Date/Time: Sat, 17 Oct 2026 00:24:10 +0000
DOM - Current Traded Total Volume - Volume Bars exceeding borders
View Count: 303
[2026-07-17 00:16:55]
How.tf - Posts: 10
Hi Sierra Support Team,
I am setting up my trading DOM - and have added [Current Traded Total Volume] as a visible column - with "Show Volume Bars".
All was working well until I (accidentally) dragged on the Price column, which then adjusted the vertical scale of the DOM.
This then resulted in the volume bars in the [Current Traded Total Volume] column (most right in screenshot) sitting outside its borders, and I cannot get it to fit back inside (even if I try to adjust the vertical scale):
https://www.sierrachart.com/image.php?Image=1784247389471.png
How can I fix this?
Date Time Of Last Edit: 2026-07-17 00:17:45
[2026-07-17 00:24:06]
How.tf - Posts: 10
Similarly with the [Current Traded Bid Volume] and [Current Traded Ask Volume] - last 3 columns on the right along with [Current Traded Total Volume]:
https://www.sierrachart.com/image.php?Image=1784247703663.png
[2026-07-17 00:37:32]
blt - Posts: 219
to:
How.tf
Has been addressed by me weeks ago
I "solved" it by enlarging the thickness of DOM grid
Sorry if I am missing your point
TradeDOM misalignment of Volume Bars
Date Time Of Last Edit: 2026-07-17 00:44:07
[2026-07-17 14:45:49]
John - SC Support - Posts: 48239
If you are referring to the Grid Lines and how they cut through the volume bars in the DOM and that it does not line up perfectly, then this is a known issue that we have not yet resolved. This is caused by how the grid is set to offset when it is displayed in the DOM.
As such, the only "solution" is to not display the grid in the DOM. Refer to the following setting:
Global Trade Settings Windows: Extend Chart Horizontal Grid onto Chart DOM (Global Settings >> Chart DOM Settings >> Other >> Other Settings)
If you are referring to something else, then we are not sure what it is and need more information.
