Date/Time: Tue, 24 Nov 2026 17:08:59 +0000
Window Tiling Pre-sets
View Count: 289
| [2026-07-02 15:50:51] |
| User547290 - Posts: 89 |
I would like to set different buttons in a control bar to set different window tiling grids. Can I do This? For example I have a 5x3 window tile and would like to press a button on go to a 3x1 window tile. Is this possible? |
| [2026-07-02 16:13:56] |
| John - SC Support - Posts: 48640 |
Sierra Chart does not have a way to set different tiling options. There is just one setup. Refer to the following: General Settings Window: Window Tiling (Global Settings >> General Settings >> Windows) You can set a Control Bar button to perform the tiling based on the above settings, as there are options for "Windows Tile as Grid - Horizontal" and "Windows Tile as Grid - Vertical" for the control bar buttons under the "Window" category. Refer to the following: Control Bar: Customize Control Bars >> Control Bar 1-12 (Global Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
