Date/Time: Tue, 06 Oct 2026 17:29:27 +0000
Relative Volume Study bar coloring
View Count: 215
| [2026-07-06 13:10:52] |
| User247273 - Posts: 51 |
Currently, the Relative Volume study inputs 9-10 (high/low percent threshold) and 11-12 (high/low threshold color) can control the coloring of Relative Volume bars (SG1). Would it be possible to adjust the study so that those inputs also control the coloring of the Cumulative Volume Ratio bars (SG2)?
| [2026-07-06 16:54:24] |
| John - SC Support - Posts: 48121 |
It would not be straightforward to make those same inputs apply to the "Cumulative Volume Ratio", as those percentages relate directly to the values of the bars themselves. The Cumulative Volume Ratio is a comparison of the previous days volume versus the current day, so the numbers are completely different. The point is that this would require a completely separate set of Inputs in which you would enter the high and low values where you would want to color the line different along with the particular colors. You can accomplish this using the "Color Bar Based on Alert Condition". We have attached a Study Collection that colors the Cumulative Volume Ratio if the value is above 90. Refer to the following for how to use this study collection: Study Collections: Using a Study Collection Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
