Date/Time: Fri, 06 Nov 2026 12:56:03 +0000
Intermittent connectivity dropouts - CQG
View Count: 447
[2026-06-12 00:58:33]
User629461 - Posts: 213
Hi, been having intermittent dropouts in data connectivity with CQG via my broker. Not sure if its at their end or my end (software or network related) but hoping you can help narrow the problem. Tried hot-spotting off the phone with no luck. Here's an extract from the Log of the most recent dropout. Doesn't happen daily but on days like today its every 5-10min or so for a few seconds up to minutes. Hoping you can assist in some way or at least point in the right direction. Frustrating as you can imagine. I trade Asian mkts which you don't support otherwise I'd be with you but no other option sadly. Thanks in advance.
2026-06-12 10:31:56.613 | No download requests in the queue to start downloads for.
2026-06-12 10:32:07.006 | Saved Chartbook: NK225M_Day Trade_Live (CQG).Cht. Time: 0.0333 seconds.
2026-06-12 10:41:11.574 | CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2026-06-12 10:41:11.574 | CQG WebSocket socket (1) | Socket gracefully closed by remote side.
2026-06-12 10:41:11.574 | CQG WebSocket socket (1) | CloseSocket call.
2026-06-12 10:41:11.574 | CQG WebSocket socket (1) | Max send buffers used during socket life: 4
2026-06-12 10:41:11.574 | CQG WebSocket socket (1) | Max send buffer size during socket life: 309
2026-06-12 10:41:11.574 | CQG WebSocket | Network socket for WebSocket has been closed by remote side or error.
2026-06-12 10:41:11.574 | CQG WebAPI | WebSocket closed.
2026-06-12 10:41:11.574 | Connection to the external service has been lost.
2026-06-12 10:41:11.574 | CQG WebSocket socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-06-12 10:41:11.574 | CQG WebSocket socket (1) | Closed.
2026-06-12 10:41:11.590 | CQG WebSocket socket (0) | CloseSocket call.
2026-06-12 10:41:11.590 | CQG WebAPI | Disconnected.
2026-06-12 10:41:11.590 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-06-12 10:41:13.590 |
2026-06-12 10:41:13.590 | CQG WebAPI | Connecting to server api.cqg.com
2026-06-12 10:41:13.590 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443
2026-06-12 10:41:13.814 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2.
2026-06-12 10:41:13.815 | CQG WebSocket socket (1) | New receive buffer size: 0
2026-06-12 10:41:13.815 | CQG WebSocket socket (1) | Connecting to IP: 203.192.64.156.
2026-06-12 10:41:34.848 | CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2026-06-12 10:41:34.848 | CQG WebSocket socket (1) | CloseSocket call.
2026-06-12 10:41:34.848 | CQG WebSocket | WebSocket closed.
2026-06-12 10:41:34.848 | CQG WebAPI | WebSocket closed.
2026-06-12 10:41:34.848 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-06-12 10:41:34.848 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-06-12 10:41:34.848 | CQG WebSocket socket (1) | Closed.
2026-06-12 10:41:34.864 | CQG WebSocket socket (0) | CloseSocket call.
2026-06-12 10:41:34.864 | CQG WebAPI | Disconnected.
2026-06-12 10:41:34.864 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
Date Time Of Last Edit: 2026-06-12 00:59:50
[2026-06-12 13:42:03]
You do have the following in your log:
This means a general connectivity issue and not being able to stay connected. But it does not give any indication of where the issue is, and there really is nothing that we can do to know whether the issue is on your computer, your Internet connectivity or something with the vendor (CQG in this case). We just know that connectivity is lost. Refer to the following regarding this kind of issue:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
Since you tried a different Internet provider (connecting from your phone) or at least a slightly different routing that way (we do not know if you use the same service for both home and phone), then this would lead to the conclusion that the issue is with CQG, or at least something about the routing to them. But, this is by no means definitive.
On the other hand, we have not had reports of issues with connectivity with CQG, so it would not seem to be that.
We are sorry we can not be more help, as it is something in the connection you are having and not a general Sierra Chart issue.
