Date/Time: Tue, 17 May 2022 15:22:33 +0000
Last month's silver contract not showing the full month
View Count: 1233
[2013-05-15 04:12:45] |
pe1111112 - Posts: 35 |
I had GSIK3 loaded last month and it was working just fine. When it rolled over I switched to GSIN3 which has been working just fine. I wanted to reference something on GSIK3 and so I opened it but it only loads data from April 15th on. GSIK3 was active well before this. I tried reloading and recalculating, I tried recalculating, and I tried re-opening the chart from "Find Symbol" and none of those things would get the whole month to load. How can I load the full data for GSIK3? Thanks. Date Time Of Last Edit: 2013-05-15 04:13:28
[2013-05-15 16:34:17] |
Please refer to help topic 42.1 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-15 16:39:18] |
Thanks! Didn't even know that was an option.
