Date/Time: Sat, 31 Oct 2026 18:47:00 +0000
Could ssd speed things up besides loading data?
View Count: 1766
[2014-10-30 14:51:11]
chartb - Posts: 6
I currently run multiple copies of sierrachart on a pc with 4770k, 16gb of ram and a few 1tb hdd. If I load too many days of data onto the charts, the memory usage would go up to 80%. Buttons and functions on sierrachart become less responsive, with noticeable delay between the response and the moment I click on something. Possibly, bars update slower too, although CPU usage is less than 30%.
To solve the above issue, should I get a ssd or more ram?
[2014-10-30 16:44:58]
An SSD will not reduce memory usage. However, we do highly recommend using SSDs.
Refer to help topic 30 here for some additional information:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
[2014-11-03 17:14:48]
chartb - Posts: 6
I have made some adjustment, the memory usage is down to 50%.
I look at the cpu usage more carefully, it's moving between 20% to 50%.
I don't have ssd. The hdd usage is between 0% to 20%.
(please see images in attachment for detail)
I have 6 copies of sierrachart opened. 2 of them are very responsive and fast. However, the other 4 copies, that have more days of data and studies to process are less responsive, price bars update slower than they should.
Please tell me what hardware should I upgrade in order to make all copies of sierrachart to run as fast as they could.
image20141103 112731.png / V - Attached On 2014-11-03 16:28:42 UTC - Size: 66.38 KB - 492 views
image20141103 121000.png / V - Attached On 2014-11-03 17:12:01 UTC - Size: 44.73 KB - 570 views
[2014-11-03 18:42:54]
The first thing we recommend is using SSDs.
