Date/Time: Mon, 23 Nov 2026 15:07:12 +0000
Can't open new position: Order increases position, liquidation only mode
View Count: 291
[2026-06-28 23:07:38]
highlyskilledtrader - Posts: 3
As the title suggests, new orders are being rejected with the above message. How do I resolve this?
[2026-06-29 13:37:33]
Makes sure you have not started your Sierra Chart software with the option for "Risk Manager Mode" enabled. Refer to the following:
Trade Account and Risk Management: Setting Sierra Chart to Risk Manager Mode
The option is on the bottom right corner of the login screen.
If not the above, then you need to ask your broker about this, as they would have put you in this mode.
[2026-06-29 14:12:12]
Thanks for the response.
I do not have the risk manager mode on.
Contacted the broker, they mentioned it should have been automatically unlocked on Sunday open as the new session began.
[2026-06-29 14:38:38]
Resolved by the broker, thanks
