Date/Time: Mon, 26 Oct 2026 03:13:07 +0000
question about delta dynamics and sierra chart free trial
View Count: 250
[2026-07-26 22:41:47]
User425871 - Posts: 1
i won a lifetime license to delta dynamics on X and i was wondering if I do the 21 day free trial if I would still be able to use it. I see that in the free trial you only have access to sierra charts, and no trading but I wanted to try it out and most likely will upgrade to a membership. thanks
[2026-07-27 16:14:48]
John - SC Support - Posts: 48317
We assume Delta Dynamics is a provider of a custom study(ies) that can be used with Sierra Chart.
That being the case, then there is no limitation during the trial for using a custom study. But, you do need to consider the limitation of data available during a trial, as this could impact the study itself. Refer to the following:
Sierra Chart Trial Account
