Date/Time: Thu, 26 Nov 2026 04:45:54 +0000
Problem Teton
View Count: 226
| [2026-05-27 17:18:33] |
| eli733 - Posts: 13 |
Entschuldigung, warum funktioniert Teton Iron beam nicht. Es bewegt sich nichts . DankeĀ
| [2026-05-27 17:31:35] |
Warum kann ich mit Teton Iron Beam nicht traden? Ich finde Ihre Antwort leider nicht. Bitte senden Sie mir Ihre Antwort noch mal . Danke
| [2026-05-27 17:36:31] |
From Google Translate: Excuse me, why isn't the Teton Iron Beam working? Nothing is moving. Thank you. Why am I unable to trade with Teton Iron Beam? Unfortunately, I cannot find your previous response. Could you please send me your reply again? Thank you.[/quote]What exactly is occurring? What is the problem? Are you having an issue with data or just with trading? What happens when you try to trade? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-27 17:40:15] |
We see the following in one of the posts you made in the Account Support Tickets: 2026-05-27 16:45:45.079 | Teton CME Routing (Order reject). Info: Symbol is unknown for trading. Internal Order ID: 2923. Service Order ID: (none). Symbol: M2KM6.CME
This is the wrong symbol for Teton. This is a Rithmic symbol. You need to update your symbols when you change between services. You can also select "Edit >> Translate Symbols to Current Service" to update them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
