Date/Time: Mon, 26 Oct 2026 03:12:25 +0000
Chart book Help
View Count: 235
| [2026-07-24 15:01:44] |
| User940141 - Posts: 5 |
When I open a new chart book i detached it because i have multiple monitors and when i open another chart book my first one goes away and puts me on the 2nd chart book. Is it a way to open multiple of my templates without them disappearing because i need 3 of my templates on my other 3 screens. |
| [2026-07-24 15:05:29] |
| John - SC Support - Posts: 48317 |
Chartbooks are not detached, just charts. And when you switch between chartbooks, you are only able to view the charts for the active chartbook, except for charts that have the option for "Window >> Window Always Visible". You can either set all of your charts to have the option for "Window Always Visible", or the better solution is to use Sub-Instances, one for each chartbook. This will allow you to have all the charts open on each monitor all of the time. Refer to the following: File Menu: New Instance (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
