Date/Time: Tue, 24 Nov 2026 09:21:38 +0000
Orders not filling in Trading Evaluator - Delayed
View Count: 333
[2026-06-30 14:38:33]
User450833 - Posts: 8
Hi, i have problem placing order in Trading Evaluator - Delayed
I have follow below setup instruction
Simulated Futures Trading Service: Setup Instructions
Trade Simulation Mode On is untick.
But I am still failed to place any order,
After I place an order, I can see Sent on the Chart (refer attached image), but just less than 1 second quickly disappear
There are no message in Trade Service Log as well
imagess1.png / V - Attached On 2026-06-30 14:35:31 UTC - Size: 24.28 KB - 139 views
[2026-06-30 14:46:26]
I am getting Trading is disabled error when tried to place order in Web Trading Panel
WS 0 [Trading]: Order update received: New order rejected | Rejected | Account: xxxxxx| Symbol: NQU26 | 1782830591665_NQU26 Trading is disabled.
Date Time Of Last Edit: 2026-07-01 12:00:39
Private File
[2026-06-30 15:26:46]
John - SC Support - Posts: 48633
Edit the information for the Trading Evaluator account and check the setting for "Main >> Trading is Disabled". It looks like this is set to "Yes", but it shoudl be "No".
To edit the account, select "Trade >> Trade Account Monitor", select the account you wnat to edit, and then select "Manage >> Edit Trade Account".
[2026-07-01 11:59:41]
for my case the Trading is Disabled is alr set to No
but below it there is a Disable Trading for Parent Account Only somehow set to Yes
I am able to place order after update to No
Thanks for the help
