Date/Time: Fri, 23 Oct 2026 02:17:57 +0000
Frequent Connecting Issues; Not Allowing Second Instance when No Second Instance is Open
View Count: 257
| [2026-07-23 14:47:02] |
| User753526 - Posts: 86 |
Hi, Over the past week or two I am getting frequent issues connecting with the message box that pops up reporting that a Second Instance is not being allowed but I am only using one Instance of Sierra Chart. Some times it attempts to reconnect 2 or 3 times and works, today it has just been failing for 10 minutes and just connected as I am typing now. I have updated to the latest software earlier this week incase that was the issue. I am running Ver. 2930 This is a copy of the message log when its failing to reconnect. Perhaps worth nothing that all other Internet connections are fine, only Sierra Chart is effected. 2026-07-23 10:41:32.870 | Software version: 2930 64-bit 2026-07-23 10:41:32.870 | Primary Thread ID: 53564 2026-07-23 10:41:32.870 | Usage end date: 2026-07-29 2026-07-23 10:41:32.870 | Enabled for: Advanced Features 2. 2026-07-23 10:41:32.870 | Enabled for: Sierra Chart Historical Data Service. 2026-07-23 10:41:32.870 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-07-23 10:41:32.870 | Enabled for: Delayed Denali Exchange Data Feed. 2026-07-23 10:41:32.870 | Enabled for exchange2: CME 2026-07-23 10:41:32.870 | Enabled for exchange2: COMEX 2026-07-23 10:41:32.870 | Enabled for exchange2: NASDAQ TotalView US stock data 2026-07-23 10:41:32.870 | Enabled for exchange2: CBOE Global Indexes Main 2026-07-23 10:41:32.870 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-07-23 10:41:32.870 | Current selected Data/Trading service: Teton CME Routing 2026-07-23 10:41:32.870 | Custom symbol settings values: enabled 2026-07-23 10:41:32.870 | Chart Update Interval: 500 2026-07-23 10:41:32.870 | Intraday Data Storage Time Unit: 0 2026-07-23 10:41:32.870 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2026-07-23 10:41:32.870 | 2026-07-23 14:41:32 Local computer time in UTC 2026-07-23 10:41:32.870 | 2026-07-23 10:41:32 Local computer time in SC Time Zone 2026-07-23 10:41:32.870 | 2026-07-23 01:30:51 Server time in UTC 2026-07-23 10:41:32.870 | Local computer UTC time and Server UTC time difference: 2 seconds. 2026-07-23 10:41:32.870 | Program path: C:\SierraChart - EdgeClear\ 2026-07-23 10:41:32.870 | Data Files path: C:\SierraChart - EdgeClear\Data\ 2026-07-23 10:41:32.870 | OS Version Number: 10.0 2026-07-23 10:41:32.870 | Locale Setting: C 2026-07-23 10:41:32.870 | Crash reporter started: true 2026-07-23 10:41:32.870 | 2026-07-23 10:41:37.903 | File >> Reconnect selected. 2026-07-23 10:41:37.903 | DTC Client socket (1) | CloseSocket call. 2026-07-23 10:41:37.903 | Teton CME Routing | Disconnected. 2026-07-23 10:41:37.903 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 10:41:37.903 | DTC Client socket (1) | Closed. 2026-07-23 10:41:39.907 | 2026-07-23 10:41:39.908 | Teton CME Routing | Firm: IronBeam 2026-07-23 10:41:39.908 | Teton CME Routing | Connecting to the server futurestrading18.sierracharts.com. Port 11084 2026-07-23 10:41:39.908 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-23 10:41:39.908 | DTC Client socket (1) | New receive buffer size: 0 2026-07-23 10:41:39.908 | DTC Client socket (1) | Connecting to IP: 4.8.170.26. 2026-07-23 10:42:00.944 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. 2026-07-23 10:42:00.944 | DTC Client socket (1) | CloseSocket call. 2026-07-23 10:42:00.944 | Teton CME Routing | Failed connections: 17 2026-07-23 10:42:00.944 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-07-23 10:42:00.944 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 10:42:00.944 | DTC Client socket (1) | Closed. 2026-07-23 10:42:00.959 | DTC Client socket (0) | CloseSocket call. 2026-07-23 10:42:00.959 | Teton CME Routing | Disconnected. 2026-07-23 10:42:00.959 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 10:42:02.959 | 2026-07-23 10:42:02.960 | Teton CME Routing | Firm: IronBeam 2026-07-23 10:42:02.960 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 2026-07-23 10:42:02.960 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-23 10:42:02.960 | DTC Client socket (1) | New receive buffer size: 0 2026-07-23 10:42:02.960 | DTC Client socket (1) | Connecting to IP: 216.200.108.154. 2026-07-23 10:42:09.462 | NTP Client | Sending packet to 0.pool.ntp.org:123 2026-07-23 10:42:09.462 | NTP Client | Sending packet to 1.pool.ntp.org:123 2026-07-23 10:42:09.462 | NTP Client | Sending packet to 2.pool.ntp.org:123 2026-07-23 10:42:09.462 | NTP Client | Sending packet to 3.pool.ntp.org:123 2026-07-23 10:42:09.474 | NTP Client | Received Packet | RoundTripDelay=0.011782646179199219S, SystemClockOffset=1.487441062927246S 2026-07-23 10:42:09.474 | NTP Client | Received Packet | RoundTripDelay=0.01190042495727539S, SystemClockOffset=1.4881980419158936S 2026-07-23 10:42:09.474 | NTP Client | Received Packet | RoundTripDelay=0.0118560791015625S, SystemClockOffset=1.491121768951416S 2026-07-23 10:42:09.475 | NTP Client | Received Packet | RoundTripDelay=0.012974262237548828S, SystemClockOffset=1.48691725730896S 2026-07-23 10:42:10.467 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client. 2026-07-23 10:42:24.002 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. 2026-07-23 10:42:24.002 | DTC Client socket (1) | CloseSocket call. 2026-07-23 10:42:24.002 | Teton CME Routing | Failed connections: 18 2026-07-23 10:42:24.002 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-07-23 10:42:24.002 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 10:42:24.002 | DTC Client socket (1) | Closed. 2026-07-23 10:42:24.018 | DTC Client socket (0) | CloseSocket call. 2026-07-23 10:42:24.018 | Teton CME Routing | Disconnected. 2026-07-23 10:42:24.018 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 10:42:26.020 | 2026-07-23 10:42:26.021 | Teton CME Routing | Firm: IronBeam 2026-07-23 10:42:26.021 | Teton CME Routing | Connecting to the server futurestrading11.sierracharts.com. Port 11085 2026-07-23 10:42:26.021 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-23 10:42:26.021 | DTC Client socket (1) | New receive buffer size: 0 2026-07-23 10:42:26.021 | DTC Client socket (1) | Connecting to IP: 4.8.170.26. 2026-07-23 10:42:26.366 | Teton CME Routing | Network connection to server complete. 2026-07-23 10:42:26.366 | Teton CME Routing | Starting socket receive thread. 2026-07-23 10:42:26.366 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-07-23 10:42:27.075 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-07-23 10:42:27.075 | Teton CME Routing | Sending logon request message. 2026-07-23 10:42:27.362 | Teton CME Routing | Received logon response. 2026-07-23 10:42:27.362 | Teton CME Routing | Server Name: SC DTC Server. 2026-07-23 10:42:27.362 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-07-23 10:42:27.362 | Teton CME Routing | Logon error received from server: Secondary instance is not allowing connections to this server 2026-07-23 10:42:27.362 | Teton CME Routing | Failed connections: 19 2026-07-23 10:42:27.362 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-07-23 10:42:27.362 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 10:42:27.380 | Teton CME Routing | Waiting for socket receive thread to end 2026-07-23 10:42:27.380 | DTC Client socket (1) | CloseSocket call. 2026-07-23 10:42:27.380 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-07-23 10:42:27.380 | Teton CME Routing | Disconnected. 2026-07-23 10:42:27.380 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 10:42:27.615 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-07-23 10:42:27.615 | DTC Client socket (1) | Closed. 2026-07-23 10:42:29.393 | 2026-07-23 10:42:29.394 | Teton CME Routing | Firm: IronBeam 2026-07-23 10:42:29.394 | Teton CME Routing | Connecting to the server futurestrading12.sierracharts.com. Port 11084 2026-07-23 10:42:29.394 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-23 10:42:29.394 | DTC Client socket (1) | New receive buffer size: 0 2026-07-23 10:42:29.394 | DTC Client socket (1) | Connecting to IP: 4.8.170.26. |
| [2026-07-23 15:39:42] |
| John - SC Support - Posts: 48303 |
You are getting the following in your log: DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Refer to the following: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem There is nothing in the log about other instances trying to connect. If you get a message about this, then please get us that part of the log that shows this so we can see what you are referring to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-23 19:52:51] |
Hi, the error occurred again at 2026-07-23 at 13:02:20. I have pasted the Message Log from that time. The message in the pop up window reads 'Connection error message from service: Teton CME Routing Logon error received from server. Secondary instance is not allowing connections to this server |Date- Time: 2026-07-23 13:02:20' 2026-07-23 13:01:09.128 | Teton CME Routing | Firm: IronBeam 2026-07-23 13:01:09.128 | Teton CME Routing | Connecting to the server futurestrading13.sierracharts.com. Port 11084 2026-07-23 13:01:09.128 | DTC Client socket (9) | Creating socket. Using TLS 1.2. 2026-07-23 13:01:09.128 | DTC Client socket (9) | New receive buffer size: 0 2026-07-23 13:01:09.128 | DTC Client socket (9) | Connecting to IP: 4.8.170.26. 2026-07-23 13:01:17.171 | NTP Client | Sending packet to 0.pool.ntp.org:123 2026-07-23 13:01:17.171 | NTP Client | Sending packet to 1.pool.ntp.org:123 2026-07-23 13:01:17.171 | NTP Client | Sending packet to 3.pool.ntp.org:123 2026-07-23 13:01:17.182 | NTP Client | Received Packet | RoundTripDelay=0.010960102081298828S, SystemClockOffset=1.7577383518218994S 2026-07-23 13:01:17.182 | NTP Client | Received Packet | RoundTripDelay=0.010940074920654297S, SystemClockOffset=1.7577927112579346S 2026-07-23 13:01:17.185 | NTP Client | Received Packet | RoundTripDelay=0.013900279998779297S, SystemClockOffset=1.7587182521820068S 2026-07-23 13:01:18.177 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client. 2026-07-23 13:01:30.150 | DTC Client socket (9) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. 2026-07-23 13:01:30.150 | DTC Client socket (9) | CloseSocket call. 2026-07-23 13:01:30.150 | Teton CME Routing | Failed connections: 15 2026-07-23 13:01:30.150 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-07-23 13:01:30.150 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:01:30.150 | DTC Client socket (9) | Closed. 2026-07-23 13:01:30.166 | DTC Client socket (0) | CloseSocket call. 2026-07-23 13:01:30.166 | Teton CME Routing | Disconnected. 2026-07-23 13:01:30.166 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:01:32.244 | 2026-07-23 13:01:32.245 | Teton CME Routing | Firm: IronBeam 2026-07-23 13:01:32.245 | Teton CME Routing | Connecting to the server futurestrading18.sierracharts.com. Port 11084 2026-07-23 13:01:32.245 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-23 13:01:32.245 | DTC Client socket (1) | New receive buffer size: 0 2026-07-23 13:01:32.245 | DTC Client socket (1) | Connecting to IP: 4.8.170.26. 2026-07-23 13:01:53.278 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. 2026-07-23 13:01:53.419 | DTC Client socket (1) | CloseSocket call. 2026-07-23 13:01:53.419 | DTC Client socket (1) | Closed. 2026-07-23 13:01:53.419 | Teton CME Routing | Failed connections: 16 2026-07-23 13:01:53.419 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-07-23 13:01:53.419 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:01:53.550 | DTC Client socket (0) | CloseSocket call. 2026-07-23 13:01:53.550 | Teton CME Routing | Disconnected. 2026-07-23 13:01:53.550 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:01:55.564 | 2026-07-23 13:01:55.565 | Teton CME Routing | Firm: IronBeam 2026-07-23 13:01:55.565 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 2026-07-23 13:01:55.565 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-23 13:01:55.565 | DTC Client socket (1) | New receive buffer size: 0 2026-07-23 13:01:55.565 | DTC Client socket (1) | Connecting to IP: 216.200.108.154. 2026-07-23 13:02:16.626 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. 2026-07-23 13:02:16.724 | DTC Client socket (1) | CloseSocket call. 2026-07-23 13:02:16.724 | DTC Client socket (1) | Closed. 2026-07-23 13:02:16.725 | Teton CME Routing | Failed connections: 17 2026-07-23 13:02:16.725 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-07-23 13:02:16.725 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:02:16.802 | DTC Client socket (0) | CloseSocket call. 2026-07-23 13:02:16.802 | Teton CME Routing | Disconnected. 2026-07-23 13:02:16.802 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:02:17.664 | NTP Client | Sending packet to 0.pool.ntp.org:123 2026-07-23 13:02:17.664 | NTP Client | Sending packet to 1.pool.ntp.org:123 2026-07-23 13:02:17.664 | NTP Client | Sending packet to 2.pool.ntp.org:123 2026-07-23 13:02:17.664 | NTP Client | Sending packet to 3.pool.ntp.org:123 2026-07-23 13:02:17.675 | NTP Client | Received Packet | RoundTripDelay=0.010911941528320312S, SystemClockOffset=1.7602829933166504S 2026-07-23 13:02:17.676 | NTP Client | Received Packet | RoundTripDelay=0.010953903198242188S, SystemClockOffset=1.7603559494018555S 2026-07-23 13:02:17.676 | NTP Client | Received Packet | RoundTripDelay=0.010899066925048828S, SystemClockOffset=1.7628581523895264S 2026-07-23 13:02:17.677 | NTP Client | Received Packet | RoundTripDelay=0.012975215911865234S, SystemClockOffset=1.7590792179107666S 2026-07-23 13:02:18.675 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client. 2026-07-23 13:02:18.855 | 2026-07-23 13:02:18.855 | Teton CME Routing | Firm: IronBeam 2026-07-23 13:02:18.855 | Teton CME Routing | Connecting to the server futurestrading11.sierracharts.com. Port 11085 2026-07-23 13:02:18.856 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-23 13:02:18.856 | DTC Client socket (1) | New receive buffer size: 0 2026-07-23 13:02:18.856 | DTC Client socket (1) | Connecting to IP: 4.8.170.26. 2026-07-23 13:02:19.093 | Teton CME Routing | Network connection to server complete. 2026-07-23 13:02:19.093 | Teton CME Routing | Starting socket receive thread. 2026-07-23 13:02:19.093 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-07-23 13:02:19.952 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-07-23 13:02:19.952 | Teton CME Routing | Sending logon request message. 2026-07-23 13:02:20.193 | Teton CME Routing | Received logon response. 2026-07-23 13:02:20.193 | Teton CME Routing | Server Name: SC DTC Server. 2026-07-23 13:02:20.193 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-07-23 13:02:20.193 | Teton CME Routing | Logon error received from server: Secondary instance is not allowing connections to this server 2026-07-23 13:02:20.193 | Teton CME Routing | Failed connections: 18 2026-07-23 13:02:20.193 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-07-23 13:02:20.193 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:02:20.225 | Teton CME Routing | Waiting for socket receive thread to end 2026-07-23 13:02:20.225 | DTC Client socket (1) | CloseSocket call. 2026-07-23 13:02:20.225 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-07-23 13:02:20.225 | Teton CME Routing | Disconnected. 2026-07-23 13:02:20.225 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:02:20.471 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-07-23 13:02:20.471 | DTC Client socket (1) | Closed. 2026-07-23 13:02:22.304 | 2026-07-23 13:02:22.305 | Teton CME Routing | Firm: IronBeam 2026-07-23 13:02:22.305 | Teton CME Routing | Connecting to the server futurestrading12.sierracharts.com. Port 11084 2026-07-23 13:02:22.305 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-23 13:02:22.306 | DTC Client socket (1) | New receive buffer size: 0 2026-07-23 13:02:22.306 | DTC Client socket (1) | Connecting to IP: 4.8.170.26. 2026-07-23 13:02:43.348 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. 2026-07-23 13:02:43.352 | DTC Client socket (1) | CloseSocket call. 2026-07-23 13:02:43.352 | Teton CME Routing | Failed connections: 19 2026-07-23 13:02:43.352 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-07-23 13:02:43.352 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:02:43.352 | DTC Client socket (1) | Closed. 2026-07-23 13:02:43.400 | DTC Client socket (0) | CloseSocket call. 2026-07-23 13:02:43.400 | Teton CME Routing | Disconnected. 2026-07-23 13:02:43.400 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:02:45.435 | 2026-07-23 13:02:45.436 | Teton CME Routing | Firm: IronBeam 2026-07-23 13:02:45.436 | Teton CME Routing | Connecting to the server futurestrading13.sierracharts.com. Port 11084 2026-07-23 13:02:45.436 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-23 13:02:45.436 | DTC Client socket (1) | New receive buffer size: 0 2026-07-23 13:02:45.436 | DTC Client socket (1) | Connecting to IP: 4.8.170.26. 2026-07-23 13:03:06.477 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. 2026-07-23 13:03:06.488 | DTC Client socket (1) | CloseSocket call. 2026-07-23 13:03:06.488 | Teton CME Routing | Failed connections: 20 2026-07-23 13:03:06.488 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-07-23 13:03:06.488 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:03:06.488 | DTC Client socket (1) | Closed. 2026-07-23 13:03:06.653 | DTC Client socket (0) | CloseSocket call. 2026-07-23 13:03:06.653 | Teton CME Routing | Disconnected. 2026-07-23 13:03:06.653 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:03:08.681 | 2026-07-23 13:03:08.682 | Teton CME Routing | Firm: IronBeam 2026-07-23 13:03:08.682 | Teton CME Routing | Connecting to the server futurestrading18.sierracharts.com. Port 11084 2026-07-23 13:03:08.682 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-23 13:03:08.682 | DTC Client socket (1) | New receive buffer size: 0 2026-07-23 13:03:08.682 | DTC Client socket (1) | Connecting to IP: 4.8.170.26. 2026-07-23 13:03:18.235 | NTP Client | Sending packet to 0.pool.ntp.org:123 2026-07-23 13:03:18.235 | NTP Client | Sending packet to 1.pool.ntp.org:123 2026-07-23 13:03:18.235 | NTP Client | Sending packet to 3.pool.ntp.org:123 2026-07-23 13:03:18.246 | NTP Client | Received Packet | RoundTripDelay=0.010918140411376953S, SystemClockOffset=1.7618491649627686S 2026-07-23 13:03:18.246 | NTP Client | Received Packet | RoundTripDelay=0.010953903198242188S, SystemClockOffset=1.7619719505310059S 2026-07-23 13:03:18.246 | NTP Client | Received Packet | RoundTripDelay=0.01086568832397461S, SystemClockOffset=1.7645127773284912S 2026-07-23 13:03:19.240 | NTP Client | Set System Time failed: Windows error code 1314: A required privilege is not held by the client. 2026-07-23 13:03:29.718 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. 2026-07-23 13:03:29.729 | DTC Client socket (1) | CloseSocket call. 2026-07-23 13:03:29.729 | Teton CME Routing | Failed connections: 21 2026-07-23 13:03:29.729 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-07-23 13:03:29.729 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:03:29.729 | DTC Client socket (1) | Closed. 2026-07-23 13:03:29.760 | DTC Client socket (0) | CloseSocket call. 2026-07-23 13:03:29.760 | Teton CME Routing | Disconnected. 2026-07-23 13:03:29.760 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-23 13:03:31.856 | 2026-07-23 13:03:31.857 | Teton CME Routing | Firm: IronBeam 2026-07-23 13:03:31.857 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 2026-07-23 13:03:31.857 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-23 13:03:31.857 | DTC Client socket (1) | New receive buffer size: 0 2026-07-23 13:03:31.857 | DTC Client socket (1) | Connecting to IP: 216.200.108.154. 2026-07-23 13:03:32.109 | Teton CME Routing | Network connection to server complete. 2026-07-23 13:03:32.109 | Teton CME Routing | Starting socket receive thread. 2026-07-23 13:03:32.109 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-07-23 13:03:32.873 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-07-23 13:03:32.873 | Teton CME Routing | Sending logon request message. 2026-07-23 13:03:33.248 | Teton CME Routing | Received logon response. 2026-07-23 13:03:33.248 | Teton CME Routing | Server Name: SC DTC Server. Build=56481. 2026-07-23 13:03:33.248 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-07-23 13:03:33.248 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2026-07-23 13:03:33.248 | Teton CME Routing | Trading is supported. 2026-07-23 13:03:33.248 | Teton CME Routing | Order cancel and replace is supported. 2026-07-23 13:03:33.248 | Teton CME Routing | OCO Orders supported. 2026-07-23 13:03:33.248 | Teton CME Routing | Bracket Orders supported. 2026-07-23 13:03:33.248 | Teton CME Routing | MarketDepthIsSupported: 1 2026-07-23 13:03:33.248 | Teton CME Routing | Connection to server complete. 2026-07-23 13:03:33.249 | Denali Data Feed | Waiting for socket receive thread to end 2026-07-23 13:03:33.249 | DTC Client socket (5) | CloseSocket call. 2026-07-23 13:03:33.249 | DTC Client socket (5) | Shutdown started. Waiting for graceful close. 2026-07-23 13:03:33.249 | Denali Data Feed | Disconnected from the server. 2026-07-23 13:03:33.249 | Denali Data Feed | Waiting for socket receive thread to end 2026-07-23 13:03:33.249 | DTC Client socket (3) | CloseSocket call. 2026-07-23 13:03:33.249 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-07-23 13:03:33.249 | Denali Data Feed | Disconnected from the server. 2026-07-23 13:03:33.249 | Denali Data Feed | Waiting for socket receive thread to end 2026-07-23 13:03:33.249 | DTC Client socket (4) | CloseSocket call. 2026-07-23 13:03:33.249 | DTC Client socket (4) | Shutdown started. Waiting for graceful close. 2026-07-23 13:03:33.249 | Denali Data Feed | Disconnected from the server. 2026-07-23 13:03:33.249 | SC Data with Depth | Waiting for socket receive thread to end 2026-07-23 13:03:33.249 | DTC Client socket (2) | CloseSocket call. 2026-07-23 13:03:33.249 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-07-23 13:03:33.249 | SC Data with Depth | Disconnected from the server. 2026-07-23 13:03:33.249 | Delayed Data Feed | Waiting for socket receive thread to end 2026-07-23 13:03:33.250 | DTC Client socket (7) | CloseSocket call. 2026-07-23 13:03:33.250 | DTC Client socket (7) | Shutdown started. Waiting for graceful close. 2026-07-23 13:03:33.250 | Delayed Data Feed | Disconnected from the server. 2026-07-23 13:03:33.250 | Delayed Data Feed | Waiting for socket receive thread to end 2026-07-23 13:03:33.250 | DTC Client socket (6) | CloseSocket call. 2026-07-23 13:03:33.250 | DTC Client socket (6) | Shutdown started. Waiting for graceful close. 2026-07-23 13:03:33.250 | Delayed Data Feed | Disconnected from the server. 2026-07-23 13:03:33.250 | Delayed Data Feed | Waiting for socket receive thread to end 2026-07-23 13:03:33.250 | DTC Client socket (8) | CloseSocket call. 2026-07-23 13:03:33.250 | DTC Client socket (8) | Shutdown started. Waiting for graceful close. 2026-07-23 13:03:33.250 | Delayed Data Feed | Disconnected from the server. 2026-07-23 13:03:33.252 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-07-23 13:03:33.252 | Subscribing to symbol for symbol alert. XAUUSD 2026-07-23 13:03:33.252 | Using Bid/Ask average for last trade price for XAUUSD 2026-07-23 13:03:33.252 | Using symbol data fast lookup vector 2026-07-23 13:03:33.252 | SC Data with Depth | Starting real-time market data updates for: XAUUSD. ID: 1 Service code: fxcm 2026-07-23 13:03:33.252 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2026-07-23 13:03:33.252 | SC Data with Depth | Requesting security definition data for: XAUUSD. ID: 1 2026-07-23 13:03:33.252 | Subscribing to symbol for symbol alert. XAUUSD 2026-07-23 13:03:33.252 | Subscribing to symbol for symbol alert. SPX500 2026-07-23 13:03:33.252 | Using Bid/Ask average for last trade price for SPX500 2026-07-23 13:03:33.252 | SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 2 Service code: fxcm 2026-07-23 13:03:33.252 | SC Data with Depth | Requesting security definition data for: SPX500. ID: 2 2026-07-23 13:03:33.252 | Subscribing to symbol for symbol alert. SPX500 2026-07-23 13:03:33.252 | Subscribing to symbol for symbol alert. NAS100 2026-07-23 13:03:33.252 | Using Bid/Ask average for last trade price for NAS100 2026-07-23 13:03:33.252 | SC Data with Depth | Starting real-time market data updates for: NAS100. ID: 3 Service code: fxcm 2026-07-23 13:03:33.253 | SC Data with Depth | Requesting security definition data for: NAS100. ID: 3 2026-07-23 13:03:33.253 | Updated verified funded futures trading account ending date to: 2026-08-22 17:03:33 2026-07-23 13:03:33.256 | Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data 2026-07-23 13:03:33.256 | Denali Data Feed | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 4 Service code: nasdaq_exchange.data 2026-07-23 13:03:33.256 | Denali Data Feed | Connecting to the server ds31.sierracharts.com. Port 10045 2026-07-23 13:03:33.256 | Denali Data Feed | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 4 2026-07-23 13:03:33.256 | Added historical Intraday data request for AAPL-NQTV to the queue. 2026-07-23 13:03:33.256 | Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. 2026-07-23 13:03:33.256 | Triggering next historical data download in queue. 2026-07-23 13:03:33.256 | AAPL-NQTV [CBV-D][M] 5 Min #8 | Started historical data download for additional symbol AAPL-NQTV. Download ID: 299 2026-07-23 13:03:33.256 | Mapping AMZN-NQTV to AMZN-NQTV. Service code: nasdaq_exchange.data 2026-07-23 13:03:33.256 | Denali Data Feed | Starting real-time market data updates for: AMZN-NQTV (AMZN-NQTV). ID: 5 Service code: nasdaq_exchange.data 2026-07-23 13:03:33.256 | Denali Data Feed | Requesting security definition data for: AMZN-NQTV (AMZN-NQTV). ID: 5 2026-07-23 13:03:33.256 | Added historical Intraday data request for AMZN-NQTV to the queue. 2026-07-23 13:03:33.256 | Intraday data recording state for symbol AMZN-NQTV is set to download 'Pending'. 2026-07-23 13:03:33.256 | AAPL-NQTV [CBV-D][M] 5 Min #8 | Started historical data download for additional symbol AMZN-NQTV. Download ID: 300 2026-07-23 13:03:33.256 | Mapping GOOGL-NQTV to GOOGL-NQTV. Service code: nasdaq_exchange.data 2026-07-23 13:03:33.256 | Denali Data Feed | Starting real-time market data updates for: GOOGL-NQTV (GOOGL-NQTV). ID: 6 Service code: nasdaq_exchange.data 2026-07-23 13:03:33.256 | Denali Data Feed | Requesting security definition data for: GOOGL-NQTV (GOOGL-NQTV). ID: 6 2026-07-23 13:03:33.256 | Added historical Intraday data request for GOOGL-NQTV to the queue. 2026-07-23 13:03:33.256 | Intraday data recording state for symbol GOOGL-NQTV is set to download 'Pending'. 2026-07-23 13:03:33.256 | AAPL-NQTV [CBV-D][M] 5 Min #8 | Started historical data download for additional symbol GOOGL-NQTV. Download ID: 301 2026-07-23 13:03:33.256 | Mapping META-NQTV to META-NQTV. Service code: nasdaq_exchange.data 2026-07-23 13:03:33.256 | Denali Data Feed | Starting real-time market data updates for: META-NQTV (META-NQTV). ID: 7 Service code: nasdaq_exchange.data 2026-07-23 13:03:33.256 | Denali Data Feed | Requesting security definition data for: META-NQTV (META-NQTV). ID: 7 2026-07-23 13:03:33.256 | Added historical Intraday data request for META-NQTV to the queue. 2026-07-23 13:03:33.256 | Intraday data recording state for symbol META-NQTV is set to download 'Pending'. 2026-07-23 13:03:33.256 | AAPL-NQTV [CBV-D][M] 5 Min #8 | Started historical data download for additional symbol META-NQTV. Download ID: 302 2026-07-23 13:03:33.256 | Mapping MSFT-NQTV to MSFT-NQTV. Service code: nasdaq_exchange.data 2026-07-23 13:03:33.256 | Denali Data Feed | Starting real-time market data updates for: MSFT-NQTV (MSFT-NQTV). ID: 8 Service code: nasdaq_exchange.data 2026-07-23 13:03:33.256 | Denali Data Feed | Requesting security definition data for: MSFT-NQTV (MSFT-NQTV). ID: 8 2026-07-23 13:03:33.256 | Added historical Intraday data request for MSFT-NQTV to the queue. 2026-07-23 13:03:33.256 | Intraday data recording state for symbol MSFT-NQTV is set to download 'Pending'. 2026-07-23 13:03:33.256 | AAPL-NQTV [CBV-D][M] 5 Min #8 | Started historical data download for additional symbol MSFT-NQTV. Download ID: 303 2026-07-23 13:03:33.256 | Mapping NVDA-NQTV to NVDA-NQTV. Service code: nasdaq_exchange.data 2026-07-23 13:03:33.256 | Denali Data Feed | Starting real-time market data updates for: NVDA-NQTV (NVDA-NQTV). ID: 9 Service code: nasdaq_exchange.data 2026-07-23 13:03:33.256 | Denali Data Feed | Requesting security definition data for: NVDA-NQTV (NVDA-NQTV). ID: 9 2026-07-23 13:03:33.256 | Added historical Intraday data request for NVDA-NQTV to the queue. 2026-07-23 13:03:33.256 | Intraday data recording state for symbol NVDA-NQTV is set to download 'Pending'. 2026-07-23 13:03:33.256 | AAPL-NQTV [CBV-D][M] 5 Min #8 | Started historical data download for additional symbol NVDA-NQTV. Download ID: 304 2026-07-23 13:03:33.257 | Mapping TSLA-NQTV to TSLA-NQTV. Service code: nasdaq_exchange.data 2026-07-23 13:03:33.257 | Denali Data Feed | Starting real-time market data updates for: TSLA-NQTV (TSLA-NQTV). ID: 10 Service code: nasdaq_exchange.data 2026-07-23 13:03:33.257 | Denali Data Feed | Requesting security definition data for: TSLA-NQTV (TSLA-NQTV). ID: 10 2026-07-23 13:03:33.257 | Added historical Intraday data request for TSLA-NQTV to the queue. 2026-07-23 13:03:33.257 | Intraday data recording state for symbol TSLA-NQTV is set to download 'Pending'. 2026-07-23 13:03:33.257 | AAPL-NQTV [CBV-D][M] 5 Min #8 | Started historical data download for additional symbol TSLA-NQTV. Download ID: 305 2026-07-23 13:03:33.257 | Mapping VIX3M_CGI to VIX3M_CGI. Service code: cboe_global_indexes.data 2026-07-23 13:03:33.257 | Denali Data Feed | Starting real-time market data updates for: VIX3M_CGI (VIX3M_CGI). ID: 11 Service code: cboe_global_indexes.data 2026-07-23 13:03:33.257 | Denali Data Feed | Connecting to the server ds30.sierracharts.com. Port 10047 2026-07-23 13:03:33.257 | Denali Data Feed | Requesting security definition data for: VIX3M_CGI (VIX3M_CGI). ID: 11 2026-07-23 13:03:33.257 | Added historical Intraday data request for VIX3M_CGI to the queue. 2026-07-23 13:03:33.257 | Intraday data recording state for symbol VIX3M_CGI is set to download 'Pending'. 2026-07-23 13:03:33.257 | VIX_CGI [CBV-D][M] 5 Min #2 | Started historical data download for additional symbol VIX3M_CGI. Download ID: 306 2026-07-23 13:03:33.257 | Mapping VIX6M_CGI to VIX6M_CGI. Service code: cboe_global_indexes.data 2026-07-23 13:03:33.257 | Denali Data Feed | Starting real-time market data updates for: VIX6M_CGI (VIX6M_CGI). ID: 12 Service code: cboe_global_indexes.data 2026-07-23 13:03:33.257 | Denali Data Feed | Requesting security definition data for: VIX6M_CGI (VIX6M_CGI). ID: 12 2026-07-23 13:03:33.257 | Added historical Intraday data request for VIX6M_CGI to the queue. 2026-07-23 13:03:33.257 | Intraday data recording state for symbol VIX6M_CGI is set to download 'Pending'. 2026-07-23 13:03:33.257 | VIX_CGI [CBV-D][M] 5 Min #2 | Started historical data download for additional symbol VIX6M_CGI. Download ID: 307 2026-07-23 13:03:33.269 | Mapping SKEW_CGI to SKEW_CGI. Service code: cboe_global_indexes.data 2026-07-23 13:03:33.269 | Denali Data Feed | Starting real-time market data updates for: SKEW_CGI (SKEW_CGI). ID: 13 Service code: cboe_global_indexes.data 2026-07-23 13:03:33.269 | Denali Data Feed | Requesting security definition data for: SKEW_CGI (SKEW_CGI). ID: 13 2026-07-23 13:03:33.282 | Added historical Intraday data request for SPX500 to the queue. 2026-07-23 13:03:33.282 | Intraday data recording state for symbol SPX500 is set to download 'Pending'. 2026-07-23 13:03:33.282 | SPX_CGI [CBV-D][M] 30 Min #16 | Started historical data download for additional symbol SPX500. Download ID: 308 2026-07-23 13:03:33.283 | Mapping SPY-NQTV to SPY-NQTV. Service code: nasdaq_exchange.data 2026-07-23 13:03:33.283 | Denali Data Feed | Starting real-time market data updates for: SPY-NQTV (SPY-NQTV). ID: 14 Service code: nasdaq_exchange.data 2026-07-23 13:03:33.283 | Denali Data Feed | Requesting security definition data for: SPY-NQTV (SPY-NQTV). ID: 14 2026-07-23 13:03:33.283 | Added historical Intraday data request for SPY-NQTV to the queue. 2026-07-23 13:03:33.283 | Intraday data recording state for symbol SPY-NQTV is set to download 'Pending'. 2026-07-23 13:03:33.283 | SPX_CGI [CBV-D][M] 30 Min #16 | Started historical data download for additional symbol SPY-NQTV. Download ID: 309 2026-07-23 13:03:33.283 | Mapping ESU26_FUT_CME to ESU26. Service code: cme 2026-07-23 13:03:33.283 | Denali Data Feed | Starting real-time market data updates for: ESU26_FUT_CME (ESU26). ID: 15 Service code: cme 2026-07-23 13:03:33.283 | Denali Data Feed | Connecting to the server ds7-2.sierracharts.com. Port 443 2026-07-23 13:03:33.283 | Denali Data Feed | Requesting security definition data for: ESU26_FUT_CME (ESU26). ID: 15 2026-07-23 13:03:33.283 | Added historical Intraday data request for ESU26_FUT_CME to the queue. 2026-07-23 13:03:33.283 | Intraday data recording state for symbol ESU26_FUT_CME is set to download 'Pending'. 2026-07-23 13:03:33.283 | SPX_CGI [CBV-D][M] 30 Min #16 | Started historical data download for additional symbol ESU26_FUT_CME. Download ID: 310 2026-07-23 13:03:33.290 | Mapping VIX_CGI to VIX_CGI. Service code: cboe_global_indexes.data 2026-07-23 13:03:33.290 | Denali Data Feed | Starting real-time market data updates for: VIX_CGI (VIX_CGI). ID: 16 Service code: cboe_global_indexes.data 2026-07-23 13:03:33.290 | Denali Data Feed | Requesting security definition data for: VIX_CGI (VIX_CGI). ID: 16 2026-07-23 13:03:33.290 | Added historical Intraday data request for VIX_CGI to the queue. 2026-07-23 13:03:33.290 | Intraday data recording state for symbol VIX_CGI is set to download 'Pending'. 2026-07-23 13:03:33.290 | ESU26_FUT_CME[M]/MESU26_FUT_CME [CBV][M] 1 Min #2 | Started historical data download for additional symbol VIX_CGI. Download ID: 311 2026-07-23 13:03:33.290 | Mapping VIX9D_CGI to VIX9D_CGI. Service code: cboe_global_indexes.data 2026-07-23 13:03:33.290 | Denali Data Feed | Starting real-time market data updates for: VIX9D_CGI (VIX9D_CGI). ID: 17 Service code: cboe_global_indexes.data 2026-07-23 13:03:33.290 | Denali Data Feed | Requesting security definition data for: VIX9D_CGI (VIX9D_CGI). ID: 17 2026-07-23 13:03:33.290 | Added historical Intraday data request for VIX9D_CGI to the queue. 2026-07-23 13:03:33.290 | Intraday data recording state for symbol VIX9D_CGI is set to download 'Pending'. 2026-07-23 13:03:33.290 | ESU26_FUT_CME[M]/MESU26_FUT_CME [CBV][M] 1 Min #2 | Started historical data download for additional symbol VIX9D_CGI. Download ID: 312 2026-07-23 13:03:33.292 | Added historical Intraday data request for NAS100 to the queue. 2026-07-23 13:03:33.292 | Intraday data recording state for symbol NAS100 is set to download 'Pending'. 2026-07-23 13:03:33.292 | SPX_CGI [CBV-D][M] 1 Min #3 | Started historical data download for additional symbol NAS100. Download ID: 313 2026-07-23 13:03:33.292 | SC Data with Depth | Starting real-time market data updates for: TICK-NASDAQ. ID: 18 Service code: statscalc 2026-07-23 13:03:33.292 | SC Data with Depth | Requesting security definition data for: TICK-NASDAQ. ID: 18 2026-07-23 13:03:33.292 | Added historical Intraday data request for TICK-NASDAQ to the queue. 2026-07-23 13:03:33.292 | Intraday data recording state for symbol TICK-NASDAQ is set to download 'Pending'. 2026-07-23 13:03:33.292 | SPX_CGI [CBV-D][M] 1 Min #3 | Started historical data download for additional symbol TICK-NASDAQ. Download ID: 314 2026-07-23 13:03:33.292 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2026-07-23 13:03:33.292 | Denali Data Feed | Failed connections: 1 2026-07-23 13:03:33.292 | DTC Client socket (12) | CloseSocket call. 2026-07-23 13:03:33.292 | Denali Data Feed | Disconnected from the server. 2026-07-23 13:03:33.292 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-07-23 13:03:33.292 | Denali Data Feed | Failed connections: 1 2026-07-23 13:03:33.292 | DTC Client socket (10) | CloseSocket call. 2026-07-23 13:03:33.292 | Denali Data Feed | Disconnected from the server. 2026-07-23 13:03:33.292 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-07-23 13:03:33.292 | Denali Data Feed | Failed connections: 1 2026-07-23 13:03:33.292 | DTC Client socket (11) | CloseSocket call. 2026-07-23 13:03:33.292 | Denali Data Feed | Disconnected from the server. 2026-07-23 13:03:33.292 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-07-23 13:03:33.292 | SC Data with Depth | Failed connections: 1 2026-07-23 13:03:33.292 | DTC Client socket (9) | CloseSocket call. 2026-07-23 13:03:33.292 | SC Data with Depth | Disconnected from the server. 2026-07-23 13:03:33.292 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-07-23 13:03:33.292 | Delaying start of download for AAPL-NQTV. 2026-07-23 13:03:33.413 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-07-17 13:29:50.334522 2026-07-23 13:03:33.440 | DTC Client socket (5) | Socket gracefully closed by remote side. 2026-07-23 13:03:33.440 | DTC Client socket (5) | Closed. 2026-07-23 13:03:33.491 | DTC Client socket (7) | Socket gracefully closed by remote side. 2026-07-23 13:03:33.491 | DTC Client socket (7) | Closed. 2026-07-23 13:03:33.584 | SC Data with Depth | Starting real-time market data updates for: BTCUSD_PERP_BINANCE. ID: 19 Service code: binance_cryptocurrency.exchange.data 2026-07-23 13:03:33.584 | SC Data with Depth | Requesting security definition data for: BTCUSD_PERP_BINANCE. ID: 19 2026-07-23 13:03:33.584 | Mapping SPX_CGI to SPX_CGI. Service code: cboe_global_indexes.data 2026-07-23 13:03:33.584 | Denali Data Feed | Starting real-time market data updates for: SPX_CGI (SPX_CGI). ID: 20 Service code: cboe_global_indexes.data 2026-07-23 13:03:33.584 | Denali Data Feed | Requesting security definition data for: SPX_CGI (SPX_CGI). ID: 20 2026-07-23 13:03:33.584 | Mapping NQU26_FUT_CME to NQU26. Service code: cme 2026-07-23 13:03:33.584 | Denali Data Feed | Starting real-time market data updates for: NQU26_FUT_CME (NQU26). ID: 21 Service code: cme 2026-07-23 13:03:33.584 | Denali Data Feed | Requesting security definition data for: NQU26_FUT_CME (NQU26). ID: 21 2026-07-23 13:03:33.584 | Using Bid/Ask average for last trade price for AUS200 2026-07-23 13:03:33.584 | SC Data with Depth | Starting real-time market data updates for: AUS200. ID: 22 Service code: fxcm 2026-07-23 13:03:33.584 | SC Data with Depth | Requesting security definition data for: AUS200. ID: 22 2026-07-23 13:03:33.584 | Using Bid/Ask average for last trade price for USOil 2026-07-23 13:03:33.584 | SC Data with Depth | Starting real-time market data updates for: USOil. ID: 23 Service code: fxcm 2026-07-23 13:03:33.584 | SC Data with Depth | Requesting security definition data for: USOil. ID: 23 2026-07-23 13:03:33.584 | Mapping GCQ26_FUT_CME to GCQ26. Service code: comex 2026-07-23 13:03:33.584 | Denali Data Feed | Starting real-time market data updates for: GCQ26_FUT_CME (GCQ26). ID: 24 Service code: comex 2026-07-23 13:03:33.584 | Denali Data Feed | Requesting security definition data for: GCQ26_FUT_CME (GCQ26). ID: 24 2026-07-23 13:03:33.584 | Mapping SIU26_FUT_CME to SIU26. Service code: comex 2026-07-23 13:03:33.584 | Denali Data Feed | Starting real-time market data updates for: SIU26_FUT_CME (SIU26). ID: 25 Service code: comex 2026-07-23 13:03:33.584 | Denali Data Feed | Requesting security definition data for: SIU26_FUT_CME (SIU26). ID: 25 2026-07-23 13:03:33.584 | Mapping QQQ-NQTV to QQQ-NQTV. Service code: nasdaq_exchange.data 2026-07-23 13:03:33.584 | Denali Data Feed | Starting real-time market data updates for: QQQ-NQTV (QQQ-NQTV). ID: 26 Service code: nasdaq_exchange.data 2026-07-23 13:03:33.584 | Denali Data Feed | Requesting security definition data for: QQQ-NQTV (QQQ-NQTV). ID: 26 2026-07-23 13:03:33.584 | Using Bid/Ask average for last trade price for USDOLLAR 2026-07-23 13:03:33.584 | SC Data with Depth | Starting real-time market data updates for: USDOLLAR. ID: 27 Service code: fxcm 2026-07-23 13:03:33.584 | SC Data with Depth | Requesting security definition data for: USDOLLAR. ID: 27 2026-07-23 13:03:33.584 | Using Bid/Ask average for last trade price for AUDUSD 2026-07-23 13:03:33.584 | SC Data with Depth | Starting real-time market data updates for: AUDUSD. ID: 28 Service code: fxcm 2026-07-23 13:03:33.584 | SC Data with Depth | Requesting security definition data for: AUDUSD. ID: 28 2026-07-23 13:03:33.584 | Mapping SPCX to SPCX. Service code: us_equities_utp_cta_exchange.data 2026-07-23 13:03:33.584 | Delayed Data Feed | Starting real-time market data updates for: SPCX (SPCX). ID: 29 Service code: us_equities_utp_cta_exchange.data 2026-07-23 13:03:33.584 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2026-07-23 13:03:33.584 | Delayed Data Feed | Requesting security definition data for: SPCX (SPCX). ID: 29 2026-07-23 13:03:33.584 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: AAPL-NQTV. ID = 4 2026-07-23 13:03:33.584 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: AMZN-NQTV. ID = 5 2026-07-23 13:03:33.584 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: GOOGL-NQTV. ID = 6 2026-07-23 13:03:33.584 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: META-NQTV. ID = 7 2026-07-23 13:03:33.644 | Added historical Intraday data request for SPX_CGI to the queue. 2026-07-23 13:03:33.644 | Intraday data recording state for symbol SPX_CGI is set to download 'Pending'. 2026-07-23 13:03:33.644 | Triggering next historical data download in queue. 2026-07-23 13:03:33.658 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: MSFT-NQTV. ID = 8 2026-07-23 13:03:33.658 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: NVDA-NQTV. ID = 9 2026-07-23 13:03:33.658 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: TSLA-NQTV. ID = 10 2026-07-23 13:03:33.658 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: VIX3M_CGI. ID = 11 2026-07-23 13:03:33.658 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: VIX6M_CGI. ID = 12 2026-07-23 13:03:33.658 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: SKEW_CGI. ID = 13 2026-07-23 13:03:33.658 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: SPY-NQTV. ID = 14 2026-07-23 13:03:33.658 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESU26_FUT_CME 2026-07-23 13:03:33.659 | Teton CME Routing | Setting external service identifier for symbol ESU26_FUT_CME to 42140870 2026-07-23 13:03:33.659 | Teton CME Routing | Received security definition for symbol ESU26_FUT_CME 2026-07-23 13:03:33.659 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: VIX_CGI. ID = 16 2026-07-23 13:03:33.659 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: VIX9D_CGI. ID = 17 2026-07-23 13:03:33.659 | Updated verified funded futures trading account ending date to: 2026-08-22 17:03:33 2026-07-23 13:03:33.663 | Mapping MESU26_FUT_CME to MESU26. Service code: cme 2026-07-23 13:03:33.663 | Denali Data Feed | Starting real-time market data updates for: MESU26_FUT_CME (MESU26). ID: 30 Service code: cme 2026-07-23 13:03:33.663 | Denali Data Feed | Requesting security definition data for: MESU26_FUT_CME (MESU26). ID: 30 2026-07-23 13:03:33.663 | Added historical Intraday data request for MESU26_FUT_CME to the queue. 2026-07-23 13:03:33.663 | Intraday data recording state for symbol MESU26_FUT_CME is set to download 'Pending'. 2026-07-23 13:03:33.663 | Triggering next historical data download in queue. 2026-07-23 13:03:33.667 | Added historical Intraday data request for QQQ-NQTV to the queue. 2026-07-23 13:03:33.667 | Intraday data recording state for symbol QQQ-NQTV is set to download 'Pending'. 2026-07-23 13:03:33.667 | Triggering next historical data download in queue. 2026-07-23 13:03:33.774 | DTC Client socket (6) | Socket gracefully closed by remote side. 2026-07-23 13:03:33.774 | DTC Client socket (6) | Closed. 2026-07-23 13:03:33.789 | Teton CME Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=40233487 2026-07-23 13:03:33.810 | DTC Client socket (8) | Socket gracefully closed by remote side. 2026-07-23 13:03:33.810 | DTC Client socket (8) | Closed. 2026-07-23 13:03:33.826 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-07-23 13:03:33.826 | DTC Client socket (3) | Closed. 2026-07-23 13:03:33.831 | DTC Client socket (4) | Socket gracefully closed by remote side. 2026-07-23 13:03:33.831 | DTC Client socket (4) | Closed. 2026-07-23 13:03:33.843 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-07-23 13:03:33.843 | DTC Client socket (2) | Closed. 2026-07-23 13:03:33.862 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: SPX_CGI. ID = 20 2026-07-23 13:03:33.866 | Mapping VVIX_CGI to VVIX_CGI. Service code: cboe_global_indexes.data 2026-07-23 13:03:33.866 | Denali Data Feed | Starting real-time market data updates for: VVIX_CGI (VVIX_CGI). ID: 31 Service code: cboe_global_indexes.data 2026-07-23 13:03:33.866 | Denali Data Feed | Requesting security definition data for: VVIX_CGI (VVIX_CGI). ID: 31 2026-07-23 13:03:33.866 | Added historical Intraday data request for VVIX_CGI to the queue. 2026-07-23 13:03:33.866 | Intraday data recording state for symbol VVIX_CGI is set to download 'Pending'. 2026-07-23 13:03:33.866 | Triggering next historical data download in queue. 2026-07-23 13:03:33.867 | Mapping VIX1D_CGI to VIX1D_CGI. Service code: cboe_global_indexes.data 2026-07-23 13:03:33.867 | Denali Data Feed | Starting real-time market data updates for: VIX1D_CGI (VIX1D_CGI). ID: 32 Service code: cboe_global_indexes.data 2026-07-23 13:03:33.867 | Denali Data Feed | Requesting security definition data for: VIX1D_CGI (VIX1D_CGI). ID: 32 2026-07-23 13:03:33.867 | Added historical Intraday data request for VIX1D_CGI to the queue. 2026-07-23 13:03:33.867 | Intraday data recording state for symbol VIX1D_CGI is set to download 'Pending'. 2026-07-23 13:03:33.867 | Triggering next historical data download in queue. 2026-07-23 13:03:34.029 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQU26_FUT_CME 2026-07-23 13:03:34.029 | Teton CME Routing | Setting external service identifier for symbol NQU26_FUT_CME to 42004177 2026-07-23 13:03:34.029 | Teton CME Routing | Received security definition for symbol NQU26_FUT_CME 2026-07-23 13:03:34.029 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCQ26_FUT_CME 2026-07-23 13:03:34.029 | Teton CME Routing | Setting external service identifier for symbol GCQ26_FUT_CME to 42011464 2026-07-23 13:03:34.029 | Teton CME Routing | Received security definition for symbol GCQ26_FUT_CME 2026-07-23 13:03:34.029 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: SIU26_FUT_CME 2026-07-23 13:03:34.029 | Teton CME Routing | Setting external service identifier for symbol SIU26_FUT_CME to 42014414 2026-07-23 13:03:34.029 | Teton CME Routing | Received security definition for symbol SIU26_FUT_CME 2026-07-23 13:03:34.029 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: QQQ-NQTV. ID = 26 2026-07-23 13:03:34.029 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESU26_FUT_CME 2026-07-23 13:03:34.029 | Teton CME Routing | Setting external service identifier for symbol MESU26_FUT_CME to 42003239 2026-07-23 13:03:34.029 | Teton CME Routing | Received security definition for symbol MESU26_FUT_CME 2026-07-23 13:03:34.029 | Mapping VXV26_FUT_CFE to VXV26_FUT_CFE. Service code: cfe_exchange.data 2026-07-23 13:03:34.029 | Delayed Data Feed | Starting real-time market data updates for: VXV26_FUT_CFE (VXV26_FUT_CFE). ID: 33 Service code: cfe_exchange.data 2026-07-23 13:03:34.029 | Delayed Data Feed | Connecting to the server ds30.sierracharts.com. Port 10043 2026-07-23 13:03:34.029 | Delayed Data Feed | Requesting security definition data for: VXV26_FUT_CFE (VXV26_FUT_CFE). ID: 33 2026-07-23 13:03:34.029 | Mapping 10YN26_FUT_CME to 10YN26. Service code: cbot 2026-07-23 13:03:34.029 | Delayed Data Feed | Starting real-time market data updates for: 10YN26_FUT_CME (10YN26). ID: 34 Service code: cbot 2026-07-23 13:03:34.029 | Delayed Data Feed | Connecting to the server ds7-2.sierracharts.com. Port 10043 2026-07-23 13:03:34.030 | Delayed Data Feed | Requesting security definition data for: 10YN26_FUT_CME (10YN26). ID: 34 2026-07-23 13:03:34.146 | DTC Client socket (5) | Creating socket. 2026-07-23 13:03:34.146 | DTC Client socket (5) | New receive buffer size: 0 2026-07-23 13:03:34.146 | DTC Client socket (5) | Connecting to IP: 64.152.155.116. 2026-07-23 13:03:34.147 | DTC Client socket (2) | Creating socket. 2026-07-23 13:03:34.147 | DTC Client socket (2) | New receive buffer size: 0 2026-07-23 13:03:34.147 | DTC Client socket (2) | Connecting to IP: 67.214.125.11. 2026-07-23 13:03:34.147 | DTC Client socket (3) | Creating socket. 2026-07-23 13:03:34.147 | DTC Client socket (3) | New receive buffer size: 0 2026-07-23 13:03:34.147 | DTC Client socket (3) | Connecting to IP: 69.39.70.254. 2026-07-23 13:03:34.161 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: VVIX_CGI. ID = 31 2026-07-23 13:03:34.161 | Mapping VXU26_FUT_CFE to VXU26_FUT_CFE. Service code: cfe_exchange.data 2026-07-23 13:03:34.161 | Delayed Data Feed | Starting real-time market data updates for: VXU26_FUT_CFE (VXU26_FUT_CFE). ID: 35 Service code: cfe_exchange.data 2026-07-23 13:03:34.161 | Delayed Data Feed | Requesting security definition data for: VXU26_FUT_CFE (VXU26_FUT_CFE). ID: 35 2026-07-23 13:03:34.162 | Mapping VXQ26_FUT_CFE to VXQ26_FUT_CFE. Service code: cfe_exchange.data 2026-07-23 13:03:34.162 | Delayed Data Feed | Starting real-time market data updates for: VXQ26_FUT_CFE (VXQ26_FUT_CFE). ID: 36 Service code: cfe_exchange.data 2026-07-23 13:03:34.162 | Delayed Data Feed | Requesting security definition data for: VXQ26_FUT_CFE (VXQ26_FUT_CFE). ID: 36 2026-07-23 13:03:34.162 | Mapping VRO_CGI to VRO_CGI. Service code: cboe_global_indexes.data 2026-07-23 13:03:34.162 | Denali Data Feed | Starting real-time market data updates for: VRO_CGI (VRO_CGI). ID: 37 Service code: cboe_global_indexes.data 2026-07-23 13:03:34.162 | Denali Data Feed | Requesting security definition data for: VRO_CGI (VRO_CGI). ID: 37 2026-07-23 13:03:34.235 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: VIX1D_CGI. ID = 32 2026-07-23 13:03:34.432 | Delayed Data Feed | Network connection to server complete. 2026-07-23 13:03:34.432 | Delayed Data Feed | Starting socket receive thread. 2026-07-23 13:03:34.432 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-07-23 13:03:34.432 | Delayed Data Feed | Network connection to server complete. 2026-07-23 13:03:34.432 | Delayed Data Feed | Starting socket receive thread. 2026-07-23 13:03:34.432 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-07-23 13:03:34.432 | Delayed Data Feed | Network connection to server complete. 2026-07-23 13:03:34.432 | Delayed Data Feed | Starting socket receive thread. 2026-07-23 13:03:34.432 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-07-23 13:03:34.432 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: VRO_CGI. ID = 37 2026-07-23 13:03:34.844 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2026-07-23 13:03:34.844 | Delayed Data Feed | Sending logon request message. 2026-07-23 13:03:34.844 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2026-07-23 13:03:34.844 | Delayed Data Feed | Sending logon request message. 2026-07-23 13:03:34.844 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2026-07-23 13:03:34.844 | Delayed Data Feed | Sending logon request message. 2026-07-23 13:03:35.355 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 2026-07-23 13:03:35.446 | DTC Client socket (4) | Creating socket. 2026-07-23 13:03:35.446 | DTC Client socket (4) | New receive buffer size: 0 2026-07-23 13:03:35.446 | DTC Client socket (4) | Connecting to IP: 69.39.70.241. 2026-07-23 13:03:35.609 | Delayed Data Feed | Received logon response. 2026-07-23 13:03:35.609 | Delayed Data Feed | Server Name: SC Realtime Server. 2026-07-23 13:03:35.609 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2026-07-23 13:03:35.609 | Delayed Data Feed | Successfully connected. 2026-07-23 13:03:35.609 | Delayed Data Feed | Trading is not supported. 2026-07-23 13:03:35.609 | Delayed Data Feed | MarketDepthIsSupported: 1 2026-07-23 13:03:35.609 | Delayed Data Feed | Restarting real-time data updates for symbol: 10YN26_FUT_CME -> 10YN26 2026-07-23 13:03:35.612 | Delayed Data Feed | Received logon response. 2026-07-23 13:03:35.612 | Delayed Data Feed | Server Name: SC Realtime Server. 2026-07-23 13:03:35.612 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2026-07-23 13:03:35.612 | Delayed Data Feed | Successfully connected. 2026-07-23 13:03:35.612 | Delayed Data Feed | Trading is not supported. 2026-07-23 13:03:35.612 | Delayed Data Feed | MarketDepthIsSupported: 1 2026-07-23 13:03:35.612 | Delayed Data Feed | Restarting real-time data updates for symbol: SPCX -> SPCX 2026-07-23 13:03:35.628 | Delayed Data Feed | Received logon response. 2026-07-23 13:03:35.628 | Delayed Data Feed | Server Name: SC Realtime Server. 2026-07-23 13:03:35.628 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2026-07-23 13:03:35.628 | Delayed Data Feed | Successfully connected. 2026-07-23 13:03:35.628 | Delayed Data Feed | Trading is not supported. 2026-07-23 13:03:35.628 | Delayed Data Feed | MarketDepthIsSupported: 1 2026-07-23 13:03:35.628 | Delayed Data Feed | Restarting real-time data updates for symbol: VXQ26_FUT_CFE -> VXQ26_FUT_CFE 2026-07-23 13:03:35.628 | Delayed Data Feed | Restarting real-time data updates for symbol: VXU26_FUT_CFE -> VXU26_FUT_CFE 2026-07-23 13:03:35.628 | Delayed Data Feed | Restarting real-time data updates for symbol: VXV26_FUT_CFE -> VXV26_FUT_CFE 2026-07-23 13:03:35.847 | SC Data with Depth | Network connection to server complete. 2026-07-23 13:03:35.847 | SC Data with Depth | Starting socket receive thread. 2026-07-23 13:03:35.847 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high 2026-07-23 13:03:36.114 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-07-23 13:03:36.114 | SC Data with Depth | Sending logon request message. 2026-07-23 13:03:36.348 | Denali Data Feed | Connecting to the server ds45.sierracharts.com. Port 443 2026-07-23 13:03:36.348 | Denali Data Feed | Connecting to the server ds30.sierracharts.com. Port 10045 2026-07-23 13:03:36.348 | Denali Data Feed | Connecting to the server ds31.sierracharts.com. Port 10047 2026-07-23 13:03:36.359 | Delayed Data Feed | Setting external service identifier for symbol 10YN26_FUT_CME to 42271006 2026-07-23 13:03:36.359 | Delayed Data Feed | Received security definition for symbol 10YN26_FUT_CME 2026-07-23 13:03:36.363 | Delayed Data Feed | Setting external service identifier for symbol SPCX to 852 2026-07-23 13:03:36.363 | Delayed Data Feed | Received security definition for symbol SPCX 2026-07-23 13:03:36.411 | Delayed Data Feed | Setting external service identifier for symbol VXQ26_FUT_CFE to 7 2026-07-23 13:03:36.411 | Delayed Data Feed | Received security definition for symbol VXQ26_FUT_CFE 2026-07-23 13:03:36.411 | Delayed Data Feed | Setting external service identifier for symbol VXU26_FUT_CFE to 30 2026-07-23 13:03:36.411 | Delayed Data Feed | Received security definition for symbol VXU26_FUT_CFE 2026-07-23 13:03:36.412 | Delayed Data Feed | Setting external service identifier for symbol VXV26_FUT_CFE to 6 2026-07-23 13:03:36.412 | Delayed Data Feed | Received security definition for symbol VXV26_FUT_CFE 2026-07-23 13:03:36.436 | DTC Client socket (6) | Creating socket. 2026-07-23 13:03:36.436 | DTC Client socket (6) | New receive buffer size: 0 2026-07-23 13:03:36.436 | DTC Client socket (6) | Connecting to IP: 146.88.135.98. 2026-07-23 13:03:36.436 | DTC Client socket (7) | Creating socket. 2026-07-23 13:03:36.436 | DTC Client socket (7) | New receive buffer size: 0 2026-07-23 13:03:36.436 | DTC Client socket (7) | Connecting to IP: 67.214.125.11. 2026-07-23 13:03:36.436 | DTC Client socket (8) | Creating socket. 2026-07-23 13:03:36.436 | DTC Client socket (8) | New receive buffer size: 0 2026-07-23 13:03:36.436 | DTC Client socket (8) | Connecting to IP: 64.152.155.116. 2026-07-23 13:03:36.543 | Denali Data Feed | Network connection to server complete. 2026-07-23 13:03:36.543 | Denali Data Feed | Starting socket receive thread. 2026-07-23 13:03:36.543 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-07-23 13:03:36.652 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-07-23 13:03:36.652 | Denali Data Feed | Sending logon request message. 2026-07-23 13:03:36.683 | Denali Data Feed | Network connection to server complete. 2026-07-23 13:03:36.683 | Denali Data Feed | Starting socket receive thread. 2026-07-23 13:03:36.683 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-07-23 13:03:36.700 | Denali Data Feed | Network connection to server complete. 2026-07-23 13:03:36.700 | Denali Data Feed | Starting socket receive thread. 2026-07-23 13:03:36.700 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-07-23 13:03:36.864 | SC Data with Depth | Received logon response. 2026-07-23 13:03:36.864 | SC Data with Depth | Server Name: SC Realtime Server. 2026-07-23 13:03:36.864 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2026-07-23 13:03:36.864 | SC Data with Depth | Successfully connected. 2026-07-23 13:03:36.864 | SC Data with Depth | Trading is not supported. 2026-07-23 13:03:36.864 | SC Data with Depth | MarketDepthIsSupported: 1 2026-07-23 13:03:36.864 | SC Data with Depth | Restarting real-time data updates for symbol: AUDUSD 2026-07-23 13:03:36.864 | SC Data with Depth | Restarting real-time data updates for symbol: AUS200 2026-07-23 13:03:36.864 | SC Data with Depth | Restarting real-time data updates for symbol: BTCUSD_PERP_BINANCE 2026-07-23 13:03:36.864 | SC Data with Depth | Restarting real-time data updates for symbol: NAS100 2026-07-23 13:03:36.864 | SC Data with Depth | Restarting real-time data updates for symbol: SPX500 2026-07-23 13:03:36.864 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NASDAQ 2026-07-23 13:03:36.864 | SC Data with Depth | Restarting real-time data updates for symbol: USDOLLAR 2026-07-23 13:03:36.864 | SC Data with Depth | Restarting real-time data updates for symbol: USOil 2026-07-23 13:03:36.864 | SC Data with Depth | Restarting real-time data updates for symbol: XAUUSD 2026-07-23 13:03:36.950 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-07-23 13:03:36.950 | Denali Data Feed | Sending logon request message. 2026-07-23 13:03:36.986 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-07-23 13:03:36.986 | Denali Data Feed | Sending logon request message. 2026-07-23 13:03:37.614 | SC Data with Depth | Setting external service identifier for symbol AUDUSD to 5 2026-07-23 13:03:37.614 | SC Data with Depth | Received security definition for symbol AUDUSD 2026-07-23 13:03:37.614 | SC Data with Depth | Setting external service identifier for symbol AUS200 to 42 2026-07-23 13:03:37.614 | SC Data with Depth | Received security definition for symbol AUS200 2026-07-23 13:03:37.614 | SC Data with Depth | Setting external service identifier for symbol BTCUSD_PERP_BINANCE to 21 2026-07-23 13:03:37.614 | SC Data with Depth | Received security definition for symbol BTCUSD_PERP_BINANCE 2026-07-23 13:03:37.614 | SC Data with Depth | Setting external service identifier for symbol NAS100 to 52 2026-07-23 13:03:37.614 | SC Data with Depth | Received security definition for symbol NAS100 2026-07-23 13:03:37.614 | SC Data with Depth | Setting external service identifier for symbol SPX500 to 55 2026-07-23 13:03:37.614 | SC Data with Depth | Received security definition for symbol SPX500 2026-07-23 13:03:37.614 | SC Data with Depth | Setting external service identifier for symbol TICK-NASDAQ to 37 2026-07-23 13:03:37.614 | SC Data with Depth | Received security definition for symbol TICK-NASDAQ 2026-07-23 13:03:37.614 | SC Data with Depth | Setting external service identifier for symbol USDOLLAR to 63 2026-07-23 13:03:37.614 | SC Data with Depth | Received security definition for symbol USDOLLAR 2026-07-23 13:03:37.614 | SC Data with Depth | Setting external service identifier for symbol USOil to 60 2026-07-23 13:03:37.614 | SC Data with Depth | Received security definition for symbol USOil 2026-07-23 13:03:37.614 | SC Data with Depth | Setting external service identifier for symbol XAUUSD to 62 2026-07-23 13:03:37.614 | SC Data with Depth | Received security definition for symbol XAUUSD 2026-07-23 13:03:37.733 | Denali Data Feed | Received logon response. 2026-07-23 13:03:37.733 | Denali Data Feed | Server Name: SC Realtime Server. 2026-07-23 13:03:37.733 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-07-23 13:03:37.733 | Denali Data Feed | Successfully connected. 2026-07-23 13:03:37.733 | Denali Data Feed | Trading is not supported. 2026-07-23 13:03:37.733 | Denali Data Feed | MarketDepthIsSupported: 1 2026-07-23 13:03:37.733 | Denali Data Feed | Restarting real-time data updates for symbol: SKEW_CGI -> SKEW_CGI 2026-07-23 13:03:37.733 | Denali Data Feed | Restarting real-time data updates for symbol: SPX_CGI -> SPX_CGI 2026-07-23 13:03:37.733 | Denali Data Feed | Restarting real-time data updates for symbol: VIX1D_CGI -> VIX1D_CGI 2026-07-23 13:03:37.733 | Denali Data Feed | Restarting real-time data updates for symbol: VIX3M_CGI -> VIX3M_CGI 2026-07-23 13:03:37.733 | Denali Data Feed | Restarting real-time data updates for symbol: VIX6M_CGI -> VIX6M_CGI 2026-07-23 13:03:37.733 | Denali Data Feed | Restarting real-time data updates for symbol: VIX9D_CGI -> VIX9D_CGI 2026-07-23 13:03:37.733 | Denali Data Feed | Restarting real-time data updates for symbol: VIX_CGI -> VIX_CGI 2026-07-23 13:03:37.733 | Denali Data Feed | Restarting real-time data updates for symbol: VRO_CGI -> VRO_CGI 2026-07-23 13:03:37.733 | Denali Data Feed | Restarting real-time data updates for symbol: VVIX_CGI -> VVIX_CGI 2026-07-23 13:03:37.896 | Denali Data Feed | Received logon response. 2026-07-23 13:03:37.896 | Denali Data Feed | Server Name: SC Realtime Server. 2026-07-23 13:03:37.896 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-07-23 13:03:37.896 | Denali Data Feed | Successfully connected. 2026-07-23 13:03:37.896 | Denali Data Feed | Trading is not supported. 2026-07-23 13:03:37.896 | Denali Data Feed | MarketDepthIsSupported: 1 2026-07-23 13:03:37.896 | Denali Data Feed | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV 2026-07-23 13:03:37.896 | Denali Data Feed | Restarting real-time data updates for symbol: AMZN-NQTV -> AMZN-NQTV 2026-07-23 13:03:37.896 | Denali Data Feed | Restarting real-time data updates for symbol: GOOGL-NQTV -> GOOGL-NQTV 2026-07-23 13:03:37.896 | Denali Data Feed | Restarting real-time data updates for symbol: META-NQTV -> META-NQTV 2026-07-23 13:03:37.896 | Denali Data Feed | Restarting real-time data updates for symbol: MSFT-NQTV -> MSFT-NQTV 2026-07-23 13:03:37.896 | Denali Data Feed | Restarting real-time data updates for symbol: NVDA-NQTV -> NVDA-NQTV 2026-07-23 13:03:37.896 | Denali Data Feed | Restarting real-time data updates for symbol: QQQ-NQTV -> QQQ-NQTV 2026-07-23 13:03:37.896 | Denali Data Feed | Restarting real-time data updates for symbol: SPY-NQTV -> SPY-NQTV 2026-07-23 13:03:37.896 | Denali Data Feed | Restarting real-time data updates for symbol: TSLA-NQTV -> TSLA-NQTV 2026-07-23 13:03:38.391 | Requesting market depth updates for: ESU26_FUT_CME if supported. NumLevels=50 2026-07-23 13:03:38.391 | Requesting market depth updates for: MESU26_FUT_CME if supported. NumLevels=50 2026-07-23 13:03:38.391 | Denali Data Feed | Received logon response. 2026-07-23 13:03:38.391 | Denali Data Feed | Server Name: SC Realtime Server. 2026-07-23 13:03:38.391 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-07-23 13:03:38.391 | Denali Data Feed | Successfully connected. 2026-07-23 13:03:38.391 | Denali Data Feed | Trading is not supported. 2026-07-23 13:03:38.391 | Denali Data Feed | MarketDepthIsSupported: 1 2026-07-23 13:03:38.391 | Denali Data Feed | Restarting real-time data updates for symbol: ESU26_FUT_CME -> ESU26. Market Depth data restarted. 2026-07-23 13:03:38.391 | Denali Data Feed | Restarting real-time data updates for symbol: GCQ26_FUT_CME -> GCQ26 2026-07-23 13:03:38.391 | Denali Data Feed | Restarting real-time data updates for symbol: MESU26_FUT_CME -> MESU26. Market Depth data restarted. 2026-07-23 13:03:38.391 | Denali Data Feed | Restarting real-time data updates for symbol: NQU26_FUT_CME -> NQU26 2026-07-23 13:03:38.391 | Denali Data Feed | Restarting real-time data updates for symbol: SIU26_FUT_CME -> SIU26 2026-07-23 13:03:38.671 | Denali Data Feed | Setting external service identifier for symbol AAPL-NQTV to 41 2026-07-23 13:03:38.671 | Denali Data Feed | Received security definition for symbol AAPL-NQTV 2026-07-23 13:03:38.671 | Denali Data Feed | Setting external service identifier for symbol AMZN-NQTV to 594 2026-07-23 13:03:38.671 | Denali Data Feed | Received security definition for symbol AMZN-NQTV 2026-07-23 13:03:38.671 | Denali Data Feed | Setting external service identifier for symbol GOOGL-NQTV to 5019 2026-07-23 13:03:38.671 | Denali Data Feed | Received security definition for symbol GOOGL-NQTV 2026-07-23 13:03:38.671 | Denali Data Feed | Setting external service identifier for symbol META-NQTV to 7330 2026-07-23 13:03:38.671 | Denali Data Feed | Received security definition for symbol META-NQTV 2026-07-23 13:03:38.671 | Denali Data Feed | Setting external service identifier for symbol MSFT-NQTV to 7651 2026-07-23 13:03:38.671 | Denali Data Feed | Received security definition for symbol MSFT-NQTV 2026-07-23 13:03:38.671 | Denali Data Feed | Setting external service identifier for symbol NVDA-NQTV to 8263 2026-07-23 13:03:38.671 | Denali Data Feed | Received security definition for symbol NVDA-NQTV 2026-07-23 13:03:38.671 | Denali Data Feed | Setting external service identifier for symbol QQQ-NQTV to 9510 2026-07-23 13:03:38.671 | Denali Data Feed | Received security definition for symbol QQQ-NQTV 2026-07-23 13:03:38.671 | Denali Data Feed | Setting external service identifier for symbol SPY-NQTV to 10848 2026-07-23 13:03:38.671 | Denali Data Feed | Received security definition for symbol SPY-NQTV 2026-07-23 13:03:38.671 | Denali Data Feed | Setting external service identifier for symbol TSLA-NQTV to 11619 2026-07-23 13:03:38.671 | Denali Data Feed | Received security definition for symbol TSLA-NQTV 2026-07-23 13:03:39.037 | Denali Data Feed | Clearing market depth for ESU26_FUT_CME 2026-07-23 13:03:39.037 | Denali Data Feed | Clearing market depth for MESU26_FUT_CME 2026-07-23 13:03:39.037 | Denali Data Feed | Setting external service identifier for symbol ESU26_FUT_CME to 42140870 2026-07-23 13:03:39.037 | Denali Data Feed | Received security definition for symbol ESU26_FUT_CME 2026-07-23 13:03:39.037 | Denali Data Feed | Setting external service identifier for symbol GCQ26_FUT_CME to 42011464 2026-07-23 13:03:39.037 | Denali Data Feed | Received security definition for symbol GCQ26_FUT_CME 2026-07-23 13:03:39.037 | Denali Data Feed | Setting external service identifier for symbol MESU26_FUT_CME to 42003239 2026-07-23 13:03:39.037 | Denali Data Feed | Received security definition for symbol MESU26_FUT_CME 2026-07-23 13:03:39.037 | Denali Data Feed | Setting external service identifier for symbol NQU26_FUT_CME to 42004177 2026-07-23 13:03:39.037 | Denali Data Feed | Received security definition for symbol NQU26_FUT_CME 2026-07-23 13:03:39.037 | Denali Data Feed | Setting external service identifier for symbol SIU26_FUT_CME to 42014414 2026-07-23 13:03:39.037 | Denali Data Feed | Received security definition for symbol SIU26_FUT_CME 2026-07-23 13:03:39.041 | Denali Data Feed | Setting external service identifier for symbol SKEW_CGI to 1172 2026-07-23 13:03:39.041 | Denali Data Feed | Received security definition for symbol SKEW_CGI 2026-07-23 13:03:39.041 | Denali Data Feed | Setting external service identifier for symbol SPX_CGI to 1328 2026-07-23 13:03:39.041 | Denali Data Feed | Received security definition for symbol SPX_CGI 2026-07-23 13:03:39.041 | Denali Data Feed | Setting external service identifier for symbol VIX1D_CGI to 1463 2026-07-23 13:03:39.041 | Denali Data Feed | Received security definition for symbol VIX1D_CGI 2026-07-23 13:03:39.041 | Denali Data Feed | Setting external service identifier for symbol VIX3M_CGI to 1465 2026-07-23 13:03:39.041 | Denali Data Feed | Received security definition for symbol VIX3M_CGI 2026-07-23 13:03:39.041 | Denali Data Feed | Setting external service identifier for symbol VIX6M_CGI to 1466 2026-07-23 13:03:39.041 | Denali Data Feed | Received security definition for symbol VIX6M_CGI 2026-07-23 13:03:39.041 | Denali Data Feed | Setting external service identifier for symbol VIX9D_CGI to 1467 2026-07-23 13:03:39.041 | Denali Data Feed | Received security definition for symbol VIX9D_CGI 2026-07-23 13:03:39.041 | Denali Data Feed | Setting external service identifier for symbol VIX_CGI to 1462 2026-07-23 13:03:39.041 | Denali Data Feed | Received security definition for symbol VIX_CGI 2026-07-23 13:03:39.041 | Denali Data Feed | Setting external service identifier for symbol VRO_CGI to 1475 2026-07-23 13:03:39.041 | Denali Data Feed | Received security definition for symbol VRO_CGI 2026-07-23 13:03:39.041 | Denali Data Feed | Setting external service identifier for symbol VVIX_CGI to 1478 2026-07-23 13:03:39.041 | Denali Data Feed | Received security definition for symbol VVIX_CGI 2026-07-23 13:03:43.425 | HD Request # 291 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data 2026-07-23 13:03:43.425 | HD Request # 291 | Download start date-time: 2026-07-23 12:57:02.000000. File last date-time: 2026-07-23 12:57:02.675000 2026-07-23 13:03:43.425 | HD Request # 291 | Using server: ds33.sierracharts.com port 10149 2026-07-23 13:03:43.513 | Socket (9) | Creating socket. 2026-07-23 13:03:43.513 | Socket (9) | New receive buffer size: 0 2026-07-23 13:03:43.513 | Socket (9) | Connecting to IP: 69.39.70.245. 2026-07-23 13:03:44.029 | HD Request # 291 | Setting DTC encoding to Binary VLS 2026-07-23 13:03:44.029 | HD Request # 291 | Sending historical data logon request message. 2026-07-23 13:03:44.316 | HD Request # 291 | Requesting Intraday data. Start date-time: 2026-07-23 12:57:02. Record interval: 0. Symbol: AAPL-NQTV 2026-07-23 13:03:44.573 | HD Request # 291 | Decompressing data. 2026-07-23 13:03:44.833 | HD Request # 291 | Receiving Intraday data for AAPL-NQTV starting at 2026-07-23 12:57:02.675000 2026-07-23 13:03:44.834 | Socket (9) | CloseSocket call. 2026-07-23 13:03:44.834 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-07-23 13:03:44.875 | Historical data download thread signaled to stop. 2026-07-23 13:03:44.875 | HD Request # 291 | Timestamp of first Intraday data file record written: 2026-07-23 12:57:05.013000. 2026-07-23 13:03:44.875 | HD Request # 291 | Received 1626 Intraday data records from 2026-07-23 12:57:02.675000 to 2026-07-23 13:03:46.115001 (6.7 minutes. Delay: -1.2 seconds) and wrote 1625 records for AAPL-NQTV 2026-07-23 13:03:44.876 | HD Request # 291 | Add time&sales data | Remembered last file record date-time: 2026-07-23 17:03:46.115001 2026-07-23 13:03:44.876 | Added 1 Time and Sales records to Intraday data file for AAPL-NQTV after download. 2026-07-23 13:03:44.876 | HD Request # 291 | Completion time: 1s. 2026-07-23 13:03:44.876 | HD Request # 291 | Intraday data download complete for AAPL-NQTV. Unique request ID: 299 2026-07-23 13:03:44.876 | Removing historical data download ID 299. 2026-07-23 13:03:44.876 | Real-time Intraday chart data file updates started for AAPL-NQTV 2026-07-23 13:03:44.876 | Intraday chart data file opened for AAPL-NQTV 2026-07-23 13:03:44.876 | HD Request # 291 | Enabling Intraday chart updating for symbol. 2026-07-23 13:03:44.876 | AAPL-NQTV [CBV-D][M] 5 Min #8 | Historical data download for additional symbol AAPL-NQTV with ID 299 has completed. |
| [2026-07-23 20:01:26] |
| John - SC Support - Posts: 48303 |
This message: Teton CME Routing | Logon error received from server: Secondary instance is not allowing connections to this server
Can be ignored. We do not know exactly why it was added by Engineering, but we see it in nearly all logs connected to Teton and it is not of any concern. It does not have anything to do with secondar instances. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-24 04:19:47] |
| Sierra_Chart Engineering - Posts: 25248 |
Refer to: Sierra Chart Teton Futures Order Routing: "Secondary Instance is Not Allowing Connections" Connection Error Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
