Date/Time: Tue, 03 Nov 2026 17:43:12 +0000
Rithmic data issue
View Count: 505
| [2026-06-01 05:39:35] |
| User710679 - Posts: 45 |
Hi, i have an issue with real time data. I have the denali feed activated, and allow support for sierra chart data feeds is set to yes. However, i am not receiving real time data for NQ or ES. i am attaching here the service log as well. Any idea what is happening. Last week was working perfect. thanks
| [2026-06-01 06:13:34] |
| Sierra_Chart Engineering - Posts: 25362 |
This is the problem: 2026-06-01 01:38:06.027 | External Service | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
Refer to: Denali Exchange Data Feed: Connections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-06-01 06:14:28
| [2026-06-01 11:10:43] |
| User252436 - Posts: 5 |
Hello. I have a problem .... it is not connecting anymore. I don't know why...maybe I have deleted any files or what I have also attached the message that I get. Look forward to your reply |
Attachment Deleted. Private File Private File |
| [2026-06-01 16:34:17] |
| John - SC Support - Posts: 48408 |
User252436: We need to see your entire Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-01 17:04:58] |
2026-06-01 09:12:49.151 | Trade activity files set size: 1887 2026-06-01 09:12:49.157 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:12:49.241 | Created the DTC Protocol server. 2026-06-01 09:12:49.242 | DTC Protocol Server listening on port 11099. Address: 0.0.0.0 2026-06-01 09:12:49.242 | Reading Internal Order ID file. 2026-06-01 09:12:49.244 | Reading Trade Orders file. 2026-06-01 09:12:49.245 | Reading Trade Positions file. 2026-06-01 09:12:49.246 | Reading Trade Account Data files. 2026-06-01 09:12:49.257 | Software version: 2897 64-bit 2026-06-01 09:12:49.257 | Primary Thread ID: 13380 2026-06-01 09:12:49.257 | Usage end date: 2026-06-18 2026-06-01 09:12:49.257 | Enabled for: Advanced Features 2. 2026-06-01 09:12:49.257 | Enabled for: Sierra Chart Historical Data Service. 2026-06-01 09:12:49.257 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-06-01 09:12:49.257 | Enabled for: Delayed Denali Exchange Data Feed. 2026-06-01 09:12:49.257 | Enabled for exchange2: CME (Trading Account Required) 2026-06-01 09:12:49.257 | Enabled for exchange2: CBOT (Trading Account Required) 2026-06-01 09:12:49.257 | Enabled for exchange2: COMEX (Trading Account Required) 2026-06-01 09:12:49.257 | Enabled for exchange2: NYMEX (Trading Account Required) 2026-06-01 09:12:49.257 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-06-01 09:12:49.257 | Current selected Data/Trading service: Rithmic Direct - DTC 2026-06-01 09:12:49.257 | Custom symbol settings values: disabled 2026-06-01 09:12:49.257 | Chart Update Interval: 50 2026-06-01 09:12:49.257 | Intraday Data Storage Time Unit: 0 2026-06-01 09:12:49.257 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2026-06-01 09:12:49.257 | 2026-06-01 13:12:49 Local computer time in UTC 2026-06-01 09:12:49.257 | 2026-06-01 09:12:49 Local computer time in SC Time Zone 2026-06-01 09:12:49.257 | 2026-06-01 13:12:41 Server time in UTC 2026-06-01 09:12:49.257 | Local computer UTC time and Server UTC time difference: 1 seconds. 2026-06-01 09:12:49.257 | Program path: C:\SierraChart\Data\ 2026-06-01 09:12:49.257 | Data Files path: C:\SierraChart\Data\Data\ 2026-06-01 09:12:49.257 | OS Version Number: 10.0 2026-06-01 09:12:49.257 | Locale Setting: C 2026-06-01 09:12:49.257 | Crash reporter started: false 2026-06-01 09:12:49.257 | 2026-06-01 09:12:49.270 | Created the DTC Protocol historical data server. 2026-06-01 09:12:49.272 | HD Server Manager | Listening on port 11098. 2026-06-01 09:12:49.272 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. 2026-06-01 09:12:49.274 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 09:12:49.365 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. 2026-06-01 09:12:49.365 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 2026-06-01 09:12:49.365 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. 2026-06-01 09:12:49.400 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2026-06-01 09:12:49.400 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2026-06-01 09:12:49.686 | Received 5 login tokens. 2026-06-01 09:12:50.036 | Symbol settings MD5 received. Request ID: 1. 2026-06-01 09:12:50.036 | Requested symbol settings for service code rithmic_v2.trading. Request ID: 2. 2026-06-01 09:12:50.758 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:12:50.759 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:12:50.826 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:12:50.826 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call. 2026-06-01 09:12:50.826 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:12:50.826 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed. 2026-06-01 09:12:51.154 | Symbol settings received. Request ID: 2. 2026-06-01 09:12:51.785 | Requested user files to download. 2026-06-01 09:12:52.453 | File to download: OrderflowTriggers2_64.dll. Action: 1 2026-06-01 09:12:52.493 | File to download: OrderFlowLabs.com.free_64.dll. Action: 1 2026-06-01 09:12:52.532 | File to download: OrderFlowLabs.com.free_ARM64.dll. Action: 1 2026-06-01 09:12:52.544 | File to download: LOHPHOLP_64.dll. Action: 1 2026-06-01 09:12:52.566 | File to download: GoogleSheetsImporter_64.dll. Action: 1 2026-06-01 09:12:52.592 | File to download: FlowTriggers_64.dll. Action: 1 2026-06-01 09:12:52.616 | File to download: DeltaFlipSignals_64.dll. Action: 1 2026-06-01 09:12:52.648 | File to download: CheckAccount_64.dll. Action: 1 2026-06-01 09:12:52.680 | File to download: BreakScanner_64.dll. Action: 1 2026-06-01 09:12:52.711 | File to download: ABSindi_64.dll. Action: 1 2026-06-01 09:12:52.745 | User files to download complete 2026-06-01 09:12:53.799 | 2026-06-01 09:12:53.799 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:12:53.799 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:12:53.800 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:12:53.800 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:12:53.800 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:12:53.814 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:12:53.814 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:12:53.814 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:12:57.021 | Files to Open on Startup | Opening file: ExampleChartbook.cht 2026-06-01 09:12:57.077 | ESM6.CME #2 | Reloading chart. 2026-06-01 09:12:57.119 | ESM5.CME 30 Min #10 | Reloading chart. 2026-06-01 09:12:57.173 | MESM6.CME [CBV] #5 | Reloading chart. 2026-06-01 09:12:57.174 | Starting DelayedDownloadMonitoringTimer 2026-06-01 09:12:57.174 | Starting HDTimeoutTimer 2026-06-01 09:12:57.174 | Added historical Intraday data request for MESM6.CME to the queue. 2026-06-01 09:12:57.174 | Triggering next historical data download in queue. 2026-06-01 09:12:57.192 | MESM6.CME [CBV] #5 | Waiting for historical downloads to complete with the IDs: 1, 2026-06-01 09:12:57.217 | ESM6.CME [CBV] #6 | Reloading chart. 2026-06-01 09:12:57.218 | Added historical Intraday data request for ESM6.CME to the queue. 2026-06-01 09:12:57.237 | ESM6.CME [CBV] #6 | Waiting for historical downloads to complete with the IDs: 2, 2026-06-01 09:12:57.281 | Loading DLL: C:\SierraChart\Data\Data\Zyp Free by Zyp.dll (Zyp Free by Zyp_64.dll). Handle: 7ff928490000 2026-06-01 09:12:57.308 | Loading DLL: C:\SierraChart\Data\Data\D.ATR.dll (D.ATR_64.dll). Handle: 66000000 2026-06-01 09:12:57.332 | Loading DLL: C:\SierraChart\Data\Data\BBDynamicSR.dll (BBDynamicSR_64.dll). Handle: 8d40000 2026-06-01 09:12:57.368 | Loading DLL: C:\SierraChart\Data\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ff8f0740000 2026-06-01 09:12:57.390 | ESM6.CME [CBV] 5000 Volume #7 | Reloading chart. 2026-06-01 09:12:57.414 | ESM6.CME [CBV] 5000 Volume #7 | Waiting for historical downloads to complete with the IDs: 2, 2026-06-01 09:12:57.605 | ESM6.CME [C] Renko 8t #21 | Reloading chart. 2026-06-01 09:12:57.606 | ESM6.CME [C] Renko 8t #21 | Waiting for historical downloads to complete with the IDs: 2, 2026-06-01 09:12:57.636 | ESM6.CME Renko 8t #4 | Reloading chart. 2026-06-01 09:12:57.665 | ESM6.CME 3.00 Range #24 | Reloading chart. 2026-06-01 09:12:57.703 | Loading DLL: C:\SierraChart\Data\Data\volume_initiative.dll (volume_initiative_64.dll). Handle: f550000 2026-06-01 09:12:57.741 | Loading DLL: C:\SierraChart\Data\Data\Full_VZscore.dll (Full_VZscore_64.dll). Handle: f640000 2026-06-01 09:12:57.748 | Loading DLL: C:\SierraChart\Data\Data\DeltaFlipSignals.dll (DeltaFlipSignals_64.dll). Handle: f730000 2026-06-01 09:12:57.788 | ESM6.CME/MESM6.CME [CBV] 2 Min #3 | Reloading chart. 2026-06-01 09:12:57.813 | ESM6.CME/MESM6.CME [CBV] 2 Min #3 | Waiting for historical downloads to complete with the IDs: 2, 2026-06-01 09:12:58.052 | Loading DLL: C:\SierraChart\Data\Data\Zyp RTH Discord 7.dll (Zyp RTH Discord 7.dll). Handle: 7ff94a950000 2026-06-01 09:12:58.085 | ESM6.CME [CBV] 2 Min #11 | Reloading chart. 2026-06-01 09:12:58.119 | ESM6.CME [CBV] 2 Min #11 | Waiting for historical downloads to complete with the IDs: 2, 2026-06-01 09:12:58.190 | Loading DLL: C:\SierraChart\Data\Data\gcUserStudies.dll (gcUserStudies_2500_64.dll). Handle: 7ff9283a0000 2026-06-01 09:12:58.246 | ESM6.CME #13 | Reloading chart. 2026-06-01 09:12:58.311 | ESM6.CME #14 | Reloading chart. 2026-06-01 09:12:58.376 | ESM6.CME #17 | Reloading chart. 2026-06-01 09:12:58.431 | Loading DLL: C:\SierraChart\Data\Data\BookmapBubbles.dll (BookmapBubbles_64.dll). Handle: 11210000 2026-06-01 09:12:58.471 | ESM6.CME 2.00 Range #12 | Reloading chart. 2026-06-01 09:12:58.514 | ESM6.CME Renko 8t #16 | Reloading chart. 2026-06-01 09:12:58.556 | ESM6.CME Renko 8t #18 | Reloading chart. 2026-06-01 09:12:58.569 | Loading DLL: C:\SierraChart\Data\Data\ABSindi.dll (ABSindi_64.dll). Handle: 13f50000 2026-06-01 09:12:58.579 | Loading market depth data. 2026-06-01 09:12:58.582 | Loading DLL: C:\SierraChart\Data\Data\OrderFlowLabs.com.free.dll (OrderFlowLabs.com.free_64.dll). Handle: 7ff9281f0000 2026-06-01 09:12:58.582 | Loaded depth data records for ESM6.CME 2026-05-30 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:12:58.583 | The custom study OrderFlowLabs.com.free.dll requires version 2911 or higher of Sierra Chart. Current version: 2897. Select 'Help >> Download Current Version'. * 2026-06-01 09:12:58.627 | Loading DLL: C:\SierraChart\Data\Data\Trap&ABS-TradingEdgeResources.dll (Trap&ABS-TradingEdgeResources_64.dll). Handle: 14240000 2026-06-01 09:12:58.645 | Loaded depth data records for ESM6.CME 2026-05-31 from 2026-05-31 08:00:06.017000 to 2026-05-31 19:59:59.997000. 2026-06-01 09:12:58.678 | ESM6.CME 1250 Volume #19 | Reloading chart. 2026-06-01 09:12:59.063 | ESM6.CME 2000 Volume #22 | Reloading chart. 2026-06-01 09:12:59.092 | Loaded depth data records for ESM6.CME 2026-06-01 from 2026-05-31 20:00:00.004000 to 2026-06-01 06:32:34.221000. 2026-06-01 09:12:59.153 | Loading DLL: C:\SierraChart\Data\Data\MomoVolatility.dll (MomoVolatility_64.dll). Handle: ac10000 2026-06-01 09:12:59.196 | ESM6.CME [CBV] 1500 Trades #23 | Reloading chart. 2026-06-01 09:12:59.234 | ESM6.CME [CBV] 1500 Trades #23 | Waiting for historical downloads to complete with the IDs: 2, 2026-06-01 09:12:59.245 | Loading DLL: C:\SierraChart\Data\Data\CheckAccount.dll (CheckAccount_64.dll). Handle: ae50000 2026-06-01 09:12:59.327 | Loading DLL: C:\SierraChart\Data\Data\STOBTOTriggers.dll (STOBTOTriggers_64.dll). Handle: b130000 2026-06-01 09:12:59.342 | Loading DLL: C:\SierraChart\Data\Data\GoogleSheetsImporter.dll (GoogleSheetsImporter_64.dll). Handle: c1f0000 2026-06-01 09:12:59.436 | ESM6.CME/MESM6.CME [CBV] Renko 8t #25 | Reloading chart. 2026-06-01 09:12:59.543 | ESM6.CME/MESM6.CME [CBV] Renko 8t #25 | Waiting for historical downloads to complete with the IDs: 2, 2026-06-01 09:12:59.735 | MESM6.CME Renko 6t #28 | Reloading chart. 2026-06-01 09:13:00.592 | ESM6.CME Renko 8t #9 | Reloading chart. 2026-06-01 09:13:00.695 | ESM6.CME 1250 Volume #15 | Reloading chart. 2026-06-01 09:13:01.048 | MESM6.CME [CBV] #1 | Reloading chart. 2026-06-01 09:13:01.105 | MESM6.CME [CBV] #1 | Waiting for historical downloads to complete with the IDs: 1, 2026-06-01 09:13:01.160 | ESM5.CME 30 Min #10 | Chart data loading complete. 2026-06-01 09:13:01.188 | Mapping MESM6.CME to MESM26. Service code: cme 2026-06-01 09:13:01.188 | Using symbol data fast lookup vector 2026-06-01 09:13:01.189 | HD Request # 1 | Downloading Intraday chart data for MESM6.CME to the file MESM6.CME.scid. Service: cme 2026-06-01 09:13:01.191 | HD Request # 1 | Download start date-time: 2026-06-01 06:32:34.000000. File last date-time: 2026-06-01 06:32:34.329000 2026-06-01 09:13:01.192 | HD Request # 1 | Using server: ds28.sierracharts.com port 10150 2026-06-01 09:13:01.301 | 2026-06-01 09:13:01.302 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:13:01.302 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:13:01.302 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:13:01.302 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:13:01.302 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:01.328 | Socket (1) | Creating socket. 2026-06-01 09:13:01.328 | Socket (1) | New receive buffer size: 0 2026-06-01 09:13:01.328 | Socket (1) | Connecting to IP: 67.214.125.5. 2026-06-01 09:13:01.340 | ESM6.CME #13 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:01.357 | ESM6.CME #13 | Chart data loading complete. 2026-06-01 09:13:01.362 | ESM6.CME #14 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:01.363 | ESM6.CME #14 | Chart data loading complete. 2026-06-01 09:13:01.375 | ESM6.CME #17 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:01.397 | ESM6.CME #17 | Chart data loading complete. 2026-06-01 09:13:01.462 | ESM6.CME 2.00 Range #12 | Chart data loading complete. 2026-06-01 09:13:01.588 | ESM6.CME 3.00 Range #24 | Chart data loading complete. 2026-06-01 09:13:01.599 | MESM6.CME Renko 6t #28 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:01.612 | MESM6.CME Renko 6t #28 | Chart data loading complete. 2026-06-01 09:13:01.613 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:13:01.613 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:13:01.613 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:01.646 | Chart #14 has tagged chart #24 for full recalculation. Chartbook: ExampleChartbook.cht 2026-06-01 09:13:01.676 | HD Request # 1 | Setting DTC encoding to Binary VLS 2026-06-01 09:13:01.676 | HD Request # 1 | Sending historical data logon request message. 2026-06-01 09:13:01.840 | Mapping ESM6.CME to ESM26. Service code: cme 2026-06-01 09:13:01.840 | Mapping ESM5.CME to ESM25. Service code: cme 2026-06-01 09:13:01.841 | Added historical Intraday data request for ESM5.CME to the queue. 2026-06-01 09:13:01.841 | Intraday data recording state for symbol ESM5.CME is set to download 'Pending'. 2026-06-01 09:13:01.841 | Triggering next historical data download in queue. 2026-06-01 09:13:02.008 | HD Request # 1 | Requesting Intraday data. Start date-time: 2026-06-01 06:32:34. Record interval: 0. Symbol: MESM26 2026-06-01 09:13:02.133 | ESM6.CME[M] Renko 8t #18 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:02.143 | ESM6.CME[M] Renko 8t #18 | Chart data loading complete. 2026-06-01 09:13:02.238 | HD Request # 1 | Decompressing data. 2026-06-01 09:13:02.239 | HD Request # 1 | Receiving Intraday data for MESM6.CME starting at 2026-06-01 06:32:34.285000 2026-06-01 09:13:02.931 | HD Request # 1 | Timestamp of first Intraday data file record written: 2026-06-01 06:32:35.349000. 2026-06-01 09:13:03.070 | Socket (1) | CloseSocket call. 2026-06-01 09:13:03.070 | Historical data download thread signaled to stop. 2026-06-01 09:13:03.071 | HD Request # 1 | Received 50331 Intraday data records from 2026-06-01 06:32:34.285000 to 2026-06-01 09:13:01.600000 (2.7 hours. Delay: 1.5 seconds) and wrote 50328 records for MESM6.CME 2026-06-01 09:13:03.071 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-06-01 09:13:03.077 | HD Request # 1 | Completion time: 2s. 2026-06-01 09:13:03.077 | HD Request # 1 | Intraday data download complete for MESM6.CME. Unique request ID: 1 2026-06-01 09:13:03.077 | Removing historical data download ID 1. 2026-06-01 09:13:03.077 | Real-time Intraday chart data file updates started for MESM6.CME 2026-06-01 09:13:03.077 | Intraday chart data file opened for MESM6.CME 2026-06-01 09:13:03.077 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2026-06-01 09:13:03.077 | 2026-06-01 09:13:03.077 | Triggering next historical data download in queue. 2026-06-01 09:13:03.077 | Historical data for MESM6.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2026-06-01 09:13:03.077 | HD Request # 2 | Downloading Intraday chart data for ESM6.CME to the file ESM6.CME.scid. Service: cme 2026-06-01 09:13:03.104 | HD Request # 2 | Download start date-time: 2026-06-01 06:32:34.000000. File last date-time: 2026-06-01 06:32:34.221001 2026-06-01 09:13:03.104 | HD Request # 2 | Using server: ds32.sierracharts.com port 10149 2026-06-01 09:13:03.136 | MESM6.CME [CBV] #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-06-01 09:13:03.137 | MESM6.CME [CBV] #1 | Reloading chart. 2026-06-01 09:13:03.169 | MESM6.CME [CBV] #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-06-01 09:13:03.182 | MESM6.CME [CBV] #5 | Reloading chart. 2026-06-01 09:13:03.207 | MESM6.CME [CBV] #1 | Reloading chart. 2026-06-01 09:13:03.214 | Socket (1) | Socket gracefully closed by remote side. 2026-06-01 09:13:03.214 | Socket (1) | Closed. 2026-06-01 09:13:03.254 | MESM6.CME [CBV] #5 | Reloading chart. 2026-06-01 09:13:03.262 | Socket (2) | Creating socket. 2026-06-01 09:13:03.262 | Socket (2) | New receive buffer size: 0 2026-06-01 09:13:03.262 | Socket (2) | Connecting to IP: 69.39.70.248. 2026-06-01 09:13:03.586 | HD Request # 2 | Setting DTC encoding to Binary VLS 2026-06-01 09:13:03.586 | HD Request # 2 | Sending historical data logon request message. 2026-06-01 09:13:03.851 | HD Request # 2 | Requesting Intraday data. Start date-time: 2026-06-01 06:32:34. Record interval: 0. Symbol: ESM26 2026-06-01 09:13:04.066 | HD Request # 2 | Decompressing data. 2026-06-01 09:13:04.105 | HD Request # 2 | Receiving Intraday data for ESM6.CME starting at 2026-06-01 06:32:34.221000 2026-06-01 09:13:04.854 | HD Request # 2 | Timestamp of first Intraday data file record written: 2026-06-01 06:32:39.609000. 2026-06-01 09:13:05.119 | : Array is unallocated. | Number times message added: 1 2026-06-01 09:13:05.130 | Socket (2) | CloseSocket call. 2026-06-01 09:13:05.130 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-06-01 09:13:05.130 | Historical data download thread signaled to stop. 2026-06-01 09:13:05.136 | HD Request # 2 | Received 63357 Intraday data records from 2026-06-01 06:32:34.221000 to 2026-06-01 09:13:04.160000 (2.7 hours. Delay: 1.0 seconds) and wrote 63355 records for ESM6.CME 2026-06-01 09:13:05.180 | HD Request # 2 | Completion time: 2s. 2026-06-01 09:13:05.180 | HD Request # 2 | Intraday data download complete for ESM6.CME. Unique request ID: 2 2026-06-01 09:13:05.180 | Removing historical data download ID 2. 2026-06-01 09:13:05.180 | Real-time Intraday chart data file updates started for ESM6.CME 2026-06-01 09:13:05.180 | Intraday chart data file opened for ESM6.CME 2026-06-01 09:13:05.180 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2026-06-01 09:13:05.180 | 2026-06-01 09:13:05.180 | Triggering next historical data download in queue. 2026-06-01 09:13:05.180 | Historical data for ESM6.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2026-06-01 09:13:05.180 | HD Request # 3 | Downloading Intraday chart data for ESM5.CME to the file ESM5.CME.scid. Service: cme 2026-06-01 09:13:05.181 | HD Request # 3 | Download start date-time: 2025-06-20 09:29:59.000000. File last date-time: 2025-06-20 09:29:59.576000 2026-06-01 09:13:05.181 | HD Request # 3 | Using server: ds26.sierracharts.com port 10150 2026-06-01 09:13:05.258 | Socket (1) | Creating socket. 2026-06-01 09:13:05.258 | Socket (1) | New receive buffer size: 0 2026-06-01 09:13:05.258 | Socket (1) | Connecting to IP: 64.152.155.17. 2026-06-01 09:13:05.290 | Socket (2) | Socket gracefully closed by remote side. 2026-06-01 09:13:05.290 | Socket (2) | Closed. 2026-06-01 09:13:05.313 | ESM6.CME[M] Renko 8t #16 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:05.319 | ESM6.CME[M] Renko 8t #16 | Chart data loading complete. 2026-06-01 09:13:05.322 | ESM6.CME/MESM6.CME [CBV] Renko 8t #25 | Download is complete for all contract months in chart. Proceeding with data load. 2026-06-01 09:13:05.352 | ESM6.CME/MESM6.CME [CBV] Renko 8t #25 | Reloading chart. 2026-06-01 09:13:05.359 | ESM6.CME [C] Renko 8t #21 | Download is complete for all contract months in chart. Proceeding with data load. 2026-06-01 09:13:05.385 | ESM6.CME [C] Renko 8t #21 | Reloading chart. 2026-06-01 09:13:05.505 | : Array is unallocated. | Number times message added: 1 2026-06-01 09:13:05.506 | ESM6.CME [CBV] #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-06-01 09:13:05.507 | ESM6.CME [CBV] #6 | Reloading chart. 2026-06-01 09:13:05.516 | ESM6.CME [CBV] 5000 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load. 2026-06-01 09:13:05.517 | ESM6.CME [CBV] 5000 Volume #7 | Reloading chart. 2026-06-01 09:13:05.519 | ESM6.CME/MESM6.CME [CBV] 2 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2026-06-01 09:13:05.521 | ESM6.CME/MESM6.CME [CBV] 2 Min #3 | Reloading chart. 2026-06-01 09:13:05.591 | ESM6.CME [CBV] 2 Min #11 | Download is complete for all contract months in chart. Proceeding with data load. 2026-06-01 09:13:05.592 | ESM6.CME [CBV] 2 Min #11 | Reloading chart. 2026-06-01 09:13:05.639 | 2026-06-01 09:13:05.639 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:13:05.639 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:13:05.639 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:13:05.639 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:13:05.639 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:05.642 | ESM6.CME [CBV] 1500 Trades #23 | Download is complete for all contract months in chart. Proceeding with data load. 2026-06-01 09:13:05.681 | HD Request # 3 | Setting DTC encoding to Binary VLS 2026-06-01 09:13:05.681 | HD Request # 3 | Sending historical data logon request message. 2026-06-01 09:13:05.690 | ESM6.CME [CBV] 1500 Trades #23 | Reloading chart. 2026-06-01 09:13:05.819 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:13:05.819 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:13:05.819 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:05.823 | Starting DelayedDownloadMonitoringTimer 2026-06-01 09:13:05.823 | Starting HDTimeoutTimer 2026-06-01 09:13:05.823 | Added historical Market Depth data request for ESM6.CME to the queue. 2026-06-01 09:13:05.823 | Market depth data recording state for symbol ESM6.CME is set to download 'Pending'. 2026-06-01 09:13:05.824 | Triggering next historical data download in queue. 2026-06-01 09:13:05.824 | HD Request # 4 | Downloading Market Depth data for ESM6.CME. Service: cme.marketdepth. 2026-06-01 09:13:05.928 | HD Request # 4 | Download start date-time: 2026-06-01 06:32:42.664000. 2026-06-01 09:13:05.928 | HD Request # 4 | Using server: ds37.sierracharts.com port 10150 2026-06-01 09:13:06.014 | Socket (2) | Creating socket. 2026-06-01 09:13:06.014 | HD Request # 3 | Requesting Intraday data. Start date-time: 2025-06-20 09:29:59. Record interval: 0. Symbol: ESM25 2026-06-01 09:13:06.014 | Socket (2) | New receive buffer size: 0 2026-06-01 09:13:06.014 | Socket (2) | Connecting to IP: 4.8.175.92. 2026-06-01 09:13:06.061 | ESM6.CME/MESM6.CME [CBV] Renko 8t #25 | Reloading chart. 2026-06-01 09:13:06.156 | ESM6.CME [C] Renko 8t #21 | Reloading chart. 2026-06-01 09:13:06.210 | ESM6.CME/MESM6.CME [CBV] 2 Min #3 | Reloading chart. 2026-06-01 09:13:06.310 | HD Request # 3 | Decompressing data. 2026-06-01 09:13:06.450 | ESM6.CME [CBV] 5000 Volume #7 | Reloading chart. 2026-06-01 09:13:06.561 | HD Request # 3 | Receiving Intraday data for ESM5.CME starting at 2025-06-20 09:29:59.576000 2026-06-01 09:13:06.561 | Socket (1) | CloseSocket call. 2026-06-01 09:13:06.609 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-06-01 09:13:06.609 | HD Request # 4 | Setting DTC encoding to Binary VLS 2026-06-01 09:13:06.609 | HD Request # 4 | Sending historical data logon request message. 2026-06-01 09:13:06.629 | Historical data download thread signaled to stop. 2026-06-01 09:13:06.629 | HD Request # 3 | Received 1 Intraday data record from 2025-06-20 09:29:59.576000 to 2025-06-20 09:29:59.576000 (0.0 seconds. Delay: 346.0 days) and wrote 0 records for ESM5.CME 2026-06-01 09:13:06.629 | HD Request # 3 | Completion time: 1s. 2026-06-01 09:13:06.629 | HD Request # 3 | Intraday data download complete for ESM5.CME. Unique request ID: 3 2026-06-01 09:13:06.629 | Removing historical data download ID 3. 2026-06-01 09:13:06.629 | Real-time Intraday chart data file updates started for ESM5.CME 2026-06-01 09:13:06.629 | Intraday chart data file opened for ESM5.CME 2026-06-01 09:13:06.629 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2026-06-01 09:13:06.629 | 2026-06-01 09:13:06.629 | No download requests in the queue to start downloads for. 2026-06-01 09:13:06.629 | Historical data for ESM5.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2026-06-01 09:13:06.669 | ESM6.CME [CBV] #6 | Reloading chart. 2026-06-01 09:13:06.767 | ESM6.CME [CBV] 2 Min #11 | Reloading chart. 2026-06-01 09:13:06.894 | ESM6.CME [CBV] 1500 Trades #23 | Reloading chart. 2026-06-01 09:13:07.066 | Socket (1) | Socket gracefully closed by remote side. 2026-06-01 09:13:07.066 | Socket (1) | Closed. 2026-06-01 09:13:07.119 | HD Request # 4 | Requesting market depth data. Start date-time: 2026-06-01 06:32:42. Symbol: ESM26 2026-06-01 09:13:07.730 | HD Request # 4 | Decompressing data. 2026-06-01 09:13:07.731 | HD Request # 4 | Receiving market depth data for ESM6.CME starting at 2026-06-01 06:32:42.664000 2026-06-01 09:13:08.230 | HD Request # 4 | Timestamp of first market depth data file record written: 2026-06-01 06:32:42.664000. 2026-06-01 09:13:08.328 | ESM6.CME [CBV][M] #6 | Chart data loading complete. 2026-06-01 09:13:08.334 | ESM6.CME[M] Renko 8t #9 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:08.343 | ESM6.CME[M] Renko 8t #9 | Chart data loading complete. 2026-06-01 09:13:09.960 | 2026-06-01 09:13:09.961 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:13:09.961 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:13:09.961 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:13:09.961 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:13:09.961 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:10.003 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:13:10.003 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:13:10.003 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:10.279 | Loading market depth data. 2026-06-01 09:13:10.875 | ESM6.CME [C][M] Renko 8t #21 | Chart data loading complete. 2026-06-01 09:13:11.277 | Loading market depth data. 2026-06-01 09:13:11.344 | Loaded depth data records for ESM6.CME 2026-05-22 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:11.449 | ESM6.CME [CBV][M] 5000 Volume #7 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:11.457 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.6898, Ref: 7534.34, High: 7535.03, Low: 7533.65, YesterClose: 0.00 2026-06-01 09:13:11.458 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 1.3015, Ref: 7555.19, High: 7556.49, Low: 7553.89, YesterClose: 7484.12 2026-06-01 09:13:11.458 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.4821, Ref: 7538.99, High: 7539.48, Low: 7538.51, YesterClose: 7540.25 2026-06-01 09:13:11.458 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.5714, Ref: 7543.14, High: 7543.71, Low: 7542.56, YesterClose: 7541.75 2026-06-01 09:13:11.458 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.5727, Ref: 7515.52, High: 7516.09, Low: 7514.94, YesterClose: 7512.19 2026-06-01 09:13:11.458 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.5383, Ref: 7580.46, High: 7581.00, Low: 7579.93, YesterClose: 7582.81 2026-06-01 09:13:11.459 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.8393, Ref: 7591.52, High: 7592.36, Low: 7590.68, YesterClose: 0.00 2026-06-01 09:13:11.459 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 1.1250, Ref: 7615.62, High: 7616.75, Low: 7614.50, YesterClose: 7591.38 2026-06-01 09:13:11.493 | Loaded depth data records for ESM6.CME 2026-05-23 from 2026-05-23 00:18:21.792091 to 2026-05-23 16:00:28.133226. 2026-06-01 09:13:11.536 | Socket (2) | CloseSocket call. 2026-06-01 09:13:11.541 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-06-01 09:13:11.662 | ESM6.CME [CBV][M] 5000 Volume #7 | Chart data loading complete. 2026-06-01 09:13:11.665 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.6898, Ref: 7534.34, High: 7535.03, Low: 7533.65, YesterClose: 0.00 2026-06-01 09:13:11.665 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 1.3015, Ref: 7555.19, High: 7556.49, Low: 7553.89, YesterClose: 7484.12 2026-06-01 09:13:11.665 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.4821, Ref: 7538.99, High: 7539.48, Low: 7538.51, YesterClose: 7540.25 2026-06-01 09:13:11.665 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.5714, Ref: 7543.14, High: 7543.71, Low: 7542.56, YesterClose: 7541.75 2026-06-01 09:13:11.665 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.5727, Ref: 7515.52, High: 7516.09, Low: 7514.94, YesterClose: 7512.19 2026-06-01 09:13:11.665 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.5383, Ref: 7580.46, High: 7581.00, Low: 7579.93, YesterClose: 7582.81 2026-06-01 09:13:11.665 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.8393, Ref: 7591.52, High: 7592.36, Low: 7590.68, YesterClose: 0.00 2026-06-01 09:13:11.665 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 1.1250, Ref: 7615.62, High: 7616.75, Low: 7614.50, YesterClose: 7591.38 2026-06-01 09:13:11.708 | Socket (2) | Socket gracefully closed by remote side. 2026-06-01 09:13:11.708 | Socket (2) | Closed. 2026-06-01 09:13:11.726 | Loading market depth data. 2026-06-01 09:13:11.763 | Loaded depth data records for ESM6.CME 2026-05-24 from 2026-05-24 06:32:40.618559 to 2026-05-24 19:59:59.929000. 2026-06-01 09:13:11.855 | Historical data download thread signaled to stop. 2026-06-01 09:13:11.856 | HD Request # 4 | Received 699182 Market Depth data records from 2026-06-01 06:32:42.664000 to 2026-06-01 09:13:07.328000 (2.7 hours. Delay: 4.5 seconds) and wrote 699182 records for ESM6.CME 2026-06-01 09:13:11.886 | HD Request # 4 | Completion time: 6s. 2026-06-01 09:13:11.886 | HD Request # 4 | Market Depth data download complete for ESM6.CME. Unique request ID: 4 2026-06-01 09:13:11.886 | Removing historical data download ID 4. 2026-06-01 09:13:11.886 | ESM6.CME[M] #2 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME [CBV][M] #6 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME [CBV][M] 5000 Volume #7 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME [C][M] Renko 8t #21 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME[M] Renko 8t #4 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME[M] 3.00 Range #24 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME/MESM6.CME [CBV][M] 2 Min #3 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME [CBV][M] 2 Min #11 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME[M] #13 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME[M] #14 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME[M] #17 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME[M] Renko 8t #16 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME[M] Renko 8t #18 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME[M] 1250 Volume #19 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME[M] 2000 Volume #22 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME [CBV][M] 1500 Trades #23 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #25 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME[M] Renko 8t #9 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | ESM6.CME[M] 1250 Volume #15 | Flagging to reload Intraday data on market depth download completion. 2026-06-01 09:13:11.886 | 2026-06-01 09:13:11.886 | No download requests in the queue to start downloads for. 2026-06-01 09:13:11.986 | ESM6.CME[M] #2 | Reloading chart. 2026-06-01 09:13:11.988 | ESM6.CME[M] Renko 8t #4 | Reloading chart. 2026-06-01 09:13:11.991 | ESM6.CME [CBV][M] #6 | Reloading chart. 2026-06-01 09:13:12.137 | ESM6.CME[M] #17 | Reloading chart. 2026-06-01 09:13:12.222 | ESM6.CME[M] #13 | Reloading chart. 2026-06-01 09:13:12.229 | ESM6.CME[M] #14 | Reloading chart. 2026-06-01 09:13:12.239 | ESM6.CME[M] 3.00 Range #24 | Reloading chart. 2026-06-01 09:13:12.247 | ESM6.CME[M] Renko 8t #18 | Reloading chart. 2026-06-01 09:13:12.251 | ESM6.CME [CBV][M] 5000 Volume #7 | Reloading chart. 2026-06-01 09:13:12.669 | ESM6.CME[M] 2000 Volume #22 | Chart data loading complete. 2026-06-01 09:13:12.733 | ESM6.CME[M] #17 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:12.745 | ESM6.CME[M] #17 | Chart data loading complete. 2026-06-01 09:13:12.755 | ESM6.CME[M] #14 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:12.756 | ESM6.CME[M] #14 | Chart data loading complete. 2026-06-01 09:13:12.780 | ESM6.CME[M] #13 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:12.817 | ESM6.CME[M] #13 | Chart data loading complete. 2026-06-01 09:13:12.947 | ESM6.CME [CBV][M] 2 Min #11 | Reloading chart. 2026-06-01 09:13:13.052 | ESM6.CME [CBV][M] 1500 Trades #23 | Reloading chart. 2026-06-01 09:13:13.332 | ESM6.CME[M] 1250 Volume #19 | Reloading chart. 2026-06-01 09:13:13.355 | ESM6.CME[M] 2000 Volume #22 | Reloading chart. 2026-06-01 09:13:13.437 | ESM6.CME [C][M] Renko 8t #21 | Reloading chart. 2026-06-01 09:13:13.544 | ESM6.CME/MESM6.CME [CBV][M] 2 Min #3 | Reloading chart. 2026-06-01 09:13:13.660 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #25 | Reloading chart. 2026-06-01 09:13:14.309 | ESM6.CME[M] Renko 8t #16 | Reloading chart. 2026-06-01 09:13:14.330 | 2026-06-01 09:13:14.330 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:13:14.330 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:13:14.330 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:13:14.330 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:13:14.330 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:14.336 | ESM6.CME[M] Renko 8t #9 | Reloading chart. 2026-06-01 09:13:14.346 | ESM6.CME[M] 1250 Volume #15 | Reloading chart. 2026-06-01 09:13:14.380 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:13:14.380 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:13:14.380 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:15.555 | Loaded depth data records for ESM6.CME 2026-05-26 from 2026-05-26 09:30:00.000000 to 2026-05-26 16:59:59.973000. 2026-06-01 09:13:16.793 | Loaded depth data records for ESM6.CME 2026-05-25 from 2026-05-24 20:00:00.002000 to 2026-05-25 19:59:59.988000. 2026-06-01 09:13:16.860 | ESM6.CME [CBV][M] #6 | Chart data loading complete. 2026-06-01 09:13:16.959 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #25 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:16.967 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #25 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:13:17.234 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #25 | Chart data loading complete. 2026-06-01 09:13:18.050 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #25 | Reloading chart. 2026-06-01 09:13:18.388 | 2026-06-01 09:13:18.389 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:13:18.389 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:13:18.389 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:13:18.389 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:13:18.389 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:18.404 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:13:18.404 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:13:18.404 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:18.631 | ESM6.CME[M] 3.00 Range #24 | Chart data loading complete. 2026-06-01 09:13:19.985 | ESM6.CME[M] Renko 8t #18 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:20.003 | ESM6.CME[M] Renko 8t #18 | Chart data loading complete. 2026-06-01 09:13:21.162 | ESM6.CME [C][M] Renko 8t #21 | Chart data loading complete. 2026-06-01 09:13:22.416 | 2026-06-01 09:13:22.417 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:13:22.417 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:13:22.417 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:13:22.417 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:13:22.417 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:22.433 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:13:22.433 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:13:22.433 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:23.801 | Loaded depth data records for ESM6.CME 2026-05-26 from 2026-05-25 20:00:00.001000 to 2026-05-26 19:59:59.875000. 2026-06-01 09:13:23.928 | ESM6.CME [CBV][M] 5000 Volume #7 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:23.930 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.6898, Ref: 7534.34, High: 7535.03, Low: 7533.65, YesterClose: 0.00 2026-06-01 09:13:23.930 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 1.3015, Ref: 7555.19, High: 7556.49, Low: 7553.89, YesterClose: 7484.12 2026-06-01 09:13:23.930 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.4821, Ref: 7538.99, High: 7539.48, Low: 7538.51, YesterClose: 7540.25 2026-06-01 09:13:23.930 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.5714, Ref: 7543.14, High: 7543.71, Low: 7542.56, YesterClose: 7541.75 2026-06-01 09:13:23.931 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.5727, Ref: 7515.52, High: 7516.09, Low: 7514.94, YesterClose: 7512.19 2026-06-01 09:13:23.931 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.5383, Ref: 7580.46, High: 7581.00, Low: 7579.93, YesterClose: 7582.81 2026-06-01 09:13:23.931 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.8393, Ref: 7591.52, High: 7592.36, Low: 7590.68, YesterClose: 0.00 2026-06-01 09:13:23.931 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 1.1250, Ref: 7615.62, High: 7616.75, Low: 7614.50, YesterClose: 7591.38 2026-06-01 09:13:24.133 | ESM6.CME [CBV][M] 5000 Volume #7 | Chart data loading complete. 2026-06-01 09:13:24.136 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.6898, Ref: 7534.34, High: 7535.03, Low: 7533.65, YesterClose: 0.00 2026-06-01 09:13:24.136 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 1.3015, Ref: 7555.19, High: 7556.49, Low: 7553.89, YesterClose: 7484.12 2026-06-01 09:13:24.136 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.4821, Ref: 7538.99, High: 7539.48, Low: 7538.51, YesterClose: 7540.25 2026-06-01 09:13:24.136 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.5714, Ref: 7543.14, High: 7543.71, Low: 7542.56, YesterClose: 7541.75 2026-06-01 09:13:24.137 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.5727, Ref: 7515.52, High: 7516.09, Low: 7514.94, YesterClose: 7512.19 2026-06-01 09:13:24.137 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.5383, Ref: 7580.46, High: 7581.00, Low: 7579.93, YesterClose: 7582.81 2026-06-01 09:13:24.137 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 0.8393, Ref: 7591.52, High: 7592.36, Low: 7590.68, YesterClose: 0.00 2026-06-01 09:13:24.137 | Chart: ESM6.CME [CBV][M] 5000 Volume #7 Heikin-Ashi | Study: D ATR Levels | ATR: 1.1250, Ref: 7615.62, High: 7616.75, Low: 7614.50, YesterClose: 7591.38 2026-06-01 09:13:24.566 | Loaded depth data records for ESM6.CME 2026-05-26 from 2026-05-26 00:00:00.003000 to 2026-05-26 19:59:59.875000. 2026-06-01 09:13:25.750 | ESM6.CME[M] Renko 8t #16 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:13:25.757 | ESM6.CME[M] Renko 8t #16 | Chart data loading complete. 2026-06-01 09:13:26.443 | 2026-06-01 09:13:26.443 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:13:26.443 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:13:26.443 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:13:26.443 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:13:26.443 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:26.458 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:13:26.458 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:13:26.458 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:28.161 | Loaded depth data records for ESM6.CME 2026-05-27 from 2026-05-27 09:30:00.000000 to 2026-05-27 16:59:59.865000. 2026-06-01 09:13:29.742 | Saved Chartbook: ExampleChartbook.cht. Time: 0.1736 seconds. 2026-06-01 09:13:29.777 | ESM6.CME #2 | Chart Data Loading Thread: Load canceled. 2026-06-01 09:13:29.797 | MESM6.CME [CBV] #5 | Chart Data Loading Thread: Load canceled. 2026-06-01 09:13:30.082 | ESM6.CME Renko 8t #4 | Chart Data Loading Thread: Load canceled. 2026-06-01 09:13:30.182 | Loaded depth data records for ESM6.CME 2026-05-27 from 2026-05-26 20:00:00.005000 to 2026-05-27 15:01:25.417000. 2026-06-01 09:13:30.183 | Loaded depth data records for ESM6.CME 2026-05-28 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.200 | Loaded depth data records for ESM6.CME 2026-05-29 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.201 | Loaded depth data records for ESM6.CME 2026-05-30 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.202 | Loaded depth data records for ESM6.CME 2026-05-31 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.203 | Loaded depth data records for ESM6.CME 2026-06-01 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.203 | ESM6.CME/MESM6.CME [CBV] 2 Min #3 | Chart Data Loading Thread: Load canceled. 2026-06-01 09:13:30.251 | Loaded depth data records for ESM6.CME 2026-05-28 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.253 | Loaded depth data records for ESM6.CME 2026-05-29 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.256 | Loaded depth data records for ESM6.CME 2026-05-30 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.256 | Loaded depth data records for ESM6.CME 2026-05-31 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.257 | Loaded depth data records for ESM6.CME 2026-06-01 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.257 | ESM6.CME [CBV] 2 Min #11 | Chart Data Loading Thread: Load canceled. 2026-06-01 09:13:30.410 | ESM6.CME 1250 Volume #19 | Chart Data Loading Thread: Load canceled. 2026-06-01 09:13:30.427 | ESM6.CME[M] 2000 Volume #22 | Chart Data Loading Thread: Load canceled. 2026-06-01 09:13:30.438 | Loaded depth data records for ESM6.CME 2026-05-27 from 2026-05-26 20:00:00.005000 to 2026-05-27 10:53:59.980000. 2026-06-01 09:13:30.438 | Loaded depth data records for ESM6.CME 2026-05-28 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.439 | Loaded depth data records for ESM6.CME 2026-05-29 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.440 | Loaded depth data records for ESM6.CME 2026-05-30 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.440 | Loaded depth data records for ESM6.CME 2026-05-31 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.441 | Loaded depth data records for ESM6.CME 2026-06-01 from 00:00:00.000000 to 00:00:00.000000. 2026-06-01 09:13:30.442 | ESM6.CME [CBV] 1500 Trades #23 | Chart Data Loading Thread: Load canceled. 2026-06-01 09:13:30.470 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #25 | Chart Data Loading Thread: Load canceled. 2026-06-01 09:13:30.647 | ESM6.CME[M] Renko 8t #9 | Chart Data Loading Thread: Load canceled. 2026-06-01 09:13:30.687 | ESM6.CME 1250 Volume #15 | Chart Data Loading Thread: Load canceled. 2026-06-01 09:13:30.699 | MESM6.CME [CBV] #1 | Chart Data Loading Thread: Load canceled. 2026-06-01 09:13:30.713 | 2026-06-01 09:13:30.713 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:13:30.713 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:13:30.713 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:13:30.713 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:13:30.713 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:30.739 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:13:30.739 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:13:30.739 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:13:34.216 | ESM5.CME 30 Min #1 | Reloading chart. 2026-06-01 09:13:34.239 | ESM5.CME 30 Min #2 | Reloading chart. 2026-06-01 09:13:34.264 | ESM6.CME #3 | Reloading chart. 2026-06-01 09:13:34.323 | ESM6.CME #10 | Reloading chart. 2026-06-01 09:13:34.399 | ESM6.CME [CBV] #13 | Reloading chart. 2026-06-01 09:13:34.485 | ESM6.CME/MESM6.CME [CBV] 3000 Volume #28 | Reloading chart. 2026-06-01 09:13:34.548 | Loading DLL: C:\SierraChart\Data\Data\BreakScanner.dll (BreakScanner_64.dll). Handle: ab20000 2026-06-01 09:13:34.607 | ESM6.CME [CBV] 3000 Volume #6 | Reloading chart. 2026-06-01 09:13:35.202 | Loading DLL: C:\SierraChart\Data\Data\LOHPHOLP.dll (LOHPHOLP_64.dll). Handle: e3c0000 2026-06-01 09:13:35.277 | ESM6.CME [CBV] 2 Min #22 | Reloading chart. 2026-06-01 09:13:35.380 | Loading DLL: C:\SierraChart\Data\Data\DeltaFlipSignals_64 (1).dll (DeltaFlipSignals_64 (1).dll). Handle: 10a90000 2026-06-01 09:13:35.411 | ESM6.CME/MESM6.CME [CBV] 3 Min #42 | Reloading chart. 2026-06-01 09:13:35.487 | ESM6.CME [C] 15 Min #23 | Reloading chart. 2026-06-01 09:13:35.893 | ESM6.CME/MESM6.CME [CBV] 10000 Volume #24 | Reloading chart. 2026-06-01 09:13:36.030 | ESM6.CME #20 | Reloading chart. 2026-06-01 09:13:36.134 | Loading DLL: C:\SierraChart\Data\Data\ColorThemeSwitcher.dll (ColorThemeSwitcher_64.dll). Handle: 13c40000 2026-06-01 09:13:36.262 | Loading DLL: C:\SierraChart\Data\Data\VolatilitySmartLevels.dll (VolatilitySmartLevels_64.dll). Handle: 13d30000 2026-06-01 09:13:36.302 | ESM6.CME/MESM6.CME 15 Min #9 | Reloading chart. 2026-06-01 09:13:36.346 | ESM5.CME 30 Min #29 | Reloading chart. 2026-06-01 09:13:36.387 | ESM5.CME 30 Min #30 | Reloading chart. 2026-06-01 09:13:36.536 | ESM6.CME [CBV] #15 | Reloading chart. 2026-06-01 09:13:36.723 | ESM6.CME [CBV] #7 | Reloading chart. 2026-06-01 09:13:37.082 | ESM6.CME/MESM6.CME [CBV] Renko 8t #8 | Reloading chart. 2026-06-01 09:13:37.867 | Loading DLL: C:\SierraChart\Data\Data\Zyp RTH Discord 4.dll (Zyp RTH Discord 4.dll). Handle: 7ff97b9b0000 2026-06-01 09:13:37.962 | ESM6.CME [CB] 5 Min #38 | Reloading chart. 2026-06-01 09:13:39.519 | ESM6.CME [CBV] 30 Min #54 | Reloading chart. 2026-06-01 09:13:39.814 | ESM6.CME [CBV] 30 Min #55 | Reloading chart. 2026-06-01 09:13:39.891 | Loading market depth data. 2026-06-01 09:13:40.170 | Loaded depth data records for ESM6.CME 2026-05-25 from 2026-05-25 18:00:00.000000 to 2026-05-25 19:59:59.988000. 2026-06-01 09:13:40.332 | MESM6.CME Renko 8t #4 | Reloading chart. 2026-06-01 09:13:40.590 | ESM6.CME/MESM6.CME [CBV] 3 Min #17 | Reloading chart. 2026-06-01 09:13:41.075 | ESM6.CME 2 Min #21 | Reloading chart. 2026-06-01 09:13:41.731 | ESM6.CME 3000 Volume #25 | Reloading chart. 2026-06-01 09:13:41.946 | ESM6.CME Renko 8t #14 | Reloading chart. 2026-06-01 09:13:42.480 | ESM6.CME/MESM6.CME [CBV] Renko 8t #32 | Reloading chart. 2026-06-01 09:13:43.068 | Loading DLL: C:\SierraChart\Data\Data\Zyp RTH Discord 18.dll (Zyp RTH Discord 18.dll). Handle: 7ff97b980000 2026-06-01 09:13:43.212 | Loading market depth data. | Number times message added: 1 2026-06-01 09:13:43.377 | ESM6.CME [CBV] 3 Min #33 | Reloading chart. 2026-06-01 09:13:43.694 | Loaded depth data records for ESM6.CME 2026-05-25 from 2026-05-25 16:00:00.000000 to 2026-05-25 19:59:59.988000. 2026-06-01 09:13:43.877 | Loaded depth data records for ESM6.CME 2026-05-25 from 2026-05-25 18:00:00.000000 to 2026-05-25 19:59:59.988000. 2026-06-01 09:13:43.971 | MESM6.CME Renko 6t #12 | Reloading chart. 2026-06-01 09:13:44.798 | ESM6.CME/MESM6.CME [CBV] Renko 8t #19 | Reloading chart. 2026-06-01 09:13:46.991 | NQM6.CME/MNQM6.CME [CBV] Renko 24t #18 | Reloading chart. 2026-06-01 09:13:46.994 | Added historical Intraday data request for NQM6.CME to the queue. 2026-06-01 09:13:46.994 | Triggering next historical data download in queue. 2026-06-01 09:13:47.457 | Loaded depth data records for ESM6.CME 2026-05-26 from 2026-05-25 20:00:00.001000 to 2026-05-26 19:59:59.875000. 2026-06-01 09:13:47.996 | NQM6.CME/MNQM6.CME [CBV] Renko 24t #18 | Waiting for historical downloads to complete with the IDs: 5, 2026-06-01 09:13:48.992 | ESM6.CME #34 | Reloading chart. 2026-06-01 09:13:50.598 | MESM6.CME [CV] #37 | Reloading chart. 2026-06-01 09:13:50.742 | MESM6.CME [CV] #37 | StartDateTimeForLoadingOrderFills: 2026-05-31 15:00:00 2026-06-01 09:13:50.778 | MESM6.CME [CV] #37 | Chart data loading complete. 2026-06-01 09:13:51.355 | MESM6.CME [CV] #31 | Reloading chart. 2026-06-01 09:13:51.502 | MESM6.CME [CV] #31 | StartDateTimeForLoadingOrderFills: 2026-05-31 15:00:00 2026-06-01 09:13:51.722 | MESM6.CME [CV] #31 | Chart data loading complete. 2026-06-01 09:13:52.000 | Loading DLL: C:\SierraChart\Data\Data\OrderflowTriggers2.dll (OrderflowTriggers2_64.dll). Handle: 1c260000 2026-06-01 09:13:52.570 | ESM6.CME/MESM6.CME [CBV] 3000 Volume #16 | Reloading chart. 2026-06-01 09:13:53.282 | Loaded depth data records for ESM6.CME 2026-05-26 from 2026-05-25 20:00:00.001000 to 2026-05-26 19:59:59.875000. 2026-06-01 09:13:56.398 | ESM6.CME/MESM6.CME [CBV] 2500 Volume #5 | Reloading chart. 2026-06-01 09:13:59.540 | Loaded depth data records for ESM6.CME 2026-05-27 from 2026-05-26 20:00:00.005000 to 2026-05-27 19:59:59.985000. 2026-06-01 09:13:59.700 | ESM6.CME #35 | Reloading chart. 2026-06-01 09:14:01.193 | Loaded depth data records for ESM6.CME 2026-05-26 from 2026-05-25 20:00:00.001000 to 2026-05-26 19:59:59.875000. 2026-06-01 09:14:01.345 | ESM6.CME Renko 6t #26 | Reloading chart. 2026-06-01 09:14:02.213 | ESM6.CME 2500 Volume #27 | Reloading chart. 2026-06-01 09:14:02.398 | ESM5.CME 30 Min #1 | Chart data loading complete. 2026-06-01 09:14:02.403 | ESM5.CME 30 Min #2 | Chart data loading complete. 2026-06-01 09:14:03.150 | ESM6.CME #3 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:03.271 | ESM6.CME #3 | Chart data loading complete. 2026-06-01 09:14:03.306 | ESM6.CME #10 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:03.322 | ESM6.CME #10 | Chart data loading complete. 2026-06-01 09:14:03.715 | 2026-06-01 09:14:03.720 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:14:03.720 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:14:03.720 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:14:03.721 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:14:03.721 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:14:04.338 | Loading market depth data. 2026-06-01 09:14:04.563 | ESM5.CME 30 Min #29 | Chart data loading complete. 2026-06-01 09:14:04.567 | ESM5.CME 30 Min #30 | Chart data loading complete. 2026-06-01 09:14:05.312 | Loaded depth data records for ESM6.CME 2026-05-27 from 2026-05-26 20:00:00.005000 to 2026-05-27 19:59:59.985000. 2026-06-01 09:14:05.670 | Loaded depth data records for ESM6.CME 2026-05-25 from 2026-05-25 18:00:00.000000 to 2026-05-25 19:59:59.988000. 2026-06-01 09:14:08.360 | Loaded depth data records for ESM6.CME 2026-05-28 from 2026-05-27 20:00:00.000000 to 2026-05-28 19:59:59.981000. 2026-06-01 09:14:11.065 | ESM6.CME Renko 8t #14 | Chart data loading complete. 2026-06-01 09:14:14.500 | Loaded depth data records for ESM6.CME 2026-05-28 from 2026-05-27 20:00:00.000000 to 2026-05-28 19:59:59.981000. 2026-06-01 09:14:14.690 | Mapping NQM6.CME to NQM26. Service code: cme 2026-06-01 09:14:14.692 | HD Request # 5 | Downloading Intraday chart data for NQM6.CME to the file NQM6.CME.scid. Service: cme 2026-06-01 09:14:14.694 | HD Request # 5 | Download start date-time: 2026-05-18 10:30:37.000000. File last date-time: 2026-05-18 10:30:37.478001 2026-06-01 09:14:14.696 | HD Request # 5 | Using server: ds28.sierracharts.com port 10149 2026-06-01 09:14:14.698 | Socket (1) | Creating socket. 2026-06-01 09:14:14.698 | Socket (1) | New receive buffer size: 0 2026-06-01 09:14:14.699 | Socket (1) | Connecting to IP: 67.214.125.5. 2026-06-01 09:14:15.142 | HD Request # 5 | Setting DTC encoding to Binary VLS 2026-06-01 09:14:15.142 | HD Request # 5 | Sending historical data logon request message. 2026-06-01 09:14:15.464 | HD Request # 5 | Requesting Intraday data. Start date-time: 2026-05-18 10:30:37. Record interval: 0. Symbol: NQM26 2026-06-01 09:14:15.693 | HD Request # 5 | Decompressing data. 2026-06-01 09:14:15.694 | HD Request # 5 | Receiving Intraday data for NQM6.CME starting at 2026-05-18 10:30:37.033000 2026-06-01 09:14:16.718 | HD Request # 5 | Timestamp of first Intraday data file record written: 2026-05-18 10:30:37.530000. 2026-06-01 09:14:18.705 | Loaded depth data records for ESM6.CME 2026-05-29 from 2026-05-28 20:00:00.005000 to 2026-05-29 16:59:59.974000. 2026-06-01 09:14:18.707 | Loaded depth data records for ESM6.CME 2026-05-30 from 2026-05-30 01:24:05.211382 to 2026-05-30 16:00:28.511673. 2026-06-01 09:14:19.049 | Loaded depth data records for ESM6.CME 2026-05-31 from 2026-05-31 08:00:06.017000 to 2026-05-31 19:59:59.997000. 2026-06-01 09:14:19.758 | + Loading additional symbol data. 2026-06-01 09:14:19.759 | Failed to open the file C:\SierraChart\Data\Data\ADR-NASDAQ.scid for reading. File error: Windows error code 2: The system cannot find the file specified. C:\SierraChart\Data\Data\ADR-NASDAQ.scid * 2026-06-01 09:14:19.759 | + Loading additional symbol data. 2026-06-01 09:14:19.759 | Failed to open the file C:\SierraChart\Data\Data\ADR-NYSE.scid for reading. File error: Windows error code 2: The system cannot find the file specified. C:\SierraChart\Data\Data\ADR-NYSE.scid * 2026-06-01 09:14:19.759 | + Loading additional symbol data. 2026-06-01 09:14:19.760 | Failed to open the file C:\SierraChart\Data\Data\TICK-NYSE.scid for reading. File error: Windows error code 2: The system cannot find the file specified. C:\SierraChart\Data\Data\TICK-NYSE.scid * 2026-06-01 09:14:20.576 | ESM6.CME #34 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:20.731 | ESM6.CME #34 | Chart data loading complete. 2026-06-01 09:14:20.747 | MESM6.CME Renko 6t #12 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:20.762 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2. 2026-06-01 09:14:20.773 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | New receive buffer size: 0 2026-06-01 09:14:20.773 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Connecting to IP: 38.79.0.89. 2026-06-01 09:14:20.782 | MESM6.CME Renko 6t #12 | Chart data loading complete. 2026-06-01 09:14:21.368 | Loaded depth data records for ESM6.CME 2026-06-01 from 2026-05-31 20:00:00.004000 to 2026-06-01 09:13:04.160000. 2026-06-01 09:14:23.391 | Loaded depth data records for ESM6.CME 2026-05-29 from 2026-05-28 20:00:00.005000 to 2026-05-29 17:00:00.064000. 2026-06-01 09:14:23.392 | Loaded depth data records for ESM6.CME 2026-05-30 from 2026-05-30 01:24:05.211382 to 2026-05-30 16:00:28.511673. 2026-06-01 09:14:24.099 | Loaded depth data records for ESM6.CME 2026-05-31 from 2026-05-31 08:00:06.017000 to 2026-05-31 19:59:59.997000. 2026-06-01 09:14:25.293 | Loaded depth data records for ESM6.CME 2026-05-27 from 2026-05-26 20:00:00.005000 to 2026-05-27 19:59:59.985000. 2026-06-01 09:14:25.502 | Loaded depth data records for ESM6.CME 2026-06-01 from 2026-05-31 20:00:00.004000 to 2026-06-01 09:13:04.160000. 2026-06-01 09:14:26.874 | Loaded depth data records for ESM6.CME 2026-05-26 from 2026-05-25 20:00:00.001000 to 2026-05-26 19:59:59.875000. 2026-06-01 09:14:30.742 | ESM6.CME #35 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:30.860 | ESM6.CME #35 | Chart data loading complete. 2026-06-01 09:14:33.304 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:14:33.305 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:14:33.305 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:14:33.419 | ESM6.CME/MESM6.CME [CBV] Renko 8t #32 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:33.429 | ESM6.CME/MESM6.CME [CBV] Renko 8t #32 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:14:34.051 | ESM6.CME/MESM6.CME [CBV] Renko 8t #32 | Chart data loading complete. 2026-06-01 09:14:34.229 | ESM6.CME [CBV] 30 Min #54 | Chart data loading complete. 2026-06-01 09:14:36.713 | ESM6.CME/MESM6.CME [CBV] Renko 8t #19 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:36.732 | ESM6.CME/MESM6.CME [CBV] Renko 8t #19 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:14:37.238 | ESM6.CME/MESM6.CME [CBV] Renko 8t #19 | Chart data loading complete. 2026-06-01 09:14:38.666 | Loaded depth data records for ESM6.CME 2026-05-28 from 2026-05-27 20:00:00.000000 to 2026-05-28 19:59:59.981000. 2026-06-01 09:14:40.346 | Loaded depth data records for ESM6.CME 2026-05-27 from 2026-05-26 20:00:00.005000 to 2026-05-27 19:59:59.985000. 2026-06-01 09:14:41.461 | Socket (1) | CloseSocket call. 2026-06-01 09:14:41.479 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-06-01 09:14:41.497 | ESM6.CME [CBV] 30 Min #55 | Chart data loading complete. 2026-06-01 09:14:41.738 | + Loading additional symbol data. 2026-06-01 09:14:41.740 | Failed to open the file C:\SierraChart\Data\Data\ADR-NASDAQ.scid for reading. File error: Windows error code 2: The system cannot find the file specified. C:\SierraChart\Data\Data\ADR-NASDAQ.scid * 2026-06-01 09:14:41.740 | + Loading additional symbol data. 2026-06-01 09:14:41.740 | Failed to open the file C:\SierraChart\Data\Data\ADR-NYSE.scid for reading. File error: Windows error code 2: The system cannot find the file specified. C:\SierraChart\Data\Data\ADR-NYSE.scid * 2026-06-01 09:14:41.740 | + Loading additional symbol data. 2026-06-01 09:14:41.741 | Failed to open the file C:\SierraChart\Data\Data\TICK-NYSE.scid for reading. File error: Windows error code 2: The system cannot find the file specified. C:\SierraChart\Data\Data\TICK-NYSE.scid * 2026-06-01 09:14:42.451 | ESM6.CME Renko 6t #26 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:43.086 | ESM6.CME Renko 6t #26 | Chart data loading complete. 2026-06-01 09:14:43.419 | ESM6.CME/MESM6.CME [CBV] 2500 Volume #5 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:43.544 | Added historical Intraday data request for ADR-NYSE to the queue. 2026-06-01 09:14:43.544 | Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'. 2026-06-01 09:14:43.544 | Triggering next historical data download in queue. 2026-06-01 09:14:43.544 | ESM6.CME/MESM6.CME [CBV] 2500 Volume #5 | Started historical data download for additional symbol ADR-NYSE. Download ID: 6 2026-06-01 09:14:43.544 | ESM6.CME/MESM6.CME [CBV] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:14:43.550 | Added historical Intraday data request for ADR-NASDAQ to the queue. 2026-06-01 09:14:43.550 | Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'. 2026-06-01 09:14:43.550 | ESM6.CME/MESM6.CME [CBV] 2500 Volume #5 | Started historical data download for additional symbol ADR-NASDAQ. Download ID: 7 2026-06-01 09:14:43.551 | Added historical Intraday data request for TICK-NYSE to the queue. 2026-06-01 09:14:43.551 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2026-06-01 09:14:43.551 | ESM6.CME/MESM6.CME [CBV] 2500 Volume #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 8 2026-06-01 09:14:44.076 | ESM6.CME/MESM6.CME [CBV] 2500 Volume #5 | Chart data loading complete. 2026-06-01 09:14:46.130 | Loaded depth data records for ESM6.CME 2026-05-28 from 2026-05-27 20:00:00.000000 to 2026-05-28 19:59:59.981000. 2026-06-01 09:14:46.164 | ESM6.CME/MESM6.CME [CBV] 3000 Volume #28 | Chart data loading complete. 2026-06-01 09:14:46.406 | Loaded depth data records for ESM6.CME 2026-05-29 from 2026-05-28 20:00:00.005000 to 2026-05-29 15:59:59.999000. 2026-06-01 09:14:46.407 | Loaded depth data records for ESM6.CME 2026-05-30 from 2026-05-30 01:24:05.211382 to 2026-05-30 15:00:25.385108. 2026-06-01 09:14:46.447 | ESM6.CME/MESM6.CME [CBV] 3 Min #17 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:46.680 | Loaded depth data records for ESM6.CME 2026-05-31 from 2026-05-31 08:00:06.017000 to 2026-05-31 19:59:59.997000. 2026-06-01 09:14:48.010 | ESM6.CME/MESM6.CME [CBV] 3 Min #17 | Chart data loading complete. 2026-06-01 09:14:48.341 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (9) | Creating socket. Using TLS 1.2. 2026-06-01 09:14:48.342 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (9) | New receive buffer size: 0 2026-06-01 09:14:48.342 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (9) | Connecting to IP: 38.79.0.89. 2026-06-01 09:14:48.435 | Loaded depth data records for ESM6.CME 2026-06-01 from 2026-05-31 20:00:00.004000 to 2026-06-01 09:13:04.160000. 2026-06-01 09:14:48.513 | ESM6.CME/MESM6.CME [CBV] Renko 8t #8 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:48.608 | ESM6.CME/MESM6.CME [CBV] Renko 8t #8 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 09:14:49.280 | ESM6.CME/MESM6.CME [CBV] Renko 8t #8 | Chart data loading complete. 2026-06-01 09:14:49.624 | ESM6.CME/MESM6.CME [CBV] 10000 Volume #24 | Chart data loading complete. 2026-06-01 09:14:50.258 | ESM6.CME #20 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 09:14:50.259 | ESM6.CME #20 | Chart data loading complete. 2026-06-01 09:14:50.572 | Loaded depth data records for ESM6.CME 2026-05-29 from 2026-05-28 20:00:00.005000 to 2026-05-29 16:59:59.974000. 2026-06-01 09:14:50.573 | Loaded depth data records for ESM6.CME 2026-05-30 from 2026-05-30 01:24:05.211382 to 2026-05-30 16:00:28.511673. 2026-06-01 09:14:50.726 | Loaded depth data records for ESM6.CME 2026-05-31 from 2026-05-31 08:00:06.017000 to 2026-05-31 19:59:59.997000. 2026-06-01 09:14:50.803 | Chart #23 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:14:50.803 | ESM6.CME [C] 15 Min #23 | Chart data loading complete. 2026-06-01 09:14:50.830 | ESM6.CME/MESM6.CME [CBV] 3 Min #42 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:50.919 | ESM6.CME/MESM6.CME [CBV] 3 Min #42 | Chart data loading complete. 2026-06-01 09:14:51.403 | 2026-06-01 09:14:51.403 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:14:51.403 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:14:51.403 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:14:51.403 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:14:51.403 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:14:51.463 | Chart #21 has tagged chart #24 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:14:51.463 | Chart #21 has tagged chart #28 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:14:51.464 | ESM6.CME 2 Min #21 | Chart data loading complete. 2026-06-01 09:14:51.534 | ESM6.CME [CBV] #7 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 09:14:51.560 | ESM6.CME [CBV] #7 | Chart data loading complete. 2026-06-01 09:14:51.732 | ESM6.CME 3000 Volume #25 | Chart data loading complete. 2026-06-01 09:14:51.922 | Loaded depth data records for ESM6.CME 2026-06-01 from 2026-05-31 20:00:00.004000 to 2026-06-01 09:13:04.160000. 2026-06-01 09:14:52.080 | Historical data download thread signaled to stop. 2026-06-01 09:14:52.081 | HD Request # 5 | Received 4940936 Intraday data records from 2026-05-18 10:30:37.033000 to 2026-06-01 09:14:33.391002 (13.9 days. Delay: 18.7 seconds) and wrote 4940904 records for NQM6.CME 2026-06-01 09:14:52.121 | HD Request # 5 | Completion time: 38s. 2026-06-01 09:14:52.121 | HD Request # 5 | Intraday data download complete for NQM6.CME. Unique request ID: 5 2026-06-01 09:14:52.121 | Removing historical data download ID 5. 2026-06-01 09:14:52.122 | Real-time Intraday chart data file updates started for NQM6.CME 2026-06-01 09:14:52.122 | Intraday chart data file opened for NQM6.CME 2026-06-01 09:14:52.122 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2026-06-01 09:14:52.122 | 2026-06-01 09:14:52.122 | Historical data for NQM6.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2026-06-01 09:14:52.177 | ESM6.CME/MESM6.CME [CBV] 3000 Volume #16 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:52.447 | ESM6.CME/MESM6.CME [CBV] 3000 Volume #16 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:14:52.900 | Chart #16 has tagged chart #26 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:14:52.900 | Chart #16 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:14:52.937 | ESM6.CME/MESM6.CME [CBV] 3000 Volume #16 | Chart data loading complete. 2026-06-01 09:14:53.069 | HD Request # 6 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc 2026-06-01 09:14:53.071 | HD Request # 6 | Download start date-time: 2025-04-27 09:14:53.000000. File last date-time: 00:00:00.000000 2026-06-01 09:14:53.071 | HD Request # 6 | Using server: ds12.sierracharts.com port 10150 2026-06-01 09:14:55.502 | ESM6.CME [CBV] #13 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:55.574 | Chart #13 has tagged chart #16 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:14:55.574 | Chart #13 has tagged chart #19 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:14:55.574 | Chart #13 has tagged chart #32 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:14:55.574 | Chart #13 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:14:55.574 | Chart #13 has tagged chart #8 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:14:55.649 | ESM6.CME [CBV] #13 | Chart data loading complete. 2026-06-01 09:14:55.933 | Chart #22 has tagged chart #24 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:14:55.933 | Chart #22 has tagged chart #28 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:14:55.933 | ESM6.CME [CBV] 2 Min #22 | Chart data loading complete. 2026-06-01 09:14:56.029 | ESM6.CME [CBV] #15 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:56.116 | ESM6.CME [CBV] #15 | Chart data loading complete. 2026-06-01 09:14:56.253 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:14:56.253 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:14:56.253 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:14:56.452 | ESM6.CME [CBV] 3 Min #33 | Chart data loading complete. 2026-06-01 09:14:57.807 | ESM6.CME Renko 8t #14 | Reloading chart. 2026-06-01 09:14:57.815 | ESM6.CME/MESM6.CME [CBV] Renko 8t #32 | Reloading chart. 2026-06-01 09:14:58.054 | ESM6.CME/MESM6.CME [CBV] Renko 8t #19 | Reloading chart. 2026-06-01 09:14:58.147 | NQM6.CME/MNQM6.CME [CBV] Renko 24t #18 | Download is complete for all contract months in chart. Proceeding with data load. 2026-06-01 09:14:58.152 | NQM6.CME/MNQM6.CME [CBV] Renko 24t #18 | Reloading chart. 2026-06-01 09:14:58.418 | ESM6.CME Renko 8t #14 | Chart data loading complete. 2026-06-01 09:14:58.546 | Enabling compression for file: C:\SierraChart\Data\Data\ADR-NYSE.scid 2026-06-01 09:14:59.244 | ESM6.CME 2500 Volume #27 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:14:59.340 | ESM6.CME 2500 Volume #27 | Chart data loading complete. 2026-06-01 09:14:59.615 | ESM6.CME Renko 6t #26 | Reloading chart. 2026-06-01 09:14:59.989 | NQM6.CME/MNQM6.CME [CBV] Renko 24t #18 | Reloading chart. 2026-06-01 09:15:00.347 | 2026-06-01 09:15:00.348 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:00.348 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:00.348 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:00.348 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:00.348 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:00.418 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:00.418 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:00.418 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:00.658 | Mapping MNQM6.CME to MNQM26. Service code: cme 2026-06-01 09:15:02.708 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:02.708 | HTTPS connection ID:1 to docs.google.com:443 for request ID:1 (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:02.708 | HTTPS connection ID:2 to docs.google.com:443 for request ID:2 (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:02.708 | HTTPS connection ID:1 to docs.google.com:443 for request ID:1 (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:02.708 | HTTPS connection ID:2 to docs.google.com:443 for request ID:2 (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:02.708 | HTTPS connection ID:1 to docs.google.com:443 for request ID:1 (7) | Connect event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:02.708 | HTTPS connection ID:2 to docs.google.com:443 for request ID:2 (8) | Connect event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:02.708 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (9) | Connect event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:02.708 | HTTPS connection ID:1 to docs.google.com:443 for request ID:1 (10) | Connect event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:02.708 | HTTPS connection ID:1 to docs.google.com:443 for request ID:1 (11) | Connect event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:02.708 | HTTPS connection ID:1 to docs.google.com:443 for request ID:1 (12) | Connect event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:02.708 | HTTPS connection ID:1 to docs.google.com:443 for request ID:1 (13) | Connect event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:02.708 | HTTPS connection ID:2 to docs.google.com:443 for request ID:2 (14) | Connect event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:02.708 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. 2026-06-01 09:15:02.708 | Socket (1) | Socket gracefully closed by remote side. 2026-06-01 09:15:02.709 | Socket (1) | Closed. 2026-06-01 09:15:03.056 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (9) | CloseSocket call. 2026-06-01 09:15:03.084 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (9) | Closed. 2026-06-01 09:15:03.275 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | CloseSocket call. 2026-06-01 09:15:03.280 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:15:03.280 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Closed. 2026-06-01 09:15:04.462 | 2026-06-01 09:15:04.462 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:04.462 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:04.462 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:04.462 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:04.462 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:04.555 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:04.555 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:04.555 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:05.213 | Error getting address info for ds12.sierracharts.com. Windows error code 11001: No such host is known. * 2026-06-01 09:15:05.213 | Socket (15) | CloseSocket call. 2026-06-01 09:15:05.213 | Socket (0) | CloseSocket call. 2026-06-01 09:15:05.297 | HD Request # 6 | Error downloading historical Intraday data for ADR-NYSE. The network socket has been closed. Retrying download. 2026-06-01 09:15:05.297 | Added historical Intraday data request for ADR-NYSE to the queue. 2026-06-01 09:15:05.299 | Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'. 2026-06-01 09:15:05.300 | Triggering next historical data download in queue. 2026-06-01 09:15:05.301 | Historical data download thread signaled to stop. 2026-06-01 09:15:05.353 | HD Request # 6 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ADR-NYSE 2026-06-01 09:15:05.353 | HD Request # 6 | Completion time: 12s. 2026-06-01 09:15:05.354 | 2026-06-01 09:15:05.370 | HD Request # 7 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc 2026-06-01 09:15:05.371 | HD Request # 7 | Download start date-time: 2025-04-27 09:15:05.000000. File last date-time: 00:00:00.000000 2026-06-01 09:15:05.371 | HD Request # 7 | Using server: ds4.sierracharts.com port 10149 2026-06-01 09:15:07.522 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:15:07.742 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Chart data loading complete. 2026-06-01 09:15:07.751 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:15:08.577 | 2026-06-01 09:15:08.584 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:08.584 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:08.584 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:08.584 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:08.584 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:08.586 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:15:08.779 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Chart data loading complete. 2026-06-01 09:15:08.791 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:15:09.150 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:09.150 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:09.150 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:13.334 | 2026-06-01 09:15:13.334 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:13.334 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:13.334 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:13.334 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:13.334 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:13.414 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:13.414 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:13.414 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:13.704 | ESM6.CME[M] Renko 6t #26 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:15:14.053 | ESM6.CME[M] Renko 6t #26 | Chart data loading complete. 2026-06-01 09:15:16.546 | MESM6.CME[M] Renko 8t #4 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:15:16.807 | MESM6.CME[M] Renko 8t #4 | Chart data loading complete. 2026-06-01 09:15:17.385 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (16) | Using previously cached IP address because unable to resolve domain name 2026-06-01 09:15:17.385 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (16) | Creating socket. Using TLS 1.2. 2026-06-01 09:15:17.386 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (16) | New receive buffer size: 0 2026-06-01 09:15:17.386 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (16) | Connecting to IP: 38.79.0.89. 2026-06-01 09:15:17.424 | Socket (1) | Creating socket. 2026-06-01 09:15:17.424 | Socket (1) | New receive buffer size: 0 2026-06-01 09:15:17.424 | Socket (1) | Connecting to IP: 64.152.155.113. 2026-06-01 09:15:17.432 | 2026-06-01 09:15:17.493 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:17.493 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:17.493 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:17.493 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:17.493 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:17.511 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:17.511 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:17.511 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:17.815 | HD Request # 7 | Setting DTC encoding to Binary VLS 2026-06-01 09:15:17.815 | HD Request # 7 | Sending historical data logon request message. 2026-06-01 09:15:17.976 | HD Request # 7 | Requesting Intraday data. Start date-time: 2025-04-27 09:15:05. Record interval: 0. Symbol: ADR-NYSE 2026-06-01 09:15:18.343 | HD Request # 7 | Decompressing data. 2026-06-01 09:15:18.345 | HD Request # 7 | Receiving Intraday data for ADR-NYSE starting at 2025-04-28 04:00:00.000000 2026-06-01 09:15:18.824 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (16) | Socket gracefully closed by remote side. 2026-06-01 09:15:19.101 | HD Request # 7 | Timestamp of first Intraday data file record written: 2025-04-28 04:00:00.000000. 2026-06-01 09:15:20.024 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 09:15:21.630 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Chart data loading complete. 2026-06-01 09:15:21.632 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (16) | Socket gracefully closed by remote side. 2026-06-01 09:15:21.634 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:15:21.788 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:15:21.793 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (16) | CloseSocket call. 2026-06-01 09:15:21.793 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (16) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:15:21.793 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (16) | Closed. 2026-06-01 09:15:21.854 | 2026-06-01 09:15:21.854 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:21.854 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:21.854 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:21.854 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:21.854 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:21.878 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:21.878 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:21.878 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:25.893 | 2026-06-01 09:15:25.893 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:25.893 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:25.893 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:25.893 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:25.893 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:25.920 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:25.920 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:25.920 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:29.964 | Socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:15:29.964 | Socket (1) | Socket gracefully closed by remote side. 2026-06-01 09:15:29.964 | Socket (1) | CloseSocket call. 2026-06-01 09:15:29.964 | Socket (0) | CloseSocket call. 2026-06-01 09:15:29.964 | Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:15:29.964 | Socket (1) | Closed. 2026-06-01 09:15:29.991 | 2026-06-01 09:15:29.991 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:29.991 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:29.991 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:29.991 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:29.991 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:29.993 | HD Request # 7 | Error downloading historical Intraday data for ADR-NYSE. The network socket has been closed. Retrying download. 2026-06-01 09:15:29.993 | Added historical Intraday data request for ADR-NYSE to the queue. 2026-06-01 09:15:29.993 | Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'. 2026-06-01 09:15:29.993 | Triggering next historical data download in queue. 2026-06-01 09:15:29.993 | Historical data download thread signaled to stop. 2026-06-01 09:15:29.994 | HD Request # 7 | Received 2177130 Intraday data records from 2025-04-28 04:00:00.000000 to 2025-06-20 16:44:47.000000 (53.5 days. Delay: 345.7 days) and wrote 2177130 records for ADR-NYSE 2026-06-01 09:15:30.064 | HD Request # 7 | Completion time: 25s. 2026-06-01 09:15:30.064 | 2026-06-01 09:15:30.064 | HD Request # 8 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc 2026-06-01 09:15:30.068 | HD Request # 8 | Download start date-time: 2025-06-20 16:44:47.000000. File last date-time: 2025-06-20 16:44:47.000000 2026-06-01 09:15:30.068 | HD Request # 8 | Using server: ds12.sierracharts.com port 10150 2026-06-01 09:15:30.070 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:30.070 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:30.070 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:30.242 | Socket (1) | Creating socket. 2026-06-01 09:15:30.243 | Socket (1) | New receive buffer size: 0 2026-06-01 09:15:30.243 | Socket (1) | Connecting to IP: 69.39.70.241. 2026-06-01 09:15:30.246 | Socket (1) | Connect event error. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. * 2026-06-01 09:15:30.246 | Socket (1) | CloseSocket call. 2026-06-01 09:15:30.246 | Socket (0) | CloseSocket call. 2026-06-01 09:15:30.250 | Socket (1) | Closed. 2026-06-01 09:15:30.253 | HD Request # 8 | Error downloading historical Intraday data for ADR-NYSE. The network socket has been closed. Retrying download. 2026-06-01 09:15:30.253 | Historical data download thread signaled to stop. 2026-06-01 09:15:30.254 | HD Request # 8 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ADR-NYSE 2026-06-01 09:15:30.254 | HD Request # 8 | Completion time: 0s. 2026-06-01 09:15:30.254 | HD Request # 8 | Intraday data download complete for ADR-NYSE. Unique request ID: 6 2026-06-01 09:15:30.254 | Removing historical data download ID 6. 2026-06-01 09:15:30.254 | Real-time Intraday chart data file updates started for ADR-NYSE 2026-06-01 09:15:30.254 | Intraday chart data file opened for ADR-NYSE 2026-06-01 09:15:30.254 | HD Request # 8 | Enabling Intraday chart updating for symbol. 2026-06-01 09:15:30.254 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Historical data download for additional symbol ADR-NYSE with ID 6 has completed. 2026-06-01 09:15:30.254 | 2026-06-01 09:15:30.254 | Triggering next historical data download in queue. 2026-06-01 09:15:30.254 | HD Request # 9 | Downloading Intraday chart data for ADR-NASDAQ to the file ADR-NASDAQ.scid. Service: statscalc 2026-06-01 09:15:30.255 | HD Request # 9 | Download start date-time: 2025-04-27 09:15:30.000000. File last date-time: 00:00:00.000000 2026-06-01 09:15:30.256 | HD Request # 9 | Using server: ds4.sierracharts.com port 10149 2026-06-01 09:15:30.261 | Socket (1) | Creating socket. 2026-06-01 09:15:30.261 | Socket (1) | New receive buffer size: 0 2026-06-01 09:15:30.261 | Socket (1) | Connecting to IP: 64.152.155.113. 2026-06-01 09:15:30.539 | HD Request # 9 | Setting DTC encoding to Binary VLS 2026-06-01 09:15:30.539 | HD Request # 9 | Sending historical data logon request message. 2026-06-01 09:15:30.590 | Enabling compression for file: C:\SierraChart\Data\Data\ADR-NASDAQ.scid 2026-06-01 09:15:30.665 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:15:30.682 | HD Request # 9 | Requesting Intraday data. Start date-time: 2025-04-27 09:15:30. Record interval: 0. Symbol: ADR-NASDAQ 2026-06-01 09:15:30.815 | HD Request # 9 | Decompressing data. 2026-06-01 09:15:30.847 | HD Request # 9 | Receiving Intraday data for ADR-NASDAQ starting at 2025-04-28 04:00:00.000000 2026-06-01 09:15:31.612 | HD Request # 9 | Timestamp of first Intraday data file record written: 2025-04-28 04:00:00.000000. 2026-06-01 09:15:34.132 | 2026-06-01 09:15:34.133 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:34.133 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:34.133 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:34.133 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:34.133 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:34.210 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:34.210 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:34.211 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:38.233 | 2026-06-01 09:15:38.233 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:38.233 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:38.234 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:38.234 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:38.234 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:38.260 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:38.260 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:38.260 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:39.793 | ESM6.CME/MESM6.CME[M] 15 Min #9 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:15:39.974 | Chart: ESM6.CME/MESM6.CME[M] 15 Min #9 | Study: Color Theme Switcher | Color Theme Switcher Applied "Custom" | BG RGB(0,0,0) | ValScale RGB(218,214,208) | TimeScale RGB(168,164,158) | PriceBox BG RGB(40,34,28) FG RGB(218,214,208) | Up RGB(255,255,255) | Down RGB(218,100,28) 2026-06-01 09:15:39.981 | ESM6.CME/MESM6.CME[M] 15 Min #9 | Chart data loading complete. 2026-06-01 09:15:40.132 | Chart: ESM6.CME/MESM6.CME[M] 15 Min #9 | Study: Color Theme Switcher | Color Theme Switcher Applied "Custom" | BG RGB(0,0,0) | ValScale RGB(218,214,208) | TimeScale RGB(168,164,158) | PriceBox BG RGB(40,34,28) FG RGB(218,214,208) | Up RGB(255,255,255) | Down RGB(218,100,28) 2026-06-01 09:15:42.276 | 2026-06-01 09:15:42.277 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:42.277 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:42.277 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:42.277 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:42.277 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:42.310 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:42.310 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:42.310 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:46.357 | 2026-06-01 09:15:46.358 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:46.358 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:46.358 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:46.358 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:46.358 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:46.389 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:46.390 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:46.390 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:50.448 | 2026-06-01 09:15:50.448 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:50.448 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:50.448 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:50.448 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:50.448 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:50.466 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:50.466 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:50.466 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:51.885 | ESM6.CME [CBV][M] 3000 Volume #6 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:15:52.600 | Chart #6 has tagged chart #16 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:15:52.695 | ESM6.CME [CBV][M] 3000 Volume #6 | Chart data loading complete. 2026-06-01 09:15:54.502 | 2026-06-01 09:15:54.503 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:54.503 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:54.503 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:54.503 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:54.503 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:54.562 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:54.562 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:54.562 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:58.632 | 2026-06-01 09:15:58.633 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:15:58.633 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:15:58.633 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:15:58.633 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:15:58.633 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:15:58.648 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:15:58.648 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:15:58.648 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:02.676 | 2026-06-01 09:16:02.677 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:02.677 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:02.677 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:02.677 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:02.677 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:02.699 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:02.699 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:02.699 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:06.717 | 2026-06-01 09:16:06.717 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:06.717 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:06.717 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:06.717 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:06.717 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:06.762 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:06.762 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:06.762 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:10.809 | 2026-06-01 09:16:10.809 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:10.809 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:10.809 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:10.809 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:10.809 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:10.841 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:10.841 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:10.841 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:14.851 | 2026-06-01 09:16:14.851 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:14.851 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:14.851 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:14.851 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:14.851 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:14.919 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:14.919 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:14.919 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:15.857 | Socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 09:16:15.857 | Socket (1) | Socket gracefully closed by remote side. 2026-06-01 09:16:15.857 | Socket (1) | CloseSocket call. 2026-06-01 09:16:15.857 | Socket (0) | CloseSocket call. 2026-06-01 09:16:15.857 | Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:16:15.857 | Socket (1) | Closed. 2026-06-01 09:16:15.865 | HD Request # 9 | Error downloading historical Intraday data for ADR-NASDAQ. The network socket has been closed. Retrying download. 2026-06-01 09:16:15.865 | Added historical Intraday data request for ADR-NASDAQ to the queue. 2026-06-01 09:16:15.865 | Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'. 2026-06-01 09:16:15.865 | Triggering next historical data download in queue. 2026-06-01 09:16:15.865 | Historical data download thread signaled to stop. 2026-06-01 09:16:15.865 | HD Request # 9 | Received 555827 Intraday data records from 2025-04-28 04:00:00.000000 to 2025-05-09 14:24:31.000000 (11.4 days. Delay: 387.8 days) and wrote 555827 records for ADR-NASDAQ 2026-06-01 09:16:15.871 | HD Request # 9 | Completion time: 45s. 2026-06-01 09:16:15.871 | 2026-06-01 09:16:15.872 | HD Request # 10 | Downloading Intraday chart data for ADR-NASDAQ to the file ADR-NASDAQ.scid. Service: statscalc 2026-06-01 09:16:15.872 | HD Request # 10 | Download start date-time: 2025-05-09 14:24:31.000000. File last date-time: 2025-05-09 14:24:31.000000 2026-06-01 09:16:15.872 | HD Request # 10 | Using server: ds12.sierracharts.com port 10150 2026-06-01 09:16:15.872 | Socket (1) | Creating socket. 2026-06-01 09:16:15.872 | Socket (1) | New receive buffer size: 0 2026-06-01 09:16:15.872 | Socket (1) | Connecting to IP: 69.39.70.241. 2026-06-01 09:16:16.162 | HD Request # 10 | Setting DTC encoding to Binary VLS 2026-06-01 09:16:16.162 | HD Request # 10 | Sending historical data logon request message. 2026-06-01 09:16:16.322 | HD Request # 10 | Requesting Intraday data. Start date-time: 2025-05-09 14:24:31. Record interval: 0. Symbol: ADR-NASDAQ 2026-06-01 09:16:16.470 | HD Request # 10 | Decompressing data. 2026-06-01 09:16:16.506 | HD Request # 10 | Receiving Intraday data for ADR-NASDAQ starting at 2025-05-09 14:24:32.000000 2026-06-01 09:16:17.366 | HD Request # 10 | Timestamp of first Intraday data file record written: 2025-05-09 14:24:32.000000. 2026-06-01 09:16:18.936 | 2026-06-01 09:16:18.937 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:18.937 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:18.937 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:18.937 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:18.937 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:19.007 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:19.007 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:19.007 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:22.386 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:16:22.621 | ESM6.CME [CB][M] 5 Min #38 | Chart data loading complete. 2026-06-01 09:16:22.662 | ESM6.CME[M]/MESM6.CME [CBV][M] 10000 Volume #24 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:22.701 | Chart #24 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:22.701 | Chart #24 has tagged chart #6 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:22.704 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:22.759 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 09:16:22.933 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:23.863 | 2026-06-01 09:16:23.864 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:23.864 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:23.864 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:23.864 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:23.864 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:23.969 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:23.969 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:23.969 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:24.206 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:24.289 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:16:24.398 | Chart #16 has tagged chart #26 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:24.398 | Chart #16 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:24.398 | Chart #16 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:24.445 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:24.455 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:16:24.553 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:24.619 | ESM6.CME[M] Renko 6t #26 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:24.770 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #28 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:24.865 | ESM6.CME [CBV][M] 3000 Volume #6 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:25.431 | Chart #6 has tagged chart #16 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:25.723 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:26.452 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:16:26.867 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:26.924 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:16:27.010 | Chart #16 has tagged chart #26 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:27.010 | Chart #16 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:27.010 | Chart #16 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:27.044 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:27.049 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:16:27.113 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:27.159 | ESM6.CME[M] Renko 6t #26 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:27.341 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:16:27.935 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 09:16:28.289 | 2026-06-01 09:16:28.289 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:28.290 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:28.290 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:28.290 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:28.290 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:28.311 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:28.311 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:28.311 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:32.320 | 2026-06-01 09:16:32.320 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:32.320 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:32.320 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:32.320 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:32.320 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:32.364 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:32.364 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:32.364 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:36.389 | 2026-06-01 09:16:36.389 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:36.389 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:36.389 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:36.389 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:36.389 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:36.401 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:36.401 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:36.401 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:40.435 | 2026-06-01 09:16:40.435 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:40.435 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:40.435 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:40.435 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:40.435 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:40.470 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:40.470 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:40.470 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:44.473 | 2026-06-01 09:16:44.473 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:44.473 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:44.473 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:44.473 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:44.473 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:44.503 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:44.503 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:44.503 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:48.583 | 2026-06-01 09:16:48.583 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:48.583 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:48.583 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:48.583 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:48.583 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:48.593 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:48.593 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:48.593 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:52.639 | 2026-06-01 09:16:52.640 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:52.640 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:52.640 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:52.640 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:52.640 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:52.673 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:52.673 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:52.673 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:56.699 | 2026-06-01 09:16:56.699 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:16:56.699 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:16:56.699 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:16:56.699 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:16:56.699 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:16:56.737 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:16:56.737 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:16:56.737 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:00.747 | 2026-06-01 09:17:00.748 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:17:00.748 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:17:00.748 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:17:00.748 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:17:00.748 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:00.781 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:17:00.781 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:17:00.781 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:04.825 | 2026-06-01 09:17:04.825 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:17:04.825 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:17:04.825 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:17:04.825 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:17:04.825 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:04.857 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:17:04.857 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:17:04.857 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:08.872 | 2026-06-01 09:17:08.872 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:17:08.872 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:17:08.872 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:17:08.872 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:17:08.872 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:08.885 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:17:08.885 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:17:08.885 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:12.908 | 2026-06-01 09:17:12.908 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:17:12.908 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:17:12.908 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:17:12.908 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:17:12.908 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:12.945 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:17:12.945 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:17:12.945 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:17.019 | 2026-06-01 09:17:17.019 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:17:17.019 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:17:17.019 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:17:17.019 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:17:17.019 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:17.029 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:17:17.029 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:17:17.029 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:21.111 | 2026-06-01 09:17:21.111 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:17:21.111 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:17:21.111 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:17:21.111 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:17:21.111 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:21.147 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:17:21.147 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:17:21.147 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:25.172 | 2026-06-01 09:17:25.172 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:17:25.172 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:17:25.172 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:17:25.172 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:17:25.172 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:25.195 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:17:25.195 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:17:25.195 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:29.211 | 2026-06-01 09:17:29.211 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:17:29.211 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:17:29.211 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:17:29.211 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:17:29.211 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:29.310 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:17:29.310 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:17:29.310 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:33.327 | 2026-06-01 09:17:33.327 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:17:33.327 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:17:33.327 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:17:33.327 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:17:33.327 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:33.422 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:17:33.422 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:17:33.422 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:37.496 | 2026-06-01 09:17:37.497 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:17:37.497 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:17:37.497 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:17:37.497 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:17:37.497 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:37.612 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:17:37.612 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:17:37.612 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:17:48.780 | Socket (1) | CloseSocket call. 2026-06-01 09:17:48.780 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-06-01 09:17:48.790 | Historical data download thread signaled to stop. 2026-06-01 09:17:48.791 | HD Request # 10 | Received 14744791 Intraday data records from 2025-05-09 14:24:32.000000 to 2026-06-01 09:17:45.000000 (387.8 days. Delay: 3.8 seconds) and wrote 14744490 records for ADR-NASDAQ 2026-06-01 09:17:48.796 | HD Request # 10 | Completion time: 1m 33s. 2026-06-01 09:17:48.796 | HD Request # 10 | Intraday data download complete for ADR-NASDAQ. Unique request ID: 7 2026-06-01 09:17:48.796 | Removing historical data download ID 7. 2026-06-01 09:17:48.797 | Real-time Intraday chart data file updates started for ADR-NASDAQ 2026-06-01 09:17:48.797 | Intraday chart data file opened for ADR-NASDAQ 2026-06-01 09:17:48.797 | HD Request # 10 | Enabling Intraday chart updating for symbol. 2026-06-01 09:17:48.797 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Historical data download for additional symbol ADR-NASDAQ with ID 7 has completed. 2026-06-01 09:17:48.797 | 2026-06-01 09:17:48.797 | Triggering next historical data download in queue. 2026-06-01 09:17:48.797 | Historical data for ADR-NASDAQ is delayed because connection to main data feed is not present. Current data will be received upon connection. 2026-06-01 09:17:48.797 | HD Request # 11 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2026-06-01 09:17:48.798 | HD Request # 11 | Download start date-time: 2025-04-27 09:17:48.000000. File last date-time: 00:00:00.000000 2026-06-01 09:17:48.798 | HD Request # 11 | Using server: ds4.sierracharts.com port 10149 2026-06-01 09:17:48.798 | Socket (2) | Creating socket. 2026-06-01 09:17:48.798 | Socket (2) | New receive buffer size: 0 2026-06-01 09:17:48.798 | Socket (2) | Connecting to IP: 64.152.155.113. 2026-06-01 09:17:48.821 | Enabling compression for file: C:\SierraChart\Data\Data\TICK-NYSE.scid 2026-06-01 09:17:48.920 | Socket (1) | Socket gracefully closed by remote side. 2026-06-01 09:17:48.920 | Socket (1) | Closed. 2026-06-01 09:17:49.071 | HD Request # 11 | Setting DTC encoding to Binary VLS 2026-06-01 09:17:49.071 | HD Request # 11 | Sending historical data logon request message. 2026-06-01 09:17:49.212 | HD Request # 11 | Requesting Intraday data. Start date-time: 2025-04-27 09:17:48. Record interval: 0. Symbol: TICK-NYSE 2026-06-01 09:17:49.338 | HD Request # 11 | Decompressing data. 2026-06-01 09:17:49.361 | HD Request # 11 | Receiving Intraday data for TICK-NYSE starting at 2025-04-28 04:00:00.000000 2026-06-01 09:17:50.045 | HD Request # 11 | Timestamp of first Intraday data file record written: 2025-04-28 04:00:00.000000. 2026-06-01 09:17:57.622 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:17:57.623 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (1) | New receive buffer size: 0 2026-06-01 09:17:57.623 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:17:58.760 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:17:58.762 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:17:58.860 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:17:58.860 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (1) | CloseSocket call. 2026-06-01 09:17:58.860 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:17:58.860 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (1) | Closed. 2026-06-01 09:19:20.902 | Socket (2) | CloseSocket call. 2026-06-01 09:19:20.902 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-06-01 09:19:20.961 | Historical data download thread signaled to stop. 2026-06-01 09:19:20.962 | HD Request # 11 | Received 15707287 Intraday data records from 2025-04-28 04:00:00.000000 to 2026-06-01 09:19:20.000000 (399.2 days. Delay: 1.0 seconds) and wrote 15706986 records for TICK-NYSE 2026-06-01 09:19:20.978 | HD Request # 11 | Completion time: 1m 32s. 2026-06-01 09:19:20.978 | HD Request # 11 | Intraday data download complete for TICK-NYSE. Unique request ID: 8 2026-06-01 09:19:20.978 | Removing historical data download ID 8. 2026-06-01 09:19:20.978 | Real-time Intraday chart data file updates started for TICK-NYSE 2026-06-01 09:19:20.978 | Intraday chart data file opened for TICK-NYSE 2026-06-01 09:19:20.978 | HD Request # 11 | Enabling Intraday chart updating for symbol. 2026-06-01 09:19:20.978 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Historical data download for additional symbol TICK-NYSE with ID 8 has completed. 2026-06-01 09:19:20.978 | 2026-06-01 09:19:20.978 | No download requests in the queue to start downloads for. 2026-06-01 09:19:20.978 | Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. 2026-06-01 09:19:21.029 | Socket (2) | Socket gracefully closed by remote side. 2026-06-01 09:19:21.029 | Socket (2) | Closed. 2026-06-01 09:19:21.030 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Reloading chart. 2026-06-01 09:19:22.572 | + Loading additional symbol data. | Number times message added: 2 2026-06-01 09:19:22.664 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | StartDateTimeForLoadingOrderFills: 2025-05-25 00:00:00 2026-06-01 09:19:22.671 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:19:22.727 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:19:22.760 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Chart data loading complete. 2026-06-01 09:19:22.914 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 09:19:23.398 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 09:19:37.640 | 2026-06-01 09:19:37.640 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:19:37.640 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:19:37.640 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:19:37.640 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:19:37.640 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:19:37.668 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:19:37.668 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:19:37.669 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:19:57.673 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:19:57.686 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | New receive buffer size: 0 2026-06-01 09:19:57.686 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:19:58.898 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:19:58.929 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:19:59.020 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:19:59.020 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | CloseSocket call. 2026-06-01 09:19:59.020 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:19:59.020 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | Closed. 2026-06-01 09:21:37.676 | 2026-06-01 09:21:37.676 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:21:37.676 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:21:37.676 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:21:37.676 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:21:37.676 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:21:37.695 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:21:37.695 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:21:37.695 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:21:57.825 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:21:57.826 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | New receive buffer size: 0 2026-06-01 09:21:57.826 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:21:59.025 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:21:59.029 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:21:59.121 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:21:59.121 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | CloseSocket call. 2026-06-01 09:21:59.121 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:21:59.121 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | Closed. 2026-06-01 09:23:37.740 | 2026-06-01 09:23:37.740 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:23:37.740 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:23:37.740 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:23:37.740 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:23:37.740 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:23:37.768 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:23:37.768 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:23:37.768 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:23:57.799 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:23:57.800 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (1) | New receive buffer size: 0 2026-06-01 09:23:57.800 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:23:58.840 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:23:58.842 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:23:58.925 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:23:58.925 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (1) | CloseSocket call. 2026-06-01 09:23:58.926 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:23:58.926 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (1) | Closed. 2026-06-01 09:25:37.775 | 2026-06-01 09:25:37.775 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:25:37.775 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:25:37.775 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:25:37.775 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:25:37.775 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:25:37.815 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:25:37.815 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:25:37.815 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:25:57.849 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:25:57.849 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (1) | New receive buffer size: 0 2026-06-01 09:25:57.849 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 09:25:58.582 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:25:58.643 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:25:58.956 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (1) | CloseSocket call. 2026-06-01 09:25:58.956 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 09:25:59.064 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (1) | Socket gracefully closed by remote side. 2026-06-01 09:25:59.064 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (1) | Closed. 2026-06-01 09:27:37.831 | 2026-06-01 09:27:37.831 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:27:37.831 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:27:37.831 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:27:37.831 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:27:37.831 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:27:37.872 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:27:37.872 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:27:37.872 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:27:57.898 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:27:57.898 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (1) | New receive buffer size: 0 2026-06-01 09:27:57.898 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 09:27:58.562 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:27:58.623 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:27:58.905 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (1) | CloseSocket call. 2026-06-01 09:27:58.905 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 09:27:59.013 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (1) | Socket gracefully closed by remote side. 2026-06-01 09:27:59.013 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (1) | Closed. 2026-06-01 09:29:37.883 | 2026-06-01 09:29:37.883 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:29:37.883 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:29:37.883 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:29:37.883 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:29:37.883 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:29:37.919 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:29:37.919 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:29:37.919 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:29:57.979 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:29:57.979 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (1) | New receive buffer size: 0 2026-06-01 09:29:57.979 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 09:29:58.696 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:29:58.785 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:29:59.148 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (1) | CloseSocket call. 2026-06-01 09:29:59.148 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 09:29:59.257 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (1) | Socket gracefully closed by remote side. 2026-06-01 09:29:59.257 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (1) | Closed. 2026-06-01 09:31:37.924 | 2026-06-01 09:31:37.924 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:31:37.924 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:31:37.924 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:31:37.924 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:31:37.924 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:31:37.958 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:31:37.958 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:31:37.958 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:31:57.990 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:31:57.991 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (1) | New receive buffer size: 0 2026-06-01 09:31:57.991 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:31:59.196 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:31:59.221 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:31:59.291 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:31:59.291 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (1) | CloseSocket call. 2026-06-01 09:31:59.291 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:31:59.291 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (1) | Closed. 2026-06-01 09:33:37.977 | 2026-06-01 09:33:37.977 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:33:37.977 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:33:37.977 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:33:37.977 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:33:37.977 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:33:38.015 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:33:38.015 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:33:38.015 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:33:58.053 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:33:58.053 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (1) | New receive buffer size: 0 2026-06-01 09:33:58.053 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:33:59.275 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:33:59.292 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:33:59.352 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:33:59.352 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (1) | CloseSocket call. 2026-06-01 09:33:59.352 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:33:59.352 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (1) | Closed. 2026-06-01 09:35:38.025 | 2026-06-01 09:35:38.025 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:35:38.025 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:35:38.025 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:35:38.025 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:35:38.025 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:35:38.044 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:35:38.044 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:35:38.044 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:35:58.114 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:35:58.114 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (1) | New receive buffer size: 0 2026-06-01 09:35:58.114 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:35:59.267 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:35:59.286 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:35:59.385 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:35:59.385 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (1) | CloseSocket call. 2026-06-01 09:35:59.385 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:35:59.385 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (1) | Closed. 2026-06-01 09:37:38.065 | 2026-06-01 09:37:38.067 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:37:38.067 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:37:38.067 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:37:38.067 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:37:38.067 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:37:38.104 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:37:38.104 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:37:38.104 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:37:58.151 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:37:58.157 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (1) | New receive buffer size: 0 2026-06-01 09:37:58.158 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:37:59.752 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:37:59.771 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:38:00.011 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:38:00.012 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (1) | CloseSocket call. 2026-06-01 09:38:00.013 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:38:00.014 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (1) | Closed. 2026-06-01 09:39:38.113 | 2026-06-01 09:39:38.114 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:39:38.114 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:39:38.114 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:39:38.114 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:39:38.114 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:39:38.147 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:39:38.147 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:39:38.147 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:39:58.138 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:39:58.138 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (1) | New receive buffer size: 0 2026-06-01 09:39:58.138 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:39:59.226 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:39:59.249 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:39:59.343 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:39:59.343 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (1) | CloseSocket call. 2026-06-01 09:39:59.344 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:39:59.344 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (1) | Closed. 2026-06-01 09:41:38.217 | 2026-06-01 09:41:38.217 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:41:38.217 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:41:38.217 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:41:38.217 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:41:38.217 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:41:38.258 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:41:38.258 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:41:38.258 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:41:58.392 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:41:58.392 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (1) | New receive buffer size: 0 2026-06-01 09:41:58.393 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:41:59.595 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:41:59.599 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:41:59.658 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:41:59.659 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (1) | CloseSocket call. 2026-06-01 09:41:59.659 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:41:59.659 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (1) | Closed. 2026-06-01 09:43:38.275 | 2026-06-01 09:43:38.275 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:43:38.275 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:43:38.275 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:43:38.275 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:43:38.275 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:43:38.323 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:43:38.323 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:43:38.323 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:43:58.340 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:43:58.341 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (1) | New receive buffer size: 0 2026-06-01 09:43:58.341 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:43:59.546 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:43:59.559 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:43:59.628 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:43:59.628 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (1) | CloseSocket call. 2026-06-01 09:43:59.629 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:43:59.629 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (1) | Closed. 2026-06-01 09:45:38.347 | 2026-06-01 09:45:38.347 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:45:38.347 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:45:38.347 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:45:38.347 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:45:38.347 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:45:38.370 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:45:38.370 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:45:38.370 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:45:58.387 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:45:58.387 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (1) | New receive buffer size: 0 2026-06-01 09:45:58.387 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:45:59.624 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:45:59.638 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:45:59.730 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:45:59.730 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (1) | CloseSocket call. 2026-06-01 09:45:59.730 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:45:59.730 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (1) | Closed. 2026-06-01 09:47:38.403 | 2026-06-01 09:47:38.403 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:47:38.403 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:47:38.403 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:47:38.403 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:47:38.403 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:47:38.423 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:47:38.423 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:47:38.423 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:47:58.467 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:47:58.467 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | New receive buffer size: 0 2026-06-01 09:47:58.467 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:47:59.748 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | Socket gracefully closed by remote side. 2026-06-01 09:47:59.765 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:47:59.776 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | Socket gracefully closed by remote side. 2026-06-01 09:47:59.873 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:47:59.874 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | CloseSocket call. 2026-06-01 09:47:59.874 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:47:59.874 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (1) | Closed. 2026-06-01 09:49:38.457 | 2026-06-01 09:49:38.457 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:49:38.458 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:49:38.458 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:49:38.458 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:49:38.458 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:49:38.499 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:49:38.499 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:49:38.499 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:49:58.617 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:49:58.617 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (1) | New receive buffer size: 0 2026-06-01 09:49:58.617 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 09:49:59.353 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:49:59.438 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:49:59.735 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (1) | CloseSocket call. 2026-06-01 09:49:59.735 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 09:49:59.844 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (1) | Socket gracefully closed by remote side. 2026-06-01 09:49:59.844 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (1) | Closed. 2026-06-01 09:51:38.555 | 2026-06-01 09:51:38.555 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:51:38.555 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:51:38.555 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:51:38.555 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:51:38.555 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:51:38.604 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:51:38.604 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:51:38.604 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:51:58.584 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:51:58.584 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (1) | New receive buffer size: 0 2026-06-01 09:51:58.585 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 09:51:59.386 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:51:59.468 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:51:59.838 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (1) | CloseSocket call. 2026-06-01 09:51:59.838 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 09:51:59.948 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (1) | Socket gracefully closed by remote side. 2026-06-01 09:51:59.948 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (1) | Closed. 2026-06-01 09:53:38.675 | 2026-06-01 09:53:38.676 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:53:38.676 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:53:38.676 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:53:38.676 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:53:38.676 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:53:38.700 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:53:38.700 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:53:38.700 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:53:58.775 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:53:58.776 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (1) | New receive buffer size: 0 2026-06-01 09:53:58.776 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 09:53:59.538 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:53:59.633 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:53:59.897 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (1) | CloseSocket call. 2026-06-01 09:53:59.897 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 09:54:00.005 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (1) | Socket gracefully closed by remote side. 2026-06-01 09:54:00.006 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (1) | Closed. 2026-06-01 09:55:38.737 | 2026-06-01 09:55:38.737 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:55:38.737 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:55:38.737 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:55:38.737 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:55:38.737 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:55:38.771 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:55:38.771 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:55:38.771 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:55:58.801 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:55:58.801 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (1) | New receive buffer size: 0 2026-06-01 09:55:58.801 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:55:59.884 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 09:55:59.912 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:55:59.975 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:55:59.975 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (1) | CloseSocket call. 2026-06-01 09:55:59.975 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:55:59.975 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (1) | Closed. 2026-06-01 09:57:38.784 | 2026-06-01 09:57:38.784 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:57:38.784 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:57:38.784 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:57:38.784 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:57:38.784 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:57:38.818 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:57:38.818 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:57:38.818 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:57:58.806 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:57:58.807 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (1) | New receive buffer size: 0 2026-06-01 09:57:58.807 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 09:57:59.892 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (1) | Socket gracefully closed by remote side. 2026-06-01 09:57:59.896 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 09:57:59.896 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (1) | Socket gracefully closed by remote side. 2026-06-01 09:57:59.962 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 09:57:59.962 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (1) | CloseSocket call. 2026-06-01 09:57:59.962 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 09:57:59.962 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (1) | Closed. 2026-06-01 09:59:38.829 | 2026-06-01 09:59:38.829 | Rithmic Direct - DTC | Using server connection: 2026-06-01 09:59:38.829 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:59:38.829 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 09:59:38.829 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 09:59:38.829 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:59:38.847 | DTC Client socket (0) | CloseSocket call. 2026-06-01 09:59:38.847 | Rithmic Direct - DTC | Disconnected. 2026-06-01 09:59:38.847 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 09:59:58.995 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (1) | Creating socket. Using TLS 1.2. 2026-06-01 09:59:58.996 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (1) | New receive buffer size: 0 2026-06-01 09:59:58.996 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:00:00.204 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:00:00.236 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:00:00.314 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:00:00.315 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (1) | CloseSocket call. 2026-06-01 10:00:00.315 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:00:00.315 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (1) | Closed. 2026-06-01 10:01:38.851 | 2026-06-01 10:01:38.851 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:01:38.851 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:01:38.851 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:01:38.851 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:01:38.851 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:01:38.889 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:01:38.889 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:01:38.889 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:01:58.977 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:01:58.978 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (1) | New receive buffer size: 0 2026-06-01 10:01:58.978 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 10:01:59.798 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:01:59.873 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:02:00.160 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (1) | CloseSocket call. 2026-06-01 10:02:00.160 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 10:02:00.274 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (1) | Socket gracefully closed by remote side. 2026-06-01 10:02:00.274 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (1) | Closed. 2026-06-01 10:03:38.902 | 2026-06-01 10:03:38.903 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:03:38.903 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:03:38.903 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:03:38.903 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:03:38.903 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:03:38.950 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:03:38.950 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:03:38.950 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:03:58.916 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:03:58.916 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (1) | New receive buffer size: 0 2026-06-01 10:03:58.916 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 10:03:59.582 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:03:59.647 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:03:59.915 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (1) | CloseSocket call. 2026-06-01 10:03:59.915 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 10:04:00.025 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (1) | Socket gracefully closed by remote side. 2026-06-01 10:04:00.025 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (1) | Closed. 2026-06-01 10:04:07.488 | ESM6.CME [CBV][M] #13 | Reloading chart. 2026-06-01 10:04:07.492 | ESM6.CME [CBV][M] #13 | Performing continuous chart historical Daily data download for symbol ESM6.CME starting at last date in file. 2026-06-01 10:04:07.493 | Starting DelayedDownloadMonitoringTimer 2026-06-01 10:04:07.493 | Starting HDTimeoutTimer 2026-06-01 10:04:07.494 | Added historical Daily data request for ESM6.CME to the queue. 2026-06-01 10:04:07.494 | Triggering next historical data download in queue. 2026-06-01 10:04:07.514 | ESM6.CME [CBV][M] #13 | Waiting for historical downloads to complete with the IDs: 9, 2026-06-01 10:04:07.519 | HD Request # 12 | Downloading Historical Daily chart data for ESM6.CME. Starting date: 2026-05-28. Service: rithmic.trading 2026-06-01 10:04:08.131 | HD Request # 12 | Requesting historical Daily data for ESM26 starting at 2026-05-27. SC External HD service. 2026-06-01 10:04:08.692 | HD Request # 12 | Receiving historical Daily data for ESM6.CME starting at 2026-05-28. 2026-06-01 10:04:08.693 | HD Request # 12 | Writing historical Daily data to the file ESM6.CME.dly. 2026-06-01 10:04:08.698 | HD Request # 12 | Bytes received: 236 2026-06-01 10:04:08.698 | HD Request # 12 | Received 4 Daily data records from 2026-05-28 00:00:00 to 2026-06-01 00:00:00 (5.0 days) and wrote 3 records for ESM6.CME 2026-06-01 10:04:08.717 | HD Request # 12 | Completion time: 1s. 2026-06-01 10:04:08.717 | HD Request # 12 | Daily data download complete for ESM6.CME. Unique request ID: 9 2026-06-01 10:04:08.717 | Removing historical data download ID 9. 2026-06-01 10:04:08.718 | 2026-06-01 10:04:08.718 | No download requests in the queue to start downloads for. 2026-06-01 10:04:08.779 | ESM6.CME [CBV][M] #13 | Download is complete for all contract months in chart. Proceeding with data load. 2026-06-01 10:04:08.780 | ESM6.CME [CBV][M] #13 | Reloading chart. | Number times message added: 1 2026-06-01 10:04:15.830 | ESM6.CME [CBV][M] #13 | StartDateTimeForLoadingOrderFills: 2025-05-22 00:00:00 2026-06-01 10:04:15.858 | Chart #13 has tagged chart #16 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:15.858 | Chart #13 has tagged chart #18 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:15.858 | Chart #13 has tagged chart #19 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:15.858 | Chart #13 has tagged chart #32 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:15.858 | Chart #13 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:15.858 | Chart #13 has tagged chart #8 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:15.871 | ESM6.CME [CBV][M] #13 | Chart data loading complete. 2026-06-01 10:04:15.926 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:15.979 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:04:16.173 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:16.183 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:04:16.238 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:16.558 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:04:17.198 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:17.277 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:04:17.366 | Chart #16 has tagged chart #26 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:17.366 | Chart #16 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:17.366 | Chart #16 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:17.384 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:17.389 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:04:17.455 | ESM6.CME[M] Renko 6t #26 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:17.534 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:17.546 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:04:17.608 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:17.778 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:04:18.358 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:05:38.987 | 2026-06-01 10:05:38.987 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:05:38.987 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:05:38.987 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:05:38.987 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:05:38.987 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:05:39.030 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:05:39.030 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:05:39.030 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:05:59.048 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:05:59.048 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (1) | New receive buffer size: 0 2026-06-01 10:05:59.048 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 10:05:59.835 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:05:59.925 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:06:00.263 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (1) | CloseSocket call. 2026-06-01 10:06:00.263 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 10:06:00.371 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (1) | Socket gracefully closed by remote side. 2026-06-01 10:06:00.371 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (1) | Closed. 2026-06-01 10:07:39.069 | 2026-06-01 10:07:39.069 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:07:39.069 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:07:39.069 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:07:39.069 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:07:39.069 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:07:39.106 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:07:39.106 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:07:39.106 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:07:59.120 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:07:59.120 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (1) | New receive buffer size: 0 2026-06-01 10:07:59.120 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:08:00.213 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:08:00.214 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:08:00.296 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:08:00.296 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (1) | CloseSocket call. 2026-06-01 10:08:00.296 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:08:00.296 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (1) | Closed. 2026-06-01 10:09:39.119 | 2026-06-01 10:09:39.120 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:09:39.120 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:09:39.120 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:09:39.120 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:09:39.120 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:09:39.214 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:09:39.214 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:09:39.214 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:09:59.131 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:09:59.131 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (1) | New receive buffer size: 0 2026-06-01 10:09:59.131 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:10:00.244 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:10:00.299 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:10:00.369 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:10:00.369 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (1) | CloseSocket call. 2026-06-01 10:10:00.369 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:10:00.369 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (1) | Closed. 2026-06-01 10:11:21.017 | Chart #13 has tagged chart #16 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:21.017 | Chart #13 has tagged chart #18 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:21.017 | Chart #13 has tagged chart #19 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:21.017 | Chart #13 has tagged chart #32 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:21.017 | Chart #13 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:21.017 | Chart #13 has tagged chart #8 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:21.104 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:21.106 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:11:21.179 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:21.187 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:11:21.240 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:21.302 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:21.334 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:11:21.474 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:21.980 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:11:22.356 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:22.358 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:11:22.396 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:22.629 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:11:22.640 | HTTPS connection ID:3 to docs.google.com:443 for request ID:3 (10) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:11:22.640 | HTTPS connection ID:3 to docs.google.com:443 for request ID:3 (10) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:11:23.312 | Chart #13 has tagged chart #18 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.312 | Chart #13 has tagged chart #19 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.312 | Chart #13 has tagged chart #32 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.312 | Chart #13 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.312 | Chart #13 has tagged chart #8 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.418 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.475 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:11:23.546 | Chart #16 has tagged chart #26 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.546 | Chart #16 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.546 | Chart #16 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.569 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.570 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:11:23.623 | ESM6.CME[M] Renko 6t #26 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.704 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.711 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:11:23.733 | HTTPS connection ID:15 to docs.google.com:443 for request ID:15 (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:11:23.733 | HTTPS connection ID:16 to docs.google.com:443 for request ID:16 (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:11:23.761 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.786 | HTTPS connection ID:15 to docs.google.com:443 for request ID:15 (5) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:11:23.786 | HTTPS connection ID:16 to docs.google.com:443 for request ID:16 (6) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:11:23.896 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:23.919 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:11:23.940 | HTTPS connection ID:5 to docs.google.com:443 for request ID:5 (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:11:24.046 | HTTPS connection ID:5 to docs.google.com:443 for request ID:5 (5) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:11:24.148 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:24.681 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:11:24.690 | HTTPS connection ID:12 to docs.google.com:443 for request ID:12 (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:11:24.693 | HTTPS connection ID:13 to docs.google.com:443 for request ID:13 (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:11:24.866 | HTTPS connection ID:12 to docs.google.com:443 for request ID:12 (5) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:11:24.866 | HTTPS connection ID:13 to docs.google.com:443 for request ID:13 (6) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:11:24.917 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:24.918 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:11:24.934 | HTTPS connection ID:9 to docs.google.com:443 for request ID:9 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:11:24.934 | HTTPS connection ID:10 to docs.google.com:443 for request ID:10 (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:11:24.958 | HTTPS connection ID:9 to docs.google.com:443 for request ID:9 (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:11:24.958 | HTTPS connection ID:10 to docs.google.com:443 for request ID:10 (2) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:11:24.973 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:11:25.190 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:11:25.199 | HTTPS connection ID:4 to docs.google.com:443 for request ID:4 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:11:25.699 | HTTPS connection ID:4 to docs.google.com:443 for request ID:4 (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:11:39.225 | 2026-06-01 10:11:39.226 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:11:39.226 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:11:39.226 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:11:39.226 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:11:39.226 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:11:39.239 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:11:39.239 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:11:39.239 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:11:59.284 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:11:59.284 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (1) | New receive buffer size: 0 2026-06-01 10:11:59.285 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:12:00.501 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:12:00.516 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:12:00.648 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:12:00.648 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (1) | CloseSocket call. 2026-06-01 10:12:00.648 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:12:00.648 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (1) | Closed. 2026-06-01 10:12:25.052 | Chart #13 has tagged chart #16 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:25.052 | Chart #13 has tagged chart #18 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:25.053 | Chart #13 has tagged chart #19 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:25.053 | Chart #13 has tagged chart #32 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:25.053 | Chart #13 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:25.053 | Chart #13 has tagged chart #8 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:25.140 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:25.141 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:25.205 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:25.210 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:25.260 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:25.348 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:25.370 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:12:25.491 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:25.968 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:26.307 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:26.308 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:26.346 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:26.561 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:12:27.116 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:27.160 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:27.221 | Chart #16 has tagged chart #26 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:27.221 | Chart #16 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:27.221 | Chart #16 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:27.260 | ESM6.CME[M] Renko 6t #26 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:27.323 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:27.328 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:27.373 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:27.459 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:27.947 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:27.963 | HTTPS connection ID:17 to docs.google.com:443 for request ID:17 (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:28.330 | HTTPS connection ID:17 to docs.google.com:443 for request ID:17 (6) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:31.488 | Chart #13 has tagged chart #16 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:31.488 | Chart #13 has tagged chart #18 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:31.488 | Chart #13 has tagged chart #19 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:31.488 | Chart #13 has tagged chart #32 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:31.488 | Chart #13 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:31.488 | Chart #13 has tagged chart #8 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:31.587 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:31.588 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:31.598 | HTTPS connection ID:13 to docs.google.com:443 for request ID:13 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:31.603 | HTTPS connection ID:14 to docs.google.com:443 for request ID:14 (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:31.625 | HTTPS connection ID:13 to docs.google.com:443 for request ID:13 (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:31.633 | HTTPS connection ID:14 to docs.google.com:443 for request ID:14 (2) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:31.672 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:31.677 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:31.684 | HTTPS connection ID:21 to docs.google.com:443 for request ID:21 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:31.685 | HTTPS connection ID:22 to docs.google.com:443 for request ID:22 (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:31.722 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:31.748 | HTTPS connection ID:21 to docs.google.com:443 for request ID:21 (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:31.748 | HTTPS connection ID:22 to docs.google.com:443 for request ID:22 (2) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:31.851 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:31.877 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:12:31.896 | HTTPS connection ID:7 to docs.google.com:443 for request ID:7 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:31.990 | HTTPS connection ID:7 to docs.google.com:443 for request ID:7 (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:32.025 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:32.505 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:32.516 | HTTPS connection ID:18 to docs.google.com:443 for request ID:18 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:32.516 | HTTPS connection ID:19 to docs.google.com:443 for request ID:19 (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:32.688 | HTTPS connection ID:18 to docs.google.com:443 for request ID:18 (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:32.688 | HTTPS connection ID:19 to docs.google.com:443 for request ID:19 (2) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:32.737 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:32.738 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:32.747 | HTTPS connection ID:13 to docs.google.com:443 for request ID:13 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:32.753 | HTTPS connection ID:14 to docs.google.com:443 for request ID:14 (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:32.776 | HTTPS connection ID:13 to docs.google.com:443 for request ID:13 (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:32.784 | HTTPS connection ID:14 to docs.google.com:443 for request ID:14 (2) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:32.791 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:33.015 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:12:33.025 | HTTPS connection ID:6 to docs.google.com:443 for request ID:6 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:33.484 | HTTPS connection ID:6 to docs.google.com:443 for request ID:6 (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:33.575 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:33.620 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:33.627 | HTTPS connection ID:13 to docs.google.com:443 for request ID:13 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:33.628 | HTTPS connection ID:14 to docs.google.com:443 for request ID:14 (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:33.686 | Chart #16 has tagged chart #26 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:33.686 | Chart #16 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:33.686 | Chart #16 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:33.697 | HTTPS connection ID:13 to docs.google.com:443 for request ID:13 (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:33.697 | HTTPS connection ID:14 to docs.google.com:443 for request ID:14 (2) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:33.769 | ESM6.CME[M] Renko 6t #26 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:33.839 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:33.844 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:33.852 | HTTPS connection ID:23 to docs.google.com:443 for request ID:23 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:33.853 | HTTPS connection ID:24 to docs.google.com:443 for request ID:24 (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:33.894 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:33.918 | HTTPS connection ID:23 to docs.google.com:443 for request ID:23 (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:33.918 | HTTPS connection ID:24 to docs.google.com:443 for request ID:24 (2) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:34.037 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:12:34.511 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:12:34.520 | HTTPS connection ID:20 to docs.google.com:443 for request ID:20 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:34.520 | HTTPS connection ID:21 to docs.google.com:443 for request ID:21 (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:12:34.695 | HTTPS connection ID:20 to docs.google.com:443 for request ID:20 (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:12:34.695 | HTTPS connection ID:21 to docs.google.com:443 for request ID:21 (2) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:13:24.677 | Chart #13 has tagged chart #16 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:24.677 | Chart #13 has tagged chart #18 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:24.677 | Chart #13 has tagged chart #19 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:24.677 | Chart #13 has tagged chart #32 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:24.677 | Chart #13 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:24.677 | Chart #13 has tagged chart #8 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:24.792 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:24.793 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:13:24.830 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:25.053 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:13:25.539 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:25.581 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:13:25.648 | Chart #16 has tagged chart #26 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:25.648 | Chart #16 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:25.648 | Chart #16 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:25.662 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:25.663 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:13:25.730 | ESM6.CME[M] Renko 6t #26 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:25.799 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:25.804 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:13:25.851 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:25.904 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:25.926 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:13:26.197 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:26.670 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:13:26.687 | HTTPS connection ID:22 to docs.google.com:443 for request ID:22 (11) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:13:26.687 | HTTPS connection ID:22 to docs.google.com:443 for request ID:22 (11) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:13:26.692 | HTTPS connection ID:23 to docs.google.com:443 for request ID:23 (12) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:13:27.009 | HTTPS connection ID:23 to docs.google.com:443 for request ID:23 (12) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:13:31.800 | Chart #13 has tagged chart #16 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:31.800 | Chart #13 has tagged chart #18 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:31.800 | Chart #13 has tagged chart #19 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:31.800 | Chart #13 has tagged chart #32 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:31.800 | Chart #13 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:31.800 | Chart #13 has tagged chart #8 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:31.908 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:31.952 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:13:32.019 | Chart #16 has tagged chart #26 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:32.019 | Chart #16 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:32.019 | Chart #16 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:32.031 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:32.032 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:13:32.050 | HTTPS connection ID:18 to docs.google.com:443 for request ID:18 (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:13:32.068 | HTTPS connection ID:18 to docs.google.com:443 for request ID:18 (4) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:13:32.090 | ESM6.CME[M] Renko 6t #26 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:32.157 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:32.162 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:13:32.170 | HTTPS connection ID:27 to docs.google.com:443 for request ID:27 (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:13:32.170 | HTTPS connection ID:28 to docs.google.com:443 for request ID:28 (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:13:32.209 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:32.234 | HTTPS connection ID:27 to docs.google.com:443 for request ID:27 (4) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:13:32.234 | HTTPS connection ID:28 to docs.google.com:443 for request ID:28 (5) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:13:32.344 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:32.373 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:13:32.380 | HTTPS connection ID:9 to docs.google.com:443 for request ID:9 (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:13:32.488 | HTTPS connection ID:9 to docs.google.com:443 for request ID:9 (4) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:13:32.572 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:33.080 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:13:33.094 | HTTPS connection ID:24 to docs.google.com:443 for request ID:24 (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:13:33.094 | HTTPS connection ID:25 to docs.google.com:443 for request ID:25 (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:13:33.271 | HTTPS connection ID:24 to docs.google.com:443 for request ID:24 (4) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:13:33.271 | HTTPS connection ID:25 to docs.google.com:443 for request ID:25 (5) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:13:33.326 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:33.327 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:13:33.349 | HTTPS connection ID:17 to docs.google.com:443 for request ID:17 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:13:33.353 | HTTPS connection ID:18 to docs.google.com:443 for request ID:18 (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:13:33.368 | HTTPS connection ID:17 to docs.google.com:443 for request ID:17 (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:13:33.376 | HTTPS connection ID:18 to docs.google.com:443 for request ID:18 (2) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:13:33.388 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:13:33.600 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:13:33.617 | HTTPS connection ID:8 to docs.google.com:443 for request ID:8 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:13:34.066 | HTTPS connection ID:8 to docs.google.com:443 for request ID:8 (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:13:39.305 | 2026-06-01 10:13:39.305 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:13:39.305 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:13:39.305 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:13:39.305 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:13:39.305 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:13:39.362 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:13:39.362 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:13:39.362 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:13:59.363 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:13:59.363 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (1) | New receive buffer size: 0 2026-06-01 10:13:59.363 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 10:14:00.117 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:14:00.183 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:14:00.463 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (1) | CloseSocket call. 2026-06-01 10:14:00.463 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 10:14:00.571 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (1) | Socket gracefully closed by remote side. 2026-06-01 10:14:00.571 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (1) | Closed. 2026-06-01 10:15:39.373 | 2026-06-01 10:15:39.373 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:15:39.373 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:15:39.373 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:15:39.373 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:15:39.373 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:15:39.410 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:15:39.410 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:15:39.410 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:15:59.383 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:15:59.383 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (1) | New receive buffer size: 0 2026-06-01 10:15:59.383 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 10:16:00.237 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:16:00.296 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:16:00.634 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (1) | CloseSocket call. 2026-06-01 10:16:00.634 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 10:16:00.743 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (1) | Socket gracefully closed by remote side. 2026-06-01 10:16:00.743 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (1) | Closed. 2026-06-01 10:17:39.445 | 2026-06-01 10:17:39.445 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:17:39.445 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:17:39.445 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:17:39.445 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:17:39.445 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:17:39.476 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:17:39.476 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:17:39.476 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:17:59.565 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:17:59.565 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (1) | New receive buffer size: 0 2026-06-01 10:17:59.565 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 10:18:00.352 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:18:00.443 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:18:00.704 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (1) | CloseSocket call. 2026-06-01 10:18:00.704 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 10:18:00.823 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (1) | Socket gracefully closed by remote side. 2026-06-01 10:18:00.823 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (1) | Closed. 2026-06-01 10:19:39.496 | 2026-06-01 10:19:39.496 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:19:39.496 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:19:39.496 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:19:39.496 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:19:39.496 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:19:39.545 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:19:39.545 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:19:39.545 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:19:59.552 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:19:59.552 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (1) | New receive buffer size: 0 2026-06-01 10:19:59.552 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:20:00.681 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:20:00.684 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:20:00.779 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:20:00.779 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (1) | CloseSocket call. 2026-06-01 10:20:00.779 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:20:00.779 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (1) | Closed. 2026-06-01 10:21:39.566 | 2026-06-01 10:21:39.566 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:21:39.566 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:21:39.566 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:21:39.566 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:21:39.566 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:21:39.616 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:21:39.616 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:21:39.616 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:21:59.682 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:21:59.682 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | New receive buffer size: 0 2026-06-01 10:21:59.682 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:22:00.911 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:22:00.926 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:22:01.050 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:22:01.050 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | CloseSocket call. 2026-06-01 10:22:01.050 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:22:01.050 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | Closed. 2026-06-01 10:23:39.620 | 2026-06-01 10:23:39.620 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:23:39.620 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:23:39.620 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:23:39.620 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:23:39.620 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:23:39.749 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:23:39.749 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:23:39.749 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:23:59.698 | HTTPS connection ID:38 to downloads.rithmic.com:443 for request ID:38 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:23:59.698 | HTTPS connection ID:38 to downloads.rithmic.com:443 for request ID:38 (1) | New receive buffer size: 0 2026-06-01 10:23:59.698 | HTTPS connection ID:38 to downloads.rithmic.com:443 for request ID:38 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:24:00.868 | HTTPS connection ID:38 to downloads.rithmic.com:443 for request ID:38 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:24:00.882 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:24:00.961 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:24:00.961 | HTTPS connection ID:38 to downloads.rithmic.com:443 for request ID:38 (1) | CloseSocket call. 2026-06-01 10:24:00.961 | HTTPS connection ID:38 to downloads.rithmic.com:443 for request ID:38 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:24:00.961 | HTTPS connection ID:38 to downloads.rithmic.com:443 for request ID:38 (1) | Closed. 2026-06-01 10:24:28.294 | Chart #13 has tagged chart #16 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.294 | Chart #13 has tagged chart #18 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.294 | Chart #13 has tagged chart #19 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.294 | Chart #13 has tagged chart #32 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.294 | Chart #13 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.294 | Chart #13 has tagged chart #8 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.396 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.463 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:24:28.552 | Chart #16 has tagged chart #26 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.553 | Chart #16 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.553 | Chart #16 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.564 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.567 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:24:28.625 | ESM6.CME[M] Renko 6t #26 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.697 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.705 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:24:28.759 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.813 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:28.848 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:24:28.982 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:29.521 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:24:30.017 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:30.019 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:24:30.039 | HTTPS connection ID:20 to docs.google.com:443 for request ID:20 (11) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:24:30.060 | HTTPS connection ID:20 to docs.google.com:443 for request ID:20 (11) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:24:30.067 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:24:30.352 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:24:30.371 | HTTPS connection ID:9 to docs.google.com:443 for request ID:9 (11) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:24:30.916 | HTTPS connection ID:9 to docs.google.com:443 for request ID:9 (11) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:25:15.362 | Chart #13 has tagged chart #16 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:15.362 | Chart #13 has tagged chart #18 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:15.362 | Chart #13 has tagged chart #19 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:15.362 | Chart #13 has tagged chart #32 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:15.362 | Chart #13 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:15.362 | Chart #13 has tagged chart #8 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:15.408 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:15.409 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #19 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:25:15.448 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:15.675 | NQM6.CME/MNQM6.CME [CBV][M] Renko 24t #18 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:25:16.238 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:16.281 | ESM6.CME[M]/MESM6.CME [CBV][M] 3000 Volume #16 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:25:16.349 | Chart #16 has tagged chart #26 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:16.349 | Chart #16 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:16.349 | Chart #16 has tagged chart #5 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:16.375 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:16.376 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #32 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:25:16.432 | ESM6.CME[M] Renko 6t #26 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:16.508 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:16.513 | ESM6.CME[M]/MESM6.CME [CBV][M] 2500 Volume #5 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:25:16.564 | Chart #5 has tagged chart #38 for full recalculation. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:16.615 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:16.641 | ESM6.CME/MESM6.CME [CBV][M] Renko 8t #8 | Study: Google Sheets Importer | Making HTTP request. 2026-06-01 10:25:16.996 | ESM6.CME [CB][M] 5 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: NEW MASTER ES.Cht 2026-06-01 10:25:17.499 | ESM6.CME [CB][M] 5 Min #38 | Study: Google Sheets Importer | Making HTTP request. | Number times message added: 1 2026-06-01 10:25:17.508 | HTTPS connection ID:29 to docs.google.com:443 for request ID:29 (10) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-06-01 10:25:17.795 | HTTPS connection ID:29 to docs.google.com:443 for request ID:29 (10) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-06-01 10:25:39.757 | 2026-06-01 10:25:39.757 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:25:39.757 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:25:39.757 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:25:39.757 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:25:39.757 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:25:39.862 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:25:39.862 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:25:39.862 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:25:59.808 | HTTPS connection ID:39 to downloads.rithmic.com:443 for request ID:39 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:25:59.809 | HTTPS connection ID:39 to downloads.rithmic.com:443 for request ID:39 (1) | New receive buffer size: 0 2026-06-01 10:25:59.809 | HTTPS connection ID:39 to downloads.rithmic.com:443 for request ID:39 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:26:00.996 | HTTPS connection ID:39 to downloads.rithmic.com:443 for request ID:39 (1) | Socket gracefully closed by remote side. 2026-06-01 10:26:01.048 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:26:01.048 | HTTPS connection ID:39 to downloads.rithmic.com:443 for request ID:39 (1) | Socket gracefully closed by remote side. 2026-06-01 10:26:01.147 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:26:01.147 | HTTPS connection ID:39 to downloads.rithmic.com:443 for request ID:39 (1) | CloseSocket call. 2026-06-01 10:26:01.147 | HTTPS connection ID:39 to downloads.rithmic.com:443 for request ID:39 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:26:01.147 | HTTPS connection ID:39 to downloads.rithmic.com:443 for request ID:39 (1) | Closed. 2026-06-01 10:27:39.894 | 2026-06-01 10:27:39.894 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:27:39.894 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:27:39.894 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:27:39.894 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:27:39.894 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:27:39.912 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:27:39.912 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:27:39.912 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:27:59.904 | HTTPS connection ID:40 to downloads.rithmic.com:443 for request ID:40 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:27:59.905 | HTTPS connection ID:40 to downloads.rithmic.com:443 for request ID:40 (1) | New receive buffer size: 0 2026-06-01 10:27:59.905 | HTTPS connection ID:40 to downloads.rithmic.com:443 for request ID:40 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:28:00.901 | HTTPS connection ID:40 to downloads.rithmic.com:443 for request ID:40 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:28:00.923 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:28:01.004 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:28:01.004 | HTTPS connection ID:40 to downloads.rithmic.com:443 for request ID:40 (1) | CloseSocket call. 2026-06-01 10:28:01.004 | HTTPS connection ID:40 to downloads.rithmic.com:443 for request ID:40 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:28:01.004 | HTTPS connection ID:40 to downloads.rithmic.com:443 for request ID:40 (1) | Closed. 2026-06-01 10:29:40.023 | 2026-06-01 10:29:40.023 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:29:40.023 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:29:40.023 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:29:40.023 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:29:40.023 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:29:40.081 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:29:40.081 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:29:40.081 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:30:00.085 | HTTPS connection ID:41 to downloads.rithmic.com:443 for request ID:41 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:30:00.085 | HTTPS connection ID:41 to downloads.rithmic.com:443 for request ID:41 (1) | New receive buffer size: 0 2026-06-01 10:30:00.085 | HTTPS connection ID:41 to downloads.rithmic.com:443 for request ID:41 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:30:01.340 | HTTPS connection ID:41 to downloads.rithmic.com:443 for request ID:41 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:30:01.350 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:30:01.417 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:30:01.417 | HTTPS connection ID:41 to downloads.rithmic.com:443 for request ID:41 (1) | CloseSocket call. 2026-06-01 10:30:01.417 | HTTPS connection ID:41 to downloads.rithmic.com:443 for request ID:41 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:30:01.417 | HTTPS connection ID:41 to downloads.rithmic.com:443 for request ID:41 (1) | Closed. 2026-06-01 10:31:40.090 | 2026-06-01 10:31:40.091 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:31:40.091 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:31:40.091 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:31:40.091 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:31:40.091 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:31:40.123 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:31:40.123 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:31:40.123 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:32:00.179 | HTTPS connection ID:42 to downloads.rithmic.com:443 for request ID:42 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:32:00.179 | HTTPS connection ID:42 to downloads.rithmic.com:443 for request ID:42 (1) | New receive buffer size: 0 2026-06-01 10:32:00.179 | HTTPS connection ID:42 to downloads.rithmic.com:443 for request ID:42 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:32:01.470 | HTTPS connection ID:42 to downloads.rithmic.com:443 for request ID:42 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:32:01.480 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:32:01.582 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:32:01.583 | HTTPS connection ID:42 to downloads.rithmic.com:443 for request ID:42 (1) | CloseSocket call. 2026-06-01 10:32:01.583 | HTTPS connection ID:42 to downloads.rithmic.com:443 for request ID:42 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:32:01.583 | HTTPS connection ID:42 to downloads.rithmic.com:443 for request ID:42 (1) | Closed. 2026-06-01 10:33:40.143 | 2026-06-01 10:33:40.143 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:33:40.143 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:33:40.143 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:33:40.143 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:33:40.143 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:33:40.172 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:33:40.173 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:33:40.173 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:34:00.157 | HTTPS connection ID:43 to downloads.rithmic.com:443 for request ID:43 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:34:00.158 | HTTPS connection ID:43 to downloads.rithmic.com:443 for request ID:43 (1) | New receive buffer size: 0 2026-06-01 10:34:00.158 | HTTPS connection ID:43 to downloads.rithmic.com:443 for request ID:43 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:34:01.318 | HTTPS connection ID:43 to downloads.rithmic.com:443 for request ID:43 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:34:01.348 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:34:01.432 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:34:01.432 | HTTPS connection ID:43 to downloads.rithmic.com:443 for request ID:43 (1) | CloseSocket call. 2026-06-01 10:34:01.432 | HTTPS connection ID:43 to downloads.rithmic.com:443 for request ID:43 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:34:01.432 | HTTPS connection ID:43 to downloads.rithmic.com:443 for request ID:43 (1) | Closed. 2026-06-01 10:35:40.198 | 2026-06-01 10:35:40.198 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:35:40.198 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:35:40.198 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:35:40.198 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:35:40.198 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:35:40.240 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:35:40.240 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:35:40.240 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:36:00.269 | HTTPS connection ID:44 to downloads.rithmic.com:443 for request ID:44 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:36:00.270 | HTTPS connection ID:44 to downloads.rithmic.com:443 for request ID:44 (1) | New receive buffer size: 0 2026-06-01 10:36:00.270 | HTTPS connection ID:44 to downloads.rithmic.com:443 for request ID:44 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:36:01.614 | HTTPS connection ID:44 to downloads.rithmic.com:443 for request ID:44 (1) | Socket gracefully closed by remote side. 2026-06-01 10:36:01.635 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:36:01.635 | HTTPS connection ID:44 to downloads.rithmic.com:443 for request ID:44 (1) | Socket gracefully closed by remote side. 2026-06-01 10:36:01.741 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:36:01.741 | HTTPS connection ID:44 to downloads.rithmic.com:443 for request ID:44 (1) | CloseSocket call. 2026-06-01 10:36:01.741 | HTTPS connection ID:44 to downloads.rithmic.com:443 for request ID:44 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:36:01.741 | HTTPS connection ID:44 to downloads.rithmic.com:443 for request ID:44 (1) | Closed. 2026-06-01 10:37:40.294 | 2026-06-01 10:37:40.294 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:37:40.294 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:37:40.294 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:37:40.294 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:37:40.294 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:37:40.334 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:37:40.334 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:37:40.334 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:38:00.378 | HTTPS connection ID:45 to downloads.rithmic.com:443 for request ID:45 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:38:00.379 | HTTPS connection ID:45 to downloads.rithmic.com:443 for request ID:45 (1) | New receive buffer size: 0 2026-06-01 10:38:00.379 | HTTPS connection ID:45 to downloads.rithmic.com:443 for request ID:45 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:38:01.638 | HTTPS connection ID:45 to downloads.rithmic.com:443 for request ID:45 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:38:01.647 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:38:01.726 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:38:01.726 | HTTPS connection ID:45 to downloads.rithmic.com:443 for request ID:45 (1) | CloseSocket call. 2026-06-01 10:38:01.727 | HTTPS connection ID:45 to downloads.rithmic.com:443 for request ID:45 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:38:01.727 | HTTPS connection ID:45 to downloads.rithmic.com:443 for request ID:45 (1) | Closed. 2026-06-01 10:39:40.349 | 2026-06-01 10:39:40.350 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:39:40.350 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:39:40.350 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:39:40.350 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:39:40.350 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:39:40.375 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:39:40.376 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:39:40.376 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:40:00.357 | HTTPS connection ID:46 to downloads.rithmic.com:443 for request ID:46 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:40:00.357 | HTTPS connection ID:46 to downloads.rithmic.com:443 for request ID:46 (1) | New receive buffer size: 0 2026-06-01 10:40:00.357 | HTTPS connection ID:46 to downloads.rithmic.com:443 for request ID:46 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:40:01.484 | HTTPS connection ID:46 to downloads.rithmic.com:443 for request ID:46 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:40:01.505 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:40:01.578 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:40:01.578 | HTTPS connection ID:46 to downloads.rithmic.com:443 for request ID:46 (1) | CloseSocket call. 2026-06-01 10:40:01.578 | HTTPS connection ID:46 to downloads.rithmic.com:443 for request ID:46 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:40:01.578 | HTTPS connection ID:46 to downloads.rithmic.com:443 for request ID:46 (1) | Closed. 2026-06-01 10:41:40.389 | 2026-06-01 10:41:40.389 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:41:40.389 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:41:40.389 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:41:40.389 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:41:40.389 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:41:40.502 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:41:40.502 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:41:40.502 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:42:00.439 | HTTPS connection ID:47 to downloads.rithmic.com:443 for request ID:47 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:42:00.440 | HTTPS connection ID:47 to downloads.rithmic.com:443 for request ID:47 (1) | New receive buffer size: 0 2026-06-01 10:42:00.440 | HTTPS connection ID:47 to downloads.rithmic.com:443 for request ID:47 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:42:01.683 | HTTPS connection ID:47 to downloads.rithmic.com:443 for request ID:47 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:42:01.704 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:42:01.774 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:42:01.774 | HTTPS connection ID:47 to downloads.rithmic.com:443 for request ID:47 (1) | CloseSocket call. 2026-06-01 10:42:01.774 | HTTPS connection ID:47 to downloads.rithmic.com:443 for request ID:47 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:42:01.774 | HTTPS connection ID:47 to downloads.rithmic.com:443 for request ID:47 (1) | Closed. 2026-06-01 10:43:40.587 | 2026-06-01 10:43:40.587 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:43:40.587 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:43:40.587 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:43:40.587 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:43:40.587 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:43:40.632 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:43:40.632 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:43:40.632 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:44:00.649 | HTTPS connection ID:48 to downloads.rithmic.com:443 for request ID:48 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:44:00.650 | HTTPS connection ID:48 to downloads.rithmic.com:443 for request ID:48 (1) | New receive buffer size: 0 2026-06-01 10:44:00.650 | HTTPS connection ID:48 to downloads.rithmic.com:443 for request ID:48 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 10:44:01.388 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:44:01.473 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:44:01.776 | HTTPS connection ID:48 to downloads.rithmic.com:443 for request ID:48 (1) | CloseSocket call. 2026-06-01 10:44:01.776 | HTTPS connection ID:48 to downloads.rithmic.com:443 for request ID:48 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 10:44:01.884 | HTTPS connection ID:48 to downloads.rithmic.com:443 for request ID:48 (1) | Socket gracefully closed by remote side. 2026-06-01 10:44:01.885 | HTTPS connection ID:48 to downloads.rithmic.com:443 for request ID:48 (1) | Closed. 2026-06-01 10:45:40.644 | 2026-06-01 10:45:40.644 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:45:40.644 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:45:40.644 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:45:40.644 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:45:40.644 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:45:40.684 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:45:40.684 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:45:40.684 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:46:00.676 | HTTPS connection ID:49 to downloads.rithmic.com:443 for request ID:49 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:46:00.676 | HTTPS connection ID:49 to downloads.rithmic.com:443 for request ID:49 (1) | New receive buffer size: 0 2026-06-01 10:46:00.676 | HTTPS connection ID:49 to downloads.rithmic.com:443 for request ID:49 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 10:46:01.411 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:46:01.472 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:46:01.732 | HTTPS connection ID:49 to downloads.rithmic.com:443 for request ID:49 (1) | CloseSocket call. 2026-06-01 10:46:01.733 | HTTPS connection ID:49 to downloads.rithmic.com:443 for request ID:49 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 10:46:01.841 | HTTPS connection ID:49 to downloads.rithmic.com:443 for request ID:49 (1) | Socket gracefully closed by remote side. 2026-06-01 10:46:01.841 | HTTPS connection ID:49 to downloads.rithmic.com:443 for request ID:49 (1) | Closed. 2026-06-01 10:47:40.741 | 2026-06-01 10:47:40.741 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:47:40.741 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:47:40.741 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:47:40.741 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:47:40.741 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:47:40.770 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:47:40.770 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:47:40.770 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:48:00.817 | HTTPS connection ID:50 to downloads.rithmic.com:443 for request ID:50 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:48:00.818 | HTTPS connection ID:50 to downloads.rithmic.com:443 for request ID:50 (1) | New receive buffer size: 0 2026-06-01 10:48:00.818 | HTTPS connection ID:50 to downloads.rithmic.com:443 for request ID:50 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 10:48:01.480 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:48:01.562 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:48:01.830 | HTTPS connection ID:50 to downloads.rithmic.com:443 for request ID:50 (1) | CloseSocket call. 2026-06-01 10:48:01.830 | HTTPS connection ID:50 to downloads.rithmic.com:443 for request ID:50 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 10:48:01.937 | HTTPS connection ID:50 to downloads.rithmic.com:443 for request ID:50 (1) | Socket gracefully closed by remote side. 2026-06-01 10:48:01.937 | HTTPS connection ID:50 to downloads.rithmic.com:443 for request ID:50 (1) | Closed. 2026-06-01 10:49:40.817 | 2026-06-01 10:49:40.817 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:49:40.817 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:49:40.817 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:49:40.817 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:49:40.817 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:49:40.842 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:49:40.842 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:49:40.842 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:50:00.876 | HTTPS connection ID:51 to downloads.rithmic.com:443 for request ID:51 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:50:00.876 | HTTPS connection ID:51 to downloads.rithmic.com:443 for request ID:51 (1) | New receive buffer size: 0 2026-06-01 10:50:00.876 | HTTPS connection ID:51 to downloads.rithmic.com:443 for request ID:51 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:50:02.172 | HTTPS connection ID:51 to downloads.rithmic.com:443 for request ID:51 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:50:02.178 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:50:02.257 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:50:02.258 | HTTPS connection ID:51 to downloads.rithmic.com:443 for request ID:51 (1) | CloseSocket call. 2026-06-01 10:50:02.258 | HTTPS connection ID:51 to downloads.rithmic.com:443 for request ID:51 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:50:02.258 | HTTPS connection ID:51 to downloads.rithmic.com:443 for request ID:51 (1) | Closed. 2026-06-01 10:51:40.857 | 2026-06-01 10:51:40.858 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:51:40.858 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:51:40.858 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:51:40.858 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:51:40.858 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:51:40.883 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:51:40.883 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:51:40.883 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:52:00.940 | HTTPS connection ID:52 to downloads.rithmic.com:443 for request ID:52 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:52:00.940 | HTTPS connection ID:52 to downloads.rithmic.com:443 for request ID:52 (1) | New receive buffer size: 0 2026-06-01 10:52:00.940 | HTTPS connection ID:52 to downloads.rithmic.com:443 for request ID:52 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:52:02.075 | HTTPS connection ID:52 to downloads.rithmic.com:443 for request ID:52 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:52:02.086 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:52:02.148 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:52:02.149 | HTTPS connection ID:52 to downloads.rithmic.com:443 for request ID:52 (1) | CloseSocket call. 2026-06-01 10:52:02.149 | HTTPS connection ID:52 to downloads.rithmic.com:443 for request ID:52 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:52:02.149 | HTTPS connection ID:52 to downloads.rithmic.com:443 for request ID:52 (1) | Closed. 2026-06-01 10:53:40.934 | 2026-06-01 10:53:40.935 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:53:40.935 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:53:40.935 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:53:40.935 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:53:40.935 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:53:40.965 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:53:40.965 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:53:40.965 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:54:01.007 | HTTPS connection ID:53 to downloads.rithmic.com:443 for request ID:53 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:54:01.007 | HTTPS connection ID:53 to downloads.rithmic.com:443 for request ID:53 (1) | New receive buffer size: 0 2026-06-01 10:54:01.007 | HTTPS connection ID:53 to downloads.rithmic.com:443 for request ID:53 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 10:54:02.229 | HTTPS connection ID:53 to downloads.rithmic.com:443 for request ID:53 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 10:54:02.280 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:54:02.349 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:54:02.349 | HTTPS connection ID:53 to downloads.rithmic.com:443 for request ID:53 (1) | CloseSocket call. 2026-06-01 10:54:02.349 | HTTPS connection ID:53 to downloads.rithmic.com:443 for request ID:53 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 10:54:02.349 | HTTPS connection ID:53 to downloads.rithmic.com:443 for request ID:53 (1) | Closed. 2026-06-01 10:55:40.994 | 2026-06-01 10:55:40.994 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:55:40.994 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:55:40.994 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:55:40.994 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:55:40.994 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:55:41.030 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:55:41.030 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:55:41.030 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:56:01.069 | HTTPS connection ID:54 to downloads.rithmic.com:443 for request ID:54 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:56:01.069 | HTTPS connection ID:54 to downloads.rithmic.com:443 for request ID:54 (1) | New receive buffer size: 0 2026-06-01 10:56:01.069 | HTTPS connection ID:54 to downloads.rithmic.com:443 for request ID:54 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 10:56:01.767 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:56:01.828 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:56:02.096 | HTTPS connection ID:54 to downloads.rithmic.com:443 for request ID:54 (1) | CloseSocket call. 2026-06-01 10:56:02.096 | HTTPS connection ID:54 to downloads.rithmic.com:443 for request ID:54 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 10:56:02.203 | HTTPS connection ID:54 to downloads.rithmic.com:443 for request ID:54 (1) | Socket gracefully closed by remote side. 2026-06-01 10:56:02.204 | HTTPS connection ID:54 to downloads.rithmic.com:443 for request ID:54 (1) | Closed. 2026-06-01 10:57:41.040 | 2026-06-01 10:57:41.040 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:57:41.040 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:57:41.040 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:57:41.040 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:57:41.040 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:57:41.072 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:57:41.072 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:57:41.072 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:58:01.049 | HTTPS connection ID:55 to downloads.rithmic.com:443 for request ID:55 (1) | Creating socket. Using TLS 1.2. 2026-06-01 10:58:01.050 | HTTPS connection ID:55 to downloads.rithmic.com:443 for request ID:55 (1) | New receive buffer size: 0 2026-06-01 10:58:01.050 | HTTPS connection ID:55 to downloads.rithmic.com:443 for request ID:55 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 10:58:01.800 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 10:58:01.866 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 10:58:02.169 | HTTPS connection ID:55 to downloads.rithmic.com:443 for request ID:55 (1) | CloseSocket call. 2026-06-01 10:58:02.169 | HTTPS connection ID:55 to downloads.rithmic.com:443 for request ID:55 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 10:58:02.277 | HTTPS connection ID:55 to downloads.rithmic.com:443 for request ID:55 (1) | Socket gracefully closed by remote side. 2026-06-01 10:58:02.277 | HTTPS connection ID:55 to downloads.rithmic.com:443 for request ID:55 (1) | Closed. 2026-06-01 10:59:41.109 | 2026-06-01 10:59:41.110 | Rithmic Direct - DTC | Using server connection: 2026-06-01 10:59:41.110 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 10:59:41.110 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 10:59:41.110 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 10:59:41.110 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 10:59:41.144 | DTC Client socket (0) | CloseSocket call. 2026-06-01 10:59:41.144 | Rithmic Direct - DTC | Disconnected. 2026-06-01 10:59:41.144 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:00:01.196 | HTTPS connection ID:56 to downloads.rithmic.com:443 for request ID:56 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:00:01.196 | HTTPS connection ID:56 to downloads.rithmic.com:443 for request ID:56 (1) | New receive buffer size: 0 2026-06-01 11:00:01.196 | HTTPS connection ID:56 to downloads.rithmic.com:443 for request ID:56 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 11:00:01.916 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:00:01.974 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:00:02.275 | HTTPS connection ID:56 to downloads.rithmic.com:443 for request ID:56 (1) | CloseSocket call. 2026-06-01 11:00:02.275 | HTTPS connection ID:56 to downloads.rithmic.com:443 for request ID:56 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 11:00:02.383 | HTTPS connection ID:56 to downloads.rithmic.com:443 for request ID:56 (1) | Socket gracefully closed by remote side. 2026-06-01 11:00:02.383 | HTTPS connection ID:56 to downloads.rithmic.com:443 for request ID:56 (1) | Closed. 2026-06-01 11:01:41.166 | 2026-06-01 11:01:41.166 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:01:41.166 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:01:41.166 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:01:41.166 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:01:41.166 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:01:41.192 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:01:41.192 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:01:41.192 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:02:01.222 | HTTPS connection ID:57 to downloads.rithmic.com:443 for request ID:57 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:02:01.222 | HTTPS connection ID:57 to downloads.rithmic.com:443 for request ID:57 (1) | New receive buffer size: 0 2026-06-01 11:02:01.222 | HTTPS connection ID:57 to downloads.rithmic.com:443 for request ID:57 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 11:02:01.898 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:02:01.963 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:02:02.223 | HTTPS connection ID:57 to downloads.rithmic.com:443 for request ID:57 (1) | CloseSocket call. 2026-06-01 11:02:02.223 | HTTPS connection ID:57 to downloads.rithmic.com:443 for request ID:57 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 11:02:02.331 | HTTPS connection ID:57 to downloads.rithmic.com:443 for request ID:57 (1) | Socket gracefully closed by remote side. 2026-06-01 11:02:02.332 | HTTPS connection ID:57 to downloads.rithmic.com:443 for request ID:57 (1) | Closed. 2026-06-01 11:03:41.211 | 2026-06-01 11:03:41.211 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:03:41.211 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:03:41.211 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:03:41.211 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:03:41.211 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:03:41.237 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:03:41.237 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:03:41.237 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:04:01.229 | HTTPS connection ID:58 to downloads.rithmic.com:443 for request ID:58 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:04:01.229 | HTTPS connection ID:58 to downloads.rithmic.com:443 for request ID:58 (1) | New receive buffer size: 0 2026-06-01 11:04:01.229 | HTTPS connection ID:58 to downloads.rithmic.com:443 for request ID:58 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 11:04:01.924 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:04:01.994 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:04:02.263 | HTTPS connection ID:58 to downloads.rithmic.com:443 for request ID:58 (1) | CloseSocket call. 2026-06-01 11:04:02.263 | HTTPS connection ID:58 to downloads.rithmic.com:443 for request ID:58 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 11:04:02.371 | HTTPS connection ID:58 to downloads.rithmic.com:443 for request ID:58 (1) | Socket gracefully closed by remote side. 2026-06-01 11:04:02.371 | HTTPS connection ID:58 to downloads.rithmic.com:443 for request ID:58 (1) | Closed. 2026-06-01 11:05:41.325 | 2026-06-01 11:05:41.325 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:05:41.325 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:05:41.325 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:05:41.325 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:05:41.325 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:05:41.368 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:05:41.368 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:05:41.368 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:06:01.375 | HTTPS connection ID:59 to downloads.rithmic.com:443 for request ID:59 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:06:01.375 | HTTPS connection ID:59 to downloads.rithmic.com:443 for request ID:59 (1) | New receive buffer size: 0 2026-06-01 11:06:01.375 | HTTPS connection ID:59 to downloads.rithmic.com:443 for request ID:59 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 11:06:02.081 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:06:02.169 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:06:02.432 | HTTPS connection ID:59 to downloads.rithmic.com:443 for request ID:59 (1) | CloseSocket call. 2026-06-01 11:06:02.432 | HTTPS connection ID:59 to downloads.rithmic.com:443 for request ID:59 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 11:06:02.541 | HTTPS connection ID:59 to downloads.rithmic.com:443 for request ID:59 (1) | Socket gracefully closed by remote side. 2026-06-01 11:06:02.541 | HTTPS connection ID:59 to downloads.rithmic.com:443 for request ID:59 (1) | Closed. 2026-06-01 11:07:41.390 | 2026-06-01 11:07:41.390 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:07:41.390 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:07:41.390 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:07:41.390 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:07:41.390 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:07:41.423 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:07:41.434 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:07:41.434 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:08:01.442 | HTTPS connection ID:60 to downloads.rithmic.com:443 for request ID:60 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:08:01.442 | HTTPS connection ID:60 to downloads.rithmic.com:443 for request ID:60 (1) | New receive buffer size: 0 2026-06-01 11:08:01.442 | HTTPS connection ID:60 to downloads.rithmic.com:443 for request ID:60 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 11:08:02.181 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:08:02.234 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:08:02.511 | HTTPS connection ID:60 to downloads.rithmic.com:443 for request ID:60 (1) | CloseSocket call. 2026-06-01 11:08:02.511 | HTTPS connection ID:60 to downloads.rithmic.com:443 for request ID:60 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 11:08:02.619 | HTTPS connection ID:60 to downloads.rithmic.com:443 for request ID:60 (1) | Socket gracefully closed by remote side. 2026-06-01 11:08:02.619 | HTTPS connection ID:60 to downloads.rithmic.com:443 for request ID:60 (1) | Closed. 2026-06-01 11:09:41.455 | 2026-06-01 11:09:41.455 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:09:41.455 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:09:41.455 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:09:41.455 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:09:41.455 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:09:41.489 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:09:41.489 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:09:41.502 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:10:01.513 | HTTPS connection ID:61 to downloads.rithmic.com:443 for request ID:61 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:10:01.513 | HTTPS connection ID:61 to downloads.rithmic.com:443 for request ID:61 (1) | New receive buffer size: 0 2026-06-01 11:10:01.513 | HTTPS connection ID:61 to downloads.rithmic.com:443 for request ID:61 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 11:10:02.285 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:10:02.368 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:10:02.631 | HTTPS connection ID:61 to downloads.rithmic.com:443 for request ID:61 (1) | CloseSocket call. 2026-06-01 11:10:02.631 | HTTPS connection ID:61 to downloads.rithmic.com:443 for request ID:61 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 11:10:02.740 | HTTPS connection ID:61 to downloads.rithmic.com:443 for request ID:61 (1) | Socket gracefully closed by remote side. 2026-06-01 11:10:02.740 | HTTPS connection ID:61 to downloads.rithmic.com:443 for request ID:61 (1) | Closed. 2026-06-01 11:11:41.528 | 2026-06-01 11:11:41.528 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:11:41.528 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:11:41.528 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:11:41.528 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:11:41.529 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:11:41.552 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:11:41.552 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:11:41.552 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:12:01.607 | HTTPS connection ID:62 to downloads.rithmic.com:443 for request ID:62 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:12:01.607 | HTTPS connection ID:62 to downloads.rithmic.com:443 for request ID:62 (1) | New receive buffer size: 0 2026-06-01 11:12:01.607 | HTTPS connection ID:62 to downloads.rithmic.com:443 for request ID:62 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 11:12:02.366 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:12:02.445 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:12:02.712 | HTTPS connection ID:62 to downloads.rithmic.com:443 for request ID:62 (1) | CloseSocket call. 2026-06-01 11:12:02.712 | HTTPS connection ID:62 to downloads.rithmic.com:443 for request ID:62 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 11:12:02.832 | HTTPS connection ID:62 to downloads.rithmic.com:443 for request ID:62 (1) | Socket gracefully closed by remote side. 2026-06-01 11:12:02.832 | HTTPS connection ID:62 to downloads.rithmic.com:443 for request ID:62 (1) | Closed. 2026-06-01 11:13:41.567 | 2026-06-01 11:13:41.567 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:13:41.567 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:13:41.567 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:13:41.567 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:13:41.567 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:13:41.628 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:13:41.628 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:13:41.628 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:14:01.713 | HTTPS connection ID:63 to downloads.rithmic.com:443 for request ID:63 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:14:01.713 | HTTPS connection ID:63 to downloads.rithmic.com:443 for request ID:63 (1) | New receive buffer size: 0 2026-06-01 11:14:01.713 | HTTPS connection ID:63 to downloads.rithmic.com:443 for request ID:63 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 11:14:02.394 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:14:02.467 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:14:02.735 | HTTPS connection ID:63 to downloads.rithmic.com:443 for request ID:63 (1) | CloseSocket call. 2026-06-01 11:14:02.735 | HTTPS connection ID:63 to downloads.rithmic.com:443 for request ID:63 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 11:14:02.843 | HTTPS connection ID:63 to downloads.rithmic.com:443 for request ID:63 (1) | Socket gracefully closed by remote side. 2026-06-01 11:14:02.843 | HTTPS connection ID:63 to downloads.rithmic.com:443 for request ID:63 (1) | Closed. 2026-06-01 11:15:41.693 | 2026-06-01 11:15:41.693 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:15:41.693 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:15:41.693 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:15:41.693 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:15:41.693 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:15:41.737 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:15:41.737 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:15:41.737 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:16:01.700 | HTTPS connection ID:64 to downloads.rithmic.com:443 for request ID:64 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:16:01.700 | HTTPS connection ID:64 to downloads.rithmic.com:443 for request ID:64 (1) | New receive buffer size: 0 2026-06-01 11:16:01.700 | HTTPS connection ID:64 to downloads.rithmic.com:443 for request ID:64 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 11:16:02.515 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:16:02.592 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:16:02.905 | HTTPS connection ID:64 to downloads.rithmic.com:443 for request ID:64 (1) | CloseSocket call. 2026-06-01 11:16:02.905 | HTTPS connection ID:64 to downloads.rithmic.com:443 for request ID:64 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 11:16:03.013 | HTTPS connection ID:64 to downloads.rithmic.com:443 for request ID:64 (1) | Socket gracefully closed by remote side. 2026-06-01 11:16:03.013 | HTTPS connection ID:64 to downloads.rithmic.com:443 for request ID:64 (1) | Closed. 2026-06-01 11:17:41.739 | 2026-06-01 11:17:41.740 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:17:41.740 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:17:41.740 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:17:41.740 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:17:41.740 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:17:41.776 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:17:41.776 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:17:41.776 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:18:01.849 | HTTPS connection ID:65 to downloads.rithmic.com:443 for request ID:65 (2) | Creating socket. Using TLS 1.2. 2026-06-01 11:18:01.849 | HTTPS connection ID:65 to downloads.rithmic.com:443 for request ID:65 (2) | New receive buffer size: 0 2026-06-01 11:18:01.849 | HTTPS connection ID:65 to downloads.rithmic.com:443 for request ID:65 (2) | Connecting to IP: 216.66.0.130. 2026-06-01 11:18:02.536 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:18:02.608 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:18:02.878 | HTTPS connection ID:65 to downloads.rithmic.com:443 for request ID:65 (2) | CloseSocket call. 2026-06-01 11:18:02.878 | HTTPS connection ID:65 to downloads.rithmic.com:443 for request ID:65 (2) | Shutdown started. Waiting for graceful close. 2026-06-01 11:18:02.988 | HTTPS connection ID:65 to downloads.rithmic.com:443 for request ID:65 (2) | Socket gracefully closed by remote side. 2026-06-01 11:18:02.988 | HTTPS connection ID:65 to downloads.rithmic.com:443 for request ID:65 (2) | Closed. 2026-06-01 11:19:41.788 | 2026-06-01 11:19:41.788 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:19:41.788 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:19:41.788 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:19:41.788 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:19:41.788 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:19:41.799 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:19:41.799 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:19:41.799 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:20:01.854 | HTTPS connection ID:66 to downloads.rithmic.com:443 for request ID:66 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:20:01.854 | HTTPS connection ID:66 to downloads.rithmic.com:443 for request ID:66 (1) | New receive buffer size: 0 2026-06-01 11:20:01.854 | HTTPS connection ID:66 to downloads.rithmic.com:443 for request ID:66 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 11:20:02.999 | HTTPS connection ID:66 to downloads.rithmic.com:443 for request ID:66 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:20:03.017 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:20:03.084 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:20:03.084 | HTTPS connection ID:66 to downloads.rithmic.com:443 for request ID:66 (1) | CloseSocket call. 2026-06-01 11:20:03.084 | HTTPS connection ID:66 to downloads.rithmic.com:443 for request ID:66 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:20:03.084 | HTTPS connection ID:66 to downloads.rithmic.com:443 for request ID:66 (1) | Closed. 2026-06-01 11:21:41.833 | 2026-06-01 11:21:41.833 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:21:41.833 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:21:41.833 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:21:41.833 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:21:41.833 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:21:41.863 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:21:41.863 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:21:41.863 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:22:01.888 | HTTPS connection ID:67 to downloads.rithmic.com:443 for request ID:67 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:22:01.889 | HTTPS connection ID:67 to downloads.rithmic.com:443 for request ID:67 (1) | New receive buffer size: 0 2026-06-01 11:22:01.889 | HTTPS connection ID:67 to downloads.rithmic.com:443 for request ID:67 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 11:22:02.925 | HTTPS connection ID:67 to downloads.rithmic.com:443 for request ID:67 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:22:02.943 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:22:03.013 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:22:03.013 | HTTPS connection ID:67 to downloads.rithmic.com:443 for request ID:67 (1) | CloseSocket call. 2026-06-01 11:22:03.013 | HTTPS connection ID:67 to downloads.rithmic.com:443 for request ID:67 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:22:03.013 | HTTPS connection ID:67 to downloads.rithmic.com:443 for request ID:67 (1) | Closed. 2026-06-01 11:23:41.880 | 2026-06-01 11:23:41.880 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:23:41.880 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:23:41.880 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:23:41.880 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:23:41.880 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:23:41.911 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:23:41.911 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:23:41.911 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:24:01.936 | HTTPS connection ID:68 to downloads.rithmic.com:443 for request ID:68 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:24:01.936 | HTTPS connection ID:68 to downloads.rithmic.com:443 for request ID:68 (1) | New receive buffer size: 0 2026-06-01 11:24:01.936 | HTTPS connection ID:68 to downloads.rithmic.com:443 for request ID:68 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 11:24:03.073 | HTTPS connection ID:68 to downloads.rithmic.com:443 for request ID:68 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:24:03.111 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:24:03.187 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:24:03.187 | HTTPS connection ID:68 to downloads.rithmic.com:443 for request ID:68 (1) | CloseSocket call. 2026-06-01 11:24:03.187 | HTTPS connection ID:68 to downloads.rithmic.com:443 for request ID:68 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:24:03.187 | HTTPS connection ID:68 to downloads.rithmic.com:443 for request ID:68 (1) | Closed. 2026-06-01 11:25:41.926 | 2026-06-01 11:25:41.926 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:25:41.926 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:25:41.926 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:25:41.926 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:25:41.926 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:25:41.956 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:25:41.956 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:25:41.956 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:26:02.022 | HTTPS connection ID:69 to downloads.rithmic.com:443 for request ID:69 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:26:02.022 | HTTPS connection ID:69 to downloads.rithmic.com:443 for request ID:69 (1) | New receive buffer size: 0 2026-06-01 11:26:02.022 | HTTPS connection ID:69 to downloads.rithmic.com:443 for request ID:69 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 11:26:03.191 | HTTPS connection ID:69 to downloads.rithmic.com:443 for request ID:69 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:26:03.226 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:26:03.282 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:26:03.282 | HTTPS connection ID:69 to downloads.rithmic.com:443 for request ID:69 (1) | CloseSocket call. 2026-06-01 11:26:03.282 | HTTPS connection ID:69 to downloads.rithmic.com:443 for request ID:69 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:26:03.282 | HTTPS connection ID:69 to downloads.rithmic.com:443 for request ID:69 (1) | Closed. 2026-06-01 11:27:41.968 | 2026-06-01 11:27:41.969 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:27:41.969 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:27:41.969 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:27:41.969 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:27:41.969 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:27:41.989 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:27:41.989 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:27:41.989 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:28:02.012 | HTTPS connection ID:70 to downloads.rithmic.com:443 for request ID:70 (2) | Creating socket. Using TLS 1.2. 2026-06-01 11:28:02.013 | HTTPS connection ID:70 to downloads.rithmic.com:443 for request ID:70 (2) | New receive buffer size: 0 2026-06-01 11:28:02.013 | HTTPS connection ID:70 to downloads.rithmic.com:443 for request ID:70 (2) | Connecting to IP: 38.79.0.89. 2026-06-01 11:28:03.047 | HTTPS connection ID:70 to downloads.rithmic.com:443 for request ID:70 (2) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:28:03.068 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:28:03.158 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:28:03.158 | HTTPS connection ID:70 to downloads.rithmic.com:443 for request ID:70 (2) | CloseSocket call. 2026-06-01 11:28:03.158 | HTTPS connection ID:70 to downloads.rithmic.com:443 for request ID:70 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:28:03.158 | HTTPS connection ID:70 to downloads.rithmic.com:443 for request ID:70 (2) | Closed. 2026-06-01 11:29:42.016 | 2026-06-01 11:29:42.016 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:29:42.016 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:29:42.016 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:29:42.016 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:29:42.016 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:29:42.055 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:29:42.055 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:29:42.055 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:30:02.100 | HTTPS connection ID:71 to downloads.rithmic.com:443 for request ID:71 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:30:02.101 | HTTPS connection ID:71 to downloads.rithmic.com:443 for request ID:71 (1) | New receive buffer size: 0 2026-06-01 11:30:02.101 | HTTPS connection ID:71 to downloads.rithmic.com:443 for request ID:71 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 11:30:03.292 | HTTPS connection ID:71 to downloads.rithmic.com:443 for request ID:71 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:30:03.310 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:30:03.365 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:30:03.365 | HTTPS connection ID:71 to downloads.rithmic.com:443 for request ID:71 (1) | CloseSocket call. 2026-06-01 11:30:03.365 | HTTPS connection ID:71 to downloads.rithmic.com:443 for request ID:71 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:30:03.365 | HTTPS connection ID:71 to downloads.rithmic.com:443 for request ID:71 (1) | Closed. 2026-06-01 11:31:42.106 | 2026-06-01 11:31:42.107 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:31:42.107 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:31:42.107 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:31:42.107 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:31:42.107 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:31:42.153 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:31:42.153 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:31:42.153 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:32:02.236 | HTTPS connection ID:72 to downloads.rithmic.com:443 for request ID:72 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:32:02.236 | HTTPS connection ID:72 to downloads.rithmic.com:443 for request ID:72 (1) | New receive buffer size: 0 2026-06-01 11:32:02.236 | HTTPS connection ID:72 to downloads.rithmic.com:443 for request ID:72 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 11:32:02.928 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:32:02.978 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:32:03.243 | HTTPS connection ID:72 to downloads.rithmic.com:443 for request ID:72 (1) | CloseSocket call. 2026-06-01 11:32:03.243 | HTTPS connection ID:72 to downloads.rithmic.com:443 for request ID:72 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 11:32:03.351 | HTTPS connection ID:72 to downloads.rithmic.com:443 for request ID:72 (1) | Socket gracefully closed by remote side. 2026-06-01 11:32:03.351 | HTTPS connection ID:72 to downloads.rithmic.com:443 for request ID:72 (1) | Closed. 2026-06-01 11:33:42.170 | 2026-06-01 11:33:42.170 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:33:42.170 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:33:42.170 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:33:42.170 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:33:42.170 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:33:42.213 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:33:42.213 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:33:42.213 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:34:02.226 | HTTPS connection ID:73 to downloads.rithmic.com:443 for request ID:73 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:34:02.226 | HTTPS connection ID:73 to downloads.rithmic.com:443 for request ID:73 (1) | New receive buffer size: 0 2026-06-01 11:34:02.226 | HTTPS connection ID:73 to downloads.rithmic.com:443 for request ID:73 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 11:34:03.031 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:34:03.099 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:34:03.364 | HTTPS connection ID:73 to downloads.rithmic.com:443 for request ID:73 (1) | CloseSocket call. 2026-06-01 11:34:03.364 | HTTPS connection ID:73 to downloads.rithmic.com:443 for request ID:73 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 11:34:03.473 | HTTPS connection ID:73 to downloads.rithmic.com:443 for request ID:73 (1) | Socket gracefully closed by remote side. 2026-06-01 11:34:03.473 | HTTPS connection ID:73 to downloads.rithmic.com:443 for request ID:73 (1) | Closed. 2026-06-01 11:35:42.247 | 2026-06-01 11:35:42.247 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:35:42.247 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:35:42.247 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:35:42.247 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:35:42.247 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:35:42.272 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:35:42.272 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:35:42.272 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:36:02.306 | HTTPS connection ID:74 to downloads.rithmic.com:443 for request ID:74 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:36:02.306 | HTTPS connection ID:74 to downloads.rithmic.com:443 for request ID:74 (1) | New receive buffer size: 0 2026-06-01 11:36:02.306 | HTTPS connection ID:74 to downloads.rithmic.com:443 for request ID:74 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 11:36:03.054 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:36:03.119 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:36:03.409 | HTTPS connection ID:74 to downloads.rithmic.com:443 for request ID:74 (1) | CloseSocket call. 2026-06-01 11:36:03.409 | HTTPS connection ID:74 to downloads.rithmic.com:443 for request ID:74 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 11:36:03.517 | HTTPS connection ID:74 to downloads.rithmic.com:443 for request ID:74 (1) | Socket gracefully closed by remote side. 2026-06-01 11:36:03.517 | HTTPS connection ID:74 to downloads.rithmic.com:443 for request ID:74 (1) | Closed. 2026-06-01 11:37:42.304 | 2026-06-01 11:37:42.304 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:37:42.304 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:37:42.304 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:37:42.304 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:37:42.304 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:37:42.331 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:37:42.331 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:37:42.331 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:38:02.379 | HTTPS connection ID:75 to downloads.rithmic.com:443 for request ID:75 (2) | Creating socket. Using TLS 1.2. 2026-06-01 11:38:02.391 | HTTPS connection ID:75 to downloads.rithmic.com:443 for request ID:75 (2) | New receive buffer size: 0 2026-06-01 11:38:02.391 | HTTPS connection ID:75 to downloads.rithmic.com:443 for request ID:75 (2) | Connecting to IP: 38.79.0.89. 2026-06-01 11:38:03.494 | HTTPS connection ID:75 to downloads.rithmic.com:443 for request ID:75 (2) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:38:03.504 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:38:03.581 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:38:03.581 | HTTPS connection ID:75 to downloads.rithmic.com:443 for request ID:75 (2) | CloseSocket call. 2026-06-01 11:38:03.581 | HTTPS connection ID:75 to downloads.rithmic.com:443 for request ID:75 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:38:03.582 | HTTPS connection ID:75 to downloads.rithmic.com:443 for request ID:75 (2) | Closed. 2026-06-01 11:39:42.338 | 2026-06-01 11:39:42.338 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:39:42.338 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:39:42.338 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:39:42.338 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:39:42.338 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:39:42.365 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:39:42.365 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:39:42.365 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:40:02.359 | HTTPS connection ID:76 to downloads.rithmic.com:443 for request ID:76 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:40:02.359 | HTTPS connection ID:76 to downloads.rithmic.com:443 for request ID:76 (1) | New receive buffer size: 0 2026-06-01 11:40:02.359 | HTTPS connection ID:76 to downloads.rithmic.com:443 for request ID:76 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 11:40:03.555 | HTTPS connection ID:76 to downloads.rithmic.com:443 for request ID:76 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:40:03.586 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:40:03.646 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:40:03.646 | HTTPS connection ID:76 to downloads.rithmic.com:443 for request ID:76 (1) | CloseSocket call. 2026-06-01 11:40:03.646 | HTTPS connection ID:76 to downloads.rithmic.com:443 for request ID:76 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:40:03.646 | HTTPS connection ID:76 to downloads.rithmic.com:443 for request ID:76 (1) | Closed. 2026-06-01 11:41:42.395 | 2026-06-01 11:41:42.395 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:41:42.395 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:41:42.395 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:41:42.395 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:41:42.395 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:41:42.420 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:41:42.420 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:41:42.420 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:42:02.529 | HTTPS connection ID:77 to downloads.rithmic.com:443 for request ID:77 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:42:02.529 | HTTPS connection ID:77 to downloads.rithmic.com:443 for request ID:77 (1) | New receive buffer size: 0 2026-06-01 11:42:02.529 | HTTPS connection ID:77 to downloads.rithmic.com:443 for request ID:77 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 11:42:03.712 | HTTPS connection ID:77 to downloads.rithmic.com:443 for request ID:77 (1) | Socket gracefully closed by remote side. 2026-06-01 11:42:03.765 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:42:03.765 | HTTPS connection ID:77 to downloads.rithmic.com:443 for request ID:77 (1) | Socket gracefully closed by remote side. 2026-06-01 11:42:03.835 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:42:03.835 | HTTPS connection ID:77 to downloads.rithmic.com:443 for request ID:77 (1) | CloseSocket call. 2026-06-01 11:42:03.835 | HTTPS connection ID:77 to downloads.rithmic.com:443 for request ID:77 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:42:03.835 | HTTPS connection ID:77 to downloads.rithmic.com:443 for request ID:77 (1) | Closed. 2026-06-01 11:43:42.441 | 2026-06-01 11:43:42.441 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:43:42.441 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:43:42.441 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:43:42.441 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:43:42.441 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:43:42.467 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:43:42.467 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:43:42.467 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:44:02.559 | HTTPS connection ID:78 to downloads.rithmic.com:443 for request ID:78 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:44:02.559 | HTTPS connection ID:78 to downloads.rithmic.com:443 for request ID:78 (1) | New receive buffer size: 0 2026-06-01 11:44:02.559 | HTTPS connection ID:78 to downloads.rithmic.com:443 for request ID:78 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 11:44:03.731 | HTTPS connection ID:78 to downloads.rithmic.com:443 for request ID:78 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:44:03.732 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:44:03.783 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:44:03.784 | HTTPS connection ID:78 to downloads.rithmic.com:443 for request ID:78 (1) | CloseSocket call. 2026-06-01 11:44:03.784 | HTTPS connection ID:78 to downloads.rithmic.com:443 for request ID:78 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:44:03.784 | HTTPS connection ID:78 to downloads.rithmic.com:443 for request ID:78 (1) | Closed. 2026-06-01 11:45:42.501 | 2026-06-01 11:45:42.502 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:45:42.502 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:45:42.502 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:45:42.502 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:45:42.502 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:45:42.529 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:45:42.529 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:45:42.529 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:46:02.528 | HTTPS connection ID:79 to downloads.rithmic.com:443 for request ID:79 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:46:02.528 | HTTPS connection ID:79 to downloads.rithmic.com:443 for request ID:79 (1) | New receive buffer size: 0 2026-06-01 11:46:02.528 | HTTPS connection ID:79 to downloads.rithmic.com:443 for request ID:79 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 11:46:03.668 | HTTPS connection ID:79 to downloads.rithmic.com:443 for request ID:79 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:46:03.706 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:46:03.788 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:46:03.788 | HTTPS connection ID:79 to downloads.rithmic.com:443 for request ID:79 (1) | CloseSocket call. 2026-06-01 11:46:03.788 | HTTPS connection ID:79 to downloads.rithmic.com:443 for request ID:79 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:46:03.788 | HTTPS connection ID:79 to downloads.rithmic.com:443 for request ID:79 (1) | Closed. 2026-06-01 11:47:42.536 | 2026-06-01 11:47:42.537 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:47:42.537 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:47:42.537 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:47:42.537 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:47:42.537 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:47:42.570 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:47:42.570 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:47:42.570 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:48:02.588 | HTTPS connection ID:80 to downloads.rithmic.com:443 for request ID:80 (2) | Creating socket. Using TLS 1.2. 2026-06-01 11:48:02.588 | HTTPS connection ID:80 to downloads.rithmic.com:443 for request ID:80 (2) | New receive buffer size: 0 2026-06-01 11:48:02.588 | HTTPS connection ID:80 to downloads.rithmic.com:443 for request ID:80 (2) | Connecting to IP: 38.79.0.89. 2026-06-01 11:48:03.631 | HTTPS connection ID:80 to downloads.rithmic.com:443 for request ID:80 (2) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:48:03.646 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:48:03.733 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:48:03.733 | HTTPS connection ID:80 to downloads.rithmic.com:443 for request ID:80 (2) | CloseSocket call. 2026-06-01 11:48:03.733 | HTTPS connection ID:80 to downloads.rithmic.com:443 for request ID:80 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:48:03.733 | HTTPS connection ID:80 to downloads.rithmic.com:443 for request ID:80 (2) | Closed. 2026-06-01 11:49:42.577 | 2026-06-01 11:49:42.578 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:49:42.578 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:49:42.578 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:49:42.578 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:49:42.578 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:49:42.605 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:49:42.605 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:49:42.605 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:50:02.646 | HTTPS connection ID:81 to downloads.rithmic.com:443 for request ID:81 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:50:02.647 | HTTPS connection ID:81 to downloads.rithmic.com:443 for request ID:81 (1) | New receive buffer size: 0 2026-06-01 11:50:02.647 | HTTPS connection ID:81 to downloads.rithmic.com:443 for request ID:81 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 11:50:03.703 | HTTPS connection ID:81 to downloads.rithmic.com:443 for request ID:81 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:50:03.747 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:50:03.826 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:50:03.826 | HTTPS connection ID:81 to downloads.rithmic.com:443 for request ID:81 (1) | CloseSocket call. 2026-06-01 11:50:03.826 | HTTPS connection ID:81 to downloads.rithmic.com:443 for request ID:81 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:50:03.826 | HTTPS connection ID:81 to downloads.rithmic.com:443 for request ID:81 (1) | Closed. 2026-06-01 11:51:42.616 | 2026-06-01 11:51:42.616 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:51:42.616 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:51:42.616 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:51:42.616 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:51:42.616 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:51:42.641 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:51:42.641 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:51:42.641 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:52:02.645 | HTTPS connection ID:82 to downloads.rithmic.com:443 for request ID:82 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:52:02.645 | HTTPS connection ID:82 to downloads.rithmic.com:443 for request ID:82 (1) | New receive buffer size: 0 2026-06-01 11:52:02.645 | HTTPS connection ID:82 to downloads.rithmic.com:443 for request ID:82 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 11:52:03.818 | HTTPS connection ID:82 to downloads.rithmic.com:443 for request ID:82 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:52:03.824 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:52:03.919 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:52:03.919 | HTTPS connection ID:82 to downloads.rithmic.com:443 for request ID:82 (1) | CloseSocket call. 2026-06-01 11:52:03.919 | HTTPS connection ID:82 to downloads.rithmic.com:443 for request ID:82 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:52:03.919 | HTTPS connection ID:82 to downloads.rithmic.com:443 for request ID:82 (1) | Closed. 2026-06-01 11:53:42.665 | 2026-06-01 11:53:42.665 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:53:42.666 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:53:42.666 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:53:42.666 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:53:42.666 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:53:42.698 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:53:42.698 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:53:42.698 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:54:02.812 | HTTPS connection ID:83 to downloads.rithmic.com:443 for request ID:83 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:54:02.812 | HTTPS connection ID:83 to downloads.rithmic.com:443 for request ID:83 (1) | New receive buffer size: 0 2026-06-01 11:54:02.812 | HTTPS connection ID:83 to downloads.rithmic.com:443 for request ID:83 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 11:54:04.030 | HTTPS connection ID:83 to downloads.rithmic.com:443 for request ID:83 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 11:54:04.045 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:54:04.108 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:54:04.108 | HTTPS connection ID:83 to downloads.rithmic.com:443 for request ID:83 (1) | CloseSocket call. 2026-06-01 11:54:04.108 | HTTPS connection ID:83 to downloads.rithmic.com:443 for request ID:83 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 11:54:04.108 | HTTPS connection ID:83 to downloads.rithmic.com:443 for request ID:83 (1) | Closed. 2026-06-01 11:55:42.708 | 2026-06-01 11:55:42.708 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:55:42.708 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:55:42.708 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:55:42.708 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:55:42.708 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:55:42.747 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:55:42.748 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:55:42.748 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:56:02.799 | HTTPS connection ID:84 to downloads.rithmic.com:443 for request ID:84 (1) | Creating socket. Using TLS 1.2. 2026-06-01 11:56:02.800 | HTTPS connection ID:84 to downloads.rithmic.com:443 for request ID:84 (1) | New receive buffer size: 0 2026-06-01 11:56:02.800 | HTTPS connection ID:84 to downloads.rithmic.com:443 for request ID:84 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 11:56:03.551 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:56:03.632 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:56:03.891 | HTTPS connection ID:84 to downloads.rithmic.com:443 for request ID:84 (1) | CloseSocket call. 2026-06-01 11:56:03.891 | HTTPS connection ID:84 to downloads.rithmic.com:443 for request ID:84 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 11:56:03.999 | HTTPS connection ID:84 to downloads.rithmic.com:443 for request ID:84 (1) | Socket gracefully closed by remote side. 2026-06-01 11:56:03.999 | HTTPS connection ID:84 to downloads.rithmic.com:443 for request ID:84 (1) | Closed. 2026-06-01 11:57:42.763 | 2026-06-01 11:57:42.763 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:57:42.763 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:57:42.763 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:57:42.763 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:57:42.763 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:57:42.797 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:57:42.797 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:57:42.797 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:58:02.777 | HTTPS connection ID:85 to downloads.rithmic.com:443 for request ID:85 (2) | Creating socket. Using TLS 1.2. 2026-06-01 11:58:02.777 | HTTPS connection ID:85 to downloads.rithmic.com:443 for request ID:85 (2) | New receive buffer size: 0 2026-06-01 11:58:02.777 | HTTPS connection ID:85 to downloads.rithmic.com:443 for request ID:85 (2) | Connecting to IP: 216.66.0.130. 2026-06-01 11:58:03.537 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 11:58:03.602 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 11:58:03.930 | HTTPS connection ID:85 to downloads.rithmic.com:443 for request ID:85 (2) | CloseSocket call. 2026-06-01 11:58:03.930 | HTTPS connection ID:85 to downloads.rithmic.com:443 for request ID:85 (2) | Shutdown started. Waiting for graceful close. 2026-06-01 11:58:04.038 | HTTPS connection ID:85 to downloads.rithmic.com:443 for request ID:85 (2) | Socket gracefully closed by remote side. 2026-06-01 11:58:04.038 | HTTPS connection ID:85 to downloads.rithmic.com:443 for request ID:85 (2) | Closed. 2026-06-01 11:59:42.828 | 2026-06-01 11:59:42.828 | Rithmic Direct - DTC | Using server connection: 2026-06-01 11:59:42.828 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 11:59:42.828 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 11:59:42.828 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 11:59:42.828 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 11:59:42.869 | DTC Client socket (0) | CloseSocket call. 2026-06-01 11:59:42.869 | Rithmic Direct - DTC | Disconnected. 2026-06-01 11:59:42.869 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:00:02.917 | HTTPS connection ID:86 to downloads.rithmic.com:443 for request ID:86 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:00:02.930 | HTTPS connection ID:86 to downloads.rithmic.com:443 for request ID:86 (1) | New receive buffer size: 0 2026-06-01 12:00:02.930 | HTTPS connection ID:86 to downloads.rithmic.com:443 for request ID:86 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:00:03.628 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:00:03.700 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:00:04.005 | HTTPS connection ID:86 to downloads.rithmic.com:443 for request ID:86 (1) | CloseSocket call. 2026-06-01 12:00:04.005 | HTTPS connection ID:86 to downloads.rithmic.com:443 for request ID:86 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:00:04.113 | HTTPS connection ID:86 to downloads.rithmic.com:443 for request ID:86 (1) | Socket gracefully closed by remote side. 2026-06-01 12:00:04.113 | HTTPS connection ID:86 to downloads.rithmic.com:443 for request ID:86 (1) | Closed. 2026-06-01 12:01:42.946 | 2026-06-01 12:01:42.946 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:01:42.946 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:01:42.946 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:01:42.946 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:01:42.946 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:01:42.985 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:01:42.985 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:01:42.986 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:02:02.995 | HTTPS connection ID:87 to downloads.rithmic.com:443 for request ID:87 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:02:02.995 | HTTPS connection ID:87 to downloads.rithmic.com:443 for request ID:87 (1) | New receive buffer size: 0 2026-06-01 12:02:02.995 | HTTPS connection ID:87 to downloads.rithmic.com:443 for request ID:87 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:02:03.713 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:02:03.782 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:02:04.049 | HTTPS connection ID:87 to downloads.rithmic.com:443 for request ID:87 (1) | CloseSocket call. 2026-06-01 12:02:04.049 | HTTPS connection ID:87 to downloads.rithmic.com:443 for request ID:87 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:02:04.157 | HTTPS connection ID:87 to downloads.rithmic.com:443 for request ID:87 (1) | Socket gracefully closed by remote side. 2026-06-01 12:02:04.157 | HTTPS connection ID:87 to downloads.rithmic.com:443 for request ID:87 (1) | Closed. 2026-06-01 12:03:43.032 | 2026-06-01 12:03:43.032 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:03:43.032 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:03:43.032 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:03:43.032 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:03:43.032 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:03:43.068 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:03:43.068 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:03:43.068 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:04:03.047 | HTTPS connection ID:88 to downloads.rithmic.com:443 for request ID:88 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:04:03.047 | HTTPS connection ID:88 to downloads.rithmic.com:443 for request ID:88 (1) | New receive buffer size: 0 2026-06-01 12:04:03.047 | HTTPS connection ID:88 to downloads.rithmic.com:443 for request ID:88 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:04:03.795 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:04:03.855 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:04:04.122 | HTTPS connection ID:88 to downloads.rithmic.com:443 for request ID:88 (1) | CloseSocket call. 2026-06-01 12:04:04.122 | HTTPS connection ID:88 to downloads.rithmic.com:443 for request ID:88 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:04:04.233 | HTTPS connection ID:88 to downloads.rithmic.com:443 for request ID:88 (1) | Socket gracefully closed by remote side. 2026-06-01 12:04:04.233 | HTTPS connection ID:88 to downloads.rithmic.com:443 for request ID:88 (1) | Closed. 2026-06-01 12:05:43.143 | 2026-06-01 12:05:43.143 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:05:43.143 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:05:43.143 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:05:43.143 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:05:43.143 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:05:43.184 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:05:43.184 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:05:43.184 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:06:03.226 | HTTPS connection ID:89 to downloads.rithmic.com:443 for request ID:89 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:06:03.226 | HTTPS connection ID:89 to downloads.rithmic.com:443 for request ID:89 (1) | New receive buffer size: 0 2026-06-01 12:06:03.226 | HTTPS connection ID:89 to downloads.rithmic.com:443 for request ID:89 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:06:04.012 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:06:04.071 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:06:04.458 | HTTPS connection ID:89 to downloads.rithmic.com:443 for request ID:89 (1) | CloseSocket call. 2026-06-01 12:06:04.458 | HTTPS connection ID:89 to downloads.rithmic.com:443 for request ID:89 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:06:04.567 | HTTPS connection ID:89 to downloads.rithmic.com:443 for request ID:89 (1) | Socket gracefully closed by remote side. 2026-06-01 12:06:04.567 | HTTPS connection ID:89 to downloads.rithmic.com:443 for request ID:89 (1) | Closed. 2026-06-01 12:07:43.201 | 2026-06-01 12:07:43.201 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:07:43.201 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:07:43.201 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:07:43.201 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:07:43.201 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:07:43.237 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:07:43.237 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:07:43.237 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:08:03.326 | HTTPS connection ID:90 to downloads.rithmic.com:443 for request ID:90 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:08:03.326 | HTTPS connection ID:90 to downloads.rithmic.com:443 for request ID:90 (1) | New receive buffer size: 0 2026-06-01 12:08:03.326 | HTTPS connection ID:90 to downloads.rithmic.com:443 for request ID:90 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:08:04.076 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:08:04.158 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:08:04.457 | HTTPS connection ID:90 to downloads.rithmic.com:443 for request ID:90 (1) | CloseSocket call. 2026-06-01 12:08:04.458 | HTTPS connection ID:90 to downloads.rithmic.com:443 for request ID:90 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:08:04.566 | HTTPS connection ID:90 to downloads.rithmic.com:443 for request ID:90 (1) | Socket gracefully closed by remote side. 2026-06-01 12:08:04.566 | HTTPS connection ID:90 to downloads.rithmic.com:443 for request ID:90 (1) | Closed. 2026-06-01 12:09:43.262 | 2026-06-01 12:09:43.262 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:09:43.262 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:09:43.262 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:09:43.262 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:09:43.262 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:09:43.297 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:09:43.297 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:09:43.297 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:10:03.272 | HTTPS connection ID:91 to downloads.rithmic.com:443 for request ID:91 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:10:03.272 | HTTPS connection ID:91 to downloads.rithmic.com:443 for request ID:91 (1) | New receive buffer size: 0 2026-06-01 12:10:03.272 | HTTPS connection ID:91 to downloads.rithmic.com:443 for request ID:91 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:10:04.042 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:10:04.120 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:10:04.402 | HTTPS connection ID:91 to downloads.rithmic.com:443 for request ID:91 (1) | CloseSocket call. 2026-06-01 12:10:04.402 | HTTPS connection ID:91 to downloads.rithmic.com:443 for request ID:91 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:10:04.517 | HTTPS connection ID:91 to downloads.rithmic.com:443 for request ID:91 (1) | Socket gracefully closed by remote side. 2026-06-01 12:10:04.518 | HTTPS connection ID:91 to downloads.rithmic.com:443 for request ID:91 (1) | Closed. 2026-06-01 12:11:43.309 | 2026-06-01 12:11:43.309 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:11:43.309 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:11:43.309 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:11:43.309 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:11:43.309 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:11:43.336 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:11:43.336 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:11:43.336 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:12:03.443 | HTTPS connection ID:92 to downloads.rithmic.com:443 for request ID:92 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:12:03.443 | HTTPS connection ID:92 to downloads.rithmic.com:443 for request ID:92 (1) | New receive buffer size: 0 2026-06-01 12:12:03.443 | HTTPS connection ID:92 to downloads.rithmic.com:443 for request ID:92 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:12:04.129 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:12:04.197 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:12:04.460 | HTTPS connection ID:92 to downloads.rithmic.com:443 for request ID:92 (1) | CloseSocket call. 2026-06-01 12:12:04.460 | HTTPS connection ID:92 to downloads.rithmic.com:443 for request ID:92 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:12:04.568 | HTTPS connection ID:92 to downloads.rithmic.com:443 for request ID:92 (1) | Socket gracefully closed by remote side. 2026-06-01 12:12:04.568 | HTTPS connection ID:92 to downloads.rithmic.com:443 for request ID:92 (1) | Closed. 2026-06-01 12:13:43.360 | 2026-06-01 12:13:43.360 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:13:43.360 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:13:43.360 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:13:43.360 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:13:43.360 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:13:43.380 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:13:43.380 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:13:43.381 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:14:03.488 | HTTPS connection ID:93 to downloads.rithmic.com:443 for request ID:93 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:14:03.489 | HTTPS connection ID:93 to downloads.rithmic.com:443 for request ID:93 (1) | New receive buffer size: 0 2026-06-01 12:14:03.489 | HTTPS connection ID:93 to downloads.rithmic.com:443 for request ID:93 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:14:04.719 | HTTPS connection ID:93 to downloads.rithmic.com:443 for request ID:93 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 12:14:04.726 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:14:04.790 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:14:04.790 | HTTPS connection ID:93 to downloads.rithmic.com:443 for request ID:93 (1) | CloseSocket call. 2026-06-01 12:14:04.790 | HTTPS connection ID:93 to downloads.rithmic.com:443 for request ID:93 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:14:04.790 | HTTPS connection ID:93 to downloads.rithmic.com:443 for request ID:93 (1) | Closed. 2026-06-01 12:15:43.400 | 2026-06-01 12:15:43.401 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:15:43.401 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:15:43.401 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:15:43.401 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:15:43.401 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:15:43.429 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:15:43.429 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:15:43.429 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:16:03.485 | HTTPS connection ID:94 to downloads.rithmic.com:443 for request ID:94 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:16:03.485 | HTTPS connection ID:94 to downloads.rithmic.com:443 for request ID:94 (1) | New receive buffer size: 0 2026-06-01 12:16:03.485 | HTTPS connection ID:94 to downloads.rithmic.com:443 for request ID:94 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:16:04.697 | HTTPS connection ID:94 to downloads.rithmic.com:443 for request ID:94 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 12:16:04.730 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:16:04.804 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:16:04.804 | HTTPS connection ID:94 to downloads.rithmic.com:443 for request ID:94 (1) | CloseSocket call. 2026-06-01 12:16:04.805 | HTTPS connection ID:94 to downloads.rithmic.com:443 for request ID:94 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:16:04.805 | HTTPS connection ID:94 to downloads.rithmic.com:443 for request ID:94 (1) | Closed. 2026-06-01 12:17:43.465 | 2026-06-01 12:17:43.465 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:17:43.465 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:17:43.465 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:17:43.465 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:17:43.465 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:17:43.493 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:17:43.493 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:17:43.493 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:18:03.596 | HTTPS connection ID:95 to downloads.rithmic.com:443 for request ID:95 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:18:03.596 | HTTPS connection ID:95 to downloads.rithmic.com:443 for request ID:95 (1) | New receive buffer size: 0 2026-06-01 12:18:03.596 | HTTPS connection ID:95 to downloads.rithmic.com:443 for request ID:95 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:18:04.815 | HTTPS connection ID:95 to downloads.rithmic.com:443 for request ID:95 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 12:18:04.852 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:18:04.926 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:18:04.926 | HTTPS connection ID:95 to downloads.rithmic.com:443 for request ID:95 (1) | CloseSocket call. 2026-06-01 12:18:04.926 | HTTPS connection ID:95 to downloads.rithmic.com:443 for request ID:95 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:18:04.926 | HTTPS connection ID:95 to downloads.rithmic.com:443 for request ID:95 (1) | Closed. 2026-06-01 12:19:43.560 | 2026-06-01 12:19:43.560 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:19:43.560 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:19:43.560 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:19:43.560 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:19:43.560 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:19:43.594 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:19:43.594 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:19:43.594 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:20:03.658 | HTTPS connection ID:96 to downloads.rithmic.com:443 for request ID:96 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:20:03.659 | HTTPS connection ID:96 to downloads.rithmic.com:443 for request ID:96 (1) | New receive buffer size: 0 2026-06-01 12:20:03.659 | HTTPS connection ID:96 to downloads.rithmic.com:443 for request ID:96 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:20:04.731 | HTTPS connection ID:96 to downloads.rithmic.com:443 for request ID:96 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 12:20:04.741 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:20:04.810 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:20:04.810 | HTTPS connection ID:96 to downloads.rithmic.com:443 for request ID:96 (1) | CloseSocket call. 2026-06-01 12:20:04.810 | HTTPS connection ID:96 to downloads.rithmic.com:443 for request ID:96 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:20:04.810 | HTTPS connection ID:96 to downloads.rithmic.com:443 for request ID:96 (1) | Closed. 2026-06-01 12:21:43.602 | 2026-06-01 12:21:43.603 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:21:43.603 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:21:43.603 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:21:43.603 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:21:43.603 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:21:43.619 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:21:43.619 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:21:43.619 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:22:03.700 | HTTPS connection ID:97 to downloads.rithmic.com:443 for request ID:97 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:22:03.701 | HTTPS connection ID:97 to downloads.rithmic.com:443 for request ID:97 (1) | New receive buffer size: 0 2026-06-01 12:22:03.701 | HTTPS connection ID:97 to downloads.rithmic.com:443 for request ID:97 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:22:04.975 | HTTPS connection ID:97 to downloads.rithmic.com:443 for request ID:97 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 12:22:04.988 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:22:05.117 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:22:05.118 | HTTPS connection ID:97 to downloads.rithmic.com:443 for request ID:97 (1) | CloseSocket call. 2026-06-01 12:22:05.118 | HTTPS connection ID:97 to downloads.rithmic.com:443 for request ID:97 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:22:05.118 | HTTPS connection ID:97 to downloads.rithmic.com:443 for request ID:97 (1) | Closed. 2026-06-01 12:23:43.654 | 2026-06-01 12:23:43.654 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:23:43.654 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:23:43.654 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:23:43.654 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:23:43.654 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:23:43.697 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:23:43.697 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:23:43.697 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:24:03.749 | HTTPS connection ID:98 to downloads.rithmic.com:443 for request ID:98 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:24:03.749 | HTTPS connection ID:98 to downloads.rithmic.com:443 for request ID:98 (1) | New receive buffer size: 0 2026-06-01 12:24:03.749 | HTTPS connection ID:98 to downloads.rithmic.com:443 for request ID:98 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:24:04.958 | HTTPS connection ID:98 to downloads.rithmic.com:443 for request ID:98 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 12:24:04.963 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:24:05.046 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:24:05.046 | HTTPS connection ID:98 to downloads.rithmic.com:443 for request ID:98 (1) | CloseSocket call. 2026-06-01 12:24:05.046 | HTTPS connection ID:98 to downloads.rithmic.com:443 for request ID:98 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:24:05.046 | HTTPS connection ID:98 to downloads.rithmic.com:443 for request ID:98 (1) | Closed. 2026-06-01 12:25:43.717 | 2026-06-01 12:25:43.718 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:25:43.718 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:25:43.718 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:25:43.718 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:25:43.718 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:25:43.746 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:25:43.746 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:25:43.746 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:26:03.786 | HTTPS connection ID:99 to downloads.rithmic.com:443 for request ID:99 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:26:03.786 | HTTPS connection ID:99 to downloads.rithmic.com:443 for request ID:99 (1) | New receive buffer size: 0 2026-06-01 12:26:03.786 | HTTPS connection ID:99 to downloads.rithmic.com:443 for request ID:99 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:26:04.542 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:26:04.616 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:26:04.918 | HTTPS connection ID:99 to downloads.rithmic.com:443 for request ID:99 (1) | CloseSocket call. 2026-06-01 12:26:04.918 | HTTPS connection ID:99 to downloads.rithmic.com:443 for request ID:99 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:26:05.030 | HTTPS connection ID:99 to downloads.rithmic.com:443 for request ID:99 (1) | Socket gracefully closed by remote side. 2026-06-01 12:26:05.030 | HTTPS connection ID:99 to downloads.rithmic.com:443 for request ID:99 (1) | Closed. 2026-06-01 12:27:43.764 | 2026-06-01 12:27:43.764 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:27:43.764 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:27:43.764 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:27:43.764 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:27:43.764 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:27:43.785 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:27:43.785 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:27:43.785 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:28:03.780 | HTTPS connection ID:100 to downloads.rithmic.com:443 for request ID:100 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:28:03.780 | HTTPS connection ID:100 to downloads.rithmic.com:443 for request ID:100 (1) | New receive buffer size: 0 2026-06-01 12:28:03.780 | HTTPS connection ID:100 to downloads.rithmic.com:443 for request ID:100 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:28:04.498 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:28:04.558 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:28:04.819 | HTTPS connection ID:100 to downloads.rithmic.com:443 for request ID:100 (1) | CloseSocket call. 2026-06-01 12:28:04.819 | HTTPS connection ID:100 to downloads.rithmic.com:443 for request ID:100 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:28:04.927 | HTTPS connection ID:100 to downloads.rithmic.com:443 for request ID:100 (1) | Socket gracefully closed by remote side. 2026-06-01 12:28:04.927 | HTTPS connection ID:100 to downloads.rithmic.com:443 for request ID:100 (1) | Closed. 2026-06-01 12:29:43.801 | 2026-06-01 12:29:43.801 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:29:43.801 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:29:43.801 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:29:43.801 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:29:43.801 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:29:43.899 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:29:43.899 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:29:43.899 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:30:03.918 | HTTPS connection ID:101 to downloads.rithmic.com:443 for request ID:101 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:30:03.919 | HTTPS connection ID:101 to downloads.rithmic.com:443 for request ID:101 (1) | New receive buffer size: 0 2026-06-01 12:30:03.919 | HTTPS connection ID:101 to downloads.rithmic.com:443 for request ID:101 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:30:04.618 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:30:04.703 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:30:04.981 | HTTPS connection ID:101 to downloads.rithmic.com:443 for request ID:101 (1) | CloseSocket call. 2026-06-01 12:30:04.981 | HTTPS connection ID:101 to downloads.rithmic.com:443 for request ID:101 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:30:05.093 | HTTPS connection ID:101 to downloads.rithmic.com:443 for request ID:101 (1) | Socket gracefully closed by remote side. 2026-06-01 12:30:05.093 | HTTPS connection ID:101 to downloads.rithmic.com:443 for request ID:101 (1) | Closed. 2026-06-01 12:31:43.986 | 2026-06-01 12:31:43.986 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:31:43.986 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:31:43.986 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:31:43.986 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:31:43.986 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:31:44.032 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:31:44.032 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:31:44.032 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:32:04.059 | HTTPS connection ID:102 to downloads.rithmic.com:443 for request ID:102 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:32:04.059 | HTTPS connection ID:102 to downloads.rithmic.com:443 for request ID:102 (1) | New receive buffer size: 0 2026-06-01 12:32:04.059 | HTTPS connection ID:102 to downloads.rithmic.com:443 for request ID:102 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:32:05.282 | HTTPS connection ID:102 to downloads.rithmic.com:443 for request ID:102 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 12:32:05.297 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:32:05.354 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:32:05.354 | HTTPS connection ID:102 to downloads.rithmic.com:443 for request ID:102 (1) | CloseSocket call. 2026-06-01 12:32:05.354 | HTTPS connection ID:102 to downloads.rithmic.com:443 for request ID:102 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:32:05.354 | HTTPS connection ID:102 to downloads.rithmic.com:443 for request ID:102 (1) | Closed. 2026-06-01 12:33:44.051 | 2026-06-01 12:33:44.052 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:33:44.052 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:33:44.052 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:33:44.052 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:33:44.052 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:33:44.094 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:33:44.094 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:33:44.094 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:34:04.093 | HTTPS connection ID:103 to downloads.rithmic.com:443 for request ID:103 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:34:04.093 | HTTPS connection ID:103 to downloads.rithmic.com:443 for request ID:103 (1) | New receive buffer size: 0 2026-06-01 12:34:04.093 | HTTPS connection ID:103 to downloads.rithmic.com:443 for request ID:103 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:34:05.138 | HTTPS connection ID:103 to downloads.rithmic.com:443 for request ID:103 (1) | Socket gracefully closed by remote side. 2026-06-01 12:34:05.168 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:34:05.168 | HTTPS connection ID:103 to downloads.rithmic.com:443 for request ID:103 (1) | Socket gracefully closed by remote side. 2026-06-01 12:34:05.236 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:34:05.236 | HTTPS connection ID:103 to downloads.rithmic.com:443 for request ID:103 (1) | CloseSocket call. 2026-06-01 12:34:05.236 | HTTPS connection ID:103 to downloads.rithmic.com:443 for request ID:103 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:34:05.236 | HTTPS connection ID:103 to downloads.rithmic.com:443 for request ID:103 (1) | Closed. 2026-06-01 12:35:44.113 | 2026-06-01 12:35:44.113 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:35:44.113 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:35:44.113 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:35:44.113 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:35:44.113 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:35:44.127 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:35:44.127 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:35:44.127 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:36:04.200 | HTTPS connection ID:104 to downloads.rithmic.com:443 for request ID:104 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:36:04.200 | HTTPS connection ID:104 to downloads.rithmic.com:443 for request ID:104 (1) | New receive buffer size: 0 2026-06-01 12:36:04.200 | HTTPS connection ID:104 to downloads.rithmic.com:443 for request ID:104 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:36:05.383 | HTTPS connection ID:104 to downloads.rithmic.com:443 for request ID:104 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 12:36:05.401 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:36:05.458 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:36:05.458 | HTTPS connection ID:104 to downloads.rithmic.com:443 for request ID:104 (1) | CloseSocket call. 2026-06-01 12:36:05.458 | HTTPS connection ID:104 to downloads.rithmic.com:443 for request ID:104 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:36:05.458 | HTTPS connection ID:104 to downloads.rithmic.com:443 for request ID:104 (1) | Closed. 2026-06-01 12:37:44.153 | 2026-06-01 12:37:44.153 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:37:44.153 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:37:44.153 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:37:44.153 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:37:44.153 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:37:44.183 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:37:44.183 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:37:44.183 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:38:04.205 | HTTPS connection ID:105 to downloads.rithmic.com:443 for request ID:105 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:38:04.205 | HTTPS connection ID:105 to downloads.rithmic.com:443 for request ID:105 (1) | New receive buffer size: 0 2026-06-01 12:38:04.205 | HTTPS connection ID:105 to downloads.rithmic.com:443 for request ID:105 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:38:05.360 | HTTPS connection ID:105 to downloads.rithmic.com:443 for request ID:105 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 12:38:05.391 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:38:05.459 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:38:05.459 | HTTPS connection ID:105 to downloads.rithmic.com:443 for request ID:105 (1) | CloseSocket call. 2026-06-01 12:38:05.459 | HTTPS connection ID:105 to downloads.rithmic.com:443 for request ID:105 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:38:05.459 | HTTPS connection ID:105 to downloads.rithmic.com:443 for request ID:105 (1) | Closed. 2026-06-01 12:39:44.192 | 2026-06-01 12:39:44.192 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:39:44.192 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:39:44.192 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:39:44.192 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:39:44.192 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:39:44.295 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:39:44.295 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:39:44.295 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:40:04.233 | HTTPS connection ID:106 to downloads.rithmic.com:443 for request ID:106 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:40:04.233 | HTTPS connection ID:106 to downloads.rithmic.com:443 for request ID:106 (1) | New receive buffer size: 0 2026-06-01 12:40:04.233 | HTTPS connection ID:106 to downloads.rithmic.com:443 for request ID:106 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:40:05.336 | HTTPS connection ID:106 to downloads.rithmic.com:443 for request ID:106 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 12:40:05.358 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:40:05.423 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:40:05.424 | HTTPS connection ID:106 to downloads.rithmic.com:443 for request ID:106 (1) | CloseSocket call. 2026-06-01 12:40:05.424 | HTTPS connection ID:106 to downloads.rithmic.com:443 for request ID:106 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:40:05.424 | HTTPS connection ID:106 to downloads.rithmic.com:443 for request ID:106 (1) | Closed. 2026-06-01 12:41:44.310 | 2026-06-01 12:41:44.311 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:41:44.311 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:41:44.311 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:41:44.311 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:41:44.311 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:41:44.408 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:41:44.408 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:41:44.408 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:42:04.366 | HTTPS connection ID:107 to downloads.rithmic.com:443 for request ID:107 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:42:04.366 | HTTPS connection ID:107 to downloads.rithmic.com:443 for request ID:107 (1) | New receive buffer size: 0 2026-06-01 12:42:04.366 | HTTPS connection ID:107 to downloads.rithmic.com:443 for request ID:107 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:42:05.614 | HTTPS connection ID:107 to downloads.rithmic.com:443 for request ID:107 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 12:42:05.629 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:42:05.717 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:42:05.717 | HTTPS connection ID:107 to downloads.rithmic.com:443 for request ID:107 (1) | CloseSocket call. 2026-06-01 12:42:05.717 | HTTPS connection ID:107 to downloads.rithmic.com:443 for request ID:107 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:42:05.717 | HTTPS connection ID:107 to downloads.rithmic.com:443 for request ID:107 (1) | Closed. 2026-06-01 12:43:44.430 | 2026-06-01 12:43:44.431 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:43:44.431 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:43:44.431 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:43:44.431 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:43:44.431 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:43:44.459 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:43:44.459 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:43:44.459 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:44:04.473 | HTTPS connection ID:108 to downloads.rithmic.com:443 for request ID:108 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:44:04.473 | HTTPS connection ID:108 to downloads.rithmic.com:443 for request ID:108 (1) | New receive buffer size: 0 2026-06-01 12:44:04.473 | HTTPS connection ID:108 to downloads.rithmic.com:443 for request ID:108 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:44:05.198 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:44:05.256 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:44:05.521 | HTTPS connection ID:108 to downloads.rithmic.com:443 for request ID:108 (1) | CloseSocket call. 2026-06-01 12:44:05.521 | HTTPS connection ID:108 to downloads.rithmic.com:443 for request ID:108 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:44:05.629 | HTTPS connection ID:108 to downloads.rithmic.com:443 for request ID:108 (1) | Socket gracefully closed by remote side. 2026-06-01 12:44:05.629 | HTTPS connection ID:108 to downloads.rithmic.com:443 for request ID:108 (1) | Closed. 2026-06-01 12:45:44.479 | 2026-06-01 12:45:44.479 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:45:44.479 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:45:44.479 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:45:44.479 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:45:44.479 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:45:44.502 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:45:44.502 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:45:44.502 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:46:04.580 | HTTPS connection ID:109 to downloads.rithmic.com:443 for request ID:109 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:46:04.580 | HTTPS connection ID:109 to downloads.rithmic.com:443 for request ID:109 (1) | New receive buffer size: 0 2026-06-01 12:46:04.580 | HTTPS connection ID:109 to downloads.rithmic.com:443 for request ID:109 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:46:05.271 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:46:05.327 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:46:05.667 | HTTPS connection ID:109 to downloads.rithmic.com:443 for request ID:109 (1) | CloseSocket call. 2026-06-01 12:46:05.667 | HTTPS connection ID:109 to downloads.rithmic.com:443 for request ID:109 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:46:05.775 | HTTPS connection ID:109 to downloads.rithmic.com:443 for request ID:109 (1) | Socket gracefully closed by remote side. 2026-06-01 12:46:05.775 | HTTPS connection ID:109 to downloads.rithmic.com:443 for request ID:109 (1) | Closed. 2026-06-01 12:47:44.559 | 2026-06-01 12:47:44.559 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:47:44.559 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:47:44.559 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:47:44.559 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:47:44.559 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:47:44.607 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:47:44.607 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:47:44.607 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:48:04.634 | HTTPS connection ID:110 to downloads.rithmic.com:443 for request ID:110 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:48:04.635 | HTTPS connection ID:110 to downloads.rithmic.com:443 for request ID:110 (1) | New receive buffer size: 0 2026-06-01 12:48:04.635 | HTTPS connection ID:110 to downloads.rithmic.com:443 for request ID:110 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:48:05.448 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:48:05.530 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:48:05.879 | HTTPS connection ID:110 to downloads.rithmic.com:443 for request ID:110 (1) | CloseSocket call. 2026-06-01 12:48:05.879 | HTTPS connection ID:110 to downloads.rithmic.com:443 for request ID:110 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:48:06.016 | HTTPS connection ID:110 to downloads.rithmic.com:443 for request ID:110 (1) | Socket gracefully closed by remote side. 2026-06-01 12:48:06.017 | HTTPS connection ID:110 to downloads.rithmic.com:443 for request ID:110 (1) | Closed. 2026-06-01 12:49:44.611 | 2026-06-01 12:49:44.611 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:49:44.611 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:49:44.611 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:49:44.611 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:49:44.611 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:49:44.660 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:49:44.660 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:49:44.660 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:50:04.703 | HTTPS connection ID:111 to downloads.rithmic.com:443 for request ID:111 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:50:04.703 | HTTPS connection ID:111 to downloads.rithmic.com:443 for request ID:111 (1) | New receive buffer size: 0 2026-06-01 12:50:04.703 | HTTPS connection ID:111 to downloads.rithmic.com:443 for request ID:111 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:50:05.495 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:50:05.566 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:50:05.861 | HTTPS connection ID:111 to downloads.rithmic.com:443 for request ID:111 (1) | CloseSocket call. 2026-06-01 12:50:05.861 | HTTPS connection ID:111 to downloads.rithmic.com:443 for request ID:111 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:50:05.969 | HTTPS connection ID:111 to downloads.rithmic.com:443 for request ID:111 (1) | Socket gracefully closed by remote side. 2026-06-01 12:50:05.969 | HTTPS connection ID:111 to downloads.rithmic.com:443 for request ID:111 (1) | Closed. 2026-06-01 12:51:44.668 | 2026-06-01 12:51:44.668 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:51:44.668 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:51:44.668 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:51:44.668 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:51:44.668 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:51:44.730 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:51:44.730 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:51:44.730 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:52:04.675 | HTTPS connection ID:112 to downloads.rithmic.com:443 for request ID:112 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:52:04.676 | HTTPS connection ID:112 to downloads.rithmic.com:443 for request ID:112 (1) | New receive buffer size: 0 2026-06-01 12:52:04.676 | HTTPS connection ID:112 to downloads.rithmic.com:443 for request ID:112 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:52:05.461 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:52:05.550 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:52:05.810 | HTTPS connection ID:112 to downloads.rithmic.com:443 for request ID:112 (1) | CloseSocket call. 2026-06-01 12:52:05.810 | HTTPS connection ID:112 to downloads.rithmic.com:443 for request ID:112 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:52:05.918 | HTTPS connection ID:112 to downloads.rithmic.com:443 for request ID:112 (1) | Socket gracefully closed by remote side. 2026-06-01 12:52:05.919 | HTTPS connection ID:112 to downloads.rithmic.com:443 for request ID:112 (1) | Closed. 2026-06-01 12:53:44.819 | 2026-06-01 12:53:44.819 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:53:44.819 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:53:44.819 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:53:44.819 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:53:44.819 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:53:44.879 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:53:44.879 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:53:44.879 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:54:04.889 | HTTPS connection ID:113 to downloads.rithmic.com:443 for request ID:113 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:54:04.889 | HTTPS connection ID:113 to downloads.rithmic.com:443 for request ID:113 (1) | New receive buffer size: 0 2026-06-01 12:54:04.889 | HTTPS connection ID:113 to downloads.rithmic.com:443 for request ID:113 (1) | Connecting to IP: 216.66.0.130. 2026-06-01 12:54:05.738 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:54:05.825 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:54:06.080 | HTTPS connection ID:113 to downloads.rithmic.com:443 for request ID:113 (1) | CloseSocket call. 2026-06-01 12:54:06.080 | HTTPS connection ID:113 to downloads.rithmic.com:443 for request ID:113 (1) | Shutdown started. Waiting for graceful close. 2026-06-01 12:54:06.189 | HTTPS connection ID:113 to downloads.rithmic.com:443 for request ID:113 (1) | Socket gracefully closed by remote side. 2026-06-01 12:54:06.189 | HTTPS connection ID:113 to downloads.rithmic.com:443 for request ID:113 (1) | Closed. 2026-06-01 12:55:44.886 | 2026-06-01 12:55:44.886 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:55:44.886 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:55:44.886 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:55:44.886 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:55:44.886 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:55:44.927 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:55:44.927 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:55:44.927 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:56:04.928 | HTTPS connection ID:114 to downloads.rithmic.com:443 for request ID:114 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:56:04.929 | HTTPS connection ID:114 to downloads.rithmic.com:443 for request ID:114 (1) | New receive buffer size: 0 2026-06-01 12:56:04.929 | HTTPS connection ID:114 to downloads.rithmic.com:443 for request ID:114 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:56:06.105 | HTTPS connection ID:114 to downloads.rithmic.com:443 for request ID:114 (1) | Socket gracefully closed by remote side. 2026-06-01 12:56:06.117 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:56:06.117 | HTTPS connection ID:114 to downloads.rithmic.com:443 for request ID:114 (1) | Socket gracefully closed by remote side. 2026-06-01 12:56:06.201 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:56:06.201 | HTTPS connection ID:114 to downloads.rithmic.com:443 for request ID:114 (1) | CloseSocket call. 2026-06-01 12:56:06.201 | HTTPS connection ID:114 to downloads.rithmic.com:443 for request ID:114 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:56:06.201 | HTTPS connection ID:114 to downloads.rithmic.com:443 for request ID:114 (1) | Closed. 2026-06-01 12:57:44.980 | 2026-06-01 12:57:44.980 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:57:44.980 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:57:44.980 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:57:44.980 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:57:44.980 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:57:45.026 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:57:45.026 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:57:45.026 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:58:04.989 | HTTPS connection ID:115 to downloads.rithmic.com:443 for request ID:115 (1) | Creating socket. Using TLS 1.2. 2026-06-01 12:58:04.989 | HTTPS connection ID:115 to downloads.rithmic.com:443 for request ID:115 (1) | New receive buffer size: 0 2026-06-01 12:58:04.989 | HTTPS connection ID:115 to downloads.rithmic.com:443 for request ID:115 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 12:58:06.193 | HTTPS connection ID:115 to downloads.rithmic.com:443 for request ID:115 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 12:58:06.202 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 12:58:06.266 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 12:58:06.266 | HTTPS connection ID:115 to downloads.rithmic.com:443 for request ID:115 (1) | CloseSocket call. 2026-06-01 12:58:06.266 | HTTPS connection ID:115 to downloads.rithmic.com:443 for request ID:115 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 12:58:06.266 | HTTPS connection ID:115 to downloads.rithmic.com:443 for request ID:115 (1) | Closed. 2026-06-01 12:59:45.035 | 2026-06-01 12:59:45.035 | Rithmic Direct - DTC | Using server connection: 2026-06-01 12:59:45.035 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 12:59:45.035 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 12:59:45.035 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 12:59:45.035 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 12:59:45.056 | DTC Client socket (0) | CloseSocket call. 2026-06-01 12:59:45.056 | Rithmic Direct - DTC | Disconnected. 2026-06-01 12:59:45.056 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:00:05.151 | HTTPS connection ID:116 to downloads.rithmic.com:443 for request ID:116 (1) | Creating socket. Using TLS 1.2. 2026-06-01 13:00:05.151 | HTTPS connection ID:116 to downloads.rithmic.com:443 for request ID:116 (1) | New receive buffer size: 0 2026-06-01 13:00:05.151 | HTTPS connection ID:116 to downloads.rithmic.com:443 for request ID:116 (1) | Connecting to IP: 38.79.0.89. 2026-06-01 13:00:06.385 | HTTPS connection ID:116 to downloads.rithmic.com:443 for request ID:116 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2026-06-01 13:00:06.399 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\Data\RithmicConnections.json. Size: 115672 2026-06-01 13:00:06.467 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-06-01 13:00:06.467 | HTTPS connection ID:116 to downloads.rithmic.com:443 for request ID:116 (1) | CloseSocket call. 2026-06-01 13:00:06.468 | HTTPS connection ID:116 to downloads.rithmic.com:443 for request ID:116 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-06-01 13:00:06.468 | HTTPS connection ID:116 to downloads.rithmic.com:443 for request ID:116 (1) | Closed. 2026-06-01 13:00:33.521 | File >> Disconnect selected. 2026-06-01 13:00:33.521 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:00:33.524 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:00:37.787 | 2026-06-01 13:00:37.788 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:00:37.788 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:00:37.788 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:00:37.788 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:00:37.788 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:00:37.827 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:00:37.827 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:00:37.827 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:00:41.844 | 2026-06-01 13:00:41.844 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:00:41.844 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:00:41.844 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:00:41.844 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:00:41.844 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:00:41.898 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:00:41.898 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:00:41.898 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:00:45.912 | 2026-06-01 13:00:45.912 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:00:45.912 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:00:45.912 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:00:45.913 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:00:45.913 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:00:46.019 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:00:46.019 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:00:46.019 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:00:50.027 | 2026-06-01 13:00:50.027 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:00:50.027 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:00:50.027 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:00:50.027 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:00:50.027 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:00:50.046 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:00:50.046 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:00:50.046 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:00:53.339 | Saved Chartbook: NEW MASTER ES.Cht. Time: 0.5454 seconds. 2026-06-01 13:00:56.130 | 2026-06-01 13:00:56.130 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:00:56.130 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:00:56.130 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:00:56.130 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:00:56.130 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:00:56.151 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:00:56.151 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:00:56.151 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:00.155 | 2026-06-01 13:01:00.155 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:01:00.155 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:01:00.155 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:01:00.155 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:01:00.155 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:00.170 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:01:00.170 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:01:00.170 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:04.178 | 2026-06-01 13:01:04.178 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:01:04.178 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:01:04.178 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:01:04.178 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:01:04.178 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:04.193 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:01:04.193 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:01:04.193 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:08.205 | 2026-06-01 13:01:08.205 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:01:08.205 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:01:08.205 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:01:08.205 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:01:08.205 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:08.221 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:01:08.221 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:01:08.221 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:12.231 | 2026-06-01 13:01:12.231 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:01:12.231 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:01:12.231 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:01:12.231 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:01:12.231 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:12.246 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:01:12.246 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:01:12.246 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:16.260 | 2026-06-01 13:01:16.260 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:01:16.260 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:01:16.260 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:01:16.260 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:01:16.260 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:16.274 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:01:16.274 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:01:16.274 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:20.278 | 2026-06-01 13:01:20.278 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:01:20.278 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:01:20.278 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:01:20.278 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:01:20.278 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:20.294 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:01:20.294 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:01:20.294 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:24.300 | 2026-06-01 13:01:24.300 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:01:24.300 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:01:24.300 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:01:24.300 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:01:24.300 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:24.315 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:01:24.315 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:01:24.315 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:28.325 | 2026-06-01 13:01:28.325 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:01:28.325 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:01:28.325 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:01:28.325 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:01:28.325 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:28.341 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:01:28.341 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:01:28.341 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:32.353 | 2026-06-01 13:01:32.353 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:01:32.353 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:01:32.353 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:01:32.353 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:01:32.353 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:32.369 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:01:32.369 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:01:32.369 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:36.373 | 2026-06-01 13:01:36.373 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:01:36.373 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:01:36.373 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:01:36.373 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:01:36.373 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:36.388 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:01:36.388 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:01:36.388 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:40.393 | 2026-06-01 13:01:40.393 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:01:40.393 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:01:40.393 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:01:40.393 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:01:40.393 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:40.409 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:01:40.409 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:01:40.409 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:44.419 | 2026-06-01 13:01:44.420 | Rithmic Direct - DTC | Using server connection: 2026-06-01 13:01:44.420 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 13:01:44.420 | Rithmic Direct - DTC | Remote address is not set. 2026-06-01 13:01:44.420 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-06-01 13:01:44.420 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-06-01 13:01:44.435 | DTC Client socket (0) | CloseSocket call. 2026-06-01 13:01:44.435 | Rithmic Direct - DTC | Disconnected. 2026-06-01 13:01:44.435 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. |
| [2026-06-01 17:09:45] |
| User252436 - Posts: 5 |
I hope this will help
| [2026-06-01 19:08:52] |
| John - SC Support - Posts: 48408 |
From the following: 2026-06-01 09:13:05.639 | Rithmic Direct - DTC | Using server connection:
2026-06-01 09:13:05.639 | Rithmic Direct - DTC | Trading server address/port: 2026-06-01 09:13:05.639 | Rithmic Direct - DTC | Remote address is not set. It looks like you do not have a server selected for the Rithmic connection. Refer to steps #8-#11 at the following link: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-01 19:30:53] |
Still not working after following steps #8,#11 I got a new error message Date Time Of Last Edit: 2026-06-01 19:31:29
Private File |
| [2026-06-01 19:34:01] |
Apparently, you did not enter a Password for your Rithmic connection. Please go through all of the setup instructions starting at Step #1 at the following link and make sure everything is setup properly: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-01 19:44:31] |
It works now. Thanks |
