Date/Time: Thu, 29 Oct 2026 03:04:43 +0000
Trade DOM entry not activating bracket order (trailing-stop)
View Count: 270
[2026-07-27 04:48:48]
R15K50 - Posts: 19
I have a simple bracket order with a trailing-stop and on the Trade Window I have "use attached orders" checked. When I click on the DOM an entry is executed but without the bracket or trailing-stop. Does the DOM or DOM Trading support bracket orders? If yes, can you point me to the correct documentation/settings to set it up.
[2026-07-27 16:18:37]
John - SC Support - Posts: 48363
When you enter an order on the DOM, it is going to use the attached orders that are setup in the Trade Window for that chart.
But, it will NOT create an initial bracket order that you have setup in the Trade Window for the parent order. This is because on the DOM, you are deciding to enter a specific order type as defined in "Trade >> Chart DOM Settings >> Order Types". If you want to have a bracker order, then you would need to enter that order from the Trade Window.
[2026-07-27 23:16:20]
R15K50 - Posts: 19
I got it working. It did not occur to me to check if the configuration was selected on the Trade Window for the DOM.
