Date/Time: Thu, 26 Nov 2026 04:45:46 +0000
Unfinished auction from footprint chart to minute chart
View Count: 313
[2026-05-22 03:38:13]
jethrogou - Posts: 56
Is there a way to copy the unfinished auction lines from footprint chart to minute chart?
imageScreenshot 2026-05-22 113135.png / V - Attached On 2026-05-22 03:38:01 UTC - Size: 192.77 KB - 134 views
[2026-05-22 13:23:20]
In this case, you can use the "Study/Price Overlay" to overlay the Numbers Bars study from the one chart to the other. If you set the Input for the Study/Price Overlay for "Copy Extension Lines from Source Study" to "Yes", then you will get those extension lines showing on the destination chart. Refer to the following:
Study/Price Overlay Study: Copy Extension Lines from Source Study
[2026-05-22 13:30:33]
Got it, thank you!
[2026-05-22 13:35:47]
Is there a way to limit the number of look back bars?
[2026-05-22 14:09:29]
In this case, there is not a way to limit the amount of data that is displayed through the studies. The only option would be to limit the 1 minute chart to fewer days.
