Date/Time: Thu, 26 Nov 2026 04:57:45 +0000
XAUUSD Chart configuration
View Count: 703
| [2026-06-03 03:52:00] |
| User051224 - Posts: 2 |
I have been trying to scalp/day trade XAUUSD configuring Sierra chart seems complicated. Could you guide in connecting the right exchange! I have Bookmap subscription which has DXFeed... also with right setting getting on call would be efficient so we could wrap up configuration quickly
| [2026-06-03 09:08:12] |
| User135243 - Posts: 337 |
xauusd = CFD and on Bookmap you're watching Gold-futures, so you need Comex-data
| [2026-06-03 13:31:09] |
As User135243 points out, XAUUSD is a CFD, and Sierra Chart does not have connectivity to brokerages that trade CFDs. Are you actually trading with the CME Group? Also, you are on a Trial, in which you have limited data access. Refer to the following: Sierra Chart Trial Account For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-03 13:36:29] |
No I am trading Spot(XAUUSD)learnt Sierra chart is good reference for order flow. So we can use Sierra chart for gold future/spot order flow ?
| [2026-06-03 14:11:04] |
You can use Sierra Chart for charting of CFDs. But we do not have connectivity with any brokers that support trading of CFDs - so you can not trade directly from Sierra Chart for CFDs. If you are having an issue with the charts, then what exactly is the issue? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
