Date/Time: Thu, 26 Nov 2026 04:45:51 +0000
Number of market depth levels for NQ is wrong!?
View Count: 329
| [2026-05-28 08:04:36] |
| TraderBake - Posts: 63 |
Two charts with dom graph on, both 400 for maximum market depth levels. Price range for NQ is higher than for MNQ. MNQ seems correct, to many levels for NQ.
| [2026-05-28 12:55:45] |
| Sierra_Chart Engineering - Posts: 25491 |
What you see must be correct. There is no reason why the market depth data for a particular symbol would be wrong. This is not technically possible for there to be a problem. Make sure you are not combining levels though: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) Make sure this is set to 0 for both charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-05-28 12:56:37
| [2026-05-28 15:52:12] |
600 Levels each and there is a huge difference in DOM graph.
| [2026-05-28 17:56:14] |
You need to look at the Market Depth Window (File >> Open Market Depth Window) for each symbol and see what the levels look like in there. Offhand, it looks like the Bid side for the MNQ just has fewer levels of market depth actually available. You have your settings set to only show 600, but there could be less. If you scroll to the bottom of the Market Depth Window you will see the total number of levels that are actuall making up the market depth at that moment for eaach side. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-28 19:25:33] |
Ok, only the levels, where there is actually a limit order counts as level. This makes sense. I thougt every Pricelevel would count regardless wether there is an order or not. NQ has less limit orders, so this is the reason. Thank you for your help. |
