Date/Time: Thu, 08 Oct 2026 01:51:09 +0000
TPO Profile - Letter Price Increment in Ticks
View Count: 295
| [2026-07-02 23:52:48] |
| User182545 - Posts: 1 |
Hi, I have TPO and Volume by Price studies on a chart. I want to adjust Letter/Block Price Increment in Ticks setting when I change the symbol on the chart. I understand there is Volume At Price Multiplier in the symbol settings, but it doesn't seem to affect TPO chart. Is that possible to set price increment in ticks per symbol? For example I want to use 4 for ES, 16 for NQ, and 1 for CL. Thanks, |
| [2026-07-06 13:19:03] |
| John - SC Support - Posts: 48143 |
As you note, the "Volume by Price Multiplier" does not apply to the TPO study. As such, the only option to have the "Letter/Block Price Increment In Ticks" set to a specific value is to use a Study Collection and have different study collections for each increment you want to use. Refer to the following: Study Collections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
