Date/Time: Sat, 17 Oct 2026 00:23:00 +0000
How to select 24 Tool Config #xyz in Control Bar setting for use as button?
View Count: 330
| [2026-07-16 18:25:14] |
| warpigs - Posts: 83 |
I have saved 24 drawn volume profiles with various settings and 24 type text configurations. But when I attempt to setup buttons on the control bar via customize control bar>available control bar commands>tools i only see a total of 24 tool configs to add as buttons, not 24 each. The documentation states there are 24 per tool, or am I misunderstanding something? |
| [2026-07-16 22:01:29] |
| John - SC Support - Posts: 48239 |
What you are viewing in "Customize Control Bars >> Tools" is the actual 24 individual configuration selections. In other words, if you selected a tool first, you could then select the paticular configuration (1-24) that you would want to use with it. YOu need to open the section for "Tools >> Custom Drawing Tools" to setup a control bar button that selects a tool and a configuration. There are 150 of these buttons available in that section. Refer to the following for the instructions on this: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
