Date/Time: Thu, 26 Nov 2026 04:57:46 +0000
Spread SPX ES
View Count: 313
| [2026-06-02 16:39:25] |
| User437588 - Posts: 93 |
Hallo Gibt es eine Möglichkeit sich den täglichen Spread zwischen ES und SPX anzeigen zulassen? Sei es im QuoteBoard als Wert z.BSp. 10P oder im Chart. Vor allem Außerbörslich wenn die Kasse noch geschlossen hat! Vielen Dank für eure Hilfe |
| [2026-06-02 16:44:19] |
From Google Translate: Hello,
Is there a way to display the daily spread between ES and SPX? Whether in the QuoteBoard—as a value, e.g., 10 points—or directly on the chart. I am particularly interested in seeing this during off-hours, when the cash market is still closed! Thank you very much for your help. Use the "Add Additional Symbol" to add the "SPX_CGI" symbol to an ES chart. Then use whatever study you prefer to get the ratio you want. Refer to the following to start: Using the Basic Arithmetic Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
