Date/Time: Wed, 11 Nov 2026 18:50:27 +0000
Muti monitor layout corruption
View Count: 280
| [2026-06-17 02:15:25] |
| User472677 - Posts: 400 |
Hi, I have been a satisfied user of sc for several years. I run sc on a laptop with multiple monitors. If there is a momentarily power spike or power failure, all charts from external monitors shift to laptop screen. When sc is exited without saving and restarted, layout is corrupted in that all charts overlap on laptop screen and not on their proper place on external monitors. The setup is already on a UPS. Please provide a solution. |
| [2026-06-17 14:26:35] |
| Sierra_Chart Engineering - Posts: 25413 |
Not sure why this would be the case. Make sure that all monitors are actually on and functioning properly, before you open a Chartbook. Also refer to: Window Size and Position Not Restored When Opening Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
