Date/Time: Tue, 24 Nov 2026 05:23:53 +0000
MDI child window creation errors + daily timeframe data not loading with many chartbooks o
View Count: 352
[2026-07-02 10:50:57]
User368741 - Posts: 106
I'm running into two related issues that appear when I have a large number of chartbooks open at once (currently around 60).
1. Repeating "CreateDetachableWindow" errors in the Message Log
The following error is being logged repeatedly, roughly every 10 seconds:
c_Chart::CreateDetachableWindow: Error creating the MDI child window. | Number times message previously added: [varies, ~41–87]
A sample from today:
2026-07-02 10:41:42.959 | c_Chart::CreateDetachableWindow: Error creating the MDI child window. | Number times message previously added: 61
2026-07-02 10:43:20.204 | c_Chart::CreateDetachableWindow: Error creating the MDI child window. | Number times message previously added: 71
2026-07-02 10:44:47.405 | c_Chart::CreateDetachableWindow: Error creating the MDI child window. | Number times message previously added: 84
2026-07-02 10:45:35.685 | c_Chart::CreateDetachableWindow: Error creating the MDI child window. | Number times message previously added: 87
The "Number times message previously added" count is high and continuously increasing, so this is happening very frequently.
2. Daily timeframe data not loading on some charts
With all ~60 chartbooks open, some of the charts do not display the historical product data on the daily timeframe — I only see the current (most recent) candle rather than the full loaded history. When I close some chartbooks and have fewer open, the same charts then load and display the daily data correctly.
This makes me suspect both issues are tied to a resource limit (window handles / GDI objects / memory) being hit when a large number of chartbooks are open simultaneously.
Could you please advise on what is causing the MDI child window creation to fail, whether there is a configurable limit I'm exceeding, and what I can do to allow all daily timeframe data to load reliably even with this many chartbooks open
[2026-07-02 15:46:17]
John - SC Support - Posts: 48633
It may very well be a resource limitation of your system, depending on your particular hardware.
We recommend using separate sub-instances to move the load off a single application for all of those chartbooks. We think this will probably resolve all your issues. Refer to the following:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.47 - Use Sub Instances to Distribute Processing Load
