Date/Time: Fri, 23 Oct 2026 02:17:15 +0000
Gross Profit loss commission calculation
View Count: 238
[2026-07-23 10:20:35]
Pedro7 - Posts: 39
When i set the daily profit trigger amount in daily net profit management i get this eg waiting for initial profit trigger of 500. Current net P/L 75. The 75 does not take into account the commissions. How can this be arranged ?
Thx
[2026-07-23 15:21:14]
John - SC Support - Posts: 48303
The Net P/L can not be setup to include commissions.
You can set a round-turn commission in the Symbol Settings (either the global option - "Use Global Round Turn Commission", or per symbol - "Round Turn Commission"). And you can have that commission used in the chart Daily Profit/Loss calculations by setting the following option to "Yes":
Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu)
But, the issue is that this commission will only apply to closed trades, as it is a round-turn commission. So you will see this reflected in your "Daily P/L", but it will not be present in the Net P/L for open trades.
The Global Profit/Loss Management will uses that chart specific Profit/Loss, so after a trade is closed and the commissions are applied, that will be reflected in the Global Profit/Loss Management. But while the trade is open, there is not a way to have that commission accounted for.
