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.436 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.436 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.454 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.454 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.613 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.613 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.707 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.707 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.989 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.989 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.992 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:36.992 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:37.439 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:37.439 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:37.713 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:37.714 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.048 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.048 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.125 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.125 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.303 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.303 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.372 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.372 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.380 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.380 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.438 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.438 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.492 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.492 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.510 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.510 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.619 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.619 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.744 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.744 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.995 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.995 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.999 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:38.999 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:39.289 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:39.289 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:39.333 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:39.333 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:39.339 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:39.339 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:39.397 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:39.397 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:39.448 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:39.448 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:39.466 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:39.466 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.327 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.327 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.332 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.332 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.391 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.391 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.452 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.452 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.483 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.483 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.647 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.647 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.741 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:40.741 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:41.021 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:41.021 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:41.025 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:41.025 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:41.288 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:41.288 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:41.442 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:41.442 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:41.651 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:41.651 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:41.760 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:41.760 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.038 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.038 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.041 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.041 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.287 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.287 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.380 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.380 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.388 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.388 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.450 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.450 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.506 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.506 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.526 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.527 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.648 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.648 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.759 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:42.759 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.040 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.040 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.043 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.043 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.307 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.307 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.356 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.356 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.371 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.371 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.443 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.443 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.503 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.503 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.667 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.667 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.772 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:43.772 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.051 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.051 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.054 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.054 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.305 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.305 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.350 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.350 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.355 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.355 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.422 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.422 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.486 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.486 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.513 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:44.513 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:45.470 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:45.470 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.070 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.070 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.077 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.077 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.318 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.319 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.326 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.326 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.332 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.332 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.477 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.477 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.536 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.536 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.602 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.602 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.708 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.708 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.770 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:46.770 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:47.452 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:47.452 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.079 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.079 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.082 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.082 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.345 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.345 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.352 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.352 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.357 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.358 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.433 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.433 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.493 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.493 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.508 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.508 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.594 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:33:48.594 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:33:48.594 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:33:48.594 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:33:48.601 | NTP Client | Received Packet | RoundTripDelay=0.006988048553466797S, SystemClockOffset=0.15668988227844238S
2026-07-30 20:33:48.601 | NTP Client | Received Packet | RoundTripDelay=0.0069751739501953125S, SystemClockOffset=0.15654611587524414S
2026-07-30 20:33:48.602 | NTP Client | Received Packet | RoundTripDelay=0.006912708282470703S, SystemClockOffset=0.15521693229675293S
2026-07-30 20:33:48.609 | NTP Client | Received Packet | RoundTripDelay=0.014994621276855469S, SystemClockOffset=0.15680789947509766S
2026-07-30 20:33:48.735 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.735 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.780 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:48.780 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.080 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.080 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.083 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.083 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.346 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.346 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.353 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.353 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.359 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.359 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.434 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.434 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.488 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.488 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.507 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.507 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.595 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
2026-07-30 20:33:49.752 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:49.752 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.094 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.094 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.097 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.097 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.357 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.358 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.365 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.365 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.371 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.371 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.433 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.433 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.486 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.487 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.507 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.507 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.749 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.749 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.807 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:50.808 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.098 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.098 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.101 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.101 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.374 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.374 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.380 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.380 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.385 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.385 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.444 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.444 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.504 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.504 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.523 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:51.523 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:52.511 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:52.511 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:52.531 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:52.532 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:52.766 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:52.766 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:52.797 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:52.797 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.109 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.109 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.112 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.112 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.388 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.388 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.395 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.395 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.401 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.401 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.477 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.478 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.530 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.530 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.558 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.559 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.764 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.764 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.810 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:53.810 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.121 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.121 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.124 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.124 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.463 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.463 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.469 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.470 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.476 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.476 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.535 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.535 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.617 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.617 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.634 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.634 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.777 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.777 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.808 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:54.809 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.136 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.136 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.139 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.139 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.417 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.417 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.424 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.424 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.429 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.429 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.483 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.483 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.538 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.538 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.557 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.557 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.790 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.790 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.822 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:55.822 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.147 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.147 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.150 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.150 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.444 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.444 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.452 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.452 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.458 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.458 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.545 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.545 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.599 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.599 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.621 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.621 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.801 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.802 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.818 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:56.818 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:57.566 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:57.566 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:57.816 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:57.816 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:57.839 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:57.839 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.170 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.170 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.173 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.173 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.448 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.448 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.469 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.469 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.477 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.477 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.548 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.548 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.614 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.614 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.634 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.634 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.814 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.814 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.833 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:58.834 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.171 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.171 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.174 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.174 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.450 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.450 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.457 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.457 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.462 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.462 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.539 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.539 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.602 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.602 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.618 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.619 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.810 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.810 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.883 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:33:59.883 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:00.171 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:00.171 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:00.174 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:00.174 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:00.571 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:00.571 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.191 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.191 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.195 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.195 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.457 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.457 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.464 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.464 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.470 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.470 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.526 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.526 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.580 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.580 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.596 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.597 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.833 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.833 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.851 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:01.851 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.455 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.455 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.462 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.462 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.467 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.467 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.523 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.523 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.579 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.579 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.597 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.597 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.838 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.838 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.866 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:02.866 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:03.197 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:03.197 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:03.200 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:03.200 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:03.582 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:03.582 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.489 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.489 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.496 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.497 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.503 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.503 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.559 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.559 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.612 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.612 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.634 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.634 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.864 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.864 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.881 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:04.881 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:05.205 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:05.205 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:05.209 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:05.209 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:05.608 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:05.608 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.201 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.202 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.204 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.204 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.514 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.514 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.525 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.525 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.534 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.534 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.598 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.598 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.655 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.655 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.678 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.678 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.871 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.871 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.889 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:06.889 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.526 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.526 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.533 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.533 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.539 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.539 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.668 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.668 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.747 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.747 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.765 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.765 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.920 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.920 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.943 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:07.943 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.364 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.364 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.367 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.367 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.528 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.528 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.534 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.534 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.540 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.540 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.594 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.594 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.648 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.648 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.667 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.667 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.900 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.900 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.921 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:08.921 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.557 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.557 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.567 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.567 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.575 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.575 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.635 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.635 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.690 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.690 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.710 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.710 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.902 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.902 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.926 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:09.926 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.226 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.226 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.229 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.229 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.553 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.553 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.560 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.560 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.565 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.566 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.621 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.622 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.678 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.678 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.694 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.694 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.913 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.913 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.930 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:10.930 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.239 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.240 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.243 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.243 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.567 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.567 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.573 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.573 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.579 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.580 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.634 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.634 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.688 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.688 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.709 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.709 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.913 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.913 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.932 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:11.932 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.245 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.246 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.249 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.249 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.574 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.574 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.580 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.581 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.602 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.602 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.696 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.696 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.768 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.768 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.795 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.795 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.930 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.931 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.954 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:12.954 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:13.261 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:13.261 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:13.265 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:13.265 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:13.697 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:13.697 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:14.691 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:14.691 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:15.703 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:15.703 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:15.724 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:15.724 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:15.945 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:15.945 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:15.965 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:15.966 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.289 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.289 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.309 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.309 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.574 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.574 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.581 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.581 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.586 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.586 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.687 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.687 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.759 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.759 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.790 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.790 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.948 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.948 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.970 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:16.970 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.594 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.594 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.603 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.603 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.610 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.610 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.670 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.671 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.733 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.733 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.750 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.751 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.951 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.951 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.974 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:17.974 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.279 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.279 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.283 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.283 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.608 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.608 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.619 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.619 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.627 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.627 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.686 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.687 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.745 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.745 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.760 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.760 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.954 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.954 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.976 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:18.976 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.285 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.285 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.289 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.289 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.616 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.616 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.624 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.624 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.631 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.631 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.699 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.699 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.758 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:19.758 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.287 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.287 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.291 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.291 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.647 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.647 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.656 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.656 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.664 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.664 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.725 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.725 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.784 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.784 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.805 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.805 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.995 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:23.995 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.016 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.016 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.279 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.279 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.282 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.282 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.642 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.642 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.649 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.649 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.655 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.655 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.716 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.716 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.772 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.772 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.795 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:24.795 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.007 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.007 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.028 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.028 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.290 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.290 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.294 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.294 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.650 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.650 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.657 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.657 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.663 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.663 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.738 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.738 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.821 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.821 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.844 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:25.845 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.011 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.011 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.032 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.032 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.277 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.277 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.281 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.281 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.643 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.643 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.650 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.650 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.655 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.656 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.713 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.713 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.765 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.765 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.784 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:26.784 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:27.017 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:27.017 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:27.038 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:27.038 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:27.299 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:27.299 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:27.320 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:27.320 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:27.765 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:27.765 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:28.640 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:28.640 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:28.647 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:28.647 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:28.653 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:28.653 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:28.714 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:28.714 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:28.781 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:28.781 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:28.813 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:28.813 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.017 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.017 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.036 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.036 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.300 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.300 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.303 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.303 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.647 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.647 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.656 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.656 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.663 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.663 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.763 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.763 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.829 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.829 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.848 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:29.848 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:30.024 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:30.024 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:30.047 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:30.047 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:30.769 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:30.769 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:31.797 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:31.797 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.335 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.335 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.339 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.339 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.665 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.665 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.672 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.672 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.679 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.679 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.741 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.741 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.801 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.801 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.821 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:32.821 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:33.026 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:33.026 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:33.049 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:33.049 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:34.775 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:34.776 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:35.782 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:35.783 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:36.788 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:36.788 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:37.811 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:37.811 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.025 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.025 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.026 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.026 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.397 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.398 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.402 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.402 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.693 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.694 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.701 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.701 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.708 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.708 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.769 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.769 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.828 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.828 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.852 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:38.852 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:39.024 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:39.024 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:39.025 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:39.026 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:39.400 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:39.401 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:39.404 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:39.404 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:39.815 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:39.815 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.387 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.387 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.390 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.390 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.686 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.686 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.693 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.693 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.698 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.698 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.764 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.764 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.821 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.821 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.843 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:40.843 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.043 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.043 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.044 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.044 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.400 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.400 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.403 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.403 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.687 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.687 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.694 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.694 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.700 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.700 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.818 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:41.818 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.047 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.047 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.048 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.048 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.391 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.391 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.394 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.394 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.687 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.687 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.695 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.695 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.700 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.700 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.762 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.762 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.818 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.818 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.841 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:42.841 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:43.049 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:43.049 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:43.051 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:43.051 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:43.394 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:43.394 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:43.397 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:43.397 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:44.830 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:44.830 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:46.911 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:46.911 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.085 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.085 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.086 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.086 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.399 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.399 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.403 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.403 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.726 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.726 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.733 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.733 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.740 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.740 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.812 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.812 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.870 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.870 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.893 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:47.893 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.085 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.085 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.087 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.087 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.413 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.413 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.416 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.416 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.743 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.743 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.751 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.751 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.759 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.759 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:48.945 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:34:48.945 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:34:48.945 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:34:48.945 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:34:48.952 | NTP Client | Received Packet | RoundTripDelay=0.006984233856201172S, SystemClockOffset=0.15736603736877441S
2026-07-30 20:34:48.952 | NTP Client | Received Packet | RoundTripDelay=0.006986141204833984S, SystemClockOffset=0.15721631050109863S
2026-07-30 20:34:48.953 | NTP Client | Received Packet | RoundTripDelay=0.007895469665527344S, SystemClockOffset=0.15538740158081055S
2026-07-30 20:34:48.961 | NTP Client | Received Packet | RoundTripDelay=0.014994144439697266S, SystemClockOffset=0.15747380256652832S
2026-07-30 20:34:49.744 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:49.744 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:49.753 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:49.753 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:49.761 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:49.761 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:49.826 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:49.827 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:49.889 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:49.889 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:49.912 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:49.912 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:49.945 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
2026-07-30 20:34:50.117 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.117 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.118 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.118 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.416 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.416 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.420 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.420 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.756 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.756 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.763 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.763 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.769 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.769 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.839 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.839 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.910 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.910 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.932 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:50.933 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:51.900 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:51.900 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.417 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.417 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.421 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.421 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.748 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.748 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.756 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.756 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.761 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.761 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.826 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.826 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.883 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.884 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.905 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:52.905 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:53.124 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:53.124 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:53.126 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:53.126 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:53.435 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:53.435 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:53.438 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:53.439 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:53.491 | NAS100 [CB-D][M] 2 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-30 20:34:53.547 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:53.574 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:54.285 | NAS100 [CB-D][M] 2 Min #10 | Chart data loading complete.
2026-07-30 20:34:54.329 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:54.355 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.164 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.164 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.267 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.267 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.274 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.274 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.280 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.280 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.334 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.334 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.385 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.385 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.403 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.403 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.405 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.405 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.405 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.405 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.407 | FDAXU26-EUREX [CB][M] 15 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:55.410 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.414 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.444 | FDAXU26-EUREX [CB][M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:55.518 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:55.543 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:56.159 | Chart #2 has tagged chart #10 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:56.159 | Chart #2 has tagged chart #11 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:56.159 | Chart #2 has tagged chart #13 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:56.159 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:56.159 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:56.159 | Chart #2 has tagged chart #5 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:56.159 | Chart #2 has tagged chart #6 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:56.159 | Chart #2 has tagged chart #7 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:56.159 | Chart #2 has tagged chart #9 for full recalculation. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:56.167 | FDAXU26-EUREX [CB][M] 15 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:56.170 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:56.173 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:56.251 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:56.277 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:56.971 | FDAXU26-EUREX [CB][M] 2 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:56.991 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:56.999 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:58.091 | FDAXU26-EUREX [CB][M] 3 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:58.119 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:58.130 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:59.297 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:59.297 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:59.353 | FDAXU26-EUREX [CB][M] 15 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:59.357 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:59.360 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:34:59.435 | US30 [CB-D][M] 2 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:34:59.485 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:34:59.512 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.098 | FDAXU26-EUREX [CB][M] 5 Day #11 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:35:00.100 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.101 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.127 | FDAXU26-EUREX [CB][M] 240 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:35:00.128 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.130 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.144 | FDAXU26-EUREX [CB][M] 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: 000 FDAX_09Z23_Maroth.Cht
2026-07-30 20:35:00.147 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.149 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.177 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.177 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.200 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.201 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.203 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.203 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.311 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.311 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.319 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.319 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.325 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.325 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.393 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.393 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.447 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.447 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.464 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.464 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.465 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.465 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.471 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.471 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.496 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.496 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.794 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.794 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.797 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.797 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.899 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.899 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.906 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.906 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.912 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.912 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.964 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:00.964 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.022 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.022 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.183 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.183 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.184 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.184 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.479 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.479 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.503 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.503 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.815 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.816 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.818 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.818 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.918 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.918 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.926 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.926 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.931 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.931 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.984 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:01.985 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.034 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.034 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.191 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.191 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.192 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.192 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.487 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.488 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.510 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.510 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.829 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.829 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.833 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.833 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.933 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.933 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.940 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.940 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.946 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:02.946 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.000 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.000 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.049 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.049 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.188 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.188 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.189 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.189 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.487 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.487 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.510 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.510 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.832 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.832 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.835 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.835 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.942 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.942 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.948 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.948 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.953 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:03.953 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.008 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.008 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.061 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.061 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.205 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.205 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.206 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.206 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.502 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.502 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.523 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.523 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.843 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.843 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.846 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.846 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.957 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.957 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.965 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.965 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.972 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:04.972 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.031 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.031 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.086 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.086 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.205 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.205 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.207 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.207 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.516 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.516 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.538 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.538 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.845 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.845 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.850 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.850 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.951 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.951 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.958 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.958 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.963 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:05.963 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.017 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.017 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.066 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.066 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.218 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.219 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.220 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.220 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.529 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.529 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.551 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.551 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.850 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.850 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.852 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.852 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.958 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.958 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.965 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.965 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.970 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:06.971 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.026 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.026 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.078 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.078 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.239 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.239 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.240 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.240 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.551 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.551 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.574 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.574 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.861 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.861 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.863 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.863 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.967 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.967 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.974 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.974 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.980 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:07.980 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.035 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.035 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.088 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.088 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.240 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.240 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.241 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.241 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.566 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.566 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.588 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.588 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.877 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.877 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.879 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.879 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.997 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:08.997 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.006 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.006 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.014 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.014 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.076 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.076 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.127 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.127 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.236 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.236 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.237 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.237 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.582 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.582 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.616 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.616 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.889 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.889 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.891 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.891 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.993 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.993 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:09.999 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.000 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.005 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.005 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.060 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.060 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.123 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.123 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.234 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.234 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.235 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.235 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.579 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.579 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.600 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.600 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.903 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.904 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.906 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:10.906 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.008 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.008 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.015 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.015 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.020 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.020 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.074 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.074 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.125 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.125 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.233 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.233 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.234 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.234 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.579 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.579 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.601 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.601 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.908 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.909 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.915 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:11.915 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.017 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.017 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.024 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.024 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.030 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.030 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.082 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.082 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.133 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.133 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.237 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.237 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.240 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.240 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.584 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.584 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.605 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.605 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.912 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.912 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.914 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:12.914 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.017 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.017 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.025 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.025 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.031 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.031 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.088 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.088 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.139 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.139 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.242 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.242 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.244 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.244 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.605 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.606 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.645 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.645 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.928 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.928 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.933 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:13.933 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.049 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.049 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.057 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.057 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.067 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.067 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.131 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.131 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.191 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.192 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.240 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.240 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.241 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.241 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.616 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.616 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.649 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.649 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.927 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.927 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.929 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:14.929 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.030 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.030 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.037 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.037 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.043 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.043 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.096 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.096 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.145 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.145 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.241 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.241 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.242 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.242 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.618 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.618 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.643 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.643 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.930 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.930 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.933 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:15.933 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.036 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.036 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.043 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.043 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.048 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.048 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.102 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.102 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.152 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.152 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.246 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.246 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.247 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.247 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.622 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.622 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.644 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.644 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.933 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.933 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.938 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:16.938 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.051 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.051 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.057 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.057 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.063 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.063 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.116 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.116 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.165 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.165 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.247 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.247 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.250 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.250 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.639 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.639 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.673 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.673 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.934 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.934 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.937 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:17.937 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.054 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.054 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.064 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.064 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.071 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.071 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.132 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.132 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.183 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.183 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.261 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.261 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.262 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.262 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.638 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.638 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.660 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.660 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.948 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.949 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.951 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:18.951 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.055 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.055 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.063 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.064 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.069 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.069 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.143 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.143 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.205 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.205 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.278 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.278 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.281 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.281 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.654 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.654 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.685 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.685 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.959 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.959 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.961 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:19.961 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.065 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.065 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.072 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.072 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.080 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.080 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.140 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.140 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.198 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.198 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.295 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.295 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.297 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.297 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.870 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.870 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.902 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:20.902 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.093 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.093 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.095 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.095 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.202 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.203 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.210 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.210 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.216 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.216 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.271 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.271 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.322 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.322 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.339 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.339 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.340 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.340 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.639 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.639 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.660 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.660 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.965 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.965 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.968 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:21.968 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.097 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.097 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.104 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.104 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.110 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.110 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.167 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.167 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.220 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.220 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.294 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.294 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.297 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.297 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.652 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.652 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.673 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.673 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.992 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.993 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.997 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:22.997 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.097 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.098 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.104 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.104 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.111 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.111 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.165 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.166 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.216 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.217 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.319 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.319 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.320 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.320 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.653 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.653 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.681 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:23.681 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.009 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.009 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.014 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.014 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.124 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.124 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.131 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.131 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.137 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.137 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.191 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.191 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.241 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.241 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.322 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.322 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.323 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.323 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.654 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.654 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.678 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:24.678 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.012 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.012 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.016 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.016 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.129 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.130 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.136 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.136 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.142 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.143 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.199 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.199 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.254 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.254 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.310 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.310 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.311 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.311 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.655 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.655 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.679 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:25.679 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.027 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.027 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.029 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.029 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.134 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.134 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.140 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.140 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.146 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.146 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.200 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.200 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.249 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.250 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.309 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.309 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.312 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.312 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.652 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.652 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.675 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:26.675 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.057 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.057 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.062 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.062 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.166 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.166 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.173 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.173 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.180 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.180 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.237 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.238 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.290 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.290 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.322 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.322 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.323 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.323 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.685 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.685 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.727 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:27.727 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.058 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.059 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.064 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.064 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.162 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.162 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.168 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.168 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.173 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.173 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.226 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.226 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.273 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.273 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.309 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.310 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.310 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.310 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.687 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.688 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.721 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:28.721 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.073 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.073 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.078 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.078 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.177 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.177 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.183 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.183 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.188 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.188 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.241 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.242 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.291 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.291 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.324 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.324 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.325 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.325 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.700 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.700 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.721 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:29.722 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.087 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.087 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.095 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.095 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.213 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.213 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.219 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.219 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.225 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.225 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.279 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.279 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.350 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.350 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.366 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.366 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.376 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.376 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.380 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.380 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.387 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.387 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.391 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.391 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.395 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.395 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.402 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.402 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.405 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.405 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.435 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.435 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.454 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.454 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.458 | Saved Chartbook: 000 FDAX_09Z23_Maroth.Cht. Time: 0.1145 seconds.
2026-07-30 20:35:30.461 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.462 | Chart: FDAXU26-EUREX [CB][M] 1 Min #2 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.481 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.481 | Chart: FDAXU26-EUREX [CB][M] 3 Min #3 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.489 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.489 | Chart: FDAXU26-EUREX [CB][M] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.491 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.492 | Chart: FDAXU26-EUREX [CB][M] 2 Min #14 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.502 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.502 | Chart: FDAXU26-EUREX [CB][M] 60 Min #6 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.504 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.504 | Chart: FDAXU26-EUREX [CB][M] 15 Min #9 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.506 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.506 | Chart: FDAXU26-EUREX [CB][M] 30 Min #4 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.508 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.508 | Chart: FDAXU26-EUREX [CB][M] 240 Min #5 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.512 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.513 | Chart: NAS100 [CB-D][M] 2 Min #10 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.541 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.542 | Chart: US30 [CB-D][M] 2 Min #13 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.557 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AussenStab | Essentials Studys Collection expired, please update
2026-07-30 20:35:30.557 | Chart: FDAXU26-EUREX [CB][M] 5 Day #11 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
2026-07-30 20:35:49.283 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:35:49.283 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:35:49.283 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:35:49.283 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:35:49.290 | NTP Client | Received Packet | RoundTripDelay=0.005988597869873047S, SystemClockOffset=0.15779566764831543S
2026-07-30 20:35:49.290 | NTP Client | Received Packet | RoundTripDelay=0.0068817138671875S, SystemClockOffset=0.15582942962646484S
2026-07-30 20:35:49.291 | NTP Client | Received Packet | RoundTripDelay=0.006983757019042969S, SystemClockOffset=0.15789556503295898S
2026-07-30 20:35:49.298 | NTP Client | Received Packet | RoundTripDelay=0.014994621276855469S, SystemClockOffset=0.15744352340698242S
2026-07-30 20:35:50.297 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
2026-07-30 20:36:49.562 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:36:49.562 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:36:49.562 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:36:49.562 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:36:49.568 | NTP Client | Received Packet | RoundTripDelay=0.005987644195556641S, SystemClockOffset=0.15797734260559082S
2026-07-30 20:36:49.570 | NTP Client | Received Packet | RoundTripDelay=0.006771564483642578S, SystemClockOffset=0.15609049797058105S
2026-07-30 20:36:49.570 | NTP Client | Received Packet | RoundTripDelay=0.006983757019042969S, SystemClockOffset=0.15807867050170898S
2026-07-30 20:36:49.577 | NTP Client | Received Packet | RoundTripDelay=0.014995098114013672S, SystemClockOffset=0.15766263008117676S
2026-07-30 20:36:50.576 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
2026-07-30 20:37:05.417 | Enabling compression for file: C:\SierraChart\Data\GER30.scid
2026-07-30 20:37:05.418 | GER30 60 Min #1 | Reloading chart.
2026-07-30 20:37:05.425 | GER30 60 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid
2026-07-30 20:37:05.427 | GER30 60 Min #1 | Chart data loading complete.
2026-07-30 20:37:06.441 | Using Bid/Ask average for last trade price for GER30
2026-07-30 20:37:06.441 | SC Data with Depth | Starting real-time market data updates for: GER30. ID: 4 Service code: fxcm
2026-07-30 20:37:06.441 | SC Data with Depth | Requesting security definition data for: GER30. ID: 4
2026-07-30 20:37:06.441 | Added historical Intraday data request for GER30 to the queue.
2026-07-30 20:37:06.441 | Intraday data recording state for symbol GER30 is set to download 'Pending'.
2026-07-30 20:37:06.441 | Triggering next historical data download in queue.
2026-07-30 20:37:06.442 | Delaying start of download for GER30.
2026-07-30 20:37:06.653 | SC Data with Depth | Setting external service identifier for symbol GER30 to 49
2026-07-30 20:37:06.653 | SC Data with Depth | Received security definition for symbol GER30
2026-07-30 20:37:11.900 | HD Request # 6 | Downloading Intraday chart data for GER30 to the file GER30.scid. Service: fxcm
2026-07-30 20:37:11.900 | HD Request # 6 | Download start date-time: 2026-01-25 19:37:11.000000. File last date-time: 00:00:00.000000
2026-07-30 20:37:11.900 | HD Request # 6 | Using server: ds12.sierracharts.com port 10150
2026-07-30 20:37:11.900 | Socket (2) | Creating socket.
2026-07-30 20:37:11.900 | Socket (2) | New receive buffer size: 0
2026-07-30 20:37:11.900 | Socket (2) | Connecting to IP: 69.39.70.241.
2026-07-30 20:37:12.194 | HD Request # 6 | Setting DTC encoding to Binary VLS
2026-07-30 20:37:12.194 | HD Request # 6 | Sending historical data logon request message.
2026-07-30 20:37:12.360 | HD Request # 6 | Requesting Intraday data. Start date-time: 2026-01-25 19:37:11. Record interval: 0. Symbol: GER30
2026-07-30 20:37:12.505 | HD Request # 6 | Decompressing data.
2026-07-30 20:37:12.826 | HD Request # 6 | Receiving Intraday data for GER30 starting at 2026-01-26 01:31:00.731000
2026-07-30 20:37:13.152 | HD Request # 6 | Timestamp of first Intraday data file record written: 2026-01-26 01:31:00.731000.
2026-07-30 20:37:49.943 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:37:49.943 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:37:49.943 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:37:49.943 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:37:49.950 | NTP Client | Received Packet | RoundTripDelay=0.005984306335449219S, SystemClockOffset=0.1589055061340332S
2026-07-30 20:37:49.951 | NTP Client | Received Packet | RoundTripDelay=0.0068988800048828125S, SystemClockOffset=0.15695762634277344S
2026-07-30 20:37:49.951 | NTP Client | Received Packet | RoundTripDelay=0.006985187530517578S, SystemClockOffset=0.15900826454162598S
2026-07-30 20:37:49.958 | NTP Client | Received Packet | RoundTripDelay=0.014995098114013672S, SystemClockOffset=0.15861248970031738S
2026-07-30 20:37:50.950 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
2026-07-30 20:38:50.323 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:38:50.323 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:38:50.323 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:38:50.323 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:38:50.330 | NTP Client | Received Packet | RoundTripDelay=0.005984306335449219S, SystemClockOffset=0.159576416015625S
2026-07-30 20:38:50.330 | NTP Client | Received Packet | RoundTripDelay=0.006979942321777344S, SystemClockOffset=0.1589527130126953S
2026-07-30 20:38:50.331 | NTP Client | Received Packet | RoundTripDelay=0.006914615631103516S, SystemClockOffset=0.157637357711792S
2026-07-30 20:38:50.339 | NTP Client | Received Packet | RoundTripDelay=0.015995025634765625S, SystemClockOffset=0.15871334075927734S
2026-07-30 20:38:51.326 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
2026-07-30 20:39:50.650 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:39:50.650 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:39:50.650 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:39:50.650 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:39:50.657 | NTP Client | Received Packet | RoundTripDelay=0.006985664367675781S, SystemClockOffset=0.1587691307067871S
2026-07-30 20:39:50.658 | NTP Client | Received Packet | RoundTripDelay=0.007976055145263672S, SystemClockOffset=0.15889382362365723S
2026-07-30 20:39:50.658 | NTP Client | Received Packet | RoundTripDelay=0.00790548324584961S, SystemClockOffset=0.15757346153259277S
2026-07-30 20:39:50.666 | NTP Client | Received Packet | RoundTripDelay=0.015994548797607422S, SystemClockOffset=0.15920758247375488S
2026-07-30 20:39:51.655 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
2026-07-30 20:40:07.643 | File >> Disconnect selected.
2026-07-30 20:40:07.644 | Denali Data Feed | Waiting for socket receive thread to end
2026-07-30 20:40:07.644 | DTC Client socket (1) | CloseSocket call.
2026-07-30 20:40:07.644 | Denali Data Feed | Disconnected from the server.
2026-07-30 20:40:07.644 | SC Data with Depth | Waiting for socket receive thread to end
2026-07-30 20:40:07.644 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-07-30 20:40:07.644 | DTC Client socket (8) | CloseSocket call.
2026-07-30 20:40:07.644 | SC Data with Depth | Disconnected from the server.
2026-07-30 20:40:07.644 | SC Data | Disconnected.
2026-07-30 20:40:07.644 | HD Request # 6 | Active download canceled.
2026-07-30 20:40:07.644 | DTC Client socket (8) | Shutdown started. Waiting for graceful close.
2026-07-30 20:40:07.644 | Historical data download thread signaled to stop.
2026-07-30 20:40:07.644 | Socket (2) | CloseSocket call.
2026-07-30 20:40:07.645 | Socket (2) | Shutdown started. Waiting for graceful close.
2026-07-30 20:40:07.645 | HD Request # 6 | Received 5026091 Intraday data records from 2026-01-26 01:31:00.731000 to 2026-03-06 19:52:49.823000 (39.8 days. Delay: 146.0 days) and wrote 5026091 records for GER30
2026-07-30 20:40:07.645 | HD Request # 6 | Completion time: 2m 56s.
2026-07-30 20:40:07.645 | HD Request # 6 | Intraday data download complete for GER30. Unique request ID: 6
2026-07-30 20:40:07.645 | Removing historical data download ID 6.
2026-07-30 20:40:07.645 | Real-time Intraday chart data file updates started for GER30
2026-07-30 20:40:07.645 | Intraday chart data file opened for GER30
2026-07-30 20:40:07.645 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2026-07-30 20:40:07.645 | No download requests in the queue to start downloads for.
2026-07-30 20:40:07.724 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-07-30 20:40:07.724 | DTC Client socket (1) | Closed.
2026-07-30 20:40:07.969 | DTC Client socket (8) | Socket gracefully closed by remote side.
2026-07-30 20:40:07.969 | DTC Client socket (8) | Closed.
2026-07-30 20:40:08.357 | Socket (2) | Socket gracefully closed by remote side.
2026-07-30 20:40:08.357 | Socket (2) | Closed.
2026-07-30 20:40:50.989 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:40:50.989 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:40:50.989 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:40:50.989 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:40:50.996 | NTP Client | Received Packet | RoundTripDelay=0.007987022399902344S, SystemClockOffset=0.15983867645263672S
2026-07-30 20:40:50.996 | NTP Client | Received Packet | RoundTripDelay=0.007983684539794922S, SystemClockOffset=0.1599428653717041S
2026-07-30 20:40:50.997 | NTP Client | Received Packet | RoundTripDelay=0.007894515991210938S, SystemClockOffset=0.1585545539855957S
2026-07-30 20:40:51.005 | NTP Client | Received Packet | RoundTripDelay=0.015995025634765625S, SystemClockOffset=0.1600184440612793S
2026-07-30 20:40:51.992 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
2026-07-30 20:41:51.480 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:41:51.480 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:41:51.480 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:41:51.480 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:41:51.487 | NTP Client | Received Packet | RoundTripDelay=0.006983757019042969S, SystemClockOffset=0.16038846969604492S
2026-07-30 20:41:51.488 | NTP Client | Received Packet | RoundTripDelay=0.006909847259521484S, SystemClockOffset=0.15896821022033691S
2026-07-30 20:41:51.489 | NTP Client | Received Packet | RoundTripDelay=0.007975578308105469S, SystemClockOffset=0.1605391502380371S
2026-07-30 20:41:51.497 | NTP Client | Received Packet | RoundTripDelay=0.015994548797607422S, SystemClockOffset=0.16086459159851074S
2026-07-30 20:41:52.523 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
2026-07-30 20:42:51.878 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:42:51.878 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:42:51.878 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:42:51.878 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:42:51.885 | NTP Client | Received Packet | RoundTripDelay=0.005988597869873047S, SystemClockOffset=0.1607954502105713S
2026-07-30 20:42:51.885 | NTP Client | Received Packet | RoundTripDelay=0.006886482238769531S, SystemClockOffset=0.1589031219482422S
2026-07-30 20:42:51.885 | NTP Client | Received Packet | RoundTripDelay=0.006984233856201172S, SystemClockOffset=0.1602170467376709S
2026-07-30 20:42:51.893 | NTP Client | Received Packet | RoundTripDelay=0.013995170593261719S, SystemClockOffset=0.1609344482421875S
2026-07-30 20:42:52.883 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
2026-07-30 20:43:13.482 |
2026-07-30 20:43:13.482 | SC Data | Connection to server complete.
2026-07-30 20:43:13.482 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-07-30 20:43:13.482 | Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees.
2026-07-30 20:43:14.067 | Using Bid/Ask average for last trade price for GER30
2026-07-30 20:43:14.067 | Using symbol data fast lookup vector
2026-07-30 20:43:14.067 | SC Data with Depth | Starting real-time market data updates for: GER30. ID: 1 Service code: fxcm
2026-07-30 20:43:14.067 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443
2026-07-30 20:43:14.067 | SC Data with Depth | Requesting security definition data for: GER30. ID: 1
2026-07-30 20:43:14.067 | Added historical Intraday data request for GER30 to the queue.
2026-07-30 20:43:14.067 | Intraday data recording state for symbol GER30 is set to download 'Pending'.
2026-07-30 20:43:14.067 | Triggering next historical data download in queue.
2026-07-30 20:43:14.068 | DTC Client socket (1) | Creating socket.
2026-07-30 20:43:14.068 | DTC Client socket (1) | New receive buffer size: 0
2026-07-30 20:43:14.068 | DTC Client socket (1) | Connecting to IP: 64.152.155.113.
2026-07-30 20:43:14.085 | Delaying start of download for GER30.
2026-07-30 20:43:14.205 | SC Data with Depth | Network connection to server complete.
2026-07-30 20:43:14.205 | SC Data with Depth | Starting socket receive thread.
2026-07-30 20:43:14.206 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard
2026-07-30 20:43:14.351 | SC Data with Depth | Setting DTC encoding to Binary VLS
2026-07-30 20:43:14.351 | SC Data with Depth | Sending logon request message.
2026-07-30 20:43:14.598 | SC Data with Depth | Received logon response.
2026-07-30 20:43:14.598 | SC Data with Depth | Server Name: SC Realtime Server.
2026-07-30 20:43:14.598 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2026-07-30 20:43:14.598 | SC Data with Depth | Successfully connected.
2026-07-30 20:43:14.598 | SC Data with Depth | Trading is not supported.
2026-07-30 20:43:14.598 | SC Data with Depth | MarketDepthIsSupported: 1
2026-07-30 20:43:14.598 | SC Data with Depth | Restarting real-time data updates for symbol: GER30
2026-07-30 20:43:14.820 | SC Data with Depth | Setting external service identifier for symbol GER30 to 49
2026-07-30 20:43:14.820 | SC Data with Depth | Received security definition for symbol GER30
2026-07-30 20:43:19.217 | HD Request # 7 | Downloading Intraday chart data for GER30 to the file GER30.scid. Service: fxcm
2026-07-30 20:43:19.217 | HD Request # 7 | Download start date-time: 2026-03-06 19:52:49.000000. File last date-time: 2026-03-06 19:52:49.823000
2026-07-30 20:43:19.217 | HD Request # 7 | Using server: ds4.sierracharts.com port 10149
2026-07-30 20:43:19.217 | Socket (2) | Creating socket.
2026-07-30 20:43:19.217 | Socket (2) | New receive buffer size: 0
2026-07-30 20:43:19.217 | Socket (2) | Connecting to IP: 64.152.155.113.
2026-07-30 20:43:19.496 | HD Request # 7 | Setting DTC encoding to Binary VLS
2026-07-30 20:43:19.496 | HD Request # 7 | Sending historical data logon request message.
2026-07-30 20:43:19.652 | HD Request # 7 | Requesting Intraday data. Start date-time: 2026-03-06 19:52:49. Record interval: 0. Symbol: GER30
2026-07-30 20:43:19.795 | HD Request # 7 | Decompressing data.
2026-07-30 20:43:20.094 | HD Request # 7 | Receiving Intraday data for GER30 starting at 2026-03-06 19:52:49.189000
2026-07-30 20:43:20.381 | HD Request # 7 | Timestamp of first Intraday data file record written: 2026-03-06 19:52:50.240000.
2026-07-30 20:43:52.281 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:43:52.281 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:43:52.281 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:43:52.281 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:43:52.288 | NTP Client | Received Packet | RoundTripDelay=0.006987094879150391S, SystemClockOffset=0.16122841835021973S
2026-07-30 20:43:52.288 | NTP Client | Received Packet | RoundTripDelay=0.006983280181884766S, SystemClockOffset=0.16115546226501465S
2026-07-30 20:43:52.289 | NTP Client | Received Packet | RoundTripDelay=0.006900787353515625S, SystemClockOffset=0.15982723236083984S
2026-07-30 20:43:52.297 | NTP Client | Received Packet | RoundTripDelay=0.014994621276855469S, SystemClockOffset=0.16135740280151367S
2026-07-30 20:43:53.283 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
2026-07-30 20:44:52.643 | NTP Client | Sending packet to 0.pool.ntp.org:123
2026-07-30 20:44:52.643 | NTP Client | Sending packet to 1.pool.ntp.org:123
2026-07-30 20:44:52.643 | NTP Client | Sending packet to 2.pool.ntp.org:123
2026-07-30 20:44:52.643 | NTP Client | Sending packet to 3.pool.ntp.org:123
2026-07-30 20:44:52.650 | NTP Client | Received Packet | RoundTripDelay=0.006987571716308594S, SystemClockOffset=0.1614055633544922S
2026-07-30 20:44:52.650 | NTP Client | Received Packet | RoundTripDelay=0.006984710693359375S, SystemClockOffset=0.16134405136108398S
2026-07-30 20:44:52.651 | NTP Client | Received Packet | RoundTripDelay=0.007890701293945312S, SystemClockOffset=0.15952539443969727S
2026-07-30 20:44:52.659 | NTP Client | Received Packet | RoundTripDelay=0.014995098114013672S, SystemClockOffset=0.16150546073913574S
2026-07-30 20:44:53.644 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client.
[2026-07-30 19:18:00]
We do not see anything in the log that shows any issues with the data for the DAX. The log shows that you are properly getting data for the symbol FDAXU26-EUREX.
Why do you believe that you are having a problem with the data? What exactly are you seeing that shows this?
We do see the following in your log:
Refer to the following regarding this:
Network Time Protocol Client: Operating System Privileges for Setting Time
And we also see the following:
Chart: FDAXU26-EUREX [CB] 15 Min #7 | Study: AussenStab | Essentials Studys Collection expired, please update
Chart: FDAXU26-EUREX [CB] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update
You need to talk to whomever you got those studies from to update them. If they are not working properly then you should remove them from your charts.
2026-07-30 20:32:03.776 | Chart: FDAXU26-EUREX [CB] 15 Min #7 | Study: AS Last (Yes) | Essentials Studys Collection expired, please update[
