Date/Time: Wed, 30 Sep 2026 00:32:56 +0000
Change Color of Chart DOM Current Traded Ask Minus Bid Volume Bars
View Count: 319
[2026-06-22 12:38:50]
Oz - Posts: 57
Hi I've made changes to the color of my Chart DOM Current Traded Ask Minus Bid Volume Bars Column.
They appear grey, however I've made changes the changes are not present on my DOM/Chart.
I can not see any setting titled Chart DOM Current Traded Ask Minus Bid Volume Bar?
Only Current traded Ask Volume Bid Volume Difference Positive Volume Bar/Negative Volume Bar,
I presume this is the setting for such?
What have I missed? and how do I make the appropriate color change for the volume bars as marked in DOM.
Thank you.
imageChart DOM Column Current Traded AskMinus Bid Volume Bars Col.jpg / V - Attached On 2026-06-22 12:35:00 UTC - Size: 826.18 KB - 98 views
[2026-06-22 18:42:24]
John - SC Support - Posts: 48062
Those are the correct items to change.
The image you show is of the "Global" color graphics settings. If changing these is not updating the Trading DOM, then that would mean that you have that Trading DOM setup to use its own graphics settings rather than the global graphics settings. So you would need to select "Chart >> Graphics Settings >> Graphics Settings for Chart - Color" and change it in there. Refer to the following:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
[2026-07-03 22:04:05]
Sierra_Chart Engineering - Posts: 25005
Make sure you are running an up-to-date version of Sierra Chart to see all of the relevant settings and for all of the recent development with this functionality. This is critical. Instructions:
Date Time Of Last Edit: 2026-07-03 22:04:21
