Date/Time: Sun, 11 Oct 2026 00:03:02 +0000
RECENT BID ASK NOT SHOWING WHEN COMBINE INCREMENT TICKS IS SET TO ON
View Count: 306
| [2026-07-07 16:18:58] |
| Trade with ICE - Posts: 50 |
I just updated to the latest version, and the recent bid ask is not showing when this setting is set to on.
Private File Private File |
| [2026-07-07 17:02:55] |
| John - SC Support - Posts: 48169 |
This had to change due to some other changes that were being done. You should no longer change the Tick Size for your charts and then set the "Market Depth Combine Increment in Ticks" to 1. Rather, you should set the Tick Size to the exchange default value and the use the "Market Depth Combine Increment in Ticks" to set the aggregation amount. You can then set "Chart >> Chart Settings >> Market Depth >> Apply Combine Increment in Ticks to Other Market Data Columns" to "Yes". Refer to the following: Global Trade Settings Windows: Combining Price Levels for Market Data Columns in the Chart/Trade DOM And for aggregating Volume at Price levels, use the "Volume at Price Multiplier". Refer to the following: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-07 17:20:49] |
Thanks, that worked. The pull stack and current bid-ask volume bars are not filling the cell like the volume and delta bars do, but I can live with that. Just so you know, they did fill the cell in the previous version. Thanks again! |
Private File |
| [2026-07-07 18:17:03] |
Refer to the following setting: Global Trade Settings Windows: Chart DOM Volume Bars Filled Combined Price Level (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-07 20:12:24] |
Thanks... everything is good now
Private File |
