Date/Time: Thu, 26 Nov 2026 04:57:39 +0000
[Programming Help] - Rithmic problem
View Count: 282
| [2026-06-01 17:04:16] |
| Topdog33 - Posts: 44 |
Hi John, so I’m having a discrepancy between what is showing on my actual RT trader as far as the PNL and what is showing on Sierra chart. On Sierra chart it’s showing 60 points profit but on RT trader it’s showing only $600. Kindly advise.
| [2026-06-01 19:06:04] |
If you are asking about the display of Points versus Currency for a chart, then refer to the following: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) If the 60 points of profit is incorrect, then refer to the following: Help With Daily Profit/Loss Value: Simplified Steps to Solve Incorrect Daily Profit/Loss If it's something else, then we need more information on exactly the problem and what you are seeing and what you expect to see. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-01 22:00:22] |
Problem solved thank you brother
