Date/Time: Mon, 09 Nov 2026 06:12:18 +0000
latest update and changes to combined Pull/Stack column
View Count: 975
| [2026-05-27 01:03:26] |
| User993067 - Posts: 200 |
updated to latest version and the combined pull stack column is using ABS values for the volume bars? This was never the case prior and is fundamental to my trading last 6 years. is this an error or new feature?...I dont like it
| [2026-05-27 15:05:49] |
| John - SC Support - Posts: 48459 |
There are updates still being worked on relative to the Volume Bars for the Pulling/Stacking. Look for these updates in the next Pre-Release (v 2914).
| [2026-06-03 01:25:24] |
| Sierra_Chart Engineering - Posts: 25404 |
Update to the latest version of Sierra Chart: Software Download: Fast Update There are now new color settings for negative volume bars for the pulling and stacking market data columns. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-09 16:37:14] |
| ChrisK - Posts: 54 |
Hello, I’m currently on v2913. After update will we be able to have negative P/S volume bars not affect the scale width of positive value P/S volume bars on combined pulling/stacking? In my view, as it was prior, a pulled -1000 volume bar shouldn’t have a greater width than a stacked 600 volume bar. Thank you! |
| [2026-06-09 17:17:38] |
Today’s volatility is a great example why using absolute values to determine volume bar width, regardless of color, for pulling/stacking column doesn’t work well live. I believe most traders would agree a negative/pulled value shouldn’t have a volume bar at all. It’s more intuitive that way and quicker to understand at a glance. Hope we have the option to keep it the way it used to be. |
| [2026-06-09 17:30:17] |
| User16876 - Posts: 16 |
ChrisK There is a simple workaround - set negative volume bar to same color as P/S column background color. |
| [2026-06-09 17:35:04] |
That doesn’t resolve the volume bar width issue. A pulled/negative value on a given level shouldn’t have a volume bar and certainly shouldn’t influence the width/scale of the rest of the bars at price levels with positive values.
Date Time Of Last Edit: 2026-06-09 17:35:55
| [2026-06-09 18:15:03] |
I would like Sierra Engineering to clarify why beginning with 2913 ABS values are now calculated in the Pull Stack Volume bars? this was never the case prior to that update, and disrupts the visual flow of the entire tool. Where negative bars (pulling) have the identical VB visual impact as positive (stacking). Why are we being forced to re-interpet the usage of this critical scalping tool? Please explain.... you added additional coloring functionality to the volume bars to compensate for this new design that really is unnecessary, as the actual values have coloring capability, the pattern ingrained is the SHAPE of the column, not coloring. To be clear I am asking for reversion to previous form, and if unable please explain reasoning...why fix unbroken tools? |
| [2026-06-09 23:40:08] |
Agreed. This issue came up once before after an update last year and SC Engineering acknowledged it was wrong and fixed it: pull/stack volume bars broken I’m confident SC will fix it again. By default this tool should not have a Volume Bar for negative/pulled values…any other configuration should be secondary options in my opinion. |
| [2026-06-10 01:50:48] |
| blt - Posts: 229 |
... @ChrisK Do not get too confident please...I love to see "negative" bars Visual perception is key in this case for me I do not even pay attention on numbers at levels-only on those bars that are in my case in light grey Of course I wouldn't mind at all to have that option as a second choice Do not take this in a wrong way but my choice is clear-bars work for me All the best |
| [2026-06-10 02:28:56] |
I’m always confident the SC team listens and works out solutions for their clients when they give productive feedback. What User993067 and I are saying is we’d like to see the original form and function of Pulling/Stacking Volume Bars made available to us. Doesn’t have to be either or, but from our point of view this new function isn’t as intuitive. |
| [2026-06-10 02:58:01] |
| chartsandcode - Posts: 1 |
@ChrisK and @User993067 both making a great point here sierra chart team. The pulling of the orders shouldn’t be more important than the stacking. Thank you for your attention to this matter.
| [2026-06-17 14:21:23] |
We apologize for the delay on this. This is now all fully resolved. We will have a new release out today. Although if you update to the latest version 2920 you are not going to see pulling and stacking volume bars for negative values. There is one other minor change that was needed to ensure that the negative values do not contribute towards the maximum values. You can enable negative volume bars with these settings: Graphics Settings - Colors >> Chart/TradeDOM >> Chart DOM Bid Market Depth Pulling/Stacking Negative Volume Bar Graphics Settings - Colors >> Chart/TradeDOM >> Chart DOM Ask Market Depth Pulling/Stacking Negative Volume Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-06-17 14:22:06
| [2026-06-17 14:31:42] |
Thank you.
| [2026-06-17 14:59:59] |
| blt - Posts: 229 |
... to: SIERRA CHART With this newest "resolved" issue misalignment of volume bars and cells showed up again Am I supposed to do some additional adjustments/setting on my side or should I wait for next update as you mentioned Also enabling/disenabling NVB's works perfect Thank you |
| [2026-06-17 16:27:33] |
Please get us an image of the "misalignment" you are seeing.
| [2026-06-17 17:07:25] |
| blt - Posts: 229 |
... This is the same issue I reported and sent image https://www.sierrachart.com/image.php?Image=1780343640692.png Post is from: TradeDOM misalignment of Volume Bars |
| [2026-06-17 20:22:22] |
| blt - Posts: 229 |
... to: SIERRA CHART Regarding misalignment of Volume Bars and cells-I just increased Trade DOM Grid to 3 from 2 and got misalignment covered It doesn't bother me much any longer Thank you |
| [2026-06-22 21:30:15] |
| spoxx - Posts: 5 |
Since last version (2922) i have not pull/Stack negative bar... an option to re-enable or other ?
| [2026-06-22 21:40:10] |
Graphics Settings - Colors >> Chart/TradeDOM >> Chart DOM Bid Market Depth Pulling/Stacking Negative Volume Bar Graphics Settings - Colors >> Chart/TradeDOM >> Chart DOM Ask Market Depth Pulling/Stacking Negative Volume Bar SC Team did great job incorporating both options for us. Thanks again to them. |
