Date/Time: Tue, 27 Oct 2026 17:53:53 +0000
Denali data feed delayed still
View Count: 447
[2026-06-11 19:41:39]
User710662 - Posts: 2
I think I activated all exchange and data feed for Denali, paid $27 for month. Set up on data feed to connect to AMP with Teton Routing. The message log on connection says Delayed Data Feed.
[2026-06-11 19:51:44]
John - SC Support - Posts: 48342
Depending on what you are looking at in the Message Log, that may, or may not, be relevant. It could just be our standard statement that you are able to get delayed data.
You currently have the following exchanges active with our Denali Exchange Data Feed:
- NASDAQ TotalView
- U.S. Equities Consolidated Tape
So you should be getting real-time data for U.S. Equities. Keep in mind that in order to get the combined data from the two exchanges, you need to add an _MBO suffix to the standard ticker symbol. Refer to the following:
Denali Exchange Data Feed: U.S. Equities Consolidated Tape with NASDAQ TotalView
You state you have an AMP account with Teton, therefore, you need real-time data for the CME Group from our Denali Exchange Data Feed, which you do not have currently setup. We see that you have completed the agreements, but you have no activated any exchanges. You can activate the exchanges you want for the CME Group at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
[2026-06-11 20:03:45]
Thank you that is the step I was missing
