Date/Time: Fri, 23 Oct 2026 02:16:42 +0000
VBP resetting time
View Count: 241
| [2026-07-22 15:05:50] |
| User988582 - Posts: 12 |
so my New york starts at 11:30pm im making a RTH profile and every time i put 11:30pm to 6am in the custom intraday the 6am keeps resetting back to 11:29pm and i have the multiple profiles based on fixed time aswell and its happening with all my profiles same with ETH
| [2026-07-22 16:42:24] |
| John - SC Support - Posts: 48303 |
When using the "Custom Intraday Sessions" for the Volume by Price study, you need to enter both a "Begin Time" and "End Time". And the total time that is covered by the "Volume Graph Period Type" needs to be covered by the Custom Intraday Sessions. So if you are trying to setup daily profiles, then the Custom Intraday Sessions need cover the 24 hours for that day. But if you are wanting to just have an RTH profile and your Session Times are set to have a separate Evening Session, then it is easier to set the following Inputs as specified: - Use Separate Profile for Evening Session: Yes - Exclude Evening Session Profiles Except for Last Day: Yes Refer to the following and the Input below it: Volume By Price Study: Use Separate Profile for Evening Session For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
