Date/Time: Fri, 06 Nov 2026 12:49:53 +0000
Volume by Price Hide current and keep previous visible
View Count: 384
[2026-06-16 17:27:07]
User92573 - Posts: 622
Dear Support
I have 2 instances of the Volume by Price study applied.
One is set to = One Period at End of Fixed Time Length
The other is = Multiple Profiles Based on Fixed Time
- The first is as I'd like.
- The second "Multiple Profiles Based on Fixed Time"
What I'd like to do is hide the evolving profile on the second study as I'm already displaying it on the first and instead just shoe the previous and "Keep it always visible."
Thus leaving me with the current evolving session in study one aligned against the right price axis and the second study showing all previous sessions/periods/days profiles except the current which is currently building in study one.
I hope that makes sense.
Is this possible?
Many thanks.
previous visible
[2026-06-16 17:35:04]
I have found the following:
- 1 Day Volume Profiles Showing Prior Day
- Volume By Price Study: 1 Day Volume Profiles Showing Prior Day
... but I cannot retain the last profile i.e. "Keep it always visible."
Date Time Of Last Edit: 2026-06-16 18:07:49
[2026-06-16 20:14:18]
There is no option to keep a profile always visible regardless of where you are scrolled to within the chart for when you are displaying multiple profiles. The Input for "Always Display Last Profile in View" only applies to when the bars for that period are within view, during which time you will see the entire profile. But when the bars for that time period are moved to the right off the graphics area, the profile is also removed. Refer to the following:
Volume By Price Study: Always Display Last Profile Within View
The only solution to have a profile actually Always displayed is to use a single profile and align it to the right.
