Date/Time: Thu, 29 Oct 2026 03:04:21 +0000
equities
View Count: 374
| [2026-07-28 19:08:38] |
| Robert Wojczak - Posts: 178 |
What do I need to activate to get live stock prices.. thank you
| [2026-07-28 20:02:01] |
| John - SC Support - Posts: 48363 |
We have two different exchange options for U.S. Equities. Refer to the following for an overview of each of them: US Stock/Equities Consolidated Tape Data Feed Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes And there is a third option which is to combine the above two exchanges to get the price/volume data from the U.S. Equities combined with the Market Depth from the NASDAQ TotalView. Refer to the following: Denali Exchange Data Feed: U.S. Equities Consolidated Tape with NASDAQ TotalView Whatever you choose to activate, the instructions are here: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-29 10:41:05] |
I subscribed to the first option.. restarted SC and still see delayed quotes
| [2026-07-29 14:32:53] |
You do have the "U.S. Equities Consolidated Tape" exchange active, so you should not have any issues with this data. What is one symbol for which you are having an issue? We need to know the symbol exactly as you have it entered in "Chart >> Chart Settings >> Symbol >> Symbol". What are you seeing that makes you state that the data is delayed? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
