Date/Time: Mon, 09 Nov 2026 06:13:55 +0000
[User Discussion] - Request to Convert .cht files to the current version.
View Count: 414
| [2026-06-11 23:16:43] |
| Roufyle - Posts: 7 |
| [2026-06-11 23:18:43] |
| [2026-06-11 23:25:24] |
| [2026-06-12 13:36:31] |
| John - SC Support - Posts: 48459 |
To begin with, this is not something we do, as at this point if a chartbook is old enough to not be compatible, then it probably can not be made to work with the current versions. If you want to try, the instructions are at the following link: Chartbooks (Workspaces): Opening Older Chartbooks Second, you are asking us to convert chartbooks that come from a specific company - G7FX - not your own chartbooks. You need to talk to G7FX to get their current chartbooks. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-16 20:54:02] |
I have done as mentioned above in the link which you have mentioned. I am sending the files do these are now up-to-date according to the latest version? Kindly, notify with yes or no! It would be quite helpful. Thanks!
| [2026-06-16 20:54:40] |
| [2026-06-16 20:55:00] |
| [2026-06-16 21:00:49] |
Why would you ask us to take a look at the chartbooks? If you have updated them yourself, and you are on a current release, then open them in that version and see if they work for you. There is no reason for us to do anything related to this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-16 21:28:03] |
OK! Brother! I got it! I think symbols which are in the chartbook are not available in the free trail version of sierra. I think I got to buy the service package to make it run.
| [2026-06-16 22:13:44] |
You can change the symbols of the charts to be the ones you have access to. Refer to the following: Sierra Chart Trial Account For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
