Date/Time: Thu, 26 Nov 2026 04:57:43 +0000
Custom Trading Keyboard Shortcut
View Count: 275
[2026-06-04 14:41:00]
Ricardo Zurek - Posts: 21
I am trying to create several Custom Trading Keyboard Shortcuts, but when I try to "customize trading command," the screen is completely black.
How can I fix this?
imageScreenshot 2026-06-04 163951.png / V - Attached On 2026-06-04 14:40:11 UTC - Size: 152.52 KB - 141 views
[2026-06-04 16:10:23]
You should see the window as it appears in the image we attached to this thread.
Do you have the same issue if you open other settings windows that use the new format (such as "Chart >> Chart Settings")?
If this is a problem with all the "new" settings windows, then this would be due to the color of the text for those windows. You will need to update that color. Refer to the following:
Graphics Settings: Settings Windows: Item Text Foreground Color
Date Time Of Last Edit: 2026-06-05 12:59:18
imageScreenshot 2026-06-04 110830.png / V - Attached On 2026-06-05 12:59:15 UTC - Size: 14.27 KB - 121 views
[2026-06-04 22:14:17]
No, with the other "new windows" I see them fine, this is the first time it happens.
[2026-06-05 13:04:24]
We really do not know why this would be occurring for just a single window.
First, go to that window and select "View >> Reset Column Widths". Hopefully this will resolve it.
If that does not fix it, then please reboot your computer and start just Sierra Chart and go to that window again. Let us know if it is still all blank.
