Date/Time: Mon, 23 Nov 2026 08:08:42 +0000
Cant Download file
View Count: 368
[2026-07-01 15:42:57]
User721474 - Posts: 5
Hello
I could not download the current version sierra chart
keeps getting following earro message
image1.png / V - Attached On 2026-07-01 15:42:22 UTC - Size: 18.52 KB - 128 views
[2026-07-01 19:26:02]
We are curious if you are running your Sierra Chart in an emulator of some kind, as this is typically when we see this kind of error.
In any case, use the Zip installer to install the software instead. Refer to the following:
Software Download: Sierra Chart Zip Installer
[2026-07-06 10:11:04]
pleasee attach file
image123.png / V - Attached On 2026-07-06 10:10:37 UTC - Size: 46.34 KB - 123 views
[2026-07-06 15:51:24]
That is highly unusual. Are you still having the same issue at this time?
[2026-07-07 10:12:32]
yes, just tried again. still the same error message
[2026-07-07 14:12:13]
Sierra_Chart Engineering - Posts: 25463
There is a communication problem from your location. Refer to:
HTTP Communication Errors
