Date/Time: Tue, 13 Oct 2026 17:30:43 +0000
Account assigned
View Count: 176
| [2026-07-14 08:03:15] |
| User359273 - Posts: 31 |
when i chose Teton CME Rounting, Reminder that No trade account assigned, show i notice my dormantrading agent to handle this. and the question 2, i choose the Range per Bar true in tick, The outside box of bar bottom and top show the ask and buy total number of contracts, how ignore those numbers. |
| [2026-07-14 15:35:16] |
| John - SC Support - Posts: 48193 |
If you have an account with Dorman that is setup to use Teton, then you need to talk to Dorman about this and make sure they have the setup complete. Also, make sure that you have the correct "Clearing Firm" selected when you setup the connection to your Teton account in the "Data/Trade Service Settings". Refer to Step #9 at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions and the question 2, i choose the Range per Bar true in tick, The outside box of bar bottom and top show the ask and buy total number of contracts, how ignore those numbers.
We need an image to understand what you are referring to. Please get us an image by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Although most likely you have some study that is putting that information there, so you would need to determine what study it is and remove it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-15 02:01:45] |
https://www.sierrachart.com/image.php?Image=1784080711408.png how to ignore the sum number top and bottom of range bar. example top green number 213.00000 botoom red number 309 |
| [2026-07-15 14:27:37] |
For the Numbers Bars study, set the Input for "Show Historical Pullback AskVolume BidVolume Difference" to "No". Refer to the following: Numbers Bars: Show Historical Pullback AskVolume BidVolume Difference If, by chance, that does not resolve it, then this would mean that you have another study that is putting those numbers there. You would need to find that study and remove it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
