Date/Time: Mon, 05 Oct 2026 08:15:52 +0000
Labeling the Fibonacci extension lines THE PRI 113,6% !?
View Count: 424
[2026-07-04 13:35:51]
NEONACATL T:TROMMLER - Posts: 27
HELLO TRADERS AND SIERRACHART TEAM
IF IT WAS OVERLOADED, PLEASE ATTACH A DESCRIPTION. THANK YOU.
We searched through the tools but couldn't find the labeling tool for the field lines of the extensions. This is important because the students at the "Prediction Resonance Institute" use the Field & Heat Knife 113.6³ and work in the real market. Currently, we use TV for research, but for trading, we recommend Sierra Chart.
We use the labels for communication with each other. We used the text tool ON SIERRACHART SCREENSHOT to clarify what we are saying.
imageScreenshot 2026-07-04 150332.jpg / V - Attached On 2026-07-04 13:35:20 UTC - Size: 304.64 KB - 143 views
[2026-07-05 07:22:50]
seandunaway - Posts: 398
prediction resonance fibonacci 113.6³%..
honestly, can you think of any industry sillier than ours? :D
anyway Chart Drawing Tools: Price Retracement | Price Expansion | Price Projection Configuration
tools -> tool configs -> price expansion/retracement config -> levels tab
Date Time Of Last Edit: 2026-07-05 07:37:28
[2026-07-06 15:06:49]
John - SC Support - Posts: 48095
There is no support for entering a name for the lines of the Price Retracement, Price Expansion, and Price Projection drawing tools. There is just the percentage value itself that gets displayed.
If this is in relation to something else, then we need to know what you are using.
[2026-07-08 14:39:55]
Regarding the function of the labels: it is a tool—a "knife"—used at the university to establish a shared language at the Prediction Resonance Institute.
Thank you for your attention.
imageUnbenannt.jpg / V - Attached On 2026-07-08 14:39:28 UTC - Size: 337.45 KB - 111 views
[2026-07-17 18:07:53]
113,6²³% TROMMLER-RESONANZ
Date Time Of Last Edit: 2026-07-17 18:18:20
imageScreenshot 2026-07-17 164153.jpg / V - Attached On 2026-07-17 18:05:01 UTC - Size: 516.59 KB - 82 views
imageScreenshot 2026-07-17 201341.jpg / V - Attached On 2026-07-17 18:14:37 UTC - Size: 529.14 KB - 74 views
imageScreenshot 2026-07-17 201747.jpg / V - Attached On 2026-07-17 18:18:09 UTC - Size: 472 KB - 78 views
