Date/Time: Mon, 09 Nov 2026 05:23:47 +0000
Denali feed
View Count: 515
| [2026-06-17 07:04:46] |
| User988582 - Posts: 12 |
does AMP Futures work on sierra to get denali feed if so, do i have to stay logged into the account for it or can i switch over to my topstep account and still have denali feed, also do i have to send the account statements through email?
Date Time Of Last Edit: 2026-06-17 07:05:15
| [2026-06-17 14:18:36] |
| John - SC Support - Posts: 48459 |
An account with AMP will qualify for the CME Group requirement of a live, funded, futures trading account. You only need to log into the AMP account once a month for verification. When you connect to your live trading account, your "Verified Until" date changes to 30 days in the future. We use this date to know if you have connected recently or not. This date must be in the future for you to be able to get the non-professional real-time data for the CME Group. You can view this date at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges Also refer to the following: Denali Exchange Data Feed: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees It does not matter what service you are connected to in order to get the non-professional, real-time CME Group data, as long as your "Verified Until" date is in the future. Do not send us your statements. You just need to connect your Sierra Chart software to your live AMP account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-18 09:30:05] |
so when i get denali can i use the denali feed on the prop firm account?
| [2026-06-18 16:20:34] |
When you have properly setup the Denali data for the CME Group, such that you are getting the real-time data per the requirements. Then it does not matter what service you are connected to - you will continue to get the Denali data for the CME Group until your "Verified Until" date is in the past, or if the exchange does not renew for some reason. Refer to the following: Denali Exchange Data Feed: Integration with Trading Services Just keep in mind, you need to connect at least once a month to your live trading account to update your "Verified Until" date. Refer to the following: Denali Exchange Data Feed: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
