Date/Time: Thu, 26 Nov 2026 04:45:51 +0000
unable to select 'Numbers Bars' as a 'Graph Draw Type'
View Count: 276
| [2026-05-28 17:30:57] |
| User521888 - Posts: 1 |
Hello Sierra Chart Support, I am on Service Package 11, but I am unable to select 'Numbers Bars' as a 'Graph Draw Type'. It does not appear in my dropdown menu even after setting the 'Bar Period Type' to 'Intraday Tick'. Thank you for your help |
| [2026-05-28 18:33:26] |
The Numbers Bars is not a "Graph Draw Type" it is a study. Follow the instructions at the following link: Numbers Bars: Step-By-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
