Date/Time: Thu, 26 Nov 2026 04:45:44 +0000
Numbers bars - Ask Vol Bid Vol Diff Diagonal Dominant Side
View Count: 500
| [2026-05-20 20:42:00] |
| User836008 - Posts: 7 |
Hi, I was eyeing the accuracy of the number bars calculations and I noticed that the ask vol bid vol diff diagonal dominant side was inaccurate on some price levels. I have attached a screenshot of a single numbers bar. The left is volume, middle is bid x ask, and the right is the ask vol bid vol diff diagonal dominant side. As you can see on the right column: when I calculate the bid x ask diagonally some of the numbers are off. Please advise. Thank you in advance. |
| [2026-05-20 20:46:58] |
All of the numbers are calculated properly when we look at what you have given us. What exactly are you stating is incorrect? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-20 23:44:15] |
should the delta numbers be: 0 = 0 -32+1 = -31 -49+38 = -11 -46+41 = -5 -63+29 = -34 -76+51 = -25 -21+38 = +17 (This shows up as 0) -83+7 = -76 -97+60 = -37 -105+106 = +1 (This shows up as +12) -51+63 = +12 -35+86 = +51 -1+32 = +31 0 = 0 |
| [2026-05-21 02:42:31] |
| blt - Posts: 235 |
... @User836008 You see "zero" because both sides at the same level are NOT dominant !!! ... 21 is NOT dominant to 38 7 is NOT dominant to 83 ... SIERRA CHART prints "zero" when comparison can't be done (top; bottom) and when we have level without dominance ... please wait for confirmation by SIERRA CHART !!! Leonardo |
| [2026-05-21 13:33:44] |
What blt states is correct. The zeros are there because neither side is dominant. You are also not looking at the calculations correctly. Here is a snippet of the data: 97 106 105 63 51 86 For the level that has 105 and 63, the Diagonal calculations are the following: Ask Side: 63 - 51 Bid Side: 106 - 105 The Bid Side is not greater than the next higher Ask, so it is not dominant. The Ask Side is greater then the next lower Bid, so it is dominant. Therefore, the Ask Side is dominant in this case, and a value of 12 is displayed. Refer to the information for the Diagonal Dominant side in the following section: Numbers Bars: Definitions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
