Date/Time: Tue, 06 Oct 2026 17:30:00 +0000
Large volume trade indicator issue
View Count: 233
[2026-07-06 13:08:20]
User300837 - Posts: 7
Hi! I just reinstalled sierra chart after buying a new pc and i lost my usb where i saved all my data. When i try to use the large volume trade indicator, it just shows nothing. I also added the study to multiple symbols but nothing works, it just shows nothing. Also downloading depth data it doesnt work. Thanks!
imagestudy.png / V - Attached On 2026-07-06 13:07:51 UTC - Size: 139.12 KB - 58 views
imagechart.png / V - Attached On 2026-07-06 13:07:54 UTC - Size: 31.6 KB - 54 views
[2026-07-06 15:58:59]
John - SC Support - Posts: 48121
Make sure "Global Settings >> Data/Trade Service Settings >> Common Settings >> Intraday Data Storage Time Unit" is set to "1 tick". Refer to the following:
Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings)
[2026-07-06 17:51:36]
It worked! Thank you John!
