Date/Time: Thu, 08 Oct 2026 01:52:33 +0000
Best settings for Dom
View Count: 222
[2026-07-05 14:07:04]
Jnol - Posts: 3
Hi, I have gone through the support board and some of the literature regarding dom performance. What are the best settings for dom performance? Every setting to ensure the dom performs the best it possibly can. Performance defined as fastest updates and stable. When I test Sierra Dom next to one other platform, Sierra is slightly behind on price movement at times. Higher latency, less frequent updates. A trader that does not use the dom likely would not notice this but dom traders 100% can if they have used the other dom I am referring to. Confirmed with video playback. I trade only on doms and would like to see if I can get the dom to perform like the other platform as Sierra provides everything else I like in platforms. At the moment I test 20-50ms update intervals, limited doms per instance (I use 9 doms but only trade on 2-4). Thank you.
[2026-07-05 22:45:07]
Sierra_Chart Engineering - Posts: 25102
Refer to:
Chart Trading and the Chart DOM: Improving Performance Of Chart / Trade DOM
One of the most important things is to use Sierra Chart timers. Here is some information:
General Settings Window: Troubleshooting Performance Issues Related to Timers
